TPC116S1-VR
TPC116S1-VR
    3PEAK(思瑞浦)
    TPC116S1-VR
TPC116S1-VR 数据手册
TPC112S1/ TPC114S1 / TPC116S1 3PEAK Single 16-/14-/12-Bit, Low Power, High Performance DACs Features Description  The TPC116S1/TPC114S1/TPC112S1 are pin compatible 12-bit, 14-bit and 16-bit digital-to-analog converter, these series product are single channel, low power, buffered voltage-out DACs and are guaranteed monotonic by design. The devices use a precision external reference applied through the high resistance input for rail-to-rail operation and low system power consumption. Single, 16-/14-/12-Bit Pin Compatible DACs TPC116S1: 16bit TPC114S1: 14bit TPC112S1: 12bit  Low Power Consumption(90μA typ)  Differential Nonlinearity: ±1LSB(max)  Glitch Energy: 0.1nV-s  Power-On Reset to Zero  Supply Range: 2.7V to 5.5V  Buffered Rail-to-Rail Output Operation  Safe Power-On Reset (POR) to Zero DAC Output  Fast 30MHz, 3-Wire, SPI/QSPI/MICROWIRE-Compatible Serial Interface  Schmitt-Trigger Inputs for Direct Optocoupler Interface  SYNC Interrupt Facility  High Performance Drop-In Compatible With DAC8551,DAC7512  Available in a Tiny MSOP-8 Package Applications  Gain and Offset Adjustment  2-Wire Sensors  Process Control and Servo Loops  Portable Instrumentation  Programmable voltage and current sources  Programmable attenuators  Automatic Test Equipment The TPC116S1/TPC114S1/TPC112S1 accepts a wide 2.7V to 5.5V supply voltage range. The parts incorporate a power-on reset circuit to ensure that the DAC output powers up to 0 V and remains there until a valid write takes place. The parts contain a power-down feature that reduces the current consumption of the device to 400 nA at 5 V and provides software-selectable output loads while in power-down mode. The power consumption is 0.45 mW at 5 V, reducing to 1μW in power-down mode. The TPC116S1/TPC114S1/TPC112S1 on-chip precision output amplifier allows rail-to-rail output swing to be achieved. For remote sensing applications, the output amplifier’s inverting input is available to the user. The TPC116S1/TPC114S1/TPC112S1 use a versatile 3-wire serial interface that operates at clock rates up to 30 MHz and is compatible with standard SPI®, QSPI™, MICROWIRE™, and DSP interface standards. The TPC116S1/TPC114S1/TPC112S1 are available in an small size 8-pin MSOP package, all package are specified over the -40°C to +125°C extended industrial temperature range. 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Package Information (Top View) (VREF) TPC11xS1 8-Pin MSOP VDD Power-On Reset (FB) (-V and Suffixes) REF(+) VDD 1 8 GND VREF 2 7 DIN VFB 3 6 SCLK VOUT 4 5 SYNC DAC Register REF(-) Output Buffer 16-/14-/12-BIT DAC Input Logic Control SYNC SCLK www.3peakic.com.cn GND Power-Down Control Logic VOUT Resistor Network DIN Rev. A01 1 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Order Information Model Name Order Number Package Marking Information Transport Media, Quantity TPC112S1 TPC112S1-VR 8-Pin MSOP Tape and Reel, 3,000 112S1 TPC114S1 TPC114S1-VR 8-Pin MSOP Tape and Reel, 3,000 114S1 TPC116S1 TPC116S1-VR 8-Pin MSOP Tape and Reel, 3,000 116S1 Absolute Maximum Ratings Note 1 + Supply Voltage: V – V – Note 2 ............................7.0V – Operating Temperature Range........–40°C to 125°C + Input Voltage............................. V – 0.3 to V + 0.3 Maximum Junction Temperature................... 150°C Input Current: +IN, –IN ±20mA Storage Temperature Range.......... –65°C to 150°C Output Short-Circuit Duration Note 4…......... Indefinite Lead Temperature (Soldering, 10 sec) ......... 