U2010B
DATASHEET
Phase Control Circuit for Current Feedback
Description
The U2010B is designed as a phase-control circuit in
bipolar technology. It enables load-current detection and
has a soft-start function as well as reference voltage
output. Motor control with load-current feedback and
overload protection are preferred applications.
Features
D Internal supply voltage monitoring
D Current requirement 3 mA
D Temperature compensated reference voltage
D Full wave current sensing
v
D Mains supply variation compensated
D Programmable load-current limitation
with over- and high-load output
D Variable soft-start
Applications
D Voltage and current synchronization
D Advanced motor control
D Grinder
D Drilling machine
D Automatic retriggering switchable
D Triggering pulse typical 125 mA
Package: DIP16, SO16
Block Diagram
15
14
13
11
12
Overload
Limiting
detector
Voltage
detector
Mains voltage
compensation
Automatic
retriggering
100%
Output
Current
detector
Phase
control unit
ö = f (V4)
1
2
10
Supply
voltage
High load
70%
GND
A
amax
B
Programmable Auto–
start
overload
protection
C
Imax
Full wave
rectifier
9
16
Pulse
output
1
Voltage
monitoring
Load
current
detector
2
Level
shift
3
Soft
start
4
5
6
7
Reference
voltage
8
Figure 1. Block diagram
Version 1.0
Page 1
The U2010B contains voltage limiting and can be
connected with the mains supply via D1 and R1. Supply
voltage
between Pin 10 and Pin 11
is smoothed
by C1.
Page 2
R6
230 V ~
Mains Supply
R3
General Description
In the case of V6 (70% of overload threshold voltage),
Pins 11 and 12 are connected internally whereby
VT70, the supply current
Vsat 1.2 V. When V6
flows across D3.
v
v
1
16
Limiting
detector
2
Load
current
detector
Current
detector
Automatic
retriggering
$250 mV
3.3 kW
R5
V(R6)=
3.3 kW
R4
180W
TIC
226
Load
15
C3
10 nF
3
Level
shift
ö
a max
R10
C5
0.1 m F
C4
2
P1
50 kW
13
R7
8.2 kW
Set point
Full wave
rectifier
1
R11
1 MW
Overload
BYT51K
Output
0.15 m F
5
100 kW
Load current
compensation
4
D1
Mains voltage
compensation
R8
470 k W
14
Phase
control unit
= f (V4 )
Voltage
detector
R2
330 k W
R1
18 k W /2 W
7
Soft
start
C2
4.7 m F
Voltage
monitoring
Overload
threshold
6
70%
C
Imax
B
Auto–
start
A
a max
Supply
voltage
11
8
10
9
GND
C7
1 mF
Reference
voltage
Programmable
overload
protection
100%
High load
12
VS
LED
D3
S1
A
B
C
Mode
C1
22 m F
U2010B
DATASHEET
Figure 2. Block diagram with external circuit
w
Ver 1.0
U2010B
DATASHEET
Pin Description
Isense
1
16 Output
Isense
2
15 VSync.
Cö
3
14 VRö
Control
4
13 Overload
Comp.
5
12 High load
ILoad
6
11 VS
Csoft
7
10 GND
VRef
8
9
Mode
Series resistance R1 can be calculated as follows:
R 1max
Vmains
VSmax
Itot
ISmax
Ix
+V
mains
2
– V Smax
whereas
I tot
+ Mains supply voltage
+ Maximum supply voltage
+ Total current consumption = I )I
+ Maximum current consumption of the IC
+ Current consumption of the
Smax
x
external components
Voltage Monitoring
As the voltage is built up, uncontrolled output pulses are
avoided by internal voltage monitoring. Apart from that
all the latches in the circuit (phase control, load limit
regulation) are reset and the soft-start capacitor is short
circuited. This guarantees a specified start-up behavior
each time the supply voltage is switched on or after short
interruptions of the mains supply. Soft-start is initiated
after the supply voltage has been built up. This behavior
guarantees a gentle start-up for the motor and automatically ensures the optimum run-up time.
