BOS
Detailed product information can be found on
www.bopla.de
- 8 sizes
- Various designs
- Enclosure with display cut-out or continuous
membrane keypad area
- Various battery compartments
- With matching desktop and charging station,
depending on model
Colour:
Depending on the model: black, similar to RAL
9005, or agate grey, similar to RAL 7038;
special colours on request
Protection class:
Depending on the model: IP 40 / IP 65/DIN EN
60529
Enclosure material:
ABS, seal made of CR; for details see Technical
Information
148
Hand-held enclosure series for a range of uses in a classic
design
BOS hand-held enclosures in various
designs with different equipment features.
BOS 4..: With continuous membrane
keypad area - with tip-up clip or belt clip
BOS 4..ASC
BOS 5.., BOS 7.., BOS 8..: Available with a
membrane keypad and/or different display
types.
BOS 6..: With display screen, continuous
keypad surface or integrated loudspeaker
grille.
BOS 9..: With large display and slimline
grip area – Versions with a battery
compartment are also available.
A carrying strap or a tip-up foot is
available for enclosure BOS 9.. .
Some BOS 7.. series enclosures also have a
slide switch (see table on the following
page).
Data transfer can be achieved with the
table stand for BOS 9.. (available as an
accessory).
149
Display
opening
Battery comp.
for
Ingress
protect.
Slide
switch
Panoramic
display scr.
Display
screen
UDS
application
BOS 400
9V block
IP 40
BOS 400 ASC
9V block
IP 40
BOS 401
IP 40
BOS 401 ASC
IP 40
BOS 500
x
9V block
IP 40
x
x
BOS 501
x
9V block
IP 40
x
x
BOS 502
9V block
IP 40
x
BOS 503
9V block
IP 40
x
BOS 600
x
9V block
IP 40
x
BOS 601
9V block
IP 40
BOS 602
3 mignons
IP 40
BOS 700
x
9V block
IP 40
x
x
BOS 701
x
9V block
IP 40
x
x
BOS 704
x
9V block
IP 40
x
x
x
BOS 705
x
9V block
IP 40
x
x
x
BOS 750
x
9V block
IP 40
x
x
BOS 751
x
9V block
IP 40
x
x
BOS 752
9V block
IP 40
x
BOS 753
x
IP 40
x
x
BOS 754
x
IP 40
x
x
BOS 755
IP 40
x
BOS 756
x
9V block
IP 40
x
x
x
BOS 757
x
9V block
IP 40
x
x
x
BOS 758
9V block
IP 40
x
x
BOS 759
x
IP 40
x
x
x
BOS 760
x
IP 40
x
x
x
BOS 761
IP 40
x
x
BOS 800
x
4 mignons
IP 40
x
x
BOS 801
x
4 mignons
IP 40
x
x
BOS 802
4 mignons
IP 40
x
BOS 803
x
IP 40
x
x
BOS 804
x
IP 40
x
x
BOS 805
IP 40
x
BOS 807
4 mignons
IP 40
x
BOS 808
IP 40
x
BOS 900
x
IP 65
x
x
BOS 901
x
IP 65
x
BOS 902
x
4 mignons
IP 65
x
BOS 903
x
2 x 9V block
IP 65
x
BOS 910
x
IP 65
x
x
BOS 911
x
IP 65
x
BOS 912
x
4 mignons
IP 65
x
BOS 913
x
2 x 9V block
IP 65
x
150
BOS 400 / 400 ASC / 401 / 401 ASC
| Enclosures
BOS 400/400 ASC with compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 400
34400000
100 65 24 Black
BOS 400 ASC
34400500
100 65 24 Black
Scope of delivery: Lid, base, battery compartment lid, battery compartment side, screws
For BOS 400 ASC, plus integrated clip bearing and bow
Note: As an option, 2 micro batteries can be inserted in the enclosure by using battery holder BH 2 MC (order no.:
34165572). Wall fitting for ASC types: see general accessories.
BOS 401/401 ASC
Model
Order no.
A
B C Colour
BOS 401
34401000
100 65 24 Black
BOS 401 ASC
34401500
100 65 24 Black
Scope of delivery: Lid, base, screws
24 (C)
100 (A)
83
65
65 (B)
50
18,8
For accessories, please see the end of the chapter
Z-2803235
151
BOS 500 / 501 / 502 / 503
| Enclosures
BOS 500 with panoramic display screen and compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 500
34500000
120 60 25 Black
BOS 500
34500003
120 60 25 Agate grey
Scope of delivery: Lid, base, front panel, battery compartment lid, screw, panoramic display screen
BOS 501 with display screen and compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 501
34501000
120 60 25 Black
BOS 501
34501002
Scope of delivery: Lid, base, front panel, battery compartment lid, screw, display screen
BOS 502 without display cut-out, with compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 502
34502000
120 60 25 Black
BOS 502
34502002
Scope of delivery: Lid, base, front panel, battery compartment lid, screws
BOS 503 with continuous membrane keypad area and compartment for 9V block
battery
Model
Order no.