260°C Note 3.......................... Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The supplies must be established simultaneously, with, or before, the application of any input signals. Note 3: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 4: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 8 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Thermal Resistance 2 Package Type θJA θJC Unit 8-Pin MSOP 210 45 ° C/W Rev. A01 www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Electrical Characteristics (VDD = 5V, VREF = 5V, CL = 100pF, RL = 10kΩ, TA = -40° C to +105° C, unless otherwise noted. Typical values are at TA = +25° C.) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS STATIC ACCURACY (Note 5) N INL DNL OE Resolution Integral Nonlinearity Differential Nonlinearity TPC112S1 12 TPC114S1 14 TPC116S1 16 TPC112S1 (12-bit) (Note 6) -4 ± 0.25 4 TPC114S1 (14-bit) (Note 6) -8 ±2 8 TPC116S1 (16-bit) (Note 6) -16 ±8 16 TPC112S1 (12-bit) (Note 6) -1 ± 0.05 1 TPC114S1 (14-bit) (Note 6) -1 ± 0.1 1 TPC116S1 (16-bit) (Note 6) -1 ± 0.5 1 6.5 12 mV 0 10 mV Zero Offset Error Full-Scale Offset Error -10 Offset-Error Drift GE Bits ±1 Gain Error -0.3 Gain Temperature Coefficient LSB LSB μV/° C ± 0.13 0.3 %FS ppmFS/ °C VDD V ±2 REFERENCE INPUT VREF Reference-Input Voltage Range RREF Reference-Input Impedance 2 333 kΩ DAC OUTPUT Output Voltage Range No load (typical) 10 kΩ load 0.2 DC Output Impedance CL Capacitive Load (Note 8) RL Resistive Load (Note 8) VREF VREF0.1 0.1 V Ω Series resistance = 0Ω 0.1 nF Series resistance = 1kΩ 15 μF 5 kΩ Short-Circuit Current VDD = 5.5V 35 mA Power-Up Time From power-down mode 25 μs DIGITAL INPUTS (SCLK, DIN, SYNC) VIH Input High Voltage VIL Input Low Voltage IIN Input Leakage Current CIN Input Capacitance www.3peakic.com.cn VDD = 5V VDD = 3.3V 2 V 1.5 V VDD = 5V 0.6 V VDD = 3.3V 0.4 V ±1 μA VIN = 0V or VDD ± 0.1 1 Rev. A01 pF 3 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Electrical Characteristics(continued) (VDD = 5V, VREF = 5V, CL = 100pF, RL = 10kΩ, TA = -40° C to +105° C, unless otherwise noted. Typical values are at TA = +25° C. SYMBOL VHYS PARAMETER CONDITIONS MIN Hysteresis Voltage TYP MAX UNITS 0.15 V 1 V/μs 14 μs 100 kHz DYNAMIC PERFORMANCE (Note 8) SR Voltage-Output Slew Rate Voltage-Output Settling Time Positive and negative 1/4 scale to 3/4 scale, to ≤ 0.5 LSB, 14-bit Hex code = 800 (TPC112S1), Reference -3dB Bandwidth Digital Feedthrough Hex code = 2000 (TPC114S1), Hex code = 8000 (TPC116S1) Code = 0, all digital inputs from 0V to VDD, nV·s 0.5 SCLK < 50MHz DAC Glitch Impulse Major code transition 2 nV·s Output Noise 10kHz 90 nV/√Hz Integrated Output Noise 0.1Hz to 10Hz 25 μVP-P POWER REQUIREMENTS VDD Supply Voltage 2.7 5.5 V 90 120 μA 0.4 1 μA No load; all digital inputs at 0V or VDD, IDD Supply Current supply current only; excludes reference input current, midscale Power-Down Supply Current No load, all digital inputs at 0V or VDD Note 5: Linearity is tested within 20mV of GND and VDD. Note 6: Gain and offset is tested within 100mV of GND and VDD. Note 7: Guaranteed by design; not production tested. Note 8: All timing specifications measured with VIL = VGND, VIH = VDD. 4 Rev. A01 www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Serial Write Operation DIN1 5 DIN DIN1 4 tDS DIN1 3 DIN1 2 DIN1 1 1 2 3 4 5 tCSH0 DIN9 DIN8 7 8 DIN2 DIN1 DIN1 5 DIN0 tCP tDH SCLK DIN1 0 6 14 15 16 1 tCSA tCH1 tCH tCSS0 tCL SYNC tCSF tCSPW Figure 1. 