Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CMR-5054TB-A | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
FEATURES
• noise cancelling
• 6.0 mm diameter
• solder pads
SPECIFICATIONS
parameter
conditions/description
directivity
noise cancelling
sensitivity (S)
f = 1 kHz, 1 Pa, 0 dB = 1 V/Pa
min
typ
max
-57
-54
-51
standard operating voltage (Vs)
2
max operating voltage
f = 1 kHz, 1 Pa
sensitivity reduction (∆S-Vs)
f = 1 kHz, 1 Pa, Vs = 2.0 ~ 1.0 Vdc
2.2
100
current consumption (IDSS)
Vs = 2.0 Vdc, RL = 2.2 kΩ
signal to noise ratio (S/N)
f = 1 kHz, 1 Pa, A-weighted
dimensions
Ø6.0 x 5.0
material
aluminum
terminal
solder pads
Vdc
kΩ
-3
frequency (f)
dB
Vdc
10
output impedance (Zout)
units
dB
10,000
0.5
56
Hz
mA
dBA
mm
weight
0.3
g
operating temperature
-20
70
°C
storage temperature
-20
70
°C
RoHS
Notes:
yes
1. We use the “Pascal (Pa)” indication of sensitivity as per the recomendation of I.E.C. (International Electrotechnical Commission). The sensitivity of “Pa” will increase
20 dB compared to the “ubar” indication. Example: -60 dB (0 dB = 1 V/ubar) = -40 dB ( 1V/Pa)
2. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
for 2 ± 0.5 seconds
310
320
330
°C
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CMR-5054TB-A | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
7HUP
7HUP
FREQUENCY RESPONSE CURVE
G%
APPLICATION CIRCUIT
)(7,PSHGDQFH
FRQYHUWHU
7HUP
5/
(&0
XQLW
2XWSXW
9V
6KLHOG&DVH
7HUP
RL = 2.2 kΩ
cuidevices.com
*URXQG
Product Page
3D Model
PACKAGING
units: mm
Inner Box Size: 100 x 100 x 8 mm
Outer Box Size: 230 x 230 x 270 mm
Inner Box QTY: 100 pcs per box
Outer Box QTY: 10,000 pcs per box
cuidevices.com
date 08/05/2022 | page 3 of 4
Product Page
3D Model
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
06/01/2008
1.01
brand update
04/24/2020
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMR-5054TB-A”相匹配的价格&库存,您可以联系我们找货