A
B C Colour
BOS 503
34503000
120 60 25 Black
BOS 503
34503001
60 (B)
78,8
120 (A)
53
47,6
152
25 (C)
* = Available on request
19,5
Z-2803236
BOS 600 / 601 / 602
| Enclosures
BOS 600 with display screen and compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 600
34600000
172 77 25 Black
Scope of delivery: Lid, base, 2 front panels, screws, battery compartment lid, display screen
BOS 601 with continuous membrane keypad area and compartment for 9V block
battery
Model
Order no.
A
B C Colour
BOS 601
34601000
172 77 25 Black
BOS 602 with loudspeaker grille and compartment for 3x 1.5 V mignon batteries
Model
Order no.
A
B C Colour
BOS 602
34602000
172 77 25 Black
Scope of delivery: Lid, base, 2 plastic front panels, screws
25 (C)
166
172 (A)
112
93
77 (B)
52
17,5
Z-2803237
153
BOS 700 / 701 / 704 / 705
| Enclosures
BOS 700/701 with display opening and compartment for 9V block battery
Model
Order no.
A
B C Colour Note
BOS 700
34700000
150 80 30 Black
Display opening: 23 x 58 mm
BOS 701
34701000
150 80 30 Black
Display opening: 18 x 48 mm
Scope of delivery: Lid, base, front panel, battery compartment lid, screws, threaded inserts
Please order display screen separately.
BOS 704/705 with display opening, side-fitted slide for switch and compartment for
9V block battery
Model
Order no.
A
B C Colour Note
BOS 704
34704000* 150 80 30 Black
BOS 705
34705000
150 80 30 Black
30 (C)
150 (A)
60
110,7
80 (B)
65
154
23,6
Z-2803238
BOS 750 - BOS 761
| Enclosures
BOS 750 with panoramic display screen and compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 750
34750000
157 84 30 Black
BOS 750
34750001
157 84 30 Agate grey
Scope of delivery: Lid, base, front panel, battery compartment lid, screws, panoramic display screen
BOS 751 with display screen and compartment for 9V block battery
Model
Order no.
A
B C Colour
BOS 751
34751000
157 84 30 Black
BOS 751
34751001
Scope of delivery: Lid, base, front panel, battery compartment lid, screws, display screen, slide
BOS 752 with continuous membrane keypad area and compartment for 9V block
battery
Model
Order no.
A
B C Colour
BOS 752
34752000
157 84 30 Black
BOS 752
34752001
BOS 753 with panoramic display screen
Model
Order no.
A
B C Colour
BOS 753
34753000
157 84 30 Black
Scope of delivery: Lid, base, front panel, screws, panoramic display screen
BOS 754 with display screen
Model
Order no.
A
B C Colour
BOS 754
34754000
157 84 30 Black
BOS 754
34754001
Scope of delivery: Lid, base, front panel, screws, display screen
BOS 755 with continuous membrane keypad area
Model
Order no.
A
B C Colour
BOS 755
34755000
157 84 30 Black
BOS 755
34755001
BOS 756 with panoramic display screen, side-fitted slide for switch and compartment
Model
Order no.
A
B C Colour
BOS 756
34756000
157 84 30 Black
Scope of delivery: Lid, base, front panel, battery compartment lid, screws, panoramic display screen, slide
155
BOS 750 - BOS 761
| Enclosures
BOS 757 with display screen, side-fitted slide for switch and compartment for 9V
block battery
Model
Order no.
A
B C Colour
BOS 757
34757000
157 84 30 Black
BOS 758 with continuous membrane keypad area and side-fitted slide for switch and
Model
Order no.
A
B C Colour
BOS 758
34758000
157 84 30 Black
Scope of delivery: Lid, base, front panel, battery compartment lid, screws, slide
BOS 759 with panoramic display screen and side-fitted slide for switch
Model
Order no.
A
B C Colour
BOS 759
34759000
157 84 30 Black
BOS 760 with display screen, side-fitted slide for switch
Model
Order no.
A
B C Colour
BOS 760
34760000
157 84 30 Black
BOS 761 with continuous membrane keypad area and side-fitted slide for switch
Model
Order no.
A
B C Colour
BOS 761
34761000
157 84 30 Black
84 (B)
110,8
157 (A)
86
70
156
30 (C)
24
Z-2803239
BOS 800 - BOS 808
| Enclosures
BOS 800 with panoramic display screen and compartment for 4 x 1.5 mignon
batteries
Model
Order no.
A
B
C Colour
BOS 800
34800000
196 100 40 Black
BOS 800
34800001
196 100 40 Agate grey
Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts, panoramic display screen
BOS 801 with display screen and compartment for 4 x 1.5 mignon batteries
Model
Order no.
A
B
C Colour
BOS 801
34801000
196 100 40 Black
BOS 801
34801001* 196 100 40 Agate grey
Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts, display screen
BOS 802 without display cut-out, with compartment for 4 x 1.5 V mignon batteries
Model
Order no.
A
B
C Colour
BOS 802
34802000
196 100 40 Black
BOS 802
34802001* 196 100 40 Agate grey
BOS 803 with panoramic display screen
Model
Order no.
