Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 5
MODEL: CMT-9648-85T | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• through hole
• SPL 85 dB
• magnetic
• externally driven
SPECIFICATIONS
parameter
rated voltage
conditions/description
Vo-p
min
3.0
0V
at rated voltage, 2,730 Hz, ½ duty square wave
rated frequency
sound pressure level
Vo-p
80
mA
Hz
dB
30
34.5
Ø9.0 x 4.8
1.0
material
NORYL
terminal
pins (red copper with gold plating)
operating temperature
storage temperature
RoHS
Ω
mm
weight
Notes:
Vo-p
85
25.5
units
8.0
2,730
at 10 cm, rated voltage, 2,730 Hz, ½ duty square wave
coil resistance
dimensions
max
5.0
operating voltage
current consumption
typ
g
-30
70
°C
-40
85
°C
max
units
250
°C
yes
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
wave soldering
see recommended wave soldering profile
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMT-9648-85T | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
3DGV
+ROH
Recommended PCB Layout
Top View
cuidevices.com
date 08/05/2022 | page 2 of 5
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 5
FREQUENCY RESPONSE CURVE
APPLICATION CIRCUIT
+VDC
+2.5V
0V
Vin
180Ω
cuidevices.com
TR: 2SC1741AS or EQV
Vce
很抱歉,暂时无法提供与“CMT-9648-85T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+4.65707
- 25+4.41339
- 50+4.19886
- 100+3.98434
- 国内价格
- 5+4.89867
- 10+4.65707
- 25+4.41339
- 50+4.19886
- 100+3.98434