16-Bit Serial-Interface Timing Diagram (TPC112S1) DIN1 5 DIN DIN1 4 tDS DIN1 3 DIN1 2 DIN1 1 1 2 3 4 5 tCSH0 DIN9 DIN8 7 8 DIN2 DIN1 DIN1 5 DIN0 tCP tDH SCLK DIN1 0 6 14 15 16 1 tCSA tCH1 tCH tCSS0 tCL SYNC tCSF tCSPW Figure 2. 16-Bit Serial-Interface Timing Diagram (TPC114S1) DIN2 3 DIN DIN2 2 tDS DIN2 1 DIN2 0 DIN1 9 1 2 3 4 tCSH0 DIN1 7 DIN1 6 7 8 DIN2 DIN1 DIN2 3 DIN0 tCP tDH SCLK DIN1 8 5 6 22 23 24 1 tCH1 tCH tCSA tCSS0 tCL SYNC tCSF tCSPW Figure 3. 24-Bit Serial-Interface Timing Diagram (TPC116S1) TIMING CHARACTERISTICS (Figures 1,2 and 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS 30 MHz fSCLK Serial Clock Frequency 0 tCH SCLK Pulse-Width High 8 ns tCL SCLK Pulse-Width Low 8 ns tCSS0 SYNC Fall to SCLK Fall Setup Time 8 ns tCSH0 SYNC Fall to SCLK Fall Hold Time 0 ns tCSH1 SYNC Rise to SCLK Fall Hold Time 0 tCSA SYNC Rise to SCLK Fall tCSF SCLK Fall to SYNC Fall ns 12 ns 100 ns ns tDS DIN to SCLK Fall Setup Time 5 tDH DIN to SCLK Fall Hold Time 4.5 ns tCSPW SYNC Pulse-Width High 20 ns tCLPW SYNC Pulse-Width Low 20 ns tCSC SYNC Rise to SYNC Fall 20 ns www.3peakic.com.cn Rev. A01 5 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Typical Performance Characteristics VS = 5V, At TA = +25°C, unless otherwise specified INL and DNL vs. Digital Input Code(+25°C TPC116S1) INL and DNL vs. Digital Input Code(-40°C TPC116S1) VDD = 5.1V, VREF = 5V DNL(LSB) DNL(LSB) INL(LSB) INL(LSB) VDD = 5.1V, VREF = 5V Digital Input Code INL and DNL vs. Digital Input Code(+105°C TPC116S1) Digital Input Code INL and DNL vs. Digital Input Code(+25°C TPC114S1) INL(LSB) VDD = 5.1V, VREF = 5V DNL(LSB) DNL(LSB) INL(LSB) VDD = 5.1V, VREF = 5V Digital Input Code DNL(LSB) Digital Input Code 6 VDD = 5.1V, VREF = 5V DNL(LSB) INL(LSB) VDD = 5.1V, VREF = 5V INL and DNL vs. Digital Input Code(+105°C TPC114S1) INL(LSB) INL and DNL vs. Digital Input Code(-40°C TPC114S1) Digital Input Code Rev. A01 Digital Input Code www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Typical Performance Characteristics VS = 5V, At TA = +25°C, unless otherwise specified Power-Supply Current vs. Temperature(TPC114S1) Power-Supply Current vs. Temperature(TPC114S1) 140 140 VDD= 5.1V VREF= 5V 120 100 80 80 IDD(μA) 100 IDD(μA) VDD = 2.7V VREF = 2.5V 120 60 40 60 40 20 20 0 -40 -10 20 50 80 0 110 -40 -10 Zero-Scale Error vs. Temperature(TPC114S1) 50 80 110 Zero-Scale Error vs. Temperature(TPC114S1) 5 5 VDD = 5.1V VREF = 5V VDD = 2.7V VREF = 2.5V Error(mV) Error(mV) 20 Temperature(°C) Temperature(°C) 0 0 -5 -5 -40 -10 20 50 80 -40 110 -10 20 50 80 110 Temperature(°C) Temperature(°C) Full-Scale Error vs. Temperature(TPC114S1) Full-Scale Error vs. Temperature(TPC114S1) 10 10 VDD = 5.1V VREF = 5V VDD = 2.7V VREF = 2.5V 5 Error(mV) Error(mV) 5 0 0 -5 -5 -40 -10 20 50 Temperature(°C) www.3peakic.com.cn 80 110 -40 -10 20 50 80 110 Temperature(°C) Rev. A01 7 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Typical Performance Characteristics VS = 5V, At TA = +25°C, unless otherwise specified Power-Supply Current vs. Temperature(TPC116S1) Power-Supply Current vs. Temperature(TPC116S1) 140 140 VDD = 5.1V VREF = 5V 120 100 80 80 IDD(μA) 100 IDD(μA) VDD = 2.7V VREF = 2.5V 120 60 60 40 40 20 20 0 0 -40 -10 20 50 80 -40 110 -10 Temperature(°C) 80 110 Zero-Scale Error vs. Temperature(TPC116S1) 5 5 VDD = 5.1V VREF = 5V VDD = 2.7V VREF = 2.5V Error(mV) Error(mV) 50 Temperature(°C) Zero-Scale Error vs. Temperature(TPC116S1) 0 -5 0 -5 -40 -10 20 50 80 110 -40 -10 