A
B
C Colour
BOS 803
34803000
196 100 40 Black
BOS 803
34803001* 196 100 40 Agate grey
BOS 804 with display screen
Model
Order no.
A
B
C Colour
BOS 804
34804000
196 100 40 Black
BOS 804
34804001
BOS 805, without display cut-out
Model
Order no.
A
B
C Colour
BOS 805
34805000
196 100 40 Black
BOS 805
34805001* 196 100 40 Agate grey
BOS 807 with continuous membrane keypad area and compartment for 4 x 1.5 V
mignon batteries
Model
Order no.
A
B
C Colour
BOS 807
34807000
196 100 40 Black
BOS 807
34807001
157
BOS 800 - BOS 808
| Enclosures
BOS 808 with continuous membrane keypad area
Model
Order no.
A
B
C Colour
BOS 808
34808000
196 100 40 Black
BOS 808
34808001
40 (C)
187,1
196 (A)
92,5
121,25
100 (B)
80
158
34
Z-2803240
BOS 900 - BOS 903
| Enclosures
BOS 900
Model
Order no.
A
B
C Colour
BOS 900
34900009
211 100 26 Black
BOS 900
34900000
211 100 26 Agate grey
Scope of delivery: Lid with seal, base, screws, display screen (enclosed unfitted)
Note: Fitting of display screen on request
BOS 901 with carrying strap and tip-up foot
Model
Order no.
A
B
C Colour
BOS 901
34901009* 211 100 26 Black
BOS 901
34901000
Scope of delivery: Lid with seal, base, carrying strap, tip-up foot, screws, display screen (enclosed unfitted)
BOS 902 with carrying strap and compartment for 4 x 1.5 V mignon batteries
Model
Order no.
A
B
C Colour
BOS 902
34902009
211 100 26 Black
BOS 902
34902000
Scope of delivery: Lid with seal, base with battery compartment including contacts, carrying strap, screws, display
BOS 903 with carrying strap and compartment for 2 x 9V block batteries
Model
Order no.
A
B
C Colour
BOS 903
34903009* 211 100 26 Black
BOS 903
34903000
Scope of delivery: Lid with seal, base with battery compartment, carrying strap, screws, display screen (enclosed
unfitted)
26 (C)
131,5
202,4
211 (A)
100 (B)
75
81
20,5
Z-2803241
159
BOS 910 - BOS 913
| Enclosures
BOS 910
Model
Order no.
A
B
C Colour
BOS 910
34910009
224 106 40 Black
BOS 910
34910002
224 106 40 Agate grey
BOS 911 with tip-up foot
Model
Order no.
A
B
C Colour
BOS 911
34911009
224 106 40 Black
BOS 911
34911000
Scope of delivery: Lid with seal, base, self-tapping screws, tip-up foot, display screen
BOS 912 with compartment for 4 x 1.5 V mignon batteries
Model
Order no.
A
B
C Colour
BOS 912
34912009
224 106 40 Black
BOS 912
34912000
Scope of delivery: Lid with seal, base with battery compartment including contacts, screws, display screen
(enclosed unfitted)
BOS 913 with compartment for 2 x 9V block batteries
Model
Order no.
A
B
C Colour
BOS 913
34913000
BOS 913
34913009* 224 106 40 Black
Scope of delivery: Lid with seal, base with battery compartment, screws, display screen (enclosed unfitted)
106 (B)
131,5
215,4
224 (A)
40 (C)
75
81,8
160
34
Z-2803242
BOS 500 – 913
| Accessories
Front panels BOS 500-503, ABS
Model
Order no.
Frontplatte IR
34955006
Frontplatte Alu
34055000
Scope of delivery: 1 front panel
Note: IR = Infrared-permissive
Note
For BOS 500/501/502/503
Display screens BOS 700-705, polycarbonate
Model
Order no.
Displayscheibe
26000800
Scope of delivery: 1 display screen
Note
For BOS 700/701/704/705
Intermediate frame BOS 900-903
Model
Order no.
Colour
Note
ZR 900
34900909
Black
For BOS 900/901/902/903
ZR 900
34900900
Agate grey For BOS 900/901/902/903
Scope of delivery: Intermediate frame, mounted seal, 6 screws
Table stand BOS 900-903 / BOS 910-913
Model
Order no.
STD 900
34900029*
STD 900
34900002
Colour
Note
Black
For BOS 900/901/902/903/910/911/912/913
Agate grey For BOS 900/901/902/903/910/911/912/913
Display adapter BOS 910-913
Model
Order no.
ADS 910-I
34913001*
ADS 910-II
34913002*
ADS 910-III
34913003*
Scope of delivery: 2 plastic parts, 4 screws
Model
ADS 910-I
ADS 910-II
ADS 910-III
Type
Adapter for graphic-type displays, 128 x 64 dots
Adapter for graphic-type displays, 16 characters, 4 lines
Display fitting dimensions
77 x 60
68 x 64,92
82 x 55
161
Powered by TCPDF (www.tcpdf.org)
