Laird Technologies - Item # S1718AMP10SMF, DirectLink™ Series Antennas
Page 1 of 2
Laird Technologies
Web site: www.LairdTech.com
All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client
Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > DirectLink™ Series
Antennas > Item # S1718AMP10SMF
Campus & in-building directional antennas
DirectLink is a series of wall and mast mount directional antennas that
has been designed to meet the most demanding needs of the
contemporary wireless environment. DirectLink's attractive, UV resistant
housings and mounts allow the antennas to be mounted anywhere in the
larger image
campus or in-building environment. The antennas offer very precise and
controllable pattern characteristics in frequencies starting with the 1710
MHz DCS band and continuing through the 5.725 GHz ISM band. All popular contemporary wireless system
applications are covered with gain characteristics varying with frequency.
All antennas in the series may be wall or mast mounted and all are available with a variety of flush and articulating
mounts. Flush mounts allow the antenna to hug the wall for minimal visual impact. There are two available
articulating mounts that allow the pattern to be directed while still maintaining minimal visual impact.
Standard antennas come with either TNC, SMA or N female connectors and an integrated coaxial pigtail. Other
connector and pigtail combinations are available upon request.
Specifications
Band
DCS
ISM
Frequency
1710 to 1880 MHz
Gain
7.5 dBi
3dB Beamwidth, E Plane
60 º
3dB Beamwidth, H Plane
85 º
VSWR
1.5:1
Front to Back Ratio
12 dB
Connector
SMA (Female)
Articulating Version
Yes
Power
75 watts
Power at 5 GHz
25 watts
Polarization
Linear
http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/directlink-trade-series-anten...
8/8/2012
Page 2 of 2
Standard Wall Mount Dimension
5.70 x 3.81 x 1.50 in
14.48 x 9.68 x 3.80 cm
Articulating Wall Mount
Dimension
5.80 x 3.81 x 2.26 in
14.73 x 9.68 x 5.74 cm
Weight (Standard Wall Mount)
5 oz
0.14 kg
Weight (Articulating Wall Mount)
8 oz
0.23 kg
Mounting Style
Standard units for wall mounting. Mast mount bracket kits available. Custom mount
configurations for volume users.
Cable
Low loss pigtail provided
8/8/2012
很抱歉,暂时无法提供与“S1718AMP10SMF”相匹配的价格&库存,您可以联系我们找货
