RTL8382L-VB-CG
RTL8382L-VB-CG
    REALTEK(瑞昱)
    LQFP216
    RTL8382L - 未管理26*10/100/1000M端口交换控制器
RTL8382L-VB-CG 数据手册
RTL8380M-CG MULTI-LAYER MANAGED 18*10/100/ RTL8382M-CG MULTI-LAYER MANAGED 28*10/100/ RTL8382L-CG UN-MANAGED 26*10/100/1000M-PORT SWITCH CONTROLLERS DRAFT DATASHEET (CONFIDENTIAL: Development Partners Only) Rev. 0.7 20 February. 2013 Track ID: Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com RTL8380M/RTL8382M/RTL8382L Datasheet COPYRIGHT ©2012 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document ‘as is’, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document provides detailed user guidelines to achieve the best performance when implementing the Realtek Ethernet Switch Controllers. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. REVISION HISTORY Revision 0.1 0.2 0.3 0.4 Release Date 2012/05/12 2012/08/08 2012/09/18 2012/10/18 Summary Initial draft. Updated. Revised the pin description error for MEM_TYPE[1:0] on table 14, 30 and 44. Add 11.4 AC characteristics; 0.5 2013/01/24 0.6 0.7 2013/02/20 2013/05/02 Update RTL8382L pin assignment; Add uart1 interface description; Add GPIO[14:11] and GPO10 description; Modify the ddr2 and spi flash timing Characteristics; Add ddr3 timing Characteristics; Modify the description for CLK_M_EE[1:0]; Modify the AC Characteristic of QSGMII VTX-DIFFp-p and VRX-DIFFp-p; Modify the operating range of the DVDDL, AVDDL, SVDDL, AVDDL_PLL, PLLVDDL and VDDIO. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers ii Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Table of Contents 1. GENERAL DESCRIPTION ..............................................................................................................................................1 2. FEATURES .........................................................................................................................................................................3 3. SYSTEM APPLICATIONS...............................................................................................................................................3 3.1. 3.2. 3.3. 3.4. 4. BLOCK DIAGRAMS.........................................................................................................................................................7 4.1. 4.2. 4.3. 5. RTL8380M: MANAGED 16*1000M UTP+2*1000BASE-X SWITCH ............................................................................3 RTL8382M: MANAGED 28*1000M SWITCH VIA RTL8218B PHY .............................................................................4 RTL8382M: MANAGED 20*1000M UTP+4*1000M COMBO SWITCH ........................................................................5 RTL8382M/RTL8382L: MANAGED/UNMANAGED 24*1000M UTP+2*1000BASE-X SWITCH ..................................6 RTL8380M BLOCK DIAGRAM .....................................................................................................................................7 RTL8382M BLOCK DIAGRAM .....................................................................................................................................8 RTL8382L BLOCK DIAGRAM ......................................................................................................................................9 PIN ASSIGNMENTS AND DESCRIPTION (RTL8380M)..........................................................................................10 5.1. PIN ASSIGNMENTS FIGURE (RTL8380M) ..................................................................................................................10 5.2. PACKAGE IDENTIFICATION .........................................................................................................................................11 5.3. PIN ASSIGNMENTS TABLE CODES (RTL8380M)........................................................................................................11 5.4. PIN ASSIGNMENTS TABLE (RTL8380M)....................................................................................................................11 5.5. PIN DESCRIPTIONS (RTL8380M)...............................................................................................................................16 5.5.1. 1000M Ethernet PHY MDI Interface Pins............................................................................................................16 5.5.2. SGMII Interface Pins............................................................................................................................................17 5.5.3. RSGMII Interface Pins .........................................................................................................................................18 5.5.4. QSGMII Interface Pins.........................................................................................................................................18 5.5.5. 1000Base-X/100Base-FX Interface Pins ..............................................................................................................18 5.5.6. DDR1/2 SDRAM Interface Pins ...........................................................................................................................19 5.5.7. DDR3 SDRAM Interface Pins ..............................................................................................................................19 5.5.8. Master Mode-SPI Flash Interface Pins ................................................................................................................20 5.5.9. UART Interface Pins.............................................................................................................................................20 5.5.10. LED Interface Pins ..........................................................................................................................................21 5.5.11. GPIO Interface Pins ........................................................................................................................................21 5.5.12. EJTAG Interface Pins ......................................................................................................................................21 5.5.13. Configuration Strapping Pins..........................................................................................................................22 5.5.14. Miscellaneous Interface Pins...........................................................................................................................23 5.5.15. Power and GND Pins ......................................................................................................................................24 6. PIN ASSIGNMENTS AND DESCRIPTION (RTL8382M)..........................................................................................25 6.1. PIN ASSIGNMENTS FIGURE (RTL8382M) ..................................................................................................................25 6.2. PACKAGE IDENTIFICATION .........................................................................................................................................25 6.3. PIN ASSIGNMENTS TABLE CODES (RTL8382M)........................................................................................................26 6.4. PIN ASSIGNMENTS TABLE (RTL8382M)....................................................................................................................26 6.5. PIN DESCRIPTION (RTL8382M).................................................................................................................................30 6.5.1. 1000M Ethernet PHY MDI Interface Pins............................................................................................................30 6.5.2. SGMII Interface Pins............................................................................................................................................32 6.5.3. RSGMII Interface Pins .........................................................................................................................................32 6.5.4. QSGMII Interface Pins.........................................................................................................................................32 6.5.5. 1000Base-X/100Base-FX Interface Pins ..............................................................................................................33 6.5.6. DDR1/2 SDRAM Interface Pins ...........................................................................................................................33 6.5.7. DDR3 SDRAM Interface Pins ..............................................................................................................................34 6.5.8. Master Mode-SPI Flash Interface Pins ................................................................................................................35 6.5.9. UART Interface Pins.............................................................................................................................................35 6.5.10. LED Interface Pins ..........................................................................................................................................35 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers iii Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 6.5.11. 6.5.12. 6.5.13. 6.5.14. 6.5.15. 7. GPIO Interface Pins ........................................................................................................................................35 EJTAG Interface Pins ......................................................................................................................................36 Configuration Strapping Pins..........................................................................................................................36 Miscellaneous Interface Pins...........................................................................................................................37 Power and GND Pins ......................................................................................................................................38 PIN ASSIGNMENTS AND DESCRIPTION (RTL8382L)...........................................................................................39 7.1. PIN ASSIGNMENTS FIGURE (RTL8382L) ...................................................................................................................39 7.2. PACKAGE IDENTIFICATION .........................................................................................................................................40 7.3. PIN ASSIGNMENTS TABLE CODES (RTL8382L).........................................................................................................40 7.4. PIN ASSIGNMENTS TABLE (RTL8382L).....................................................................................................................40 7.5. PIN DESCRIPTIONS (RTL8382L) ................................................................................................................................44 7.5.1. 1000M Ethernet PHY MDI Interface Pins............................................................................................................44 7.5.2. SGMII Interface Pins............................................................................................................................................46 7.5.3. QSGMII Interface Pins.........................................................................................................................................46 7.5.4. 1000Base-X/100Base-FX Interface Pins ..............................................................................................................46 7.5.5. Master Mode-SPI Flash Interface Pins ................................................................................................................47 7.5.6. UART Interface Pins.............................................................................................................................................47 7.5.7. LED Interface Pins ...............................................................................................................................................47 7.5.8. GPIO Interface Pins .............................................................................................................................................48 7.5.9. Configuration Strapping Pins...............................................................................................................................48 7.5.10. Miscellaneous Interface Pins...........................................................................................................................49 7.5.11. Power and GND Pins ......................................................................................................................................50 8. SWITCH FUNCTION DESCRIPTION .........................................................................................................................51 8.1. HARDWARE RESET AND SOFTWARE RESET ................................................................................................................51 8.1.1. Hardware Reset ....................................................................................................................................................51 8.1.2. Software Reset ......................................................................................................................................................51 8.2. CRYSTAL....................................................................................................................................................................51 8.3. IEEE 802.3AZ ENERGY EFFICIENT ETHERNET (EEE) ................................................................................................51 8.4. LAYER 2 LEARNING AND FORWARDING .....................................................................................................................52 8.4.1. Forwarding...........................................................................................................................................................52 8.4.2. Learning ...............................................................................................................................................................52 8.4.3. DA/SA Block .........................................................................................................................................................52 8.5. PORT ISOLATION ........................................................................................................................................................53 8.6. IEEE 802.3X FLOW CONTROL ...................................................................................................................................54 8.7. HALF DUPLEX BACKPRESSURE ..................................................................................................................................55 8.7.1. Collision-Based Backpressure (Jam Mode) .........................................................................................................55 8.7.2. Carrier-Based Backpressure (I.e., Defer Mode) ..................................................................................................55 8.8. LAYER 2 MULTICAST AND IP MULTICAST .................................................................................................................56 8.9. IEEE 802.1D/1W/1S (STP/RSTP/MSTP)...................................................................................................................56 8.10. IEEE 802.1P AND IEEE 802.1Q (VLAN) ..................................................................................................................57 8.11. IEEE 802.1X (NETWORK ACCESS CONTROL)............................................................................................................58 8.12. RESERVED MULTICAST ADDRESS HANDLING ............................................................................................................59 8.13. LAYER 2 TRAFFIC SUPPRESSION (STORM CONTROL) .................................................................................................60 8.14. PIE (PACKET INSPECTION ENGINE)............................................................................................................................60 8.14.1. Ingress ACL .....................................................................................................................................................60 8.15. INPUT BANDWIDTH CONTROL AND ACL TRAFFIC METER .........................................................................................61 8.15.1. Input Bandwidth Control .................................................................................................................................61 8.15.2. ACL Traffic Meter............................................................................................................................................61 8.16. IEEE 802.3AD LINK AGGREGATION PROTOCOL ........................................................................................................61 8.17. IEEE 802.1AD VLAN STACKING...............................................................................................................................62 8.18. QUALITY OF SERVICE (QOS)......................................................................................................................................63 8.19. PACKET SCHEDULING (WRR AND WFQ)...................................................................................................................64 8.20. PACKET DROP ALGORITHM (TD)...............................................................................................................................65 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers iv Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.21. EGRESS PACKET REMARKING ....................................................................................................................................65 8.22. INGRESS AND EGRESS PORT MIRROR .........................................................................................................................65 8.22.1. Remote Mirror (RAPAN) .................................................................................................................................66 8.23. MANAGEMENT INFORMATION BASE (MIB) ...............................................................................................................67 8.24. NIC AND CPU TAG FORWARDING .............................................................................................................................67 8.25. INDIRECT TABLE ACCESS ...........................................................................................................................................68 8.26. EXTERNAL PHY REGISTER ACCESS ...........................................................................................................................68 8.27. SWITCH INTERRUPT INDICATION ................................................................................................................................68 9. CPU FUNCTION DESCRIPTION .................................................................................................................................68 9.1. 