AP.17E.07.0064A
AP.17E.07.0064A
    TAOGLASLIMITED
    AP.17E.07.0064A
AP.17E.07.0064A 数据手册
Part No: AP.17E.07.0064A Description: 17mm One Stage GPS/Galileo Active Patch Antenna Module with Front End SAW Filter Features: 17mm*17mm*6.3mm 64mm 1.13 I-PEX MHF® I Wide Voltage 1.8V~5.5V 15dB LNA Tested in Free space CE Certified RoHS and REACH Compliant SPE-11-8-144-D 1. Introduction 3 2. Specifications 4 3. Passive Antenna Characteristics 6 4. Active Antenna Characteristics 8 5. Radiation Patterns 9 6. Mechanical Drawing 11 7. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-11-8-144-D www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The AP.17E is a one stage 17mm active patch antenna that has been designed specifically for embedded (inside device) integration with GPS/Galileo receiver modules. The AP.17E combines a 17*17*4mm advanced low profile ceramic patch antenna with a one stage LNA and a front-end SAW filter with ultra thin coaxial cable. It comes with it’s own integrated ground-plane. The front end SAW filter reduces the risks where there is a cellular transmitter nearby of interference from out of band frequencies which can cause LNA burn-out, saturation, or radiated spurious emissions. Introduction Typical Applications Include: - Navigation Systems - Asset Tracking - Performance Trackers/Wearables Introduction Introduction The antenna can work on a wide input voltage from 1.8V to 5.5V with best in class power consumption figures. If further tuning and optimization specific to a customer device is required Taoglas offers a custom tuned and optimized part service. Cables and connectors can be customized according to request. For further information please contact your regional Taoglas customer support team. SPE-11-8-144-D www.taoglas.com 2. Specifications 3. GNSS Frequency Bands Covered Antenna L1Characteristics2. Specifications L2 L5 L6 GPS/QZSS 3. 4. 1575.42MHz 1227.6MHz 1176.45MHz 1278.75MHz ■ □ □ □ L2PT 1246MHz L1CR 1575.42MHz L1PT 1602MHz L5R L3PT Antenna Characteristics 1176.45MHz 1201.5MHz GLONASS Galileo □ □ □ ■ □ E5a 1176.45MHz E5b 1201.5MHz E4 1215MHz E3 1256MHz E6 1278.75MHz E2 1561MHz E1 1575.42MHz □ □ □ □ □ □ ■ Antenna Radiation Patterns3.Antenna B1 Characteristics2. BeiDou 1561MHz 3. Compass 1207.14MHz 1268.52MHz □ □ □ E5B(B2)/ E6(B3) 1268.56MHz E2(B1) 1561MHz □ □ Omnistar 1542.5MHz WAAS/EGN OS 1575.42MHz Antenna Characteristics2. SBAS 3. B2 B3 Specifications Specifications Antenna □Characteristics ■ GNSS Electrical 4. Input Voltage Min:1.8V Typ.: 3.0V Max: 5.5V Antenna Radiation Patterns3.Antenna1575.42MHz +/- 1.023 MHz Frequency Range CharacteristicsGain -1.0dBic Typ. @zenith Polarization 4. 4. RHCP ratio AntennaAxialRadiation Patterns Max 3.0dB@zenith Frequency Range 1575.42MHz +/- 1.023 MHz Gain (With LNA) At 90° At 5.5V 16 ± 3dBic At 3.0V 15 ± 3dBic At 1.8V 12 ± 3dBic Antenna Radiation Patterns3.Antenna Output Impedance 50Ω Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-144-D Specifications www.taoglas.com LNA and Filter Electrical Properties Frequency 1575.42 ± 1.023MHz Outer Band Attenuation F0=1575.42MHz Gain@1.8V (Typ.) F0±30MHz 2dB min. Gain@3.0V (Typ.) F0±50MHz 18dB min. Gain@5.5V (Typ.) F0±100MHz 25dB min. Output Impedance 50Ω Output VSWR 2.0 Max Typ. -2dBm Pout at 1dB Gain Compression point Min. -6dBm LNA Gain, Power Consumption and Noise Figure Power Consumption Voltage