Additional Resources:
Product Page
date
08/05/2022
page 1 of 5
SERIES: CMS-40504N-L152 | DESCRIPTION: SPEAKER
FEATURES
• low profile
• 500 Hz resonant frequency
• wire leads with connector options
SPECIFICATIONS
parameter
conditions/description
min
typ
max
units
input power
maximum power: IEC-60268-5, filter 60s on/120s off, 10
cycles at room temp
2.0
2.5
W
impedance
at 2.0 kHz, 1.0 V
3.4
4
4.6
Ω
resonant frequency (Fo)
at 1.0 V
frequency response
output SPL -10 dB
400
Fo
500
sound pressure level
at 1.0 W, 0.1 m ave, at 0.8 ,1.0, 1.2, 1.5 kHz
at 2.0 W, 0.5 m ave, at 0.8 ,1.0, 1.2, 1.5 kHz
97
86
distortion
at 1.0 kHz, 1.0 W
buzz, rattle, etc.
must be normal at sine wave between
Fo ~ 10,000 Hz
dimensions
Ø40 x 5.0
magnet
Nd-Fe-B
material
metal
cone material
PEI
terminal
wire leads
100
89
600
Hz
7,000
Hz
103
92
dB
dB
5
2.83
V
mm
weight
12.4
g
operating temperature
-30
70
°C
storage temperature
-40
85
°C
390
°C
hand soldering
for maximum 3 seconds
RoHS
yes
Notes:
370
380
1. All specifications measured at 15~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
PART NUMBER KEY
CMS-40504N-L152 X
Base Number
cuidevices.com
Termination Options:
“blank” = wire leads, no connector
A = wire leads with Molex housing 51021-0200
B = wire leads with JST housing SHR-02V-S-B
Product Page
CUI DEVICES | SERIES: CMS-40504N-L152 | DESCRIPTION: SPEAKER
date 08/05/2022 | page 2 of 5
MECHANICAL DRAWINGS
units: mm
tolerance: ±0.2 mm
WIRE LEADS, NO CONNECTOR
wire: UL 1007 28 AWG
4
01 Ω 2
15 W
很抱歉,暂时无法提供与“CMS-40504N-L152B”相匹配的价格&库存,您可以联系我们找货