9.2. 9.3. 10. INTERFACE DESCRIPTIONS ......................................................................................................................................70 10.1. 10.2. 10.3. 10.4. 10.5. 10.6. 10.7. 10.8. 10.9. 10.10. 10.11. 10.12. 10.13. 11. MIPS-4KEC...............................................................................................................................................................68 SPI FLASH..................................................................................................................................................................69 SDRAM INTERFACE CONFIGURATION (RTL8380M/RTL8382M ONLY)..................................................................69 QSGMII ....................................................................................................................................................................70 RSGMII.....................................................................................................................................................................70 SGMII .......................................................................................................................................................................71 DDR1 SDRAM (RTL8380M/RTL8382M ONLY).....................................................................................................72 DDR2 SDRAM (RTL8380M/RTL8382M ONLY).....................................................................................................73 DDR3 SDRAM (RTL8380M/RTL8382M ONLY).....................................................................................................74 SPI FLASH INTERFACE ...............................................................................................................................................74 UART........................................................................................................................................................................75 EJTAG ......................................................................................................................................................................75 I2C MASTER FOR EEPROM ......................................................................................................................................76 I2C SLAVE INTERFACE ...............................................................................................................................................76 SPI SLAVE INTERFACE ...............................................................................................................................................77 SERIAL LED...............................................................................................................................................................78 ELECTRICAL AC/DC CHARACTERISTICS.............................................................................................................80 11.1. ABSOLUTE MAXIMUM RATINGS ................................................................................................................................80 11.2. OPERATING RANGE ....................................................................................................................................................80 11.3. DC CHARACTERISTICS ...............................................................................................................................................81 11.4. AC CHARACTERISTICS ...............................................................................................................................................81 11.4.1. QSGMII Differential Transmitter Characteristics...........................................................................................81 11.4.2. QSGMII Differential Receiver Characteristics................................................................................................82 11.4.3. RSGMII Differential Transmitter Characteristics ...........................................................................................84 11.4.4. RSGMII Differential Receiver Characteristics ................................................................................................85 11.4.5. SGMII Differential Transmitter Characteristics..............................................................................................86 11.4.6. SGMII Differential Receiver Characteristics ..................................................................................................87 11.4.7. DDR2 Characteristics .....................................................................................................................................88 11.4.8. DDR3 Characteristics .....................................................................................................................................89 11.4.9. SPI Interface Characteristics...........................................................................................................................90 11.4.10. SMI (MDC/MDIO) Interface Characteristics..................................................................................................91 12. PACKAGE INFORMATION..........................................................................................................................................92 12.1. 13. LQFP216-E-PAD (24*24MM) ...................................................................................................................................92 ORDERING INFORMATION........................................................................................................................................94 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers v Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet List of Tables TABLE 1. PIN ASSIGNMENTS TABLE (RTL8380M)......................................................................................................................11 TABLE 2. 1000M ETHERNET PHY MDI INTERFACE PINS ............................................................................................................16 TABLE 3. SGMII INTERFACE PINS ...............................................................................................................................................17 TABLE 4. RSGMII INTERFACE PINS ............................................................................................................................................18 TABLE 5. QSGMII INTERFACE PINS ............................................................................................................................................18 TABLE 6. 1000BASE-X/100BASE-FX INTERFACE PINS ...............................................................................................................18 TABLE 7. DDR1/2 SDRAM INTERFACE PINS ..............................................................................................................................19 TABLE 8. DDR3 SDRAM INTERFACE PINS .................................................................................................................................19 TABLE 9. MASTER MODE-SPI FLASH INTERFACE PINS ...............................................................................................................20 TABLE 10. UART INTERFACE PINS ...............................................................................................................................................20 TABLE 11. LED INTERFACE PINS ..................................................................................................................................................21 TABLE 12. GPIO INTERFACE PINS ................................................................................................................................................21 TABLE 13. EJTAG INTERFACE PINS ..............................................................................................................................................21 TABLE 14. CONFIGURATION STRAPPING PINS ...............................................................................................................................22 TABLE 15. MISCELLANEOUS INTERFACE PINS...............................................................................................................................23 TABLE 16. POWER AND GND PINS ................................................................................................................................................24 TABLE 17. PIN ASSIGNMENTS TABLE (RTL8382M) .....................................................................................................................26 TABLE 18. 1000M ETHERNET PHY MDI INTERFACE PINS ...........................................................................................................30 TABLE 19. SGMII INTERFACE PINS...............................................................................................................................................32 TABLE 20. RSGMII INTERFACE PINS ............................................................................................................................................32 TABLE 21. QSGMII INTERFACE PINS ............................................................................................................................................32 TABLE 22. 1000BASE-X/100BASE-FX INTERFACE PINS ...............................................................................................................33 TABLE 23. DDR1/2 SDRAM INTERFACE PINS .............................................................................................................................33 TABLE 24. DDR3 SDRAM INTERFACE PINS ................................................................................................................................34 TABLE 25. MASTER MODE-SPI FLASH INTERFACE PINS ...............................................................................................................35 TABLE 26. UART INTERFACE PINS ...............................................................................................................................................35 TABLE 27. LED INTERFACE PINS ..................................................................................................................................................35 TABLE 28. GPIO INTERFACE PINS ................................................................................................................................................35 TABLE 29. EJTAG INTERFACE PINS ..............................................................................................................................................36 TABLE 30. CONFIGURATION STRAPPING PINS ...............................................................................................................................36 TABLE 31. MISCELLANEOUS INTERFACE PINS...............................................................................................................................37 TABLE 32. POWER AND GND PINS ................................................................................................................................................38 TABLE 33. PIN ASSIGNMENTS TABLE (RTL8382L) ......................................................................................................................40 TABLE 34. 1000M ETHERNET PHY MDI INTERFACE PINS ...........................................................................................................44 TABLE 35. SGMII INTERFACE PINS...............................................................................................................................................46 TABLE 37. QSGMII INTERFACE PINS ............................................................................................................................................46 TABLE 38. 1000BASE-X/100BASE-FX INTERFACE PINS ...............................................................................................................46 TABLE 39. MASTER MODE-SPI FLASH INTERFACE PINS ...............................................................................................................47 TABLE 40. UART INTERFACE PINS ...............................................................................................................................................47 TABLE 41. LED INTERFACE PINS ..................................................................................................................................................47 TABLE 42. GPIO INTERFACE PINS ................................................................................................................................................48 TABLE 43. CONFIGURATION STRAPPING PINS ...............................................................................................................................48 TABLE 44. MISCELLANEOUS INTERFACE PINS...............................................................................................................................49 TABLE 45. POWER AND GND PINS ................................................................................................................................................50 TABLE 46. SPANNING TREE AND RAPID SPANNING TREE ACTION ................................................................................................57 TABLE 47. FORWARDING OF HOST N .............................................................................................................................................59 TABLE 48. RESERVED MULTICAST ADDRESS DEFAULT ACTIONS .................................................................................................59 TABLE 49. UART CONTROL INTERFACE PINS...............................................................................................................................75 TABLE 50. EJTAG INTERFACE PINS ..............................................................................................................................................75 TABLE 51. SPI SLAVE INTERFACE .................................................................................................................................................77 TABLE 52. ABSOLUTE MAXIMUM RATINGS ..................................................................................................................................80 TABLE 53. RECOMMENDED OPERATING RANGE ...........................................................................................................................80 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers vi Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet TABLE 54. DC CHARACTERISTICS (IO_POWER=3.3V) .................................................................................................................81 TABLE 55. QSGMII DIFFERENTIAL TRANSMITTER CHARACTERISTICS .........................................................................................81 TABLE 56. QSGMII DIFFERENTIAL RECEIVER CHARACTERISTICS ...............................................................................................82 TABLE 57. RSGMII DIFFERENTIAL TRANSMITTER CHARACTERISTICS .........................................................................................84 TABLE 58. RSGMII DIFFERENTIAL RECEIVER CHARACTERISTICS ...............................................................................................85 TABLE 59. SGMII DIFFERENTIAL TRANSMITTER CHARACTERISTICS ............................................................................................86 TABLE 60. SGMII DIFFERENTIAL RECEIVER CHARACTERISTICS .................................................................................................87 TABLE 61. DDR2 SDRAM TIMING CHARACTERISTICS ................................................................................................................88 TABLE 62. DDR3 SDRAM TIMING CHARACTERISTICS ................................................................................................................89 TABLE 63. SPI INTERFACE TIMING CHARACTERISTICS .................................................................................................................90 TABLE 64. SMI (MDC/MDIO) TIMING CHARACTERISTICS ..........................................................................................................91 TABLE 65. ORDERING INFORMATION ............................................................................................................................................94 List of Figures FIGURE 1. MANAGED 16*1000M UTP+2*1000BASE-X SWITCH ..................................................................................................3 FIGURE 2. MANAGED/UNMANAGED 28*1000M SWITCH VIA RTL8218B PHY.............................................................................4 FIGURE 3. MANAGED/UNMANAGED 20*1000M UTP+4*1000M COMBO SWITCH ........................................................................5 FIGURE 4. MANAGED/UNMANAGED 24*1000M UTP+2*1000BASE-X SWITCH ...........................................................................6 FIGURE 5. RTL8380M BLOCK DIAGRAM ......................................................................................................................................7 FIGURE 6. RTL8382M BLOCK DIAGRAM ......................................................................................................................................8 