Phase Control
The function of the phase control is largely identical to the
well known IC family U211B. The phase angle of the
trigger pulse is derived by comparing the ramp voltage V3
which is mains synchronized by the voltage detector with
the set value on the control input, Pin 4. The slope of the
Version 1.0
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Symbol
Isense
Isense
Cö
Control
Comp.
ILoad
Csoft
VRef
Mode
GND
VS
High load
Overload
VRö
VSync.
Output
Function
Load current sensing
Ramp voltage
Control input
Compensation output
Load current limitation
Soft start
Reference voltage
Mode selection
Ground
Supply voltage
High load indication
Overload indication
Ramp current adjust
Voltage synchronization
Trigger output
ramp is determined by Cö and its charging current Iö. The
charging current can be varied using Rö at Pin 14. The
maximum phase angle, αmax, can also be adjusted by
using Rö (minimum current flow angle ömin) see figure 4.
When the potential on Pin 3 reaches the set point level of
Pin 4, a trigger pulse width, tp, is determined from the
value of Cö (tp = 9 ms/nF). At the same time, a latch is set
with the output pulse, as long as the automatic
retriggering has not been activated, then no more pulses
can be generated in that half cycle. Control input at Pin 4
(with respect to Pin 10) has an active range from
V8 to –1 V. When V4 = V8, then the phase angle is at its
maximum, αmax, i.e., the current flow angle is minimum.
The minimum phase angle, αmin, is set with V4 –1 V.
w
Automatic Retriggering
The current-detector circuit monitors the state of the triac
after triggering by measuring the voltage drop at the triac
gate. A current flow through the triac is recognized, when
the voltage drop exceeds a thres hold level of typ. 40 mV.
If the triac is quenched within the relevant half-wave after
triggering; for example owing to low load currents before
or after the zero crossing of current wave or; for commutator motors, owing to brush lifters. Then the automatic
retriggering circuit ensures immediate retriggering, if
necessary with a high repetition rate, tpp/tp, until the triac
remains reliably triggered.
Page 3
U2010B
DATASHEET
Current Synchronization
Current synchronization fulfils two functions:
* Monitoring the current flow after triggering.
In case the triac extinguishes again or it does not switch
on, automatic triggering is activated until the
triggering is successful.
* Avoiding a triggering due to inductive load.
In the case of inductive load operation the current
synchronization ensures that in the new half wave no
pulse is enabled as long as there is a current available
which from the previous half-wave, which flows from
the opposite polarity to the actual supply voltage.
A special feature of the integrated circuit is the
realization of this current synchronization. The device
evaluates the voltage at the pulse output between gate and
reference electrode of the triac. This results in saving
separate current synchronization input with specified
series resistance.
Voltage Synchronization with Mains Voltage
Compensation
The voltage detector synchronizes the reference ramp
with the mains-supply voltage. At the same time, the
mains dependent input current at Pin 15 is shaped and
rectified internally. This current activates the automatic
retriggering and at the same time is available at Pin 5. By
suitable dimensioning, it is possible to attain the specified
compensation effect. Automatic retriggering and mains
voltage compensation are not activated until |V15 – 10|
increases to 8 V. Resistance, Rsync. defines the width of
the zero voltage cross over pulse, synchronization
current, and hence the mains supply voltage
compensation current.
Mains
v
Load Current Compensation
The circuit continuously measures the load current as a
voltage drop at resistance R6. The evaluation and use of
both half waves results in a quick reaction to load current
change. Due to voltage at resistance R6, there is a
difference between both input currents at Pins 1 and 2.
This difference controls the internal current source,
whose positive current values are available at Pins 5
and 6. The output current generated at Pin 5 contains the
difference from the load-current detection and from the
mains-voltage compensation (see figure 1).
The effective control voltage at Pin 4 is the final current
at Pin 5 together with the desired value network. An
increase of mains voltage causes the increase of control
angle α, an increase of load current results in a decrease
in the control angle. This avoiding a decrease in
revolution by increasing the load as well as the increase
of revolution by the increment of mains supply voltage.