Temperature(°C) 20 50 80 110 Temperature(°C) Full-Scale Error vs. Temperature(TPC116S1) Full-Scale Error vs. Temperature(TPC116S1) 10 10 VDD = 5.1V VREF = 5V VDD = 2.7V VREF = 2.5V 5 Error(mV) Error(mV) 5 0 0 -5 -5 -40 -10 20 50 Temperature(°C) 8 20 Rev. A01 80 110 -40 -10 20 50 80 110 Temperature(°C) www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Typical Performance Characteristics VS = 5V, At TA = +25°C, unless otherwise specified Source and Sink Current Capability(TPC116S1) Source and Sink Current Capability(TPC116S1) 3 6 2.5 5 DAC Loaded with FFFFh VOUT (V) VOUT(V) DAC Loaded with FFFFh 2 4 3 VDD = 5.5V VREF = VDD-10mV 2 1.5 VDD = 2.7V VREF = VDD-10mV 1 0.5 1 DAC Loaded with 0000h DAC Loaded with 0000h 0 0 0 2 4 6 8 0 10 2 Supply Current vs. Logic Input Voltage(TPC116S1) 8 10 80 TA=25°C, SCL Input(all other inputs=GND) VDD = VREF = 5.5V 270 240 70 60 210 50 180 IDD(μA) IDD(μA) 6 Supply Current vs. Logic Input Voltage(TPC116S1) 300 150 120 40 TA=25°C, SCL Input(all other inputs=GND) VDD = VREF = 2.7V 30 90 20 60 10 30 0 0 0 1 2 3 4 5 0 VLOGIC (V) 1 1.5 2 2.5 3 Full-Scale Settling Time(2.7V Falling Edge) SCLK(2V/div) 200 VREF = VDD Reference Current Included,No Load 180 0.5 VLOGIC (V) Supply Current vs. Supply Voltage(TPC116S1) 160 140 VDD == 2.7V V 2.7V VREF = 2.5V V = 2.5V FromCode: Code: FFFF FFFF From To Code:0000 Code: 0000 To 120 100 VOUT(1V/div) IDD(μA) 4 I(SOURCE/SINK) (mA) I(SOURCE/SINK) (mA) 80 60 40 20 2.7 3.1 3.5 3.9 4.3 VDD (V) www.3peakic.com.cn 4.7 5.1 5.5 Time (160ns/div) Rev. A01 9 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Typical Performance Characteristics VS = 5V, At TA = +25°C, unless otherwise specified VVDD= =5V5V = 4.096V VVREF = 4.096V FromCode: Code:0000 0000 From ToCode:FFFF Code: FFFF To VOUT(1V/div) VOUT(1V/div) SCLK(2V/div) = 5V VDD = 5V VREF = 4.096V = 4.096V From Code: FFFF To Code: 0000 Code:0000 Full-Scale Settling Time(5V Rising Edge) SCLK(2V/div) Full-Scale Settling Time(5V Falling Edge) Time (250ns/div) Time (500ns/div) Full-Scale Settling Time(2.7V Rising Edge) VOUT(1V/div) SCLK(2V/div) VDD = 2.7V = 2.7V VREF = 2.5V = 2.5V From Code: 0000 To Code:FFFF Code: FFFF Time (430ns/div) 10 Rev. A01 www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Pin Functions TPC11xS1 8-Pin MSOP (-V and Suffixes) VDD 1 8 GND VREF 2 7 DIN VFB 3 6 SCLK VOUT 4 5 SYNC PIN number PIN name 1 2 VDD VREF Function 3 VFB 4 VOUT Analog output voltage from DAC. The output amplifier has rail-to-rail operation. 5 SYNC Level-triggered control input (active LOW). This is the frame synchronization signal for the input data. When SYNC goes LOW, it enables the input shift register and data is transferred in on the falling edges of the following clocks. The DAC is updated following the 16th/24th clock (unless SYNC is taken HIGH before this edge, in which case the rising edge of SYNC acts as an interrupt and the write sequence is ignored by the TPC112S1 and TPC114S1/ TPC116S1). Schmitt-Trigger logic input. 6 SCLK 7 DIN 8 GND Power supply input, 2.7V to 5.5V Reference voltage input. Feedback connection for the output amplifier. For voltage output operation, tie to VOUT externally. Serial clock input. Data can be transferred at rates up to 30MHz. Schmitt-Trigger logic input. Serial data input. Data is clocked into the 16-/24-bit input shift register on each falling edge of the serial clock input. Schmitt-Trigger logic input. Ground reference point for all circuitry on the part. Detailed Description The TPC116S1/ TPC114S1/TPC112S1 