FIGURE 7. RTL8382L BLOCK DIAGRAM .......................................................................................................................................9 FIGURE 8. PIN ASSIGNMENTS (RTL8380M) ................................................................................................................................10 FIGURE 9. PIN ASSIGNMENTS (RTL8382M) ................................................................................................................................25 FIGURE 10. PIN ASSIGNMENTS (RTL8382L).................................................................................................................................39 FIGURE 11. DA/SA BLOCK ...........................................................................................................................................................52 FIGURE 12. PORT ISOLATION EXAMPLE ........................................................................................................................................53 FIGURE 13. TX PAUSE FRAME FORMAT ........................................................................................................................................54 FIGURE 14. FLOW CONTROL STATE MACHINE ..............................................................................................................................54 FIGURE 15. SIGNAL TIMING FOR COLLISION-BASED BACKPRESSURE ...........................................................................................55 FIGURE 16. SPANNING TREE AND RAPID SPANNING TREE PORT STATES ......................................................................................56 FIGURE 17. IEEE 802.1AD FRAME FORMAT ..................................................................................................................................62 FIGURE 18. PRIORITY SELECTION TABLE WEIGHT RULES EXAMPLE 1..........................................................................................63 FIGURE 19. PER-PORT QUEUE MANAGEMENT...............................................................................................................................64 FIGURE 20. RSPAN ENCAPSULATION ...........................................................................................................................................66 FIGURE 21. RSPAN ILLUSTRATION ..............................................................................................................................................66 FIGURE 22. NIC ARCHITECTURE ...................................................................................................................................................67 FIGURE 23. QSGMII INTERCONNECTION ......................................................................................................................................70 FIGURE 24. RSGMII INTERCONNECTION ......................................................................................................................................70 FIGURE 25. SGMII SIGNAL ...........................................................................................................................................................71 FIGURE 26. DDR1 SDRAM CONFIGURATION ..............................................................................................................................72 FIGURE 27. DDR2 SDRAM CONFIGURATION ..............................................................................................................................73 FIGURE 28. DDR3 SDRAM CONFIGURATION ..............................................................................................................................74 FIGURE 29. SPI FLASH CONFIGURATION .......................................................................................................................................74 FIGURE 30. EJTAG USING A 5-PIN JTAG INTERFACE TO ACCESS DATA BLOCK..........................................................................75 FIGURE 31. 8-BIT EEPROM SEQUENTIAL READ ..........................................................................................................................76 FIGURE 32. I2C SLAVE INTERFACE ACCESS DATA SEQUENCE ......................................................................................................76 FIGURE 33. SERIAL LED CONNECTION .........................................................................................................................................78 FIGURE 34. QSGMII DIFFERENTIAL TRANSMITTER EYE DIAGRAM ..............................................................................................82 FIGURE 35. QSGMII DIFFERENTIAL RECEIVER EYE DIAGRAM ....................................................................................................83 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers vii Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet FIGURE 36. RSGMII DIFFERENTIAL TRANSMITTER EYE DIAGRAM ..............................................................................................84 FIGURE 37. RSGMII DIFFERENTIAL RECEIVER EYE DIAGRAM .....................................................................................................85 FIGURE 38. SGMII DIFFERENTIAL TRANSMITTER EYE DIAGRAM .................................................................................................86 FIGURE 39. SGMII DIFFERENTIAL RECEIVER EYE DIAGRAM .......................................................................................................87 FIGURE 40. DDR2 TIMING CHARACTERISTICS ..............................................................................................................................88 FIGURE 41. DDR3 TIMING CHARACTERISTICS ..............................................................................................................................89 FIGURE 42. SPI INTERFACE TIMING ..............................................................................................................................................90 FIGURE 43. SMI (MDC/MDIO) TIMING .......................................................................................................................................91 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers viii Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 1. General Description The RTL8380M-CG, RTL8382M-CG, and RTL8382L-CG are new generation Gigabit switches supporting Energy Efficient Ethernet (EEE). The RTL8380M is an 18-port 10/100/1000M switch controller, and the RTL8382M is 28-port while RTL8382L is an 26-port 10/100/1000 switch controllers. All of them have an 8-port 10/100/1000M Ethernet PHY embedded. The RTL8380M/RTL8382M/RTL8382L are provided via a 55nm CMOS process in an LQFP-216 EPAD package. The Memory interface of the RTL8380M/RTL8382M support DDR1/DDR2/DDR3 and SPI Flash. The RTL8382L supports only SPI Flash. The following table list the main differences between RTL8380M/RTL8382M/RTL8382L: Features  Port Capcacity  Management  Mode  DDR1/2/3  SPI Flash  EEPROM config  Internal CPU  RTL8380M  RTL8382M  RTL8382L  16G*UTP + 2*1000Base‐X 24G*UTP + 4GCombo 24G*UTP + 2*1000Base‐X  Managed Mode Only  Yes  Yes  Yes  Yes  Managed Mode Only Yes  Yes  Yes  Yes  Unmanagement Mode Only  No  Yes  Yes  Yes  The RTL8380M support two pairs of serially connected QSGMII interface ports to connect to one Octal Gigabit PHY (RTL8218B). It also supports two interfaces of SGMII or 1000Base-X. The RTL8382M/RTL8382L support four pairs of serially connected QSGMII interface ports to connect to two Octal Gigabit PHYs (RTL8218B). The RTL8382M also supports one serially connected QSGMII interface port to connect to 1 Quad Gigabit PHY (RTL8214FC). The RTL8380M/RTL8382M/RTL8382L have an embedded 500MHz MIPS-4KEc CPU that supports a 32MByte (max.) SPI flash (Only the RTL8380M/RTL8382M support DDR1/DDR2/DDR3). Two 16C550 compatible UARTs are integrated for low speed serial data, and one E-JTAG is supported for onchip debugging. There are 8K entries in the 4-way hash L2 table for MAC address learning and searching. The RTL8380M/RTL8382M/RTL8382L supports two hash algorithms. An independent 512-entry Multicast table supports Layer 2 and IP multicast functions. The RTL8380M/RTL8382M/RTL8382L has a 4K-entry VLAN table for 802.1Q port-based, protocoland-port-based, 802.1Q-based, IP-subnet-based, and ACL Rules-based VLAN operation to separate logical connectivity from physical connectivity. Support is provided for IVL (Independent VLAN Learning), SVL (Shared VLAN Learning), and IVL/SVL (both Independent and Shared VLAN Learning) for flexible network topology architecture. The RTL8380M/RTL8382M/RTL8382L supports a 1.5Kentry Access Control List (ACL) that parses various protocol packet types and performs configurable actions, e.g., Permit/Drop, redirect, and traffic policing. The RTL8380M/RTL8382M/RTL8382L supports per-port ingress/egress bandwidth control and perqueue egress bandwidth control. It has 8 physical queues in each port. The RTL8380M/RTL832M/ 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 1 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet RTL8382L provides three types of packet scheduling; SP (Strict Priority), WFQ (Weighted Fair Queuing), and WRR (Weighted Round Robin). Each queue provides a leaky-bucket to shape the incoming traffic into the average rate behavior. Port-based 802.1X and MAC-based 802.1X authentication prevent unauthorized users from accessing internal servers. The RTL8380M/RTL8382M/RTL8382L supports port isolation to enhance port security. The RTL8380M/RTL8382M/RTL8382L also supports a 4-set port mirror configuration to mirror ingress and egress traffic. For network management purposes, complete MIB counter support reflects the switch status in real time. Support is provided for link aggregation to increase link redundancy, and increase linear bandwidth. The RTL8380M/RTL8382M/RTL8382L adopts advanced technologies such as Realtek Cable Test (RTCT), Automatic loop detection and prevention (RLPP/RLDP), Attack Prevention, and MAC Address Learning Constraints. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 2 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 2. „ Features ƒ 32 Translation Look-aside Buffer (TLB) entries ƒ Two UART interfaces to control the internal CPU via a Command Line Interface (CLI) Hardware Interface ‹ ‹ ‹ ‹ RTL8380M ƒ 18-port Gigabit wire speed forwarding capability ƒ Supports 8-port 10/100/1000M Ethernet PHY ƒ Supports 2-pairs of QSGMII to connect to external 8-port 10/100/1000M Ethernet PHYs ƒ Supports one RSGMII or two pairs of SGMII/1000Base-X RTL8382M /RTL8382L ƒ RTL8382M provide 28-port Gigabit wire speed forwarding capability ƒ RTL8382L provide 26-port Gigabit wire speed forwarding capability ƒ Supports 8-port 10/100/1000M Ethernet PHY ƒ Supports 4-pairs of QSGMII to connect to external 8-port 10/100/1000M Ethernet PHYs ƒ RTL8382M supports an extra 1 pair of QSGMII or 2 pairs of RSGMII/SGMII/1000Base-X ƒ RTL8382L supports 2 pairs of SGMII/1000Base-X DRAM and Flash Interface ƒ RTL8380M/RTL8382M supports one 8-bit 128MByte DDR1/DDR2 or one 8-bit 256MByte DDR3 for internal CPU ƒ Supports one 32MByte SPI flash interface Embedded MIPS-4KEc with MMU ƒ MIPS32 instruction set and 5-stage pipeline ƒ 500MHz CPU clock rate ƒ 16KByte I-Cache and 16KByte DCache ƒ Built-in 128KByte SRAM 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers „ ‹ Supports EJTAG interface ‹ I2C and slave SPI interface for external master interface to access internal registers L2 VLAN Function ‹ ‹ ‹ „ Supports IVL, SVL, and IVL/SVL Supports IEEE 802.1Q VLAN ƒ 4K-entry VLAN Table ƒ Port-based VLAN ƒ Port-and-protocol-based VLAN ƒ ACL-based VLAN ƒ Supports up to 64 spanning tree instances for MSTP (IEEE 802.1s), RSTP, and STP Supports flexible Q-in-Q and VLAN Tag function L2 MAC Function ‹ 4.1 Mbit SRAM Packet Buffer ‹ Packet length of 10KBytes ‹ 8K-entry L2 MAC table with 4-way hashing algorithm ‹ Independent 512-entry L2/IP Multicast table for multicast function ‹ 2-hash algorithm selection for L2 table searching/learning ‹ Aging timer range from 0.2s to 1600000s ‹ Supports IGMPv1/2/3 and MLDv1/2 snooping 3 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet „ ‹ Supports Reserved Multicast Addresses processing ‹ 256 log counters to enhance MIB count functionality ‹ Limited learned L2 MAC entry on each port and each VLAN ‹ Supports multiple action ‹ Supports L3 Unicast Routing, 512 next hop MAC Support L2 Miscellaneous Functions ‹ ‹ ‹ Supports Port Mirroring ƒ Supports 4-sets of port mirrors ƒ Flow-based mirror function ƒ RSPAN function for remote mirroring Supports Link Aggregation (IEEE 802.3ad) for 8 groups of link aggregators with up to 8 ports per-group ‹ Port isolation function to enhance port security ‹ „ Software supports IEEE 802.1x, ‹ ‹ „ Supports broadcast, multicast, unknownmulticast, and unknown-unicast packet suppression control Attack Prevention ƒ Land attack ƒ Blat attack ƒ TCP control flag attack ƒ Ping attack ƒ Packet length attack Supports Automatic loop detection and isolation (RLPP/RLDP) Access Control List (ACL) Function QoS Functions ‹ 8 physical queues per port ‹ Strict Priority (SP) and Weighted Fair Queue (WFQ), Weighted Round Robin (WRR) packet scheduling ‹ QoS remarking for 802.1p and DSCP (includes IPv4/IPv6) ‹ Supports average packet rate control leaky-bucket per queue, in 16Kbps steps up to 1Gbps maximum ‹ Ingress port bandwidth control, in 16Kbps steps up to 1Gbps maximum ‹ Egress port bandwidth control, in 16Kbps steps up to 1Gbps maximum „ EAV, 1588v2 „ Cable Diagnostics (RTCT) „ IEEE 802.3az Energy Efficient Ethernet (EEE) „ MIB Functions ‹ 1.5K-entry ACL table ‹ Ethernet-like MIB (RFC 3635) ‹ L2/L3/L4 format (e.g., DMAC, SMAC, and Ether-Type) ‹ Interface Group MIB (RFC 2863) ‹ RMON (RFC 2819) ‹ IPv6 Parsing ‹ Bridge MIB (RFC 1493) ‹ Per-flow traffic policing ‹ Bridge MIB Extension (RFC 2674) ‹ 16-entry VID range checking ‹ 8-entry IPv4 or 2-entry IPv6 range checking ‹ 256 leaky-buckets for flow traffic policing; in 16Kbps steps up to 1Gbps maximum 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers „ Others ‹ 55nm CMOS process ‹ 3.3V/1.0V dual power input ‹ LQFP216 E-PAD package 3 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 3. System Applications 3.1. RTL8380M: Managed 16*1000M UTP+2*1000Base-X Switch Figure 1. Managed 16*1000M UTP+2*1000Base-X Switch 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 3 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 3.2. RTL8382M: Managed 28*1000M Switch via RTL8218B PHY DDR1/DDR2/DDR3* Flash Managed 28*1000M port Switch RTL8382M (28*1000M Switch) LQFP216-EPAD RTL8218B RTL8218B RTL8214FC Copper /fiber auto-det LED Interface Figure 2. Managed 28*1000M Switch via RTL8218B PHY 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 4 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 3.3. RTL8382M: Managed 20*1000M UTP+4*1000M Combo Switch Figure 3. Managed 20*1000M UTP+4*1000M Combo Switch 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 5 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 3.4. RTL8382M/RTL8382L: Managed/Unmanaged 24*1000M UTP+2*1000Base-X Switch Figure 4. Managed/Unmanaged 24*1000M UTP+2*1000Base-X Switch 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 6 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 4. Block Diagrams 4.1. RTL8380M Block Diagram Scan or Serial LED GPIO DDR1/DDR2/ SPI Flash/ DDR3 I2C EEPROM UART0 UART1 EJTAG MIPS-4KEc 32bits@500M Hz LED Controller GPIO Controller EEPROM /I2C/SPI Register Controller RSGMII/SGMII/ SGMII/ 1000Base-X/ 1000Base-X/ 100Base-FX 100Base-FX Serdes2 Serdes3 GMAC16 GMAC17 Memory Controller 2*UART Controller 128KB SRAM Interrupt Controller GMAC18 and NIC Packet Buffer (4.1 Mbit SRAM) Flow Control Traffic Classification L2 and Forwarding Table 802.3ad Qos Manager Storm Control VLAN Table Scheduler(SP/WRR/WFQ) EEE 802.1x and STP ACL Table VLAN Tag/Untag Attack Prevention Input Bandwidth Control Q-in-Q Table Output Bandwidth Control MAC 0 MAC 1 MAC 2 MAC 3 MAC 4 MAC 5 MAC 6 MAC 7 PHY0~7 (Gigabit) 8*GE MAC 8-11 MAC 12-15 Serdes 0 Serdes 1 2*QSGMII Figure 5. RTL8380M Block Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 7 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 4.2. RTL8382M Block Diagram Figure 6. RTL8382M Block Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 8 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 4.3. RTL8382L Block Diagram Figure 7. RTL8382L Block Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 9 Track ID: Rev. 0.7 P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN AVDDH AGND MDIREF AVDDL RTT1 RTT2 AVDDH DVDDL DVDDH JTAG_TCK JTAG_TMS JTAG_TDO/EEPROMTYPE JTAG_TDI JTAG_TRST# DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 MVDDH DDR12_WE#/DDR3_WE# DVDDL DDR12_RAS#/DDR3_CAS# DDR12_CAS#/DDR3_RAS# DDR12_A11/DDR3_A10/LED_MODE[0] DDR12_A13/DDR3_A11/LED_MODE[1] DDR3_A14/SPI_ADDR_SEL DDR12_A8/DDR3_A1/SDS_PDOWN_EN DDR12_A6/DDR3_A8/SEL_XTAL_CLK DDR12_A4/DDR3_A6/PWRBLINK[1] DDR12_A2/DDR3_A4/PWRBLINK[0] DDR12_A0/DDR3_A12/DIS_EEE DDR12_CS#/DDR3_BA1 DDR12_ODT/DDR3_CKE DDR12_D5/DDR3_D5 DDR12_D2/DDR3_D7 DDR12_D0/DDR3_D1 DDR12_D7/DDR3_D3 VREF DDR12_DQS/DDR3_DM DDR12_CLK/DDR3_CLK DDR12_CLK#/DDR3_CLK# DVDDL DDR3_DQS# DDR12_DM/DDR3_DQS DDR12_D6/DDR3_D0 DDR12_D1/DDR3_D4 DDR12_D3/DDR3_D2 DDR12_D4/DDR3_D6 MVDDH DVDDH SPI_CLK SPI_SO/SIO1 SPI_SI/SIO0 SPI_CS#0 DVDDL UART0_RX UART0_TX/REG_IF_SEL LED_DAT LED_CLK MDIO MDC SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO/DIS_PHYAUTO_UP SSPI_CS# DVDDH RESET# GPIO0 GPIO1 GPIO2 GPIO3 DVDDL RTL8380M/RTL8382M/RTL8382L Datasheet 5. Pin Assignments and Description (RTL8380M) 5.1. Pin Assignments Figure (RTL8380M) Figure 8. Pin Assignments (RTL8380M) 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 10 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 5.2. Package Identification Green package is indicated by a ‘G’ in ‘GXXXX’ (Figure 8). 5.3. Pin Assignments Table Codes (RTL8380M) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value = 75KΩ) OPU: Output Pin With Pull-Up Resistor; (Typical Value = 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value = 75KΩ) OPD: Output Pin With Pull-Down Resistor; (Typical Value = 75KΩ) 5.4. Pin Assignments Table (RTL8380M) Name P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH Table 1. Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Pin Assignments Table (RTL8380M) Type Name AI/O P3MDICP AI/O P3MDICN AP P3MDIDP AI/O P3MDIDN AI/O AVDDH AI/O AGND AI/O MDIREF AP AVDDL AI/O RTT1 AI/O RTT2 AI/O AVDDH AI/O DVDDL AP DVDDH AP JTAG_TCK 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 11 Pin No. 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Type AI/O AI/O AI/O AI/O AP AG AO AP AI/O AI/O AP DP DP I/OPU Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name JTAG_TMS JTAG_TDO/EEPROMTYPE JTAG_TDI JTAG_TRST# DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN P5MDIDP P5MDIDN PLLVDDL ATESTCK1 P6MDIAP P6MDIAN P6MDIBP P6MDIBN AVDDL P6MDICP P6MDICN P6MDIDP P6MDIDN AVDDH P7MDIAP Pin No. 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 Type I/OPU I/OPD I/OPD I/OPU DP DP DP AP AI/O AI/O AI/O AI/O AP AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name P7MDIAN P7MDIBP P7MDIBN AVDDL P7MDICP P7MDICN P7MDIDP P7MDIDN AVDDH DVDDL CKOUT0 SVDDL S0TXP S0TXN S0RXP S0RXN SVDDL S1TXN S1TXP S1RXN S1RXP SVDDH CKOUT2 SVDDL S2TXP S2TXN S2RXP S2RXN SVDDL S3TXN S3TXP S3RXN S3RXP SVDDL AVDDH_PLL XO XI AVDDL_PLL DVDDL DVDDL GPIO3 13 Pin No. 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 Type AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP DP AO AP AO AO AI AI AP AO AO AI AI AP AO AP AO AO AI AI AP AO AO AI AI AP AP AO AI AP P P I/OPD Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name GPIO2 GPIO1 GPIO0 RESET# DVDDH SSPI_CS# SSPI_SO/ DIS_PHYAUTO_UP SSPI_SI/I2C_DAT SSPI_CLK/I2C_CLK MDC MDIO LED_CLK LED_DAT UART0_TX/REG_IF_SEL UART0_RX DVDDL SPI_CS#0 SPI_SI/SIO0 SPI_SO/SIO1 SPI_CLK DVDDH MVDDH DDR12_D4/DDR3_D6 DDR12_D3/DDR3_D2 DDR12_D1/DDR3_D4 DDR12_D6/DDR3_D0 DDR12_DM/DDR3_DQS DDR3_DQS# DVDDL DDR12_CLK#/DDR3_CLK# DDR12_CLK/DDR3_CLK DDR12_DQS/DDR3_DM VREF DDR12_D7/DDR3_D3 DDR12_D0/DDR3_D1 DDR12_D2/DDR3_D7 DDR12_D5/DDR3_D5 DDR2_ODT/DDR3_CKE DDR12_CS#/DDR3_BA1 DDR12_A0/DDR3_A12/ DIS_EEE Pin No. 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 Type I/OPD I/OPD I/OPD AI P IPU I/OPD I/OPU I/OPU OPU I/OPU OPU I/OPU I/OPD IPD P O I/OPD I/OPD OPD P P I/O I/O I/O I/O I/O I/O P O O I/O P I/O I/O I/O I/O O O I/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name DDR12_A2/DDR3_A4/ PWRBLINK[0] DDR12_A4/DDR3_A6/ PWRBLINK[1] DDR12_A6/DDR3_A8/ SEL_XTAL_CLK DDR12_A8/DDR3_A1/ SDS_PDOWN_EN DDR3_A14/ SPI_ADDR_SEL DDR12_A13/DDR3_A11/ LED/MODE[1] DDR12_A11/DDR3_A10/ LED/MODE[0] DDR12_CAS#/DDR3_RAS# DDR12_RAS#/DDR3_CAS# DVDDL DDR12_WE#/DDR3_WE# MVDDH MVDDH DDR12_CKE/DDR3_BA2 DDR12_BA1/DDR3_A9 DDR12_A1/DDR3_A13/ CPU_SLEEP DDR12_A12/DDR3_A2/ DRAM_INI_EN DDR3_RST# DDR12_A9/DDR3_A7/ MEM_TYPE[1] DDR12_A7/DDR3_A5/ MEM_TYPE[0] DDR12_A5/DDR3_A0/ CLK_M_EE[1] DDR12_A3/DDR3_A3/ CLK_M_EE[0] DDR12_A10/DDR3_BA0/ EN_DECRYPT DDR2_BA2/DDR3_CS# DDR12_BA0/DDR3_ODT DDR3_ZQ# MVDDH DVDDL VX RESERVED SVDDL 14 Pin No. 151 Type I/O 152 I/O 153 I/O 154 I/O 155 I/O 156 I/O 157 I/O 158 159 160 161 162 163 164 165 166 O O P O P P O O I/O 167 I/O 168 169 O I/O 170 I/O 171 I/O 172 I/O 173 I/O 174 175 176 177 178 179 180 181 O O I P P A AO AP Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name RESERVED RESERVED TEST0 TEST1 SVDDH RESERVED RESERVED TEST2 TEST3 SVDDL DVDDL AVDDH P0MDIAP P0MDIAN P0MDIBP P0MDIBN AVDDL P0MDICP Pin No. 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 Type AO AO AI AI AP AO AO AI AI AP P AP AI/O AI/O AI/O AI/O AP AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP P1MDIAN P1MDIBP P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN DGND 15 Pin No. 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 EPAD Type AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O G Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 5.5. Pin Descriptions (RTL8380M) 5.5.1. 1000M Ethernet PHY MDI Interface Pins Table 2. 1000M Ethernet PHY MDI Interface Pins Type Description Port 0 Media Dependent Interface A~D. AI/O For 1000Base-T operation, differential data from the media is transmitted and AI/O received on all four pairs. For 100Base-Tx and 10Base-T operation, only AI/O MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. AI/O Pin Name P0MDIAP Pin No. 194 P0MDIAN 195 P0MDIBP 196 P0MDIBN 197 P0MDICP 199 AI/O P0MDICN 200 AI/O P0MDIDP 201 AI/O P0MDIDN 202 AI/O P1MDIAP 204 AI/O P1MDIAN 205 AI/O P1MDIBP 206 AI/O P1MDIBN 207 AI/O P1MDICP 209 AI/O P1MDICN 210 AI/O P1MDIDP 211 AI/O P1MDIDN 212 AI/O P2MDIAP 215 AI/O P2MDIAN 216 AI/O P2MDIBP 1 AI/O P2MDIBN 2 AI/O P2MDICP 4 AI/O P2MDICN 5 AI/O P2MDIDP 6 AI/O P2MDIDN 7 AI/O P3MDIAP 9 AI/O P3MDIAN 10 AI/O P3MDIBP 11 AI/O P3MDIBN 12 AI/O P3MDICP 15 AI/O P3MDICN 16 AI/O P3MDIDP 17 AI/O P3MDIDN 18 AI/O Each of the differential pairs has an internal 100 ohm termination resistor. Port 1 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 2 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 16 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name P4MDIAP Pin No. 37 Type AI/O P4MDIAN 38 AI/O P4MDIBP 39 AI/O P4MDIBN 40 AI/O P4MDICP 43 AI/O P4MDICN 44 AI/O P4MDIDP 45 AI/O P4MDIDN 46 AI/O P5MDIAP 48 AI/O P5MDIAN 49 AI/O P5MDIBP 50 AI/O P5MDIBN 51 AI/O P5MDICP 53 AI/O P5MDICN 54 AI/O P5MDIDP 55 AI/O P5MDIDN 56 AI/O P6MDIAP 59 AI/O P6MDIAN 60 AI/O P6MDIBP 61 AI/O P6MDIBN 62 AI/O P6MDICP 64 AI/O P6MDICN 65 AI/O P6MDIDP 66 AI/O P6MDIDN 67 AI/O P7MDIAP 69 AI/O P7MDIAN 70 AI/O P7MDIBP 71 AI/O P7MDIBN 72 AI/O P7MDICP 74 AI/O P7MDICN 75 AI/O P7MDIDP 76 AI/O P7MDIDN 77 AI/O 5.5.2. Description Port 4 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 5 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 6 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 7 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. SGMII Interface Pins Pin Name Pin No. Type S2RXP 96 AI S2RXN 97 AI S2TXP 94 AO Table 3. SGMII Interface Pins Description SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 17 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name Pin No. Type S2TXN 95 AO S3RXP 102 AI S3RXN 101 AI S3TXP 100 AO S3TXN 99 AO 5.5.3. Pin No. 96 Type AI S2RXN 97 AI S2TXP 94 AO S2TXN 95 AO S3RXP 102 AI S3RXN 101 AI S3TXP 100 AO S3TXN 99 AO SGMII Interface Transmit Data Differential Output Pair. Table 4. RSGMII Interface Pins Description RSGMII Interface Receive Data Differential Input Pair. RSGMII Interface Transmit Data Differential Output Pair. RSGMII Interface Receive Data Differential Input Pair. RSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Pins Pin Name S0RXP Pin No. 84 Type AI S0RXN 85 AI S0TXP 82 AO S0TXN 83 AO S1RXP 90 AI S1RXN 89 AI S1TXP 88 AO S1TXN 87 AO 5.5.5. SGMII Interface Receive Data Differential Input Pair. RSGMII Interface Pins Pin Name S2RXP 5.5.4. Description Table 5. QSGMII Interface Pins Description QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Pins Table 6. 1000Base-X/100Base-FX Interface Pins Type Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. AI Pin Name S2RXP Pin No. 96 S2RXN 97 AI S2TXP 94 AO 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 18 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name Pin No. Type S2TXN 95 AO S3RXP 102 AI S3RXN 101 AI S3TXP 100 AO S3TXN 99 AO 5.5.6. Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. DDR1/2 SDRAM Interface Pins Table 7. DDR1/2 SDRAM Interface Pins Pin Name DDR12_D[7:0] Pin No. DDR2_BA[2] DDR12_BA[1:0] DDR12_WE# DDR12_CKE DDR12_RAS# DDR12_CAS# DDR12_CS#0 DDR2_ODT DDR12_DQS DDR12_CLK 144, 136, 147, 133, 134, 146, 135, 145 156, 167, 157, 173, 169, 154, 170, 153, 171, 152, 172, 151, 166, 150 174 165, 175 161 164 159 158 149 148 142 141 DDR12_CLK# 140 DDR12_A[13:0] 5.5.7. Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. I/O 8 DDR SDRAM Address Select. O O O O O O O O I/O O 8 8 8 8 8 8 8 8 8 8 O 8 DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Write Enable. DDR SDRAM Clock Enable. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Chip Select 0. DDR SDRAM On-Die Termination. DDR SDRAM Data Strobe. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR3 SDRAM Interface Pins Table 8. DDR3 SDRAM Interface Pins Pin Name DDR3_D[7:0] DDR3_A[14] DDR3_A[13:10] DDR3_A[9] DDR3_A[8:0] DDR3_DQS# Pin No. 146, 133, 147, 135, 144, 134, 145, 136 155 166, 150,156, 157 165 153, 169, 152, 170, 151, 172, 167, 154, 171 138 Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. O I/O O I/O 8 8 8 8 DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. I/O 8 DDR SDRAM Data Strobe. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 19 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name DDR3_DQS DDR3_CLK# DDR3_CLK DDR3_DM DDR3_CKE DDR3_BA[2:1] DDR3_BA[0] DDR3_RAS# DDR3_CAS# DDR3_WE# DDR3_RST# DDR3_CS# DDR3_ODT DDR3_ZQ# 5.5.8. Pin No. 137 140 141 142 148 164, 149 173 158 159 161 168 174 175 176 Drive (mA) 8 8 8 8 8 8 8 8 8 8 8 8 8 8 Description DDR SDRAM Data Strobe. DDR SDRAM Clock. DDR SDRAM Clock. DDR SDRAM Data Mask. DDR SDRAM Clock Enable. DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Write Enable. DDR SDRAM Reset. DDR SDRAM Chip Select. DDR SDRAM On-Die Termination. DDR SDRAM External Reference Ball for Output Drive Calibration. This pin is tied to an external 240 Ohm resistor, which is tied to GND. Master Mode-SPI Flash Interface Pins Pin Name SPI_CLK SPI_SO/SIO1 Pin No. 130 129 SPI_SI/SIO0 128 SPI_CS#0 127 5.5.9. Type I/O O O I/O O O I/O O O O O O O I Table 9. Master Mode-SPI Flash Interface Pins Type Drive (mA) Description OPD 12 Serial Clock Output Pin. I/OPD 12 In Serial Mode: This is a flash chip output pin In Dual Mode: This is a flash chip bi-directional pin Note: This is MSB first. I/OPD 12 In Serial Mode: This is a flash chip input pin In Dual Mode: This is a flash chip bi-directional pin Note: This is LSB first. O 12 Chip Select Output Pin. Slave Transmit Enable and active low. UART Interface Pins Pin Name UART0_RX Pin No. 125 Type IPD UART0_TX UART1_RX 124 116 UART1_TX 117 I/OPD IPU I/OPD Table 10. UART Interface Pins Drive (mA) Description 4 UART0 Interface Receive Data. 4 4 UART0 Interface Transmit Data. UART1 Interface Receive Data. 4 UART1 Interface Transmit Data. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 20 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 5.5.10. LED Interface Pins Pin Name LED_CLK Pin No. 122 Type OPU LED_DAT 123 I/OPU Table 11. LED Interface Pins Drive (mA) Description 12 (1) In Serial LED Mode Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. (2) In SMI-like LED Mode Reference output clock for I2C-like interface. 12 (1) In Serial LED Mode Serial bit stream of link status information. (2) In I2C-like LED Mode The data written to the LED IC. 5.5.11. GPIO Interface Pins Table 12. GPIO Interface Pins Type Drive (mA) Description This pin default set as system led. I/OPD 12 By the configuration, it can be set as General Purpose Input/Output Pin. Pin Name Pin No. GPIO0 113 GPIO[3:1] 110, 111, 112 I/OPD 12 General Purpose Input/Output Pins. GPO10 30 I/OPD 4 General Purpose Output Pins. GPIO11 31 I/OPD 4 General Purpose Input/Output Pins. GPIO[14:12] 32,28,29 I/OPU 4 General Purpose Input/Output Pins. 5.5.12. EJTAG Interface Pins Pin Name JTAG_TMS JTAG_TCK JTAG_TRST# JTAG_TDI JTAG_TDO Pin No. 29 28 32 31 30 Type I/OPU I/OPU I/OPU I/OPD I/OPD Table 13. EJTAG Interface Pins Drive (mA) Description 4 JTAG Test Mode Select. 4 JTAG Test Clock Input. 4 JTAG Test Reset. 4 JTAG Test Data Input. 4 JTAG Test Data Output. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 21 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 5.5.13. Configuration Strapping Pins Pin Name EEPROMTYPE DIS_PHYAUTO_UP REG_IF_SEL DIS_EEE PWRBLINK[1:0] SEL_XTAL_CLK SDS_PDOWN_EN SPI_ADDR_SEL LED_MODE[1:0] CPU_SLEEP DRAM_INI_EN MEM_TYPE[1:0] Table 14. Configuration Strapping Pins Pin No. Description 30 Select EEPROM Address Byte Size. 0b0: 1-byte 0b1: 2-byte 117 Disable Asic auto power up PHY: 0b0: enable asic auto power up phy; 0b1: disable asic auto power up phy. 124 Select Switch Core Register Access Interface. 0b0: I2C 0b1: SPI slave 150 Disable 1000M EEE and 100M EEE Function. 0b0: Enable 0b1: Disable 152, 151 Select LED Power On Blinking Timer. 0b00: Disable 0b01: 800ms 0b10: 1.6s 0b11: 3.2s 153 Select XTAL Input is 25M or 125M. 0b0: 25M 0b1:125M Note: This option is only for sync Ethernet. 154 Enable SerDes Power Down Mode. 0b0: SerDes 2/3 operate in normal mode 0b1: SerDes 2/3 operate in power down mode 155 Select address mode for SPI flash: 0b0: 3Bytes address; 0b1: 4Bytes address. 156, 157 Select LED Mode. 0b00: Serial LED mode 0b01: Scan Single mode 0b10: Scan Bicolor mode 0b11: Disable LED 166 Enable CPU function; 0b0: CPU is always under reset state; 0b1: CPU is enabled. 167 Enable DRAM Initialization Procedure. 0b0: Enable DRAM Initialization procedure 0b1: Bypass DRAM Initialization procedure 169, 170 Select Memory Type for SOC. 0b00: Select SPI flash + DDR-3 0b01: Select SPI flash + DDR-2 0b10: Select SPI flash + DDR-1 0b11: Select EEPROM 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 22 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name CLK_M_EE[1:0] Pin No. 171, 172 Description When MEM_TYPE Select is SPI Flash: This Strapping Pin Selects the Initial Clock for The Memory Controller. For DDR2: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 100MHz 0b11: Reserved for test. For DDR3: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 125MHz; 0b11: Reserved for test. Note: The initial value for this strapping pin must set as the reference design guide recommend. EN_DECRYPT 173 When MEM_TYPE Select is EEPROM: CLK_M_EE[0] is used to select SOC EEPROM address byte size. 0b0: 1-byte address 0b1: 2-byte address Enable or Disable Decrypt for Flash. 0b0: Disable decrypt 0b1: Enable decrypt 5.5.14. Miscellaneous Interface Pins Pin Name MDC MDIO SSPI_CLK/I2C_CLK Pin No. 120 121 119 SSPI_SI/I2C_DAT 118 SSPI_SO SSPI_CS# RESET# 117 116 114 XI XO MDIREF 106 105 21 RTT1 RTT2 VX CKOUT0 CKOUT2 23 24 179 80 92 Table 15. Miscellaneous Interface Pins Type Drive (mA) Description OPU 12 MII Management Interface Clock Pin. I/OPU 12 MII Management Interface Data Pin. I/OPU 4 SPI Serial Clock Input (Slave Mode). I2C Interface Clock Input (Slave Mode). I2C Interface Clock Output (Master Mode). I/OPU 4 SPI Serial Data Input (Slave Mode). I2C Interface Bi-Directional data (Slave Mode). I/OPD 4 SPI Serial Data Output (Slave Mode). OUP 4 SPI Serial Chip Select (Slave Mode). AI System Pin Reset Input (Low Active). To complete the reset function, this pin must be asserted for at least 10ms. It must be pulled up for normal operation. AI 25MHz Crystal Clock Input and Feedback Pin. AO 25MHz Crystal Clock Output Pin. AO MDI Bias Resistor. Adjust the reference current for all PHYs. This pin must connect to AGND via a 2.49k ohm resistor. AI/O Reserved for Internal Use (Must be Left Floating). AI/O Reserved for Internal Use (Must be Left Floating). A Low Voltage Power Control Resistor. AO 8 25MHz Clock Output. AO 8 25MHz Clock Output. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 23 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name ATESTCK[1:0] RESERVED TEST[3:0] Pin No. Type 58, 214 AO 180, 182, 183, 187, 188 190, 189, 185, 184 Drive (mA) Description Reserved for Internal Use (Must be Left Floating). Reserved pins (Must be Left Floating). - Reserved for Testing. 5.5.15. Power and GND Pins Pin Name AVDDL PLLVDDL AVDDH DVDDL DVDDH SVDDL AVDDL_PLL SVDDH AVDDH_PLL MVDDH VREF AGND DGND Table 16. Power and GND Pins Pin No. Type Description AP Analog Low Voltage Power. 3, 13, 22, 42, 52, 63, 73, 198, 208 57, 213 AP Analog PLL Low Voltage Power. AP Analog High Voltage Power. 8, 14, 19, 25, 36, 41, 47, 68, 78, 193, 203 P Digital Low Voltage Power. 26, 33, 34, 79, 108, 109, 126, 139, 160, 178, 192 27, 35, 115, 131 P Digital High Voltage Power. AP SerDes Low Voltage Power. 81, 86, 93, 98, 103, 181, 191 107 AP PLL Low Voltage Power. 91, 186 AP SerDes High Voltage Power. 104 AP PLL High Voltage Power. 132, 162, 163,177 P SDRAM High Voltage Power. 143 P SSTL Reference Voltage (MVDDH/2). 20 AG Analog Ground. E-PAD G Digital Ground. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 24 Track ID: Rev. 0.7 P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN AVDDH AGND MDIREF AVDDL RTT1 RTT2 AVDDH DVDDL DVDDH JTAG_TCK JTAG_TMS JTAG_TDO/EEPROMTYPE JTAG_TDI JTAG_TRST# DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 MVDDH DDR12_WE#/DDR3_WE# DVDDL DDR12_RAS#/DDR3_CAS# DDR12_CAS#/DDR3_RAS# DDR12_A11/DDR3_A10/LED_MODE[0] DDR12_A13/DDR3_A11/LED_MODE[1] DDR3_A14/SPI_ADDR_SEL DDR12_A8/DDR3_A1/SDS_PDOWN_EN DDR12_A6/DDR3_A8/SEL_XTAL_CLK DDR12_A4/DDR3_A6/PWRBLINK[1] DDR12_A2/DDR3_A4/PWRBLINK[0] DDR12_A0/DDR3_A12/DIS_EEE DDR12_CS#/DDR3_BA1 DDR2_ODT/DDR3_CKE DDR12_D5/DDR3_D5 DDR12_D2/DDR3_D7 DDR12_D0/DDR3_D1 DDR12_D7/DDR3_D3 VREF DDR12_DQS/DDR3_DM DDR12_CLK/DDR3_CLK DDR12_CLK#/DDR3_CLK# DVDDL DDR3_DQS# DDR12_DM/DDR3_DQS DDR12_D6/DDR3_D0 DDR12_D1/DDR3_D4 DDR12_D3/DDR3_D2 DDR12_D4/DDR3_D6 MVDDH DVDDH SPI_CLK SPI_SO/SIO1 SPI_SI/SIO0 SPI_CS#0 DVDDL UART0_RX UART0_TX/REG_IF_SEL LED_DAT LED_CLK MDIO MDC SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO/DIS_PHYAUTO_UP SSPI_CS# DVDDH RESET# GPIO0 GPIO1 GPIO2 GPIO3 DVDDL RTL8380M/RTL8382M/RTL8382L Datasheet 6. Pin Assignments and Description (RTL8382M) 6.1. Pin Assignments Figure (RTL8382M) Figure 9. Pin Assignments (RTL8382M) 6.2. Package Identification Green package is indicated by a ‘G’ in ‘GXXXX’ (Figure 9). 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 25 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 6.3. Pin Assignments Table Codes (RTL8382M) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value = 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value = 75KΩ) OPU: Output Pin With Pull-Up Resistor; (Typical Value = 75KΩ) OPD: Output Pin With Pull-Down Resistor; (Typical Value = 75KΩ) 6.4. Pin Assignments Table (RTL8382M) Name P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN Table 17. Pin Assignments Table (RTL8382M) Pin No. Type Name 1 AI/O AVDDH 2 AI/O AGND 3 AP MDIREF 4 AI/O AVDDL 5 AI/O RTT1 6 AI/O RTT2 7 AI/O AVDDH 8 AP DVDDL 9 AI/O DVDDH 10 AI/O JTAG_TCK 11 AI/O JTAG_TMS 12 AI/O JTAG_TDO/EEPROMTYPE 13 AP JTAG_TDI 14 AP JTAG_TRST# 15 AI/O DVDDL 16 AI/O DVDDL 17 AI/O DVDDH 18 AI/O AVDDH 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 26 Pin No. 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 Type AP AG AO AP AI/O AI/O AP DP DP I/OPU I/OPU I/OPD I/OPD I/OPU DP DP DP AP Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN P5MDIDP P5MDIDN PLLVDDL ATESTCK1 P6MDIAP P6MDIAN P6MDIBP P6MDIBN AVDDL P6MDICP P6MDICN P6MDIDP P6MDIDN AVDDH P7MDIAP P7MDIAN P7MDIBP P7MDIBN AVDDL P7MDICP P7MDICN P7MDIDP P7MDIDN Pin No. 