Load Current Limitation
The total output load current is available at Pin 6. It
results in a voltage drop across R11. When the potential
of the load current reaches about 70% of the threshold
value (VT70) i.e., ca. 4.35 V at Pin 6, it switches the high
load comparator and opens the switch between Pins 11
and 12. By using an LED between these pins, (11 and 12)
a high load indication can be realized.
If the potential at Pin 6 increases to ca. 6.2 V (= VT100),
it switches the overload comparator. The result is
programmable at Pin 9 (operation mode).
Mode selection:
R2
15
U2010B
2x
BZX55
C6V2
10
Figure 3.
Page 4
If the mains voltage compensation and the automatic
retriggering are not required, both functions can be
suppressed by limiting |V15 – 10| 7 V (figure 3).
a) αmax (V9 = 0)
In this mode of operation, after V6 has reached the
threshold VT100, Pin 13 switches to –VS (Pin 11) and
Pin 6 to GND (Pin 10). A soft-start capacitor is then
shorted and the control angle is switched to αmax.
This position is maintained until the supply voltage
is switched off. The motor can be started again with
soft-start function when the power is switched on
again. As the overload condition switches Pin 13 to
Pin 11, it is possible to set in a smaller control angle,
αmax, by connecting a further resistance between
Pins 13 and 14.
Version 1.0
U2010B
DATASHEET
b) Auto start (Pin 9 open)
The circuit behaves as written under αmax (V9 = 0),
with the exception that Pin 6 is not connected to
GND. If the value of V6 decreases to 25% of the
threshold value (VT25), the circuit becomes active
again with soft-start.
c) Imax (V9 = V8)
When V6 has attained the overload threshold
maximum value i.e. V6 = VT100; Pin 13 is switched
to Pin 8 (VRef) through the resistance R (= 2 kW)
without soft-start capacitor discharging at Pin 7.
With this mode of operation, direct load current
control (Imax) is possible. A recommended circuit is
shown in figure 18.
Absolute Maximum Ratings
Reference point Pin 10, unless otherwise specified
Parameters
Sink current
t
v
t
v
Sync. currents
Value
30
100
5
Unit
mA
Pin 15
Symbol
–IS
–is
IsyncV
isyncV
Pins 4 and 8
Pin 4
Pin 14
–VI
II
– Iϕ max
0 – V8
500
0.5
V
mA
mA
Pins 7 and 8
–VI
0 – V8
V
Pin 16
+VI
–VI
2
V11
V
Pin 8
I0
10
30
mA
Pin 11
s
10 m
s
10 m
Phase control
Control voltage
Input current
Charging current
Soft-start
Input voltage
Pulse output
Input voltage
Reference voltage source
Output current
t 10 ms
Input currents
Input voltages
Overload output
High-load output
t 10 ms
Storage temperature range
Junction temperature range
Ambient temperature range
v
v
Pins 1 and 2
Pins 5 and 6
Pin 13
Pin 12
" Ii
– Vi
IL
IL
Tstg
Tj
Tamb
1
0 – V8
1
30
100
40 to 125
125
10 to 100
mA
mA
V
mA
mA
C
C
C
Thermal Resistance
Parameters
Junction ambient
Ver 1.0
DIP16
SO16 on p.c.
SO16 on ceramic
Symbol
RthJA
Value
120
180
100
Unit
K/W
Page 5
U2010B
DATASHEET
Electrical Characteristics
VS
+ –13 V, T
amb
= 25°C, reference point Pin 10, unless otherwise specified
Parameters
Supply
Supply voltage limitation
Current requirement
Reference voltage
Temperature coefficient
Test Conditions / Pins
Pin 11
–IS = 3.5 mA
–IS = 30 mA
–VS = 13.0 V
(Pins 1, 2, 8 and 15 open)
Pin 8
IL = 10 A
IL = 2.5 mA
IS = 2.5 mA
IS = 10 A
Pin 11
Symbol
Min.
–VS
14.5
14.6
–IS
–VRef
w
8.6
8.4
TCVRef
Voltage monitoring
Turn-on threshold
–VSon
Phase control – synchronization
Pin 15
Input current
Voltage sync.