are pin-compatible and software-compatible 12-bit, 14-bit and 16-bit DACs. The TPC116S1/ TPC114S1/TPC112S1 are single-channel, low-power, high-reference input resistance, and buffered voltage-output DACs. The TPC116S1/ TPC114S1/TPC112S1 minimize the digital noise feedthrough from their inputs to their outputs by powering down the SCLK and DIN input buffers after completion of each data frame. The data frames are 16-bit for the TPC114S1/TPC112S1 and 24-bit for the TPC116S1. On power-up, the TPC116S1/ TPC114S1/TPC112S1 reset the DAC output to zero, providing additional safety for applications that drive valves or other transducers which need to be off on power-up. The TPC116S1/ TPC114S1/TPC112S1 contain a segmented resistor string-type DAC, a serial-in/parallel-out shift register, a DAC register, power-on-reset (POR) circuit, and control logic. On the falling edge of the clock (SCLK) pulse, the serial input (DIN) data is shifted into the device, MSB first. www.3peakic.com.cn Rev. A01 11 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Applications Information Output Amplifier The output buffer amplifier is capable of generating rail-to-rail voltages on its output, giving an output range of 0V to VDD. It is capable of driving a load of 2kin parallel with 1000pF to GND. The source and sink capabilities of the output amplifier can be seen in the Typical Characteristics. The slew rate is 1.8V/s with a full-scale setting time of 8s with the output unloaded. The inverting input of the output amplifier is brought out to the VFB pin. This configuration allows for better accuracy in critical applications by tying the VFB point and the amplifier output together directly at the load. Other signal conditioning circuitry may also be connected between these points for specific applications. DAC Reference (REF) The external reference input features a typical input impedance of 333kΩ and accepts an input voltage from +2V to VDD. Connect an external voltage supply between REF and GND to apply an external reference. Serial Interface The TPC116S1/ TPC114S1/TPC112S1 3-wire serial interface is compatible with MICROWIRE, SPI, QSPI, and DSP. The interface provides three inputs: SCLK, SYNC, and DIN. The chip-select input (SYNC) frames the serial data loading at DIN. Following a chip-select input high-to-low transition, the data is shifted synchronously and latched into the input register on each falling edge of the serial-clock input (SCLK). Each serial word is 16-bit for the TPC114S1/ TPC112S1 and 24-bit for the TPC116S1. The first 2 bits are the control bits followed by 12/14 data bits (MSB first) for the TPC114S1/ TPC112S1 and 22 data bits (MSB first) for the TPC116S1 as shown in Tables 1 and 2. The serial input register transfers its contents to the input registers after loading 16/24 bits of data and updates the DAC output immediately after the data is received on the 16-/24-bit falling edge of the clock. To initiate a new data transfer, drive SYNC high and keep SYNC high for a minimum of 20ns before the next write sequence. The SCLK can be either high or low between SYNC write pulses. Figures 1 and 2 show the timing diagram for the complete 3-wire serial interface transmission. The TPC116S1 DAC code is unipolar binary with VOUT = (code/65,536) x VREF. The TPC114S1 DAC code is unipolar binary with VOUT = (code/16,384) x VREF. The TPC112S1 DAC code is unipolar binary with VOUT = (code/4096) x VREF. 16-BIT WORD MSB D15 D14 X X X X X X X X X X CONTROL