Vehicular 4-Port MIMO Antenna
VLQ69273x22N
698-960 / 1710-2700 / 2300-2700 / 4900-5900 MHz
The Laird vehicular 4-port MIMO antenna covers the 698-960 / 1710-2700 MHz, 2300-2700 /
4900-5900 MHz. The VLQ69273x22N is configured with 4-port, dual-band elements.
Connector options include SMA male connectors for 3G/4G LTE with RSMA male connectors
for the WiFi port. The housing incorporates a low-profile, rugged design that meets IP67
standards. The antenna also features high impact, UV-resistant polycarbonate plastic
available in black or white.
SPECIFICATIONS
PARAMETER
Model Number
PERFORMANCE
VLQ69273B22N-518A (Black)
VLQ69273W22N-518A (White)
4 (2-ports 3G/4G LTE, 2-ports WiFi)
3G/4G (LTE) Ports
WiFi Ports
No. of Ports
Frequency Bands (MHz)
Peak Gain * dBi
698-960 MHz 1710-2700 MHz 2300-2700 MHz 4900-5900 MHz
3.2
6.3
4.5
5.5
Max Gain +/- 30o above horizon N/A
VSWR* Typical
< 1.8:1
N/A
N/A
< 1.9:1
< 2.0:1
< 1.6:1
VSWR* Max
< 2.0:1
< 2.0:1
< 2.0:1
4900-5900
< 2.0:1
Typical Port-to-Port Isolation * 698-960
4.8
1710-2700
2300-2700
LTE1-to-LTE2
LTE1-to-WiFi
> 14 dB
> 20 dB
> 23dB
> 23 dB
> 20 dB
> 20 dB
> 40 dB
LTE2-to-WiFi
> 23 dB
> 20 dB
> 20 dB
> 38 dB
> 36 dB
N/A
LTE1-to-LTE2
LTE1-to-WiFi
> 25 dB
> 19 dB
> 20 dB
> 23 dB
> 20 dB
> 21 dB
> 39 dB
LTE2-to-WiFi
N/A
N/A
> 20 dB
> 26 dB
Nominal Impedance
Polarization
Azimuth Beam Width
Input Power, Max
Operating Temperature
Dimensions (dia. x hgt)
Weight
Connector
Cable (exposed length)
Radome / Baseplate Material
Material Compliance
IP Dust & Water Ingress Rating
50 Ω
Vertical Linear
Omnidirectional
50 Watt (ambient temp. of 25°C / 77°F)
-30°C - +70°C (-22°F to +158°F)
132 mm x 75 mm (5.2" x 2.9")
Approximately 1.04 kg (2.29 lbs)
SMA-Male (3G/4G LTE port) RSMA-Male (WiFi port)
LMR195M- 518.2 cm (17 ft)
PC, UL94 - V0 Rating, UV Stable
ROHS compliant
IP67
*Measured on 1 ft. (30.48 cm) diameter ground plane
PART NUMBERS
PART NUMBER
VLQ69273B22N-518A 2-Ports 4G/LTE: SMA Male; 2 Ports WiFi:RSMA Male(Black)
VLQ69273W22N-518A 2-Ports 4G/LTE: SMA Male; 2 Ports WiFi:RSMA Male(White)
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
Laird warrants to the original end user customer of its products that its products are free from defects in material and
workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products
that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful
lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may
vary but is not to exceed five (5) years from the original date of the end product purchase.
ANT-DS-VLQ69273x22N 0815
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or
suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold
pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird,
Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the
property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“VLQ69273W22N-518A”相匹配的价格&库存,您可以联系我们找货