IsyncV
Voltage limitation
IL = 2 mA
VsyncV
Input current
Current sync.
Pin 16
IsyncI
Reference ramp, figure 4
Charging current
Pin 14
–Iϕ
Start voltage
Pin 3
–Vmax
Temperature coefficient of
Pin 3
TCR
start voltage
Final voltage
Pin 3
–Vmin
Rϕ − reference voltage
Iϕ = Α
Pins 14 and 11
VRϕ
Iϕ = Α
Pin 14
TCVRϕ
Iϕ = Α
Pulse output current
V16 = – 1.2 V, figure 5, Pin 16
I0
Output pulse width
VS = Vlimit,
tp
C3 = 3.3 nF, figure 6, Pin 16
Repetition rate
I15 150 A
tpp
Threshold voltage
Pin 16
VI
Soft start, figure 7 and 8
Pin 7
Starting current
V7 = V8
–I0
Final current
V7–10 = –1V
–I0
Discharge current
+I0
Output current
Pin 4
+I0
Supply voltage compensation, figure 9
Pin 15
Transfer gain
I15/ I5
Pin 15/5
Gi
(Pins 1 and 2 open)
Output offset current
V(R6) = V15 = V5 = 0
I0
Load current detection, R1 = R2 = 3 k, V15 = 0, V5 = V6 = V8, figure 10
Transfer gain
I5/150 mV, I6/150 mV
GI
Output offset currents
Pin 5, Pin 6 - 8
–I0
Reference voltage
I1, I2 = 100 A Pins 1 and 2
–VRef
Shunt voltage amplitude
see figure 2
V(R6)
Typ.
0.15
8.0
3
1
1.85
Page 6
Unit
16.5
16.8
3.2
V
9.2
9.1
11.3
12.3
V
8.5
2
9.0
30
mA
V
A
100
2.05
A
V
1.95
0.96
"200 mV)
V
%/K
–0.003
(V8
mA
8.9
8.8
–0.004
+0.006
%/K
1.02
0.03
0.06
125
30
1.10
V
%/K
150
mA
s
3
7.5
60
tp
mV
5
15
0.5
0.2
10
25
15
40
A
A
mA
mA
14
17
100
2
Max.
0.28
0.32
3
A
0.37
6
400
250
A/mV
A
mV
mV
Version 1.0
U2010B
DATASHEET
Parameters
Load current limitation,
High load switching
Pin 6-8, figs. 11 to 14
Threshold VT70
Symbol
Min.
Typ.
Max.
Unit
VT70
4
4.35
4.7
V
Overload switching
Threshold VT100
VT100
5.8
6.2
6.6
V
Restart switching
Threshold VT25
VT25
1.25
1.55
1.85
V
Ii
R0
2
4
1
8
mA
kW
–V9
–I9
I9
3.8
5
5
4.3
10
10
4.7
mA
Vsat
Vlim
0.5
7.0
0.75
7.4
1.0
7.8
Input current
Enquiry mode
Output impedance
Switching mode
Programming input, figure 2, Pin 9
Input voltage - auto-start
Pin 9 open
Input current
V9 = 0 (amax)
V9 = V8 (Imax)
High load output, VT70, figure 12, I12 = –3 mA, Pin 11-12
Saturation voltages
V6-8 VT70
V6-8 VT70
Overload output, VT100, V9 = open or V9 = V10, fig. 13
Leakage current
V6-8 VT25
V13 = (V11+1)V Pin 13
Saturation voltages
V6-8 VT100,
Pins 11-13
I13 = 10 mA
Output current, max. load V9 = V8, fig. 13 Pin 13
Leakage current
V6 VT100
Pin 13
Output impedance
Open collector
Pin 13
V6 VT100
Saturation voltage
V6-8 VT100,
Pin 13
I13 = 10 mA
v
w
v
w
v
w
w
0.5
Vsat
I13
Ilkg
0.1
1
4
R0
2
4
V13–8
V
mA
V
mA
mA
kW
8
100
mV
120
250
Pulse Output
VGT=–1.2V
100
3.3 nF
2.2 nF
80
IGT ( mA )
6.8 nF
200 33 nF
4.7 nF
10 nF
Phase angle a (° )
Ilkg
V
150
100
Cö/ t = 1.5 nF
60
40
400
Rö ( kW )
Figure 4.