DATA BITS BITS LSB PD1 PD0 0 0 1 1 0 1 0 1 Function D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 X X X X X X X X X X X X X X X X X X X X X X X X Power-down modes X X X X X X X X X X X X Output typically 1kΩ to GND X X X X X X X X X X X X Output typically 100kto GND X X X X X X X X X X X X High-Z Normal operation X Table 1. Operating Mode Truth Table (TPC112S1) 12 Rev. A01 www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs 16-BIT WORD CONTROL DATA BITS BITS MSB Function LSB PD1 PD0 0 0 1 1 0 1 0 1 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 X X X X X X X X X X X X X X X X X X X X X X X X X X X X Power-down modes X X X X X X X X X X X X X X Output typically 1kΩ to GND X X X X X X X X X X X X X X Output typically 100kto GND X X X X X X X X X X X X X X High-Z Normal operation X Table 2. Operating Mode Truth Table (TPC114S1) 24-BIT WORD CONTROL DATA BITS BITS MSB LSB D23 D22 D21 D20 D19 D18 X X X X X X X X X X X X X Function X X X X X X X X X X X X X X X X X PD1 PD0 0 - 0 - 0 1 1 0 1 1 D15 D14 D13 D12 D11 D10 D9 D0~D8 X X X X X X X X Normal operation X X X X X X X X Power-down modes X X X X X X X X Output typically 1kΩ to GND X X X X X X X X Output typically X X X X X X X X X 100kto GND High-Z X Table 3. Operating Mode Truth Table (TPC116S1) POWER-ON RESET The TPC116S1/ TPC114S1/TPC112S1 contains a power-on-reset circuit that controls the output voltage during power up. On power up, the DAC registers are filled with zeros and the output voltages are 0V; they remain that way until a valid write sequence is made to the DAC. The power-on reset is useful in applications where it is important to know the state of the output of the DAC while it is in the process of powering up. POWER-DOWN MODES The TPC116S1/ TPC114S1/TPC112S1 supports four separate modes of operation. These modes are programmable by setting two bits (PD1 and PD0) in the control register. Table 1~3 show how the state of the bits corresponds to the mode of operation of the device. When both bits are set to '0', the device works normally with its typical current consumption of 90μA at 5V. However, for the three power-down modes, the supply current falls to 400nA at 5V (250nA at 3V). Not only does the supply current fall, but the output stage is also internally switched from the output of the www.3peakic.com.cn Rev. A01 13 TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs amplifier to a resistor network of known values. This configuration has the advantage that the output impedance of the device is known while it is in power-down mode. There are three different options. The output is connected internally to GND through a 1kresistor, a 100kresistor, or it is left open-circuited (High-Z). The output stage is illustrated in Figure 4. All analog circuitry is shut down when the power-down mode is activated. However, the contents of the DAC register are unaffected when in power-down. The time to exit power-down is typically 2.5μs for VDD = 5V, and 5μs for VDD = 3V. See the Typical Characteristics for more information. (VREF) GND VDD (FB) REF(+) REF(-) Output Buffer 16-/14-/12-BIT DAC Power-Down Control Logic VOUT Resistor Network Figure 4. Output Stage During Power-Down 14 Rev. A01 www.3peakic.com.cn TPC112S1/ TPC114S1 / TPC116S1 Single 16-/14-/12-Bit, Low Power, High Performance DACs Package Outline Dimensions MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 www.3peakic.com.cn L L2 Rev. A01 15
TPC116S1-VR 价格&库存
很抱歉,暂时无法提供与“TPC116S1-VR”相匹配的价格&库存,您可以联系我们找货
