Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 5
MODEL: CES-361811-18PM-67 | DESCRIPTION: SPEAKER
FEATURES
• IP67 rated
• 8 ohm rated impedance
• 1 W rated power
SPECIFICATIONS
parameter
conditions/description
min
input power
max power: IEC-60268-5, filter 60 seconds on, 120 seconds off, 10 cycles(room temp)
impedance
at 2.0 kHz
resonant frequency (Fo)
at 1.0 V
frequency response
typ
max
units
1.0
1.2
W
6.8
8
9.2
Ω
720
900
Fo
sound pressure level
at 1.0 W, 10 cm, avg at 2.0 kHz
distortion
at 1.0 kHz, rated power, 10 cm
86
buzz, rattle, etc.
must be normal at sine wave, frequency range
polarity
cone moves forward w/ positive dc current to “+” terminal
dimensions
25.0 x 15.6 x 10.9
magnet
Nd-Fe-B
enclosure material
ABS
cone material
PEEK
terminal
wire leads with connector
storage temperature
Notes:
Hz
92
dB
10
2.83
V
4.0
operating temperature
IP level
Hz
mm
weight
RoHS
89
1,080
20,000
yes
IP67 (front side)
1. All specifications measured at 25~75°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
cuidevices.com
g
-30
70
°C
-40
85
°C
Product Page
3D Model
CUI DEVICES | MODEL: CES-361811-18PM-67 | DESCRIPTION: SPEAKER
date 08/05/2022 | page 2 of 5
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
wire: UL1571 30 AWG
internal speaker: CMS-18132-18SP
connector: Molex 51021-0200 or equivalent; P=1.25
5
f
UHGĀā
SLWFK
67$03
0119
%ODFNOHWWHULQJ
67$03',5(&7,21
,6)5((
很抱歉,暂时无法提供与“CES-361811-18PM-67”相匹配的价格&库存,您可以联系我们找货