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 Type AI/O AI/O AI/O AI/O AP AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name AVDDH DVDDL CKOUT2 SVDDL S2TXP S2TXN S2RXP S2RXN SVDDL S3TXN S3TXP S3RXN S3RXP SVDDH CKOUT4 SVDDL S4TXP S4TXN S4RXP S4RXN SVDDL S5TXN S5TXP S5RXN S5RXP SVDDL AVDDH_PLL XO XI AVDDL_PLL DVDDL DVDDL GPIO3 Pin No. 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 Type AP DP AO AP AO AO AI AI AP AO AO AI AI AP AO AP AO AO AI AI AP AO AO AI AI AP AP AO AI AP P P I/OPD GPIO2 GPIO1 GPIO0 RESET# DVDDH SSPI_CS# 111 112 113 114 115 116 SSPI_SO/ DIS_PHYAUTO_UP SSPI_SI/I2C_DAT 117 IPU I/OPD 118 I/OPU 27 I/OPD I/OPD I/OPD AI P Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name SSPI_CLK/I2C_CLK MDC MDIO LED_CLK LED_DAT UART0_TX/REG_IF_SEL UART0_RX DVDDL SPI_CS#0 SPI_SI/SIO0 SPI_SO/SIO1 SPI_CLK DVDDH MVDDH DDR12_D4/DDR3_D6 DDR12_D3/DDR3_D2 DDR12_D1/DDR3_D4 DDR12_D6/DDR3_D0 DDR12_DM/DDR3_DQS DDR3_DQS# DVDDL DDR12_CLK#/DDR3_CLK# DDR12_CLK/DDR3_CLK DDR12_DQS/DDR3_DM VREF DDR12_D7/DDR3_D3 DDR12_D0/DDR3_D1 DDR12_D2/DDR3_D7 DDR12_D5/DDR3_D5 DDR2_ODT/DDR3_CKE DDR12_CS#/DDR3_BA1 DDR12_A0/DDR3_A12/ DIS_EEE DDR12_A2/DDR3_A4/ PWRBLINK[0] DDR12_A4/DDR3_A6/ PWRBLINK[1] DDR12_A6/DDR3_A8/ SEL_XTAL_CLK DDR12_A8/DDR3_A1/ SDS_PDOWN_EN DDR3_A14/ SPI_ADDR_SEL Pin No. 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 Type I/OPU OPU I/OPU OPU I/OPU I/OPD IPD P O I/OPD I/OPD OPD P P I/O I/O I/O I/O I/O I/O P O O I/O P I/O I/O I/O I/O O O I/O 151 I/O 152 I/O 153 I/O 154 I/O 155 I/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name DDR12_A13/DDR3_A11/ LED/MODE[1] DDR12_A11/DDR3_A10/ LED/MODE[0] DDR12_CAS#/DDR3_RAS# DDR12_RAS#/DDR3_CAS# DVDDL DDR12_WE#/DDR3_WE# MVDDH MVDDH DDR12_CKE/DDR3_BA2 DDR12_BA1/DDR3_A9 DDR12_A1/DDR3_A13/ CPU_SLEEP DDR12_A12/DDR3_A2/ DRAM_INI_EN DDR3_RST# DDR12_A9/DDR3_A7/ MEM_TYPE[1] DDR12_A7/DDR3_A5/ MEM_TYPE[0] DDR12_A5/DDR3_A0/ CLK_M_EE[1] DDR12_A3/DDR3_A3/ CLK_M_EE[0] DDR12_A10/DDR3_BA0/ EN_DECRYPT DDR2_BA2/DDR3_CS# DDR12_BA0/DDR3_ODT DDR3_ZQ# MVDDH DVDDL VX CKOUT0 SVDDL S0TXP S0TXN S0RXP S0RXN SVDDH S1TXN S1TXP S1RXN S1RXP 28 Pin No. 156 Type I/O 157 I/O 158 159 160 161 162 163 164 165 166 O O P O P P O O I/O 167 I/O 168 169 O I/O 170 I/O 171 I/O 172 I/O 173 I/O 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 O O I P P A AO AP AO AO AI AI AP AO AO AI AI Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name SVDDL DVDDL AVDDH P0MDIAP P0MDIAN P0MDIBP P0MDIBN AVDDL P0MDICP P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP Pin No. 191 192 193 194 195 196 197 198 199 200 201 202 203 204 Type AP P AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name P1MDIAN P1MDIBP P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN DGND 29 Pin No. 205 206 207 208 209 210 211 212 213 214 215 216 EPAD Type AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O G Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 6.5. Pin Description (RTL8382M) 6.5.1. 1000M Ethernet PHY MDI Interface Pins Table 18. 1000M Ethernet PHY MDI Interface Pins Type Description Port 0 Media Dependent Interface A~D. AI/O For 1000Base-T operation, differential data from the media is transmitted and AI/O received on all four pairs. For 100Base-Tx and 10Base-T operation, only AI/O MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. AI/O Pin Name P0MDIAP Pin No. 194 P0MDIAN 195 P0MDIBP 196 P0MDIBN 197 P0MDICP 199 AI/O P0MDICN 200 AI/O P0MDIDP 201 AI/O P0MDIDN 202 AI/O P1MDIAP 204 AI/O P1MDIAN 205 AI/O P1MDIBP 206 AI/O P1MDIBN 207 AI/O P1MDICP 209 AI/O P1MDICN 210 AI/O P1MDIDP 211 AI/O P1MDIDN 212 AI/O P2MDIAP 215 AI/O P2MDIAN 216 AI/O P2MDIBP 1 AI/O P2MDIBN 2 AI/O P2MDICP 4 AI/O P2MDICN 5 AI/O P2MDIDP 6 AI/O P2MDIDN 7 AI/O P3MDIAP 9 AI/O P3MDIAN 10 AI/O P3MDIBP 11 AI/O P3MDIBN 12 AI/O P3MDICP 15 AI/O P3MDICN 16 AI/O P3MDIDP 17 AI/O P3MDIDN 18 AI/O Each of the differential pairs has an internal 100 ohm termination resistor. Port 1 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 2 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 30 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name P4MDIAP Pin No. 37 Type AI/O P4MDIAN 38 AI/O P4MDIBP 39 AI/O P4MDIBN 40 AI/O P4MDICP 43 AI/O P4MDICN 44 AI/O P4MDIDP 45 AI/O P4MDIDN 46 AI/O P5MDIAP 48 AI/O P5MDIAN 49 AI/O P5MDIBP 50 AI/O P5MDIBN 51 AI/O P5MDICP 53 AI/O P5MDICN 54 AI/O P5MDIDP 55 AI/O P5MDIDN 56 AI/O P6MDIAP 59 AI/O P6MDIAN 60 AI/O P6MDIBP 61 AI/O P6MDIBN 62 AI/O P6MDICP 64 AI/O P6MDICN 65 AI/O P6MDIDP 66 AI/O P6MDIDN 67 AI/O P7MDIAP 69 AI/O P7MDIAN 70 AI/O P7MDIBP 71 AI/O P7MDIBN 72 AI/O P7MDICP 74 AI/O P7MDICN 75 AI/O P7MDIDP 76 AI/O P7MDIDN 77 AI/O Description Port 4 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 5 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 6 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 7 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 31 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 6.5.2. SGMII Interface Pins Pin Name S4RXP Pin No. 96 Type AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 6.5.3. SGMII Interface Transmit Data Differential Output Pair. SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. RSGMII Interface Pins Pin Name S4RXP Pin No. 96 Type AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 6.5.4. Table 19. SGMII Interface Pins Description SGMII Interface Receive Data Differential Input Pair. Table 20. RSGMII Interface Pins Description RSGMII Interface Receive Data Differential Input Pair. RSGMII Interface Transmit Data Differential Output Pair. RSGMII Interface Receive Data Differential Input Pair. RSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Pins Pin Name S0RXP Pin No. 184 Type AI S0RXN 185 AI S0TXP 182 AO S0TXN 183 AO S1RXP 190 AI S1RXN 189 AI S1TXP 188 AO S1TXN 187 AO S2RXP 84 AI S2RXN 85 AI Table 21. QSGMII Interface Pins Description QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 32 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name S2TXP Pin No. 82 Type AO S2TXN 83 AO S3RXP 90 AI S3RXN 89 AI S3TXP 88 AO S3TXN 87 AO S4RXP 96 AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO 6.5.5. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Pins Table 22. 1000Base-X/100Base-FX Interface Pins Type Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. AI Pin Name S4RXP Pin No. 96 S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 6.5.6. Description QSGMII Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. DDR1/2 SDRAM Interface Pins Table 23. DDR1/2 SDRAM Interface Pins Pin Name DDR12_D[7:0] DDR12_A[13:0] DDR2_BA[2] DDR12_BA[1:0] DDR12_WE# DDR12_CKE DDR12_RAS# DDR12_CAS# DDR12_CS#0 Pin No. 144, 136, 147, 133, 134, 146, 135, 145 156, 167, 157, 173, 169, 154, 170, 153, 171, 152, 172, 151, 166, 150 174 165, 175 161 164 159 158 149 Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. I/O 8 DDR SDRAM Address Select. O O O O O O O 8 8 8 8 8 8 8 DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Write Enable. DDR SDRAM Clock Enable. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Chip Select 0. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 33 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name DDR2_ODT DDR12_DQS DDR12_CLK Pin No. 148 142 141 Type O I/O O Drive (mA) 8 8 8 DDR12_CLK# 140 O 8 6.5.7. Description DDR SDRAM On-Die Termination. DDR SDRAM Data Strobe. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR3 SDRAM Interface Pins Table 24. DDR3 SDRAM Interface Pins Pin Name DDR3_D[7:0] DDR3_A[14] DDR3_A[13:10] DDR3_A[9] DDR3_A[8:0] DDR3_DQS# DDR3_DQS DDR3_CLK# DDR3_CLK DDR3_DM DDR3_CKE DDR3_BA[2:1] DDR3_BA[0] DDR3_RAS# DDR3_CAS# DDR3_WE# DDR3_RST# DDR3_CS# DDR3_ODT DDR3_ZQ# Pin No. 146, 133, 147, 135, 144, 134, 145, 136 155 166, 150,156, 157 165 153, 169, 152, 170, 151, 172, 167, 154, 171 138 137 140 141 142 148 164, 149 173 158 159 161 168 174 175 176 Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. O I/O O I/O 8 8 8 8 DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. I/O I/O O O I/O O O I/O O O O O O O I 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 DDR SDRAM Data Strobe. DDR SDRAM Data Strobe. DDR SDRAM Clock. DDR SDRAM Clock. DDR SDRAM Data Mask. DDR SDRAM Clock Enable. DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Write Enable. DDR SDRAM Reset. DDR SDRAM Chip Select. DDR SDRAM On-Die Termination. DDR SDRAM External Reference Ball for Output Drive Calibration. This ball is tied to an external 240 Ohm resistor, which is tied to GND. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 34 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 6.5.8. Master Mode-SPI Flash Interface Pins Pin Name SPI_CLK SPI_SO/SIO1 Pin No. 130 129 SPI_SI/SIO0 128 SPI_CS#0 127 6.5.9. Table 25. Master Mode-SPI Flash Interface Pins Type Drive (mA) Description OPD 12 Serial Clock Output Pin. I/OPD 12 In Serial Mode: This is a flash chip output pin In Dual Mode: This is a flash chip bi-directional pin Note: This is MSB first. I/OPD 12 In Serial Mode: This is a flash chip input pin In Dual Mode: This is a flash chip bi-directional pin Note: This is LSB first. O 12 Chip Select Output Pin. Slave Transmit Enable and active low. UART Interface Pins Pin Name UART0_RX Pin No. 125 Type IPD UART0_TX UART1_RX UART1_TX 124 116 117 I/OPD IPU I/OPD Table 26. UART Interface Pins Drive (mA) Description 4 UART0 Interface Receive Data. 4 4 4 UART0 Interface Transmit Data. UART1 Interface Receive Data. UART1 Interface Transmit Data. 6.5.10. LED Interface Pins Pin Name LED_CLK Pin No. 122 Type OPU LED_DAT 123 I/OPU Table 27. LED Interface Pins Drive (mA) Description 12 (1) In Serial LED Mode Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. (2) In SMI-like LED Mode Reference output clock for I2C-like interface. 12 (1) In Serial LED Mode Serial bit stream of link status information. (2) In I2C-like LED Mode The data written to the LED IC. 6.5.11. GPIO Interface Pins Pin Name Pin No. GPIO0 113 GPIO[3:1] 110, 111, 112 Table 28. GPIO Interface Pins Type Drive (mA) Description This pin default set as system led. I/OPD 12 By the configuration, it can be set as General Purpose Input/Output Pin. I/OPD 12 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers General Purpose Input/Output Pins. 35 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name Pin No. Type Drive (mA) Description GPO10 30 I/OPD 4 General Purpose Output Pins. GPIO11 31 I/OPD 4 General Purpose Input/Output Pins. GPIO[14:12] 32,28,29 I/OPU 4 General Purpose Input/Output Pins. 6.5.12. EJTAG Interface Pins Pin Name JTAG_TMS JTAG_TCK JTAG_TRST# JTAG_TDI JTAG_TDO Pin No. 29 28 32 31 30 Type I/OPU I/OPU I/OPU I/OPD I/OPD Table 29. EJTAG Interface Pins Drive (mA) Description 4 JTAG Test Mode Select. 4 JTAG Test Clock Input. 4 JTAG Test Reset. 4 JTAG Test Data Input. 4 JTAG Test Data Output. 6.5.13. Configuration Strapping Pins Pin Name EEPROMTYPE DIS_PHYAUTO_UP REG_IF_SEL DIS_EEE PWRBLINK[1:0] SEL_XTAL_CLK SDS_PDOWN_EN SPI_ADDR_SEL LED_MODE[1:0] Table 30. Configuration Strapping Pins Pin No. Description 30 Select EEPROM Address Byte Size. 0b0: 1-byte 0b1: 2-byte 117 Disable Asic auto power up PHY: 0b0: enable asic auto power up phy; 0b1: disable asic auto power up phy. 124 Select Switch Core Register Access Interface. 0b0: I2C 0b1: SPI slave 150 Disable 1000M EEE and 100M EEE Function. 0b0: Enable 0b1: Disable 152, 151 Select LED Power On Blinking Timer. 0b00: Disable 0b01: 800ms 0b10: 1.6s 0b11: 3.2s 153 Select XTAL Input is 25M or 125M. 0b0: 25M 0b1:125M Note: This option is only for sync Ethernet. 154 Enable SerDes Power Down Mode. 0b0: SerDes4/5 operate in normal mode 0b1: SerDes4/5 operate in power down mode 155 Select address mode for SPI flash: 0b0: 3Bytes address; 0b1: 4Bytes address. 156, 157 Select LED Mode. 0b00: Serial LED mode 0b01: Scan Single mode 0b10: Scan Bicolor mode 0b11: Disable LED 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 36 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name CPU_SLEEP DRAM_INI_EN MEM_TYPE[1:0] CLK_M_EE[1:0] Pin No. Description 166 Enable CPU function; 0b0: CPU is always under reset state; 0b1: CPU is enabled. 167 Enable DRAM Initialization Procedure. 0b0: Enable DRAM Initialization procedure 0b1: Bypass DRAM Initialization procedure 169, 170 Select Memory Type for SOC. 0b00: Select SPI flash + DDR-3 0b01: Select SPI flash + DDR-2 0b10: Select SPI flash + DDR-1 0b11: Select EEPROM 171, 172 When MEM_TYPE Select is SPI Flash: This Strapping Pin Selects the Initial Clock for The Memory Controller. For DDR2: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 100MHz 0b11: Reserved for test. For DDR3: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 125MHz; 0b11: Reserved for test. Note: The initial value for this strapping pin must set as the reference design guide recommend. EN_DECRYPT 173 When MEM_TYPE Select is EEPROM: CLK_M_EE[0] is used to select SOC EEPROM address byte size. 0b0: 1-byte address 0b1: 2-byte address Enable or Disable Decrypt for Flash. 0b0: Disable decrypt 0b1: Enable decrypt 6.5.14. Miscellaneous Interface Pins Pin Name MDC MDIO SSPI_CLK/I2C_CLK Pin No. 120 121 119 SSPI_SI/I2C_DAT 118 SSPI_SO SSPI_CS# RESET# 117 116 114 XI XO 106 105 Table 31. Miscellaneous Interface Pins Type Drive (mA) Description OPU 12 MII Management Interface Clock Pin. I/OPU 12 MII Management Interface Data Pin. I/OPU 4 SPI Serial Clock Input (Slave Mode). I2C Interface Clock Input (Slave Mode). I2C Interface Clock Output (Master Mode). I/OPU 4 SPI Serial Data Input (Slave Mode). I2C Interface Bi-Directional data (Slave Mode). I/OPD 4 SPI Serial Data Output (Slave Mode). OUP 4 SPI Serial Chip Select (Slave Mode). AI System Pin Reset Input (Low Active). To complete the reset function, this pin must be asserted for at least 10ms. It must be pulled up for normal operation. AI 25MHz Crystal Clock Input and Feedback Pin. AO 25MHz Crystal Clock Output Pin. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 37 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name MDIREF Pin No. 21 Type AO RTT1 RTT2 VX CKOUT0 CKOUT2 CKOUT4 ATESTCK[1:0] 23 24 179 180 80 92 58, 214 AI/O AI/O A AO AO AO AO Drive (mA) Description MDI Bias Resistor. Adjust the reference current for all PHYs. This pin must connect to AGND via a 2.49k ohm resistor. Reserved for Internal Use (Must be Left Floating). Reserved for Internal Use (Must be Left Floating). Low Voltage Power Control Resistor. 8 25MHz Clock Output. 8 25MHz Clock Output. 8 25MHz Clock Output. Reserved for Internal Use (Must be Left Floating). 6.5.15. Power and GND Pins Pin Name AVDDL PLLVDDL AVDDH DVDDL DVDDH SVDDL AVDDL_PLL SVDDH AVDDH_PLL MVDDH VREF AGND DGND Table 32. Power and GND Pins Pin No. Type Description AP Analog Low Voltage Power. 3, 13, 22, 42, 52, 63, 73, 198, 208 57, 213 AP Analog PLL Low Voltage Power. AP Analog High Voltage Power. 8, 14, 19, 25, 36, 41, 47, 68, 78, 193, 203 P Digital Low Voltage Power. 26, 33, 34, 79, 108, 109, 126, 139, 160, 178, 192 27, 35, 115, 131 P Digital High Voltage Power. AP SerDes Low Voltage Power. 81, 86, 93, 98, 103, 181, 191 107 AP PLL Low Voltage Power. 91, 186 AP SerDes High Voltage Power. 104 AP PLL High Voltage Power. 132, 162, 163,177 P SDRAM High Voltage Power. 143 P SSTL Reference Voltage (MVDDH/2). 20 AG Analog Ground. E-PAD G Digital Ground. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 38 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 7. Pin Assignments and Description (RTL8382L) 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 VDDIO RESERVED DVDDL RESERVED RESERVED LED_MODE[0] LED_MODE[1] SPI_ADDR_SEL SDS_PDOWN_EN SEL_XTAL_CLK PWRBLINK[1] PWRBLINK[0] DIS_EEE RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED DVDDL RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED VDDIO DVDDH SPI_CLK SPI_SO/SIO1 SPI_SI/SIO0 SPI_CS#0 DVDDL UART0_RX UART0_TX/REG_IF_SEL LED_DAT LED_CLK MDIO MDC SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO/DIS_PHYAUTO_UP SSPI_CS# DVDDH RESET# GPIO0 GPIO1 GPIO2 GPIO3 DVDDL 7.1. Pin Assignments Figure (RTL8382L) 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 RTL8382L LLLLLLL TXXXX TAIWAN DVDDL AVDDL_PLL XI XO AVDDH_PLL SVDDL S5RXP S5RXN S5TXP S5TXN SVDDL S4RXN S4RXP S4TXN S4TXP SVDDL CKOUT4 SVDDH S3RXP S3RXN S3TXP S3TXN SVDDL S2RXN S2RXP S2TXN S2TXP SVDDL CKOUT2 DVDDL AVDDH P7MDIDN P7MDIDP P7MDICN P7MDICP AVDDL P7MDIBN P7MDIBP P7MDIAN P7MDIAP AVDDH P6MDIDN P6MDIDP P6MDICN P6MDICP AVDDL P6MDIBN P6MDIBP P6MDIAN P6MDIAP ATESTCK1 PLLVDDL P5MDIDN P5MDIDP P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN AVDDH AGND MDIREF AVDDL RTT1 RTT2 AVDDH DVDDL DVDDH RESERVED RESERVED EEPROMTYPE RESERVED RESERVED DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 VDDIO RESERVED RESERVED CPU_SLEEP RESERVED RESERVED MEM_TYPE[1] MEM_TYPE[0] CLK_M_EE[1] CLK_M_EE[0] EN_DECRYPT RESERVED RESERVED RESERVED VDDIO DVDDL VX CKOUT0 SVDDL S0TXP S0TXN S0RXP S0RXN SVDDH S1TXN S1TXP S1RXN S1RXP SVDDL DVDDL AVDDH P0MDIAP P0MDIAN P0MDIBP P0MDIBN AVDDL P0MDICP P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP P1MDIAN P1MDIBP P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN Figure 10. Pin Assignments (RTL8382L) 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 39 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 7.2. Package Identification Green package is indicated by a ‘G’ in ‘GXXXX’ (Figure 10). 7.3. Pin Assignments Table Codes (RTL8382L) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value = 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value = 75KΩ) OPU: Output Pin With Pull-Up Resistor; (Typical Value = 75KΩ) OPD: Output Pin With Pull-Down Resistor; (Typical Value = 75KΩ) 7.4. Pin Assignments Table (RTL8382L) Name P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP Table 33. Pin Assignments Table (RTL8382L) Pin No. Type Name 1 AI/O P3MDICN 2 AI/O P3MDIDP 3 AP P3MDIDN 4 AI/O AVDDH 5 AI/O AGND 6 AI/O MDIREF 7 AI/O AVDDL 8 AP RTT1 9 AI/O RTT2 10 AI/O AVDDH 11 AI/O DVDDL 12 AI/O DVDDH 13 AP RESERVED 14 AP RESERVED 15 AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 40 Pin No. 16 17 18 19 20 21 22 23 24 25 26 27 28 Type AI/O AI/O AI/O AP AG AO AP AI/O AI/O AP DP DP - 29 - Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name EEPROMTYPE Pin No. 30 Type IPD RESERVED 31 - RESERVED 32 - DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN P5MDIDP P5MDIDN PLLVDDL ATESTCK1 P6MDIAP P6MDIAN P6MDIBP P6MDIBN AVDDL P6MDICP P6MDICN P6MDIDP P6MDIDN AVDDH P7MDIAP P7MDIAN P7MDIBP 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 DP DP DP AP AI/O AI/O AI/O AI/O AP AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name P7MDIBN AVDDL P7MDICP P7MDICN P7MDIDP P7MDIDN AVDDH DVDDL CKOUT2 SVDDL S2TXP S2TXN S2RXP S2RXN SVDDL S3TXN S3TXP S3RXN S3RXP SVDDH CKOUT4 SVDDL S4TXP S4TXN S4RXP S4RXN SVDDL S5TXN S5TXP S5RXN S5RXP SVDDL AVDDH_PLL XO XI AVDDL_PLL DVDDL DVDDL GPIO3 Pin No. 