MKT-E-13026F_0.3
HR41A Series
IP68 Small Plastic Power Connector
Optimized
Optimized for
for
Outdoor
Outdoor Use
Use
Features
1. IP68* weather-resistant waterproof connector for outdoor use
2. Higher lightning surge protection (15 kV) and withstanding voltage
3. Snap-in mating with user-friendly push-on bayonet lock
4. Bayonet assembly eliminates torque management and re-tightening of
screw
*Our test condition: No water intrusion, while submerged in 2 m
5. Easy field assembly
water depth for 14 days in mated condition.
6. UL, TÜV pending
Small Size
Component
- Plug (HR41A-17WBP-5SC)
16.8
24.6
65.8
Cable Size: 10.7 to 11.5
9.0 to 9.8 (Under development)
8.2 to 9.0 (Under development)
- Receptacle (HR41A-17WBRA-5PC)
21.0
19.8
41.2
- Jack (HR41A-17WBJ-5PC)
21.0
74
Cable Size: Same as plug
- Crimping Tool
Part No.: HT802/HR41A-11-16(AWG#16)
HT802/HR41A-11-18(AWG#18)
HT802/HR41A-11-20(AWG#20)
Finish /
Remarks
Material
Housing
PBT
UL94V-0, Black
Contact
Phosphor Bronze
Gold Plating
Clamp
Polyamide Resin
UL94V-0, White
O-ring,
Gasket
Silicone Rubber
Washer
Stainless Steel
Rated Voltage
AC 250V, DC 350V
Rated Current
10 Amps
Operating
Temperature
-40℃ to +105℃
Contact
Resistance
5mΩ Max. (1A)
Insulation
Resistance
5000MΩMin. (DC500V)
Withstanding
Voltage
AC 2200V, 1 minute
Durability
500 times
Water
Resistance
IP68 (Our test condition: No water
condition.)
- Contact Extraction Tool
Part No.: HR41A-TP
Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities.
© 2014 HIROSE ELECTRIC CO., LTD. All rights reserved.
Issued: Sep. 12, 2014
很抱歉,暂时无法提供与“HR41A-TP”相匹配的价格&库存,您可以联系我们找货