Version 1.0
600
800
1000
400
600
800
1000
RGT ( W )
Figure 5.
Page 7
U2010B
DATASHEET
Output Pulse Width
Dtp/DCö=9ms/nF
40
I 5 (mA )
t p ( ms )
300
200
80
120
Mains Supply
160 Compensation
Pins 1 and 2 open
Vs=–13V
200
–2
–1
100
30
Reference Point
Pin 10
Cö = ( nF )
I15 ( mA )
Figure 6.
Figure 9.
50
200
Soft Start
VS=–13V
V6=V8
30
Reference Point Pin 8
120
10
40
5.0
10
7.5
–400
–200
V7 ( V )
200
V(R6) ( mV )
Figure 7.
Figure 10.
Load Current limitation:
Auto Start Operation
VS=–13V
Pin 9 open
Reference Points: V13=Pin 10, V6=Pin 8
1 mF
8
2.2mF
16
–V13–10 ( V )
10
V7 ( V )
Reference Point
Pin 8
Load Current
Detection
V6=VRef=V8
VS=–13V
V15=V10=0V
160
I5 ( m A )
I 7 (mA )
40
4.7mF
6
Cö=10mF
4
Soft Start
VS=–13V
V6=V8
2
4
6
t(s)
Figure 8.
Page 8
2
1
8
12
8
4
VT25
VT100
4
6
8
10
V6–8 ( V )
Figure 11.
Version 8
U2010B
DATASHEET
10
10
High Load Output ( 70% )
I12=–3mA
Power Dissipation at Series Resistance R1
8
PV ( W )
V11–12 ( V )
8
6
4
6
4
2
2
VT70
2
3
4
5
6
7
R1 ( kW )
V6 ( V )
Figure 12.
12
8
VS=–13V
V9=V8
Reference Points:
V13=Pin 10
V6=Pin 8
8
6
PV ( W )
–V13–10 ( V )
50
10
6
4
4
2
2
VT100
4
6
10
6
t(s)
15
Figure 16.
100
Load Current limitation: amax Operation
VS=–13V
V9=V10
X
Max. Series Resistance
VM=230V
80
R 1max (k W )
16
9
IS ( mA )
Figure 13.
V13–10 ( V )
40
Figure 15.
Current Control Operation
10
30
12
8
4
60
40
VT100
4
V6–8 ( V )
Figure 14.
Version 1.0
8
10
4
6
8
10
IS ( mA )
Figure 17.
Page 9
Page 10
N
R6
R4
180 W
R3
1
16
"250 mV
3.3 kW
R5
V (R6) =
3.3 k W
TIC
226
Load
2
Load
current
detector
Current
detector
Automatic
retriggering
Limiting
detector
15
C3
10 nF
3
Level
shift
ö
Phase
control unit
= f(V4 )
Voltage
detector
330 kW
R1
L
R2
18 k W /2 W
230 V ~
4
R 10
C4
P1
50 k W
mF
C5
0.1 mF
0.15
5
2
13
Set point
1 MW
R 11
R7
8.2 k W
Full wave
rectifier
1
Output
Overload
BYT51K
amax
amax
Mains voltage
compensation
R9
R8
100 kW
Load current
compensation
14
1 MW
470 k W
D1
Overload
threshold
6
C2
4.7 mF
7
Soft
start
Voltage
monitoring
I max
C
B
Auto–
start
A
amax
Supply
voltage
11
C7
1 mF
8
Reference
voltage
70%
Programmable
overload
protection
100%
High load
12
VS
LED
D3
D2
S1
R 13
100 k W
1N4148
9
GND
10
R 12
T1
C6
1m F
BC308
220 kW
A
B
C
22
mF
C1
U2010B
DATASHEET
Application Circuit
Figure 18.
Version 1.0
DATASHEET
U2010B
Dimensions in mm
Package: DIP16
Package: SO16
Version 1.0
Page 11