LNA Gain (Typ) Min. 1.8V 13dB 1.6mA 2.5dB Typ. 3.0V 16dB 3.5mA 2.5dB Max. 5.5V 17dB 7.6mA 2.6dB (mA) Typ Noise Figure Typ Mechanical Dimensions 17mm*17mm*6.3mm RF Cable Ø1.13 RF Coaxial Cable L=64mm2.5mm RF Connector I-PEX MHF® I Environmental Operation Temperature -40°C to + 85°C Storage Temperature -40°C to + 85°C Relative Humidity 40% to 95% SPE-11-8-144-D www.taoglas.com 3. Passive Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. -5 Antenna Radiation Patterns 4. Return Loss [dB] 0 -10 Antenna Radiation Patterns3.Antenna -15 Characteristics -20 4. Antenna Radiation Patterns3.Antenna -25 1475 Characteristics 3.2 4. 1500 1525 1550 1575 1600 1625 1650 1675 Frequency [MHz] Efficiency Antenna Radiation Patterns 100 90 80 4. Antenna Radiation Patterns 70 Efficiency [%] 4. 60 50 Antenna Radiation Patterns 40 30 20 4. 10 Antenna Radiation Patterns3.Antenna 0 1400 1425 Characteristics 1450 1475 1500 1525 1550 1575 1600 1625 1650 1675 1700 Frequency [MHz] 4. Antenna Radiation Patterns3.Antenna SPE-11-8-144-D www.taoglas.com 3.3 Average Gain 0 -1 -2 Aver Gain [dB] -3 -4 -5 -6 -7 -8 -9 -10 1400 1425 1450 1475 1500 1525 1550 1575 1600 1625 1650 1675 1700 Frequency [MHz] Peak Gain Gain [dBi] 3.4 6 5 4 3 2 1 0 -1 -2 -3 -4 -5 -6 -7 -8 -9 -10 -11 -12 1400 1425 1450 1475 1500 1525 1550 1575 1600 1625 1650 1675 1700 Frequency [MHz] SPE-11-8-144-D www.taoglas.com 4. 6. Active Antenna Characteristics 4.1 LNA Gain and Out Band Rejection @3.0V Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. 4.2Packaging LNA Noise Figure @3.0V 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-11-8-144-D Mechanical Drawing www.taoglas.com 5. Radiation Patterns 4. 4. 5.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-11-8-144-D www.taoglas.com 5.2 1575MHz 3D and 2D Radiation Patterns XY Plane SPE-11-8-144-D XZ Plane YZ Plane www.taoglas.com 6. Mechanical Drawing (Units: mm) 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 8. 4. Antenna Radiation Patterns3.Antenna SPE-11-8-144-D www.taoglas.com 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-11-8-144-D Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-11-8-144 – AP.17E.07.0064A Revision: D (Current Version) Date: Changes: Changes Made by: 2021-11-29 Update datasheet template & data. Gary West Previous Revisions Revision: C Date: Changes: Changes Made by: 2017-06-19 Amended Packaging Peter Monahan Revision: B Date: 2011-01-16 Changes: Changes Made by: Technical Writer Revision: A (Original First Release) Date: Notes: Author: SPE-11-8-144-D 2011-11-30 Technical Writer www.taoglas.com © Taoglas SPE-11-8-144-D www.taoglas.com
AP.17E.07.0064A 价格&库存
很抱歉,暂时无法提供与“AP.17E.07.0064A”相匹配的价格&库存,您可以联系我们找货
AP.17E.07.0064A
    AP.17E.07.0064A
    • 10+55.98134
    • 40+54.92943
    • 80+53.88960
    • 120+51.79786
    库存:553
    AP.17E.07.0064A
    • 6+117.51616
    • 30+103.74146
    • 60+101.86091
    • 150+97.84828
    库存:383
    AP.17E.07.0064A
      AP.17E.07.0064A
        • 6+126.558356+16.37370
        • 30+111.7102330+14.45270
        • 60+109.7013760+14.19280
        • 150+105.33428150+13.62780
        库存:383
        AP.17E.07.0064A
        • 1+122.973001+15.90984
        • 10+96.8346810+12.52815
        • 25+90.3086625+11.68384
        • 100+83.14214100+10.75666
        • 360+78.59142360+10.16790
        • 720+76.73288720+9.92745
        • 1080+75.802281080+9.80705
        库存:1681
