RFID HD RooTenna®
10 X 10 Die-Cast Enclosure RFID Antennas
DCE ENCLOSURE OFFERS SIX OPTIONS OF INTEGRATED RFID ANTENNAS
COVERING 860-960 MHz
The RFID HD RooTenna® from Laird Technologies is an innovative antenna system that gives the
operator ultimate system flexibility. The Radome is UV resistant ASA plastic, the hardware is
stainless steel, and the mounting plate inside for adding electronics is removable and
customizable by the user.
The die-cast enclosure can be pole or wall mounted. A heavy duty tilt bracket is available for
those installations requiring up or down tilt. Eleven (11) engineered knockouts are provided;
nine sized for N connectors, and two sized for a cable feed through.
This series of antennas is available with a choice of six different circularly polarized UHF antennas
integrated into the Radome cover. These antennas cover the standard 902-928 MHz, 865-868 MHz
RFID frequencies, as well as a wide band version that covers 865-960 MHz. All are available in a
choice of RH and LH circular polarization. These antennas feature very low VSWR, axial ratio, and a
fixed SMA connector.
ANTENNA PATTERN
345
330
30
345
345
45
315
FEATURES
MARKETS
11 engineered knockouts
IP 67 Rated
Rugged and weatherproof
Hinged cover for easy maintenance
Choice of six high-performance,
circularly-polarized antennas
Outdoors
Loading docks
Warehouses
Mast mounted
Side of building
Industrial / wet locations
60
300
75
285
-30
270
-30
-20
-20
-10
-10
dB
dB
90
dBi
105
255
120
240
225
135
210
150
195
180
SPECIFICATIONS
DCE8658PR / L
DCE8658WPR / L
Frequency:
902-928 MHz
865-870 MHz
865-960 MHz
Gain:
9 dBic
8.5 dBic
8.5 dBic
3 dB Beamwidth
70º x 70º
70º x 70º
65º x 65º
Polarization:
Right or Left
Hand Circular
Right or Left
Hand Circular
Right or Left
Hand Circular
VSWR:
很抱歉,暂时无法提供与“DCE8658PRFSMF”相匹配的价格&库存,您可以联系我们找货
