Directional Flat Panel Antenna
PAV865014
865 MHz 14 dBi FLAT PANEL ANTENNA
The PAV865014 flat panel directional antenna by Laird offers high-gain in a thin, low-profile
package. The antenna is constructed of an off white color UV resistant ASA plastic radome
with an aluminum backplate. The heavy duty mount bracket allows up or down tilt
adjustment and the stainless steel hardware assures a long service life. The antenna can be
surface mounted or pole mounted. The PAV865014 comes with an integral N connector
standard.
FEATURES
MARKETS
• High gain / low profile
• Pole mount or surface mount
• Rugged IP67 rated weatherproof construction
• Vertical or horizontal polarization
• 866 MHz RFID antenna
• RFID applications
• OEM wireless data
• Transport terminals
PARAMETER
SPECIFICATION
Part Number
PAV865014
Frequency
865-870 MHz
Gain (typical)
13.8 dBi
3 dB Beamwidth-Azimuth
38°
3 dB Beamwidth-Elevation
41°
Front-to-Back Ratio
15 dB
Input Impedance
50 Ohms
Polarization
Linear Vertical
VSWR Max
1.4:1
RF Connector
Fixed Type N (male or female)
Radome
ASA UV Stable
Lightning Protection
DC Ground
Power Rating Max
6W
Dimensions
18.3 x 18.3 x 1.4 in (46.5 x 46.5 x 3.6 cm)
Weight
2.7 kg
Operational Temperature
-40°C to +70°C
Mount Style
Surface- threaded stud x 4 / Pole- worm gear clamp
RoHS
Compliant
ORDERING GUIDE
PART NO.
SPECIFICATIONS
PAV865014-FNF
13.8 dBi 865-870 MHz directional panel - Type N female connector
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
ANT-DS-PAV865014 0515
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice.
Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes
no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for
incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a
copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are
trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing
herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“PAV865014-FNF”相匹配的价格&库存,您可以联系我们找货
