For more information, please visit the product page.
date
07/15/2016
page
1 of 3
SERIES: CDS-15118B-L100 │ DESCRIPTION: SPEAKER
micro-speaker
small footprint
8 ohm impedance
wire leads
N
U
ED
FEATURES
SPECIFICATIONS
conditions/description
min
input power
maximum power: IEC-60268-5, filter 60s on/120s
off, 10 cycles at room temp, in 1 cc closed box
impedance
at 2.5 kHz, 1.0 V
TI
parameter
resonant frequency (Fo)
1.0
W
8
9.2
Ω
600
Hz
Fo
at 0.5 W, 0.1 m ave, at 0.8, 1.0, 1.2, 1.5 kHz
83
distortion
at 1.0 kHz, 0.7 W
buzz, rattle, etc.
must be normal at sine wave between
Fo ~ 20 kHz, in 1 cc closed box
polarity
cone will move forward with positive dc current to
“+” terminal
N
0.7
500
output SPL ±10 dB
86
20,000
Hz
89
dB
10
V
O
2.37
15 x 11 x 3
mm
Nd-Fe-B
PPA
IS
C
material
cone material
mylar
terminal
wire leads
weight
1.7
operating temperature
storage temperature
RoHS
Notes:
units
6.8
sound pressure level
magnet
max
400
frequency response
dimensions
typ
g
-20
60
°C
-40
85
°C
2011/65/EU
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
D
PART NUMBER KEY
CDS-15118B-L100 X
Base Number
cui.com
Termination Style:
“blank” = wire leads, no connector
1 = JST housing SHR-2V-S-B
2 = JST housing ZHR-2
3 = JST housing PHR-2
4 = JST housing HER-2
5 = JST housing PHR-4
6 = Molex housing 51021-0200
CUI Inc │ SERIES: CDS-15118B-L100 │ DESCRIPTION: SPEAKER
date 07/15/2016 │ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
TI
N
U
ED
wire: UL1571 30 AWG
RESPONSE CURVES
Total Harmonic Distortion Curve
D
IS
C
O
N
Frequency Response Curve
cui.com
date 07/15/2016 │ page 3 of 3
REVISION HISTORY
description
date
1.0
initial release
03/25/2015
1.01
added connector options
ED
rev.
07/15/2016
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“CDS-15118B-L100”相匹配的价格&库存,您可以联系我们找货