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 I/OPD GPIO2 111 I/OPD GPIO1 112 I/OPD GPIO0 113 I/OPD 41 Track ID: Type AI/O AP AI/O AI/O AI/O AI/O AP DP AO AP AO AO AI AI AP AO AO AI AI AP AO AP AO AO AI AI AP AO AO AI AI AP AP AO AI AP P P Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name RESET# DVDDH SSPI_CS# Pin No. 114 115 116 Type AI P Name SPI_ADDR_SEL LED/MODE[1] SSPI_SO/DIS_PHYAUTO_UP 117 IPU I/OPD SSPI_SI/I2C_DAT 118 I/OPU SSPI_CLK/I2C_CLK 119 I/OPU MDC 120 MDIO 121 OPU I/OPU LED_CLK 122 LED_DAT 123 OPU I/OPU UART0_TX/REG_IF_SEL 124 I/OPD UART0_RX 125 IPD DVDDL SPI_CS#0 SPI_SI/SIO0 126 127 128 P O I/OPD SPI_SO/SIO1 129 I/OPD SPI_CLK 130 OPD DVDDH VDDIO RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED DVDDL RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED RESERVED DIS_EEE 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 P P I/O I/O I/O I/O I/O I/O P O O I/O P I/O I/O I/O I/O O O I PWRBLINK[0] 151 I PWRBLINK[1] 152 I SEL_XTAL_CLK 153 I SDS_PDOWN_EN 154 I 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Pin No. 155 156 Type I I LED/MODE[0] 157 I RESERVED RESERVED DVDDL RESERVED VDDIO VDDIO RESERVED RESERVED CPU_SLEEP 158 159 160 161 162 163 164 165 166 P P P I/OPD RESERVED RESERVED MEM_TYPE[1] 167 168 169 I/OPD MEM_TYPE[0] 170 I/OPD CLK_M_EE[1] 171 I/OPD CLK_M_EE[0] 172 I/OPD EN_DECRYPT 173 I/OPD RESERVED RESERVED RESERVED VDDIO DVDDL VX CKOUT0 SVDDL S0TXP S0TXN S0RXP S0RXN SVDDH S1TXN S1TXP S1RXN S1RXP SVDDL DVDDL AVDDH P0MDIAP P0MDIAN 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 P P A AO AP AO AO AI AI AP AO AO AI AI AP P AP AI/O AI/O 42 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Name P0MDIBP P0MDIBN AVDDL P0MDICP P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP P1MDIAN P1MDIBP Pin No. 196 197 198 199 200 201 202 203 204 205 206 Type AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers Name P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN DGND 43 Pin No. 207 208 209 210 211 212 213 214 215 216 EPAD Track ID: Type AI/O AP AI/O AI/O AI/O AI/O AP AO AI/O AI/O G Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 7.5. Pin Descriptions (RTL8382L) 7.5.1. 1000M Ethernet PHY MDI Interface Pins Table 34. 1000M Ethernet PHY MDI Interface Pins Type Description Port 0 Media Dependent Interface A~D. AI/O For 1000Base-T operation, differential data from the media is transmitted and AI/O received on all four pairs. For 100Base-Tx and 10Base-T operation, only AI/O MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. AI/O Pin Name P0MDIAP Pin No. 194 P0MDIAN 195 P0MDIBP 196 P0MDIBN 197 P0MDICP 199 AI/O P0MDICN 200 AI/O P0MDIDP 201 AI/O P0MDIDN 202 AI/O P1MDIAP 204 AI/O P1MDIAN 205 AI/O P1MDIBP 206 AI/O P1MDIBN 207 AI/O P1MDICP 209 AI/O P1MDICN 210 AI/O P1MDIDP 211 AI/O P1MDIDN 212 AI/O P2MDIAP 215 AI/O P2MDIAN 216 AI/O P2MDIBP 1 AI/O P2MDIBN 2 AI/O P2MDICP 4 AI/O P2MDICN 5 AI/O P2MDIDP 6 AI/O P2MDIDN 7 AI/O P3MDIAP 9 AI/O P3MDIAN 10 AI/O P3MDIBP 11 AI/O P3MDIBN 12 AI/O P3MDICP 15 AI/O P3MDICN 16 AI/O P3MDIDP 17 AI/O P3MDIDN 18 AI/O Each of the differential pairs has an internal 100 ohm termination resistor. Port 1 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 2 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 44 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name P4MDIAP Pin No. 37 Type AI/O P4MDIAN 38 AI/O P4MDIBP 39 AI/O P4MDIBN 40 AI/O P4MDICP 43 AI/O P4MDICN 44 AI/O P4MDIDP 45 AI/O P4MDIDN 46 AI/O P5MDIAP 48 AI/O P5MDIAN 49 AI/O P5MDIBP 50 AI/O P5MDIBN 51 AI/O P5MDICP 53 AI/O P5MDICN 54 AI/O P5MDIDP 55 AI/O P5MDIDN 56 AI/O P6MDIAP 59 AI/O P6MDIAN 60 AI/O P6MDIBP 61 AI/O P6MDIBN 62 AI/O P6MDICP 64 AI/O P6MDICN 65 AI/O P6MDIDP 66 AI/O P6MDIDN 67 AI/O P7MDIAP 69 AI/O P7MDIAN 70 AI/O P7MDIBP 71 AI/O P7MDIBN 72 AI/O P7MDICP 74 AI/O P7MDICN 75 AI/O P7MDIDP 76 AI/O P7MDIDN 77 AI/O Description Port 4 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 5 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 6 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 7 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 45 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 7.5.2. SGMII Interface Pins Pin Name Pin No. Type S4RXP 96 AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 7.5.3. SGMII Interface Transmit Data Differential Output Pair. SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Pins Pin Name Pin No. Type S0RXP 184 AI S0RXN 185 AI S0TXP 182 AO S0TXN 183 AO S1RXP 190 AI S1RXN 189 AI S1TXP 188 AO S1TXN 187 AO S2RXP 84 AI S2RXN 85 AI S2TXP 82 AO S2TXN 83 AO S3RXP 90 AI S3RXN 89 AI S3TXP 88 AO S3TXN 87 AO 7.5.4. Table 35. SGMII Interface Pins Description SGMII Interface Receive Data Differential Input Pair. Table 36. QSGMII Interface Pins Description QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Pins Pin Name Pin No. S4RXP 96 S4RXN 97 Table 37. 1000Base-X/100Base-FX Interface Pins Type Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. AI AI 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 46 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name Pin No. Type S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 7.5.5. Pin No. 130 129 SPI_SI/SIO0 128 SPI_CS#0 127 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. Table 38. Master Mode-SPI Flash Interface Pins Type Drive (mA) Description OPD 12 Serial Clock Output Pin. I/OPD 12 In Serial Mode: This is a flash chip output pin In Dual Mode: This is a flash chip bi-directional pin Note: This is MSB first. I/OPD 12 In Serial Mode: This is a flash chip input pin In Dual Mode: This is a flash chip bi-directional pin Note: This is LSB first. O 12 Chip Select Output Pin. Slave Transmit Enable and active low. UART Interface Pins Pin Name UART0_RX Pin No. 125 Type IPD UART0_TX UART1_RX 124 116 UART1_TX 117 I/OPD IPU I/OPD 7.5.7. 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. Master Mode-SPI Flash Interface Pins Pin Name SPI_CLK SPI_SO/SIO1 7.5.6. Description 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. Table 39. UART Interface Pins Drive (mA) Description 4 UART0 Interface Receive Data. 4 4 UART0 Interface Transmit Data. UART1 Interface Receive Data. 4 UART1 Interface Transmit Data. LED Interface Pins Pin Name LED_CLK Pin No. 122 Type OPU LED_DAT 123 I/OPU Table 40. LED Interface Pins Drive (mA) Description 12 (1) In Serial LED Mode Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. (2) In SMI-like LED Mode Reference output clock for I2C-like interface. 12 (1) In Serial LED Mode Serial bit stream of link status information. (2) In I2C-like LED Mode The data written to the LED IC. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 47 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 7.5.8. GPIO Interface Pins Pin Name Pin No. GPIO0 113 GPIO[3:1] 110, 111, 112 7.5.9. Table 41. GPIO Interface Pins Type Drive (mA) Description This pin default set as system led. I/OPD 12 By the configuration, it can be set as General Purpose Input/Output Pin. I/OPD 12 General Purpose Input/Output Pins. Configuration Strapping Pins Pin Name EEPROMTYPE REG_IF_SEL DIS_PHYAUTO_UP DIS_EEE PWRBLINK[1:0] SEL_XTAL_CLK SDS_PDOWN_EN SPI_ADDR_SEL LED_MODE[1:0] CPU_SLEEP MEM_TYPE[1:0] Table 42. Configuration Strapping Pins Pin No. Description 30 Select EEPROM Address Byte Size. 0b0: 1-byte 0b1: 2-byte 124 Select Switch Core Register Access Interface. 0b0: I2C 0b1: SPI slave 117 Disable Asic auto power up PHY: 0b0: enable asic auto power up phy; 0b1: disable asic auto power up phy. 150 Disable 1000M EEE and 100M EEE Function. 0b0: Enable 0b1: Disable 152, 151 Select LED Power On Blinking Timer. 0b00: Disable 0b01: 800ms 0b10: 1.6s 0b11: 3.2s 153 Select XTAL Input is 25M or 125M. 0b0: 25M 0b1:125M Note: This option is only for sync Ethernet. 154 Enable SerDes Power Down Mode. 0b0: SerDes4/5 operate in normal mode 0b1: SerDes4/5 operate in power down mode 155 Select address mode for SPI flash: 0b0: 3Bytes address; 0b1: 4Bytes address. 156, 157 Select LED Mode. 0b00: Serial LED mode 0b01: Scan Single mode 0b10: Scan Bicolor mode 0b11: Disable LED 166 Enable CPU function; 0b0: CPU is always under reset state; 0b1: CPU is enabled. 169, 170 Select Memory Type for SOC. 0b00: Select SPI flash 0b01: Reserved 0b10: Select SPI flash 0b11: Select EEPROM 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 48 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name CLK_M_EE[1:0] Pin No. 171, 172 Description When MEM_TYPE Select is SPI Flash: This Strapping Pin Selects the Initial Clock for The Memory Controller. 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 100MHz 0b11: Reserved for test. Note: The initial value for this strapping pin must set as the reference design guide recommend. EN_DECRYPT 173 When MEM_TYPE Select is EEPROM: CLK_M_EE[0] is used to select SOC EEPROM address byte size. 0b0: 1-byte address 0b1: 2-byte address Enable or Disable Decrypt for Flash. 0b0: Disable decrypt 0b1: Enable decrypt 7.5.10. Miscellaneous Interface Pins Pin Name MDC MDIO SSPI_CLK/I2C_CLK Pin No. 120 121 119 SSPI_SI/I2C_DAT 118 SSPI_SO SSPI_CS# RESET# 117 116 114 XI XO MDIREF 106 105 21 RTT1 RTT2 VX CKOUT0 CKOUT2 CKOUT4 ATESTCK[1:0] 23 24 179 180 80 92 58, 214 Table 43. Miscellaneous Interface Pins Type Drive (mA) Description OPU 12 MII Management Interface Clock Pin. I/OPU 12 MII Management Interface Data Pin. I/OPU 4 SPI Serial Clock Input (Slave Mode). I2C Interface Clock Input (Slave Mode). I2C Interface Clock Output (Master Mode). I/OPU 4 SPI Serial Data Input (Slave Mode). I2C Interface Bi-Directional data (Slave Mode). I/OPD 4 SPI Serial Data Output (Slave Mode). OUP 4 SPI Serial Chip Select (Slave Mode). AI System Pin Reset Input (Low Active). To complete the reset function, this pin must be asserted for at least 10ms. It must be pulled up for normal operation. AI 25MHz Crystal Clock Input and Feedback Pin. AO 25MHz Crystal Clock Output Pin. AO MDI Bias Resistor. Adjust the reference current for all PHYs. This pin must connect to AGND via a 2.49k ohm resistor. AI/O Reserved for Internal Use (Must be Left Floating). AI/O Reserved for Internal Use (Must be Left Floating). A Low Voltage Power Control Resistor. AO 8 25MHz Clock Output. AO 8 25MHz Clock Output. AO 8 25MHz Clock Output. AO Reserved for Internal Use (Must be Left Floating). 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 49 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Pin Name RESERVED Pin No. Type 28, 29, 31, 32,133, 134, 135, 136, 137, 138, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 158, 159, 161, 164, 165, 167, 168, 174, 175, 176 Drive (mA) Description Not Connected (Must be Left Floating). 7.5.11. Power and GND Pins Pin Name AVDDL PLLVDDL AVDDH DVDDL DVDDH SVDDL AVDDL_PLL SVDDH AVDDH_PLL VDDIO AGND DGND Table 44. Power and GND Pins Pin No. Type Description AP Analog Low Voltage Power. 3, 13, 22, 42, 52, 63, 73, 198, 208 57, 213 AP Analog PLL Low Voltage Power. AP Analog High Voltage Power. 8, 14, 19, 25, 36, 41, 47, 68, 78, 193, 203 P Digital Low Voltage Power. 26, 33, 34, 79, 108, 109, 126, 139, 160, 178, 192 27, 35, 115, 131 P Digital High Voltage Power. AP SerDes Low Voltage Power. 81, 86, 93, 98, 103, 181, 191 107 AP PLL Low Voltage Power. 91, 186 AP SerDes High Voltage Power. 104 AP PLL High Voltage Power. 132, 162, 163,177 P Strapping pin IO Voltage Power. 20 AG Analog Ground. E-PAD G Digital Ground. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 50 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8. Switch Function Description 8.1. Hardware Reset and Software Reset 8.1.1. Hardware Reset A hardware reset forces the RTL8380M/RTL8382M/RTL8382L to start the initial power-on sequence. First hardware will strap pins to give all default values when the ‘RESET’ signal terminates. Next the complete SRAM BIST (Built-In Self Test) process is run. Finally the packet buffer descriptors are initialized and internal registers and external CPU will access them. 8.1.2. Software Reset The RTL8380M/RTL8382M/RTL8382L supports software Switch NIC reset. Reset sources ar • CPU&Memory Reset: Resets MIPS 4KEc + • Switch NIC Reset: Resets the NIC interface between the CPU and Switch 8.2. Crystal The RTL8380M/RTL8382M/RTL8382L clock input frequenc a loading capacitor from XI and XO to ground. The cycle should range from 40%~60%. 8.3. IEEE 802.3az Energy Efficient Ethernet (EEE) The RTL8380M/RTL8382M/RTL8382L supports IEEE 802.3az Energy Efficient Ethernet (EEE) for 100Base-TX in full duplex operation, and supports 10Base-Te for 10Base-T in full/half duplex. The Energy Efficient Ethernet (EEE) operational mode combines the IEEE 802.3 Media Access Control (MAC) Sub-layer with a family of Physical Layers defined to support operation in Low Power Idle (LPI) Mode. When Low Power Idle Mode is enabled, systems on both sides of the link can disable portions of the functionality and save power during periods of low link utilization. The RTL8380M/RTL8382M/RTL8382L EEE operational mode supports IEEE 802.3 MAC operation at 100Mbps. For 100Mbps operation, the 100Base-TX PHY is supported. In addition, the RTL8380M/RTL8382M/RTL8382L supports a 10Mbps PHY with reduced transmit amplitude requirements in EEE operational mode. This new PHY is fully interoperable with legacy 10Base-T PHYs over 100m of Class-D (Category 5) or better cabling. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 51 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.4. Layer 2 Learning and Forwarding The RTL8380M/RTL8382M/RTL8382L has a 4K-entry VLAN table and provides a 64-entry filtering database. The RTL8380M/RTL8382M/RTL8382L supports IVL (Individual VLAN Learning) and SVL (Shared VLAN learning) mode. The mode used depends on the FID (Filtering Identifier) setting. 8.4.1. Forwarding IP multicast data packets involve multicast group table lookup and forwarding operations. If the table lookup returns a hit, the data packet is forwarded to all member ports and router ports. If the multicast address is not stored in the address table (i.e., lookup miss), the packet is broadcast to all ports of the broadcast domain. The VLAN Frame Forwarding Rules are defined as follows: • The received broadcast/multicast frame will flood to VLAN member ports only, except for the source port • The received unicast frame will be forwarded to its destination port only if the destination port is in the same VLAN as the source port. If the destination port belongs to a different VLAN, the frame will be discarded 8.4.2. Learning The RTL8380M/RTL8382M/RTL8382L features a Layer 2 table (8K entries) that uses a 4-way hash structure to store L2 entries. Each entry can be recorded in three formats, L2 Unicast, L2 Multicast, and IP Multicast. The L2 Unicast hash key is {MAC(48bits), FID/VID(12bits)}; the Multicast hash key is {MAC(48bits), FID/VID(12bits)}; the IP Multicast hash key is {MAC(48bits), FID/VID(12bits)}, {GIP(32bits), SIP(32bits)} or {0(16bits)+GIP(32bits), FID/VID(12bits)}. 8.4.3. DA/SA Block First bit transmitted: 0 = Unicast Destination 1= Multicast Destination Destination Address Second bit transmitted: 0= Globally Administered 1= Locally Administered First byte Second byte Third byte Fourth byte Fifth byte Sixth byte First byte Second byte Third byte Fourth byte Fifth byte Sixth byte Second bit transmitted: 0= Globally Administered 1= Locally Administered Source Address First bit transmitted-Routing Information Indicator (RII) 0=Routing Information Not Present (Not Source Routed) 1=Routing Information Present (Source Routed) Figure 11. DA/SA Block 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 52 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet While a frame may be sent to either a unicast or a multicast destination, frames are always sent from an individual station. The first bit of the Destination Address shows unicast or multicast. When used in its originally intended manner, the first bit of a Source Address should always be 0, indicating an individual sending station. The RTL8380M/RTL8382M/RTL8382L features DA blocking, SA blocking, or DA and SA blocking function through the Address Hash Table setting. 8.5. Port Isolation The RTL8380M/RTL8382M/RTL8382L supports the Port Isolation feature. We can control whether the hosts communicate with each other or not by controlling a register value. If we set the register to cut the connection between hosts, all packets from a host cannot be transmitted to another host directly. These packets can only be transmitted by passing through the router. This feature is called ‘Port Isolation’. In Figure 12, Host A and host B connect to the port0 and port3 of the switch, respectively, and port7 is a router. If we set the port isolation enable bit of port0 and port3 to 1, all packets between A and B need to pass through the router (in both directions, A to B and B to A). Figure 12. Port Isolation Example Each port has its own port mask configuration (19 bits in total for the RTL8380M, 29 bits for RTL8382M/RTL8382L). These bits and the TX port list will be mixed to a list. We call this mixed list the final TX port list. Port isolation port mask settings will affect received packets; however, the Mirroring function is not affected by the port isolation port mask. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 53 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.6. IEEE 802.3x Flow Control The RTL8380M/RTL8382M/RTL8382L supports IEEE 802.3x full duplex flow control. If one port’s received frame buffer is over the pause threshold, a pause-on frame is sent to indicate to the link partner to stop the transmission. When the port’s received frame buffer drops below the pause threshold, it sends a pause-off frame. The TX pause frame format is shown in Figure 13. Figure 13. TX Pause Frame Format The flow control mechanism of the RTL8380M/RTL8382M/RTL8382L is implemented on the RX side. It counts the received pages on the RX side in order to determine on which port it should send out Pause On/Off packets. Figure 14. Flow Control State Machine When RTL8380M/RTL8382M/RTL8382L flow control is enabled, the initial state is ‘Non_Congest’. The state is monitored continuously. If a pause-on trigger condition occurs, it enters the ‘Congest’ state. When in the ‘congest’ state, it is also continuously monitored. When a pause-off trigger condition occurs it reenters the ‘Non_Congest’ state. Figure 14 shows the flow control state machine. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 54 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.7. Half Duplex Backpressure There are two mechanisms for half duplex backpressure (Backpressure is for input buffer overflow). 8.7.1. Collision-Based Backpressure (Jam Mode) If the input buffer is ready to overflow, this mechanism will force a collision. When the link partner detects this collision, the transmission is rescheduled. The Reschedule procedure is: • When the link partner detects the collision, it waits for a random backoff time. The RTL8380M/RTL8382M/RTL8382L will handle packets that are in the input packet buffer during this time • RXDV and TXEN will be driven high. The RTL8380M/RTL8382M/RTL8382L will send a 12-byte Jam signal (pattern is preamble (7bytes) + SFD (1byte) + 0xAA (4bytes)). The RTL8380M/RTL8382M/RTL8382L will then drive TXEN low • When the link partner (which could be another RTL8380M/RTL8382M/RTL8382L) receives the Jam signal, it will feedback a 4-byte signal (pattern is derived from the CRC of all transmitted bytes) • After the RTL8380M/RTL8382M/RTL8382L receives this jamming signal, it drives RXDV low. The link partner waits for a random backoff time then re-sends the packet. The timing is shown in Figure 15 Figure 15. Signal Timing for Collision-Based Backpressure 8.7.2. Carrier-Based Backpressure (I.e., Defer Mode) If the input buffer is about to overflow, this mechanism will send a fix pattern to defer the other station’s transmission. The RTL8380M/RTL8382M/RTL8382L will continuously send the defer signal until the input buffer overflow is resolved. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 55 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.8. Layer 2 Multicast and IP Multicast There are two RTL8380M/RTL8382M/RTL8382L IP multicast frame types: IPv4 multicast and IPv6 multicast. An IPv4 multicast frame must satisfy two conditions: • The type must be IPv4 • DMAC should=01-00-5E-XX-XX-XX An IPv6 multicast frame must satisfy two conditions: • The type must be IPv6 • DMAC should=0x33-33-XX-XX-XX-XX The RTL8380M/RTL8382M/RTL8382L definition of a L2 multicast packet is that the packet is not an IP multicast packet, and the I/G bit of the MAC address is 1. The RTL8380M/RTL8382M/RTL8382L supports IGMPv1/2/3. IGMP and MLDv1/2 packets can be trapped to the CPU to allow software to insert an IP multicast entry into the L2 table. 8.9. IEEE 802.1d/1w/1s (STP/RSTP/MSTP) There are 64 spanning tree instances for the RTL8380M/RTL8382M/RTL8382L. The CPU will create a different Port State for different spanning tree instances at each port. The RTL8380M/RTL8382M/RTL8382L will assign a VID for a received packet, and will look up the VLAN table to check for Multiple Spanning Tree Instances (MSTI). The RTL8380M/RTL8382M/RTL8382L will follow the ports MSTI state to complete its corresponding ingress/egress check. The Spanning Tree and Rapid Spanning Tree port states are shown in Figure 16. Figure 16. Spanning Tree and Rapid Spanning Tree Port States 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 56 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet When using IEEE 802.1D, the RTL8380M/RTL8382M/RTL8382L supports four status’ for each port: Disabled Except for software forwarding, the port will not transmit/receive packets, and will not perform learning. Blocking/Listening Except for software forwarding, the port will only receive BPDU spanning tree protocol packets, but will not transmit any packets, and will not perform learning. Learning The port will receive any packet, including BPDU spanning tree protocol packets, and will perform learning, but will only transmit BPDU spanning tree protocol packets. Forwarding The port will transmit/receive all packets, and will perform learning. There are five Spanning Tree port states, and four Rapid Spanning Tree port states. Their mapping relations are DiscardingÆBlocking, LearningÆLearning, and ForwardingÆForwarding (see Table 45). Receive BPDUs Transmit BPDUs Learn Address Forward Frame Table 45. Spanning Tree and Rapid Spanning Tree Action Spanning Tree Rapid Spanning Tree Disable Blocking Listening Learning Forwarding Discard Learning Forwarding No Yes Yes Yes Yes Yes Yes Yes No No Yes Yes Yes No Yes Yes No No No Yes Yes No Yes Yes No No No No Yes No No Yes 8.10. IEEE 802.1p and IEEE 802.1Q (VLAN) The RTL8380M/RTL8382M/RTL8382L supports IEEE 802.1Q tag-based, protocol-and-port-based, portbased, MAC-based, IP-subnet-based, and application-based VLANs. It supports a 4K-entry VLAN table, supporting C-VID (Customer VLAN ID) and FID (Filtering Identifier) entries. There are 6 fields in the VLAN table, and their definitions are as below. • MBR: Determines whether the packets belong to the same VLAN • UNTAG: Determines whether Egress packets have a VLAN tag • FID_MSTI: Gets different FIDs (Filtering Identifier) or determines the index of multiple spanning tree instances from different VLANs • L2_HKEY_UBCAST: Determines the hash key (VID or FID) for L2 unicast and broadcast traffic • L2_HKEY_MCAST: Determines the hash key (VID or FID) for L2 multicast and IP multicast traffic • VLAN_PROFILE: Determines the index of the VLAN profile 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 57 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet The RTL8380M/RTL8382M/RTL8382L supports eight global VLAN profiles, each VLAN profile has the following configurations: • L2_LRN_EN: Enable L2 SA learning • L2_UNKN_MC_FLD_PMSK: Unknown L2 multicast flooding port mask • IP4_UNKN_MC_FLD_PMSK: Unknown IPv4 multicast flooding port mask • IP6_UNKN_MC_FLD_PMSK: Unknown IPv6 multicast flooding port mask For un-managed switches, there is a register setting to disable tag-based VLANs and force ‘no check’ for any VLAN settings. If a packet is tagged in, then it is tagged out. If untagged in, then it is untagged out. • The RTL8380M/RTL8382M/RTL8382L supports ingress and egress VLAN filtering functions • Ingress VLAN filtering: Packets from an input port that is not in the VLAN member set will be dropped, trapped, or forwarded depending on register configuration • Egress VLAN filtering: Packets to an output port that is not in the VLAN member set will be dropped, trapped, or forwarded depending on register configuration 8.11. IEEE 802.1X (Network Access Control) The RTL8380M/RTL8382M/RTL8382L provides a software solution for 802.1X. When a host connects to a switch, the switch will transfer the host information to an authentication server: • If authentication is successful, the switch will set the control bit of this port to ‘TRUE’ (i.e., the host will be allowed the service) • If authentication is not successful, the switch will deny the host access to the network The CPU port can be regarded as a special port where transmit and receive packets are unrestricted for 802.1X. The RTL8380M/RTL8382M/RTL8382L supports two types of 802.1X; Port-Based Network Access Control, and MAC-Based Network Access Control. • Port-Based Network Access Control: For each port, there is a bit to check whether this port has passed authentication or not. A direction control register decides whether this port needs pass-through authentication for both (IN/OUT) directions or only for receive (IN) • MAC-Based Access Control: Provides authentication for multiple logical ports. Each logical port represents a source MAC address. There are multiple logical ports for a physical port. There is a register that enables/disables each logical port MAC-based network access control function. Another register controls transmit/receive direction authentication for each port (IN/OUT) or only receive direction (IN) 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 58 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Table 46 illustrates the forwarding of host n. Authentication of Host n 0 (Unauthorized) 0 (Unauthorized) 1 (Authorized) 1 (Authorized) Table 46. Forwarding of Host n Direction of Whole Chip Fwd Frames to Host n 0 (BOTH) No 1 (IN) Yes 0 (BOTH) Yes 1 (IN) Yes Fwd Frames from Host n No No Yes Yes 8.12. Reserved Multicast Address Handling There are some Reserved Multicast Address (RMA) definitions in the IEEE 802.1 standard. The RTL8380M/RTL8382M/RTL8382L includes 01-80-C2-00-00-00 to 01-80-C2-00-00-2F RMA support and provides user defined RMA settings. For each RMA, the actions include: Table lookup, Drop, Trap to CPU, and always Flood. The action priority is higher than the results of a L2 Table lookup. Default actions are shown in Table 47. Table 47. Reserved Multicast Address Default Actions Name Address Bridge Group Address 01-80-C2-00-00-00 IEEE Std 802.3, 1988 Edition, Full Duplex PAUSE Operation 01-80-C2-00-00-01 IEEE Std 802.3ad Slow Protocols-Multicast Address 01-80-C2-00-00-02 IEEE Std 802.1X PAE Address 01-80-C2-00-00-03 Reserved for future protocol standards 01-80-C2-00-00-04 to 01-80-C2-00-00-0D, 01-80-C2-00-00-0F 01-80-C2-00-00-0E LLDP IEEE Std 802.1AB Link Layer Discovery Protocol Multicast Address All LANs Bridge Management Group Address 01-80-C2-00-00-10 GMRP 01-80-C2-00-00-20 GVRP 01-80-C2-00-00-21 Reserved for use by Multiple Registration 01-80-C2-00-00-22 to 01-80-C2-00-00-2F Protocol (MRP) applications 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 59 Default Forward Drop Drop Forward Drop Forward Drop Drop Forward Drop Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.13. Layer 2 Traffic Suppression (Storm Control) The per-port L2 storm filtering control mechanism suppresses the flow rate of some specific packets. The RTL8380M/RTL8382M/RTL8382L supports five control types: Unknown Unicast Storm, Unicast Storm, Unknown Multicast Storm, Multicast Storm, and Broadcast Storm. Each port has control registers to enable or disable the storm filtering function. These five traffic type definitions are: • Unknown Unicast: If the I/G bit of the packet’s destination address is 0, it is a unicast packet and its DA look-up in the L2 unicast table failed. I.e., the packet’s destination address is unknown • Unicast: The unicast storm filtering control includes unknown and known unicast for RTL8380M/RTL8382M/RTL8382L • Unknown Multicast: If the I/G bit of the packet’s destination address is 1, it is a multicast packet and its DA look-up in the L2 unicast table failed, i.e., the packet’s destination address is unknown • Multicast: The multicast storm filtering control includes unknown and known multicast for RTL8380M/RTL8382M/RTL8382L • Broadcast: DMAC = FF-FF-FF-FF-FF-FF indicates this is a broadcast packet Unknown Unicast and Unicast use the same traffic counter, and Unknown Multicast and Multicast use the same traffic counter. The user should set the Unicast and Multicast storm type as unknown or both known and unknown in the storm filter setting. The traffic rate for these five types can be set on a per-port basis. The priority sequence of L2 filtering control is: 1. Input bandwidth control 2. ACL policy 3. Storm-filtering control 8.14. PIE (Packet Inspection Engine) PIE is a 1.5K-entry search engine that is divided into 12 blocks (block numbers are 0~11). Each block size is 128-entries. Every entry has 216-bit data, and a 216-bit mask. There is an extra bit to indicate whether this entry is valid or not. Each block can be disabled for power saving when it is not used. All the entries are prepared for ingress ACL. 8.14.1. Ingress ACL The Ingress ACL (Access Control List) perform actions such as packet drop, forwarding, ingress I-VID Assignment, Ingress O-VID Assignment, filter, log, remarking, meter, mirror etc. When a packet hits one entry it will execute the corresponding action mapped to this entry. Each PIE memory entry corresponds to one action entry. The packet can match to multi-actions. When a multi-match occurs (i.e., there are several ACL entries that match) in one block, it will execute the lowest address entry corresponding action. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 60 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.15. Input Bandwidth Control and ACL Traffic Meter 8.15.1. Input Bandwidth Control The RTL8380M/RTL8382M/RTL8382L has input bandwidth control for each port (excluding the CPU port). The bandwidth setting range is 16Kbps~1Gbps. The granularity is 16Kbps, and each port has a 16-bit register to control the bandwidth. If the speed of received packets is faster than the bandwidth setting, it will send a ‘Pause ON’ packet to slow the link partner transmissions when the flow control function is enabled, and drop packets when the flow control function is disabled. When normal transmissions become possible and the flow control function is enabled, the switch will send a ‘Pause OFF’ packet. 8.15.2. ACL Traffic Meter For Ingress ACL entry, there is an index to point to 256 ACL rate-limited entries. The rate limit is flow controlled via leaky bucket. The rate range is 16Kbps~1Gbps, the granularity is 16Kbps, and each ratelimited entry has a 16-bit register to control the rate value. 8.16. IEEE 802.3ad Link Aggregation Protocol To ensure correct frame ordering when changing the hash algorithm, the marker protocol mechanism must be started. Software will wait for the aggregation port queues to empty, and then send a marker message to all aggregation ports. After receiving a marker reply packet, software can change the hash algorithm. The RTL8380M/RTL8382M/RTL8382L supports 802.3ad (Link Aggregation) for 8 groups of link aggregators with up to 8 ports per-group (based on DMAC/SMAC/SPA/SIP/DIP/SPORT/DPORT). The CPU port cannot be aggregated to an aggregation port. As the RTL8380M/RTL8382M/RTL8382L does not check CPU port aggregation, software should check this to avoid frame transmit errors. Frame Distribution Link aggregation group frames are sent to an aggregation port of the link aggregation group according to a hash algorithm. There are seven parameters (DMAC, SMAC, SPA, SIP, DIP, SPORT, DPROT). To prevent assigning the same hash value when hash keys simultaneously change to another value, we stagger the least significant bit of all hash keys. Mapping a Physical Port to a Logical Port No matter how many physical aggregation port members are in a link aggregation group, it is regarded as one logical port. Each link aggregation has an ID (the lowest number of the physical aggregation port members is used as its ID). Once the ID is chosen, even if the logical port ID’s corresponding physical port is link down, the ID and setting of the link aggregation group will not change. However, it will change when this corresponding port is removed or a lower-numbered port is added. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 61 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Hash Algorithm Change The algorithm will change when the following conditions occur: • The link aggregation group member port changes to link-down or link-up • The user/LACP (i.e., Link Aggregation Control Protocol) changes the link aggregation group member port or register setting 8.17. IEEE 802.1ad VLAN Stacking The RTL8380M/RTL8382M/RTL8382L supports multi-layered VLANs and can have Outer-VLAN and Inner-VLAN tagging. Standard 802.1ad takes the S-tag (Service VLAN tag) as the relay VID. The RTL8380M/RTL8382M/RTL8382L uses the Outer-tag as S-tag, and the Inner-tag as C-tag to support 802.1ad applications. The IEEE 802.1ad frame format is shown in Figure 17. Figure 17. IEEE 802.1ad Frame Format 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 62 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.18. Quality of Service (QoS) There are 5 types of Priority Assignment for the RTL8380M/RTL8382M/RTL8382L: • Port-based Inner-tag Priority • Port-based Outer-tag Priority • Inner-tag-based Priority • Outer-tag-based Priority • DSCP-based Priority These priority assignments will pass through the whole system priority selection table to decide the packets internal priority. Afterwards the internal priority will point to the adaptive output queue ID table. Priority Selection Tables A received packet may be assigned up to five different priorities. These priorities are coordinated into a final priority according to the priority selection table Figure 18. Each priority assignment has a control register. The corresponding bit set to 1, sets the priority from high bit to low bit. Inner-tag-based priority, Outer-tag-based priority, and DSCP-based priority may be NULL. The priority arbiter should check whether the item is NULL or not. The NULL item priority corresponds to the lowest priority arbitration value; the bigger the corresponding priority arbitration value, the higher the priority assignment. We can take an example to describe the priority order. The order is Inner-tag-based priority assignment > DSCP-based priority assignment > Outer-tag based priority assignment > Port-based Inner-tag Priority assignment = Port-based Outer-tag Priority assignment. Figure 18. Priority Selection Table Weight Rules Example 1 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 63 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Internal Priority to Queue ID Table Weighted Arbitor The RTL8380M/RTL8382M/RTL8382L can transfer its internal priority setting (see Figure 19) to the output queue ID. The RTL8380M/RTL8382M/RTL8382L can configure each port’s output queue level (including the CPU port). Each port has eight output queues. Figure 19. Per-Port Queue Management 8.19. Packet Scheduling (WRR and WFQ) The Packet Scheduler controls the various traffic classes (i.e., controls the packet sending sequence of the priority queue). The RTL8380M/RTL8382M/RTL8382L scheduling algorithm is divided into Weighted Fair-Queuing (WFQ) and Weighted Round-Robin (WRR). Note that the Strict Priority queue is the highest priority of all queues, and overrides WFQ & WRR. A larger strict priority queue ID indicates the priority is higher. The Scheduler operates as follows: • Weighted Fair-Queuing (WFQ): Byte-count • Weighted Round-Robin (WRR): Packet-count WFQ and WRR cannot exist at the same time. WFQ or WRR can co-exist with Strict Priority Schedule. Both WFQ and WRR are round robin, from large queue ID to small. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 64 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.20. Packet Drop Algorithm (TD) The RTL8380M/RTL8382M/RTL8382L supports Tail Drop (TD). • Tail Drop (TD): For a drop threshold value, if a packet meets queue overflow conditions before entering the output queue, the switch will drop this packet 8.21. Egress Packet Remarking The RTL8380M/RTL8382M/RTL8382L Remarking can be divided into Inner-tag remarking, Outer-tag remarking, and DSCP remarking. • For Inner-tag remarking, there is an internal priority to inner-tag priority remarking table that is used to configure the final user inner-tag priority value for per-port egress of a packet • For Outer-tag remarking, there is an internal priority to outer-tag priority remarking table that is used to configure the final Outer-tag priority value for per-port egress of a packet • DSCP remarking also has an internal priority to DSCP priority table for per-port egress of a packet 8.22. Ingress and Egress Port Mirror The RTL8380M/RTL8382M/RTL8382L has four mirror sets (set0~3), and the Mirroring port can monitor several mirrored ports simultaneously. RX mirror and TX mirror function is supported by setting a source port mask, destination port mask. The mirror function can be configured across VLANs. The RTL8380M/RTL8382M/RTL8382L supports a mirror filtering function to filter forwarded traffic. Only mirrored traffic can egress though a mirroring port. The RTL8380M/RTL8382M/RTL8382L provide a flexible flow-based mirror function. In a flow-based mirror, only specified packets will be mirrored through a configured ACL action and fill a corresponding traffic mirror table entry. For flow control, the mirroring port will drop the mirrored packets and send PAUSE frames or backpressure signals to the mirrored port for normal packets. It will resume mirror function when flow control is back to normal status. The design limitations for mirroring settings are as below. • Each mirror entry can only set one mirroring port • A mirroring port cannot be a member of a trunk group • The mirroring port is not limited by port isolation for mirrored packets 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 65 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.22.1. Remote Mirror (RAPAN) The RTL8380M/RTL8382M/RTL8382L support Remote Switched Port Analyzer (RSPAN) to analyze a remote device’s traffic flow. The RTL8380M/RTL8382M/RTL8382L defined RSPAN VLAN tag is illustrated in Figure 20. Users can configure the RSPAN tag’s TPID/VID/Priority/CFI at each port. The RTL8380M/RTL8382M/RTL8382L can parse for the RSPAN tag in RX and add or remove RSPAN tags in TX. DMAC SMAC DMAC SMAC RSPAN TPID Layer2 Header PAYLOAD RSPAN Tag PRIO Layer 2 Header CFI FCS PAYLOAD FCS RSPAN VID Figure 20. RSPAN Encapsulation Figure 21 shows an example of an RSPAN application. In Source Switch A, Port0 is configured as a mirrored port, and Port2 as a mirroring port with setting ‘TX added RSPAN tag’. In Intermediate Switch B, Port3 and Port5 are added as RSPAN VLAN members. RSPAN mirrored packets will be forwarded without any modification. In Destination Switch C, Port7 and Port9 join as RSPAN VLAN members, with Port9 configured to ‘Remove RSPAN tag in TX’. This means packets are mirrored from Source Switch A Port0 to Destination Switch C Port9 without modification. Figure 21. RSPAN Illustration 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 66 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.23. Management Information Base (MIB) The RTL8380M/RTL8382M/RTL8382L MIB (Management Information Base) counters include: • Ethernet-like MIB (RFC 3635) • Interface Group MIB (RFC 2863) • RMON (Remote Network Monitoring) MIB (RFC 2819) • Bridge MIB (RFC 1493) • Bridge MIB Extension (RFC 2674) 8.24. NIC and CPU Tag Forwarding NIC interface: This is used for receiving packets from the CPU, or transmitting packets to the CPU. The architecture is shown in Figure 22. When a packet is sent from the switch core to the CPU port, the CPU tag can carry status information. The CPU tag can be divided into a transmit CPU tag, and a receive CPU tag. • Transmit CPU Tag: Forces TX port mask. Indicates which ports the packet will NOT be sent to. For example, if we set port1, port2, and port5 mask bits, then the packet will not be sent to these ports • Receive CPU Tag: Indicates which RX port the packet came from If no CPU tag is attached, the normal process will be followed to perform a look-up in the L2 table. DMA NIC Driver SDRAM MAC Rx NIC CPU Port MAC Switch Core DMA MAC MAC Tx Figure 22. NIC Architecture 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 67 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 8.25. Indirect Table Access The RTL8380M/RTL8382M/RTL8382L employs an indirect method to set the control register and the data register to complete a VLAN/L2 Lookup/ Forwarding/SPT/ACL Table Access: 1. Sets the register to determine which table and which entry is to be accessed 2. Determines the read or write action 3. Hardware executes table access Read: After the control register setup has been completed by software, hardware access then puts this data into the data register. Software then reads this data from the data register. Write: The data is placed in the data register by software and the control register is set. Hardware writes this data to the table. 8.26. External PHY Register Access After the RTL8380M/RTL8382M/RTL8382L powers on and initializes, it will set the PHY MII register via MDC/MDIO. The RTL8380M/RTL8382M/RTL8382L supports three access control registers to indirectly access an external PHY via the MDC/MDIO interface. 8.27. Switch Interrupt Indication The RTL8380M/RTL8382M/RTL8382L provides one global interrupt function: switch interrupt. Interrupt sources are listed below: • Port Link Change interrupt • Port SA learning constraint interrupt • SerDes interrupt 9. CPU Function Description 9.1. MIPS-4KEc • MIPS 4KEc CPU Core (Targeted at 500MHz): 5-stage pipeline, MIPS32 instruction set, additional MIPS16e instruction set support, 2 GPR sets (one shadow set), and vectored/Non-Maskable Interrupts (NMI) support • Cache Configuration: I-Cache is 16KB, 4-way set associative, and 16-byte line size. D-Cache is 16KB, 4-way set associative, 16-byte line size, and write-back policy. It also has virtually indexed, physically tagged, and Prefetch instructions • MMU Configuration: 4-entry ITLB, 4-entry DTLB, and 32-entry JTLB • Misc.: Power-down mode, EJTAG support, internal BIST, internal real-time timer interrupts 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 68 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet (Count/Compare registers), and CPU breakpoints 9.2. SPI Flash The RTL8380M/RTL8382M/RTL8382L support 32M-Byte (max) serial I/O, dual I/O SPI Flash. 9.3. SDRAM Interface Configuration (RTL8380M/RTL8382M Only) Only the RTL8380M/RTL8382M support 8-bit data bus DDR1/DDR2/DDR3 SDRAM. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 69 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10. Interface Descriptions 10.1. QSGMII QSGMII-plus (Quad Serial Gigabit Media Independent Interface) reduces PCB complexity and IC pin count. This innovative 5Gbps serial interface provides an up to 10 inch MAC to PHY communication path. QSGMII can carry the full duplex gigabit Ethernet data streams of four ports simultaneously, using only 4 pins. Port0 MAC PHY TX+/- RX+/- TX Port0 RX Port1 Port1 25MHz QGMII RX+/- Port2 QSGMII TX+/- RX Port2 TX Port3 Port3 Figure 23. QSGMII Interconnection 10.2. RSGMII RSGMII (Reduced Serial Gigabit Media Independent Interface) reduces PCB complexity and IC pin count. This innovative 2.5Gbps serial interface provides an up to 10 inch MAC to PHY communication path. RSGMII can carry the full duplex gigabit Ethernet data streams of two ports simultaneously, using only 4 pins. Figure 24. RSGMII Interconnection 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 70 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.3. SGMII SGMII (Serial Gigabit Media Independent Interface) conveys PHY and MAC data with significantly less pins than required for GMII. It operates in both half and full duplex, and at all port speeds. It includes 4 data signals and 2 CLK signals to convey frame data and link rate information between the PHY and MAC. The data signals operate at 1.25Gbaud, and the CLK operates at 625MHz. Each of these signals is carried as a differential pair, thus providing signal integrity while minimizing system noise. Figure 25. SGMII Signal 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 71 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.4. DDR1 SDRAM (RTL8380M/RTL8382M Only) The RTL8380M/RTL8382M support DDR1 SDRAM with the following features: • Bus width is 8 bits • One chip selection • Supports 4 banks • Row count range is 4~16K, and column count range is 512~4K • Supports maximum 128M Bytes DDR1 SDRAM Figure 26. DDR1 SDRAM Configuration 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 72 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.5. DDR2 SDRAM (RTL8380M/RTL8382M Only) The RTL8380M/RTL8382M supports DDR2 SDRAM with the following features: • Bus width is 8 bits • One chip selection • Supports 4 banks or 8 banks • Row count range is 4~16K, and column count range is 512~4K • Supports maximum 128M Bytes DDR2 SDRAM Figure 27. DDR2 SDRAM Configuration 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 73 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.6. DDR3 SDRAM (RTL8380M/RTL8382M Only) The RTL8380M/RTL8382M supports DDR3 SDRAM with the following features: • Bus width is 8 bits • One chip selection • Supports 8 banks • Supports maximum 256M Bytes DDR3 SDRAM Figure 28. DDR3 SDRAM Configuration 10.7. SPI Flash Interface The RTL8380M/RTL8382M/RTL8382L support SPI Flash with the following features: • Supports serial I/O, dual I/O SPI Flash (max) • Supports both MMIO (Memory Mapped I/O) and PIO (Programmed I/O) mode • One chip selection • Supports maximum 32M Bytes SPI Flash in PIO mode and 16M Bytes in MMIO mode Figure 29. SPI Flash Configuration 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 74 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.8. UART The RTL8380M/RTL8382M/RTL8382L provides two UARTs, and each contains a 16-byte FIFO buffer. The baud rate can be up to 1Mbps and a programmable baud rate generator allows division of any input reference clock by 1 to 65535, and generates an internal 16x clock. The RTL8380M/RTL8382M provides a fully programmable serial interface. In addition to the above functions, the RTL8380M/RTL8382M/RTL8382L provides fully prioritized interrupt control and loopback functionality for diagnostic capabilities. The UART interface pins are shown in the following table. Signal Name TXD# RXD# Table 48. UART Control Interface Pins Type Description Output Transmit Data. Input Receive Data. 10.9. EJTAG EJTAG is inexpensive, and easy to implement. EJTAG utilizes the 5-pin IEEE 1149.1 JTAG (Joint Test Action Group) specification for off-chip communication. The interface pins are shown in Table 49. Signal Name TDI TDO TCK TMS TRST Table 49. EJTAG Interface Pins Type Description Input Test Data In. Output Test Data Out. Output Test Clock. Output Test Mode Select. Output (Optional) Test Reset. EJTAG Circuitry TRST TMS TAP Controller A+ D TCK CPU Addr . Direct Memory Access Data TDO TDI A+ D Debug Registers A+ D System Memory Addr. Instruction, Data, and Control Registers Processor Access Data Address / Data Busses Figure 30. EJTAG Using a 5-Pin JTAG Interface to Access Data Block 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 75 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet EJTAG provides a path to access internal debug registers and circuitry that monitor and control the address and data busses of the processor. The DMA and Processor circuit blocks are used to setup and monitor the processor’s internal busses and to execute the code from the EJTAG interface. When an access is detected, the EJTAG circuitry makes the transaction address available in the EJTAG Address Register, and the appropriate data available in the EJTAG Data Register. It takes about 200 TCK periods to access 32-bit address and data registers in this fashion, so with a 40MHz TCK frequency, the access time is in the range of 5µs. 10.10. I2C Master for EEPROM The EEPROM can be divided into two sizes: 2Kb~8Kb and 32Kb~512Kb. The address of the small size EEPROM is 8-bits, however the larger EEPROM has word-high addressing and word-low addressing, and it is 16-bits (two bytes). Figure 31. 8-Bit EEPROM Sequential Read 10.11. I2C Slave Interface The RTL8380M/RTL8382M/RTL8382L supports a I2C slave interface (Slave mode) for external CPU to access the internal register. It has two I/O pins (i.e., SDA and SCL). SDA is the access data signal, and SCL is the clock signal (typical clock is 1~2MHz). The read/write data sequence is shown below. Figure 32. I2C Slave Interface Access Data Sequence 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 76 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.12. SPI Slave Interface The RTL8380M/RTL8382M/RTL8382L supports an SPI slave interface (Slave mode) for an external CPU to access the internal register. It has four I/O pins (SI, SO, SCK, and CS#). The instruction sets are as shown in the following table. Instruction Name Table 50. SPI Slave Interface Byte 2 Byte 3 Byte 4 Byte 5 Write Data Byte 1 (Code) 02h A23~A16 A15~A8 A7~A0 Read Data 03h A23~A16 A15~A8 A7~A0 Byte 6 Byte 7 Byte 8 D31~D24 D23~D16 D15~D8 D7~D0 D31~D24 D23~D16 D15~D8 D7~D0 Note: A23~A8: Maps to the switch’s 16-bits register address. A7~A0 in Write Data Instruction: Dummy byte for switch and conforms to standard SPI 24-bits address format. A7~A0 in Read Data Instruction: Dummy byte waits for the switch to prepare the register data and conforms to standard SPI 24-bits address format. D31~D0: 32-bits Register Data. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 77 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 10.13. Serial LED The RTL8380M/RTL8382M/RTL8382L supports a serial LED interface to display the link status. The serial LED interface, LED_CK and LED_DA provide clock and data to enable/disable the external shift registers. A 74HC164 8-Bit Serial-In, Parallel-Out Shift Register captures the per-port link status and diagnostic information. In serial shift LED mode, the RTL8380M/RTL8382M/RTL8382L supports perport one/two/three single-color LED to show the speed, link status, and other information. Figure 33. Serial LED Connection 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 78 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet The default LED status for RTL8380M/RTL8382M/RTL8382L is as follows: LED Number LED0 Defintion LED1 Defintion LED2 Defintion 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 3-LEDs 1000M Link 100M Link Link/Act 79 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11. Electrical AC/DC Characteristics 11.1. Absolute Maximum Ratings WARNING: Absolute maximum ratings are limits beyond which permanent damage may be caused to the device, or device reliability will be affected. All voltages are specified referenced to GND unless otherwise specified. Table 51. Absolute Maximum Ratings Parameter Min Junction Temperature (Tj) Storage Temperature -10 DVDDH, AVDDH, SVDDH, AVDDH_PLL Supply Referenced to DGND, 2.97 AGND DVDDL, AVDDL, SVDDL, AVDDL_PLL, PLLVDDL Supply Referenced 0.90 to DGND, AGND MVDDH Supply Referenced to DGND(for DDR1) 2.375 MVDDH Supply Referenced to DGND(for DDR2) 1.71 MVDDH Supply Referenced to DGND(for DDR3) 1.425 VDDIO 1.875(2.5) 1.350(1.5) Max +125 +125 Units °C °C 3.63 V 1.18 V 2.625 1.89 1.575 2.625(2.5) V V V V 1.575(1.5) V 11.2. Operating Range Table 52. Recommended Operating Range Parameter Min Typical Ambient Operating Temperature (Ta) 0 DVDDH, AVDDH, SVDDH, AVDDH_PLL 3.135 3.3 Supply Voltage Range DVDDL, AVDDL, AVDDL_PLL, PLLVDDL 0.95 1.1 Supply Voltage Range SVDDL Supply Voltage Range 1.05 1.1 MVDDH Supply Voltage Range(for DDR1) 2.375 2.5 MVDDH Supply Voltage Range(for DDR2) 1.71 1.8 MVDDH Supply Voltage Range(for DDR3) 1.425 1.5 VDDIO 1.875 2.5 1.350 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 80 1.5 Max 55 Units °C 3.465 V 1.15 V 1.15 2.625 1.89 1.575 V V V V 2.625 V 1.575 V Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.3. DC Characteristics Symbol VIH VIL VOH VOL Table 53. DC Characteristics (IO_Power=3.3V) Parameter Min TTL Input High Voltage 2.0 TTL Input Low Voltage Output High Voltage 2.4 Output Low Voltage - Typical - Max 0.8 0.4 Units V V V V 11.4. AC Characteristics 11.4.1. QSGMII Differential Transmitter Characteristics Symbol UI T_X1 T_X2 T_Y1 T_Y2 VTX-DIFFp-p TTX-EYE TTX-JITTER TTX-RISE TTX-FALL RTX Table 54. QSGMII Differential Transmitter Characteristics Parameter Min Typical Max Units Unit Interval 199.94 200 200.06 ps Eye Mask 0.2 UI Eye Mask 0.4 UI Eye Mask 150 mV Eye Mask 650 mV Output Differential Voltage 600 900 1300 mV Minimum TX Eye Width 0.6 UI Output Jitter 0.4 UI Output Rise Time 0.15 UI Output Fall Time 0.15 UI Differential Resistance 80 100 120 ohm - CTX LTX Notes 200ps±300ppm - Transmit Length in PCB - 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers - 81 10 inch - Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet TTX-EYE-MIN T_Y2 T_Y1 Amplitude 0V VTX-DIFFp-p-MIN VTX-DIFFp-p-MAX -T_Y1 -T_Y2 0.0 T_X1 T_X2 1-T_X2 1-T_X1 1.0 Time UI Figure 34. QSGMII Differential Transmitter Eye Diagram 11.4.2. QSGMII Differential Receiver Characteristics Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE TRX-JITTER RRX Table 55. QSGMII Differential Receiver Characteristics Parameter Min Typical Max Units Unit Interval Eye Mask Eye Mask Eye Mask Input Differential Voltage Minimum RX Eye Width Input Jitter Tolerance Differential Resistance 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 199.94 100 200 0.4 80 200 100 82 200.06 0.3 650 1300 0.6 120 ps UI mV mV mV UI UI ohm Notes 200ps±300ppm Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 35. QSGMII Differential Receiver Eye Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 83 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.3. RSGMII Differential Transmitter Characteristics Symbol UI T_X1 T_X2 T_Y1 T_Y2 VTX-DIFFp-p TTX-EYE TTX-JITTER TTX-RISE TTX-FALL RTX Table 56. RSGMII Differential Transmitter Characteristics Parameter Min Typical Max Units Unit Interval 399.88 400 400.12 ps Eye Mask 0.2 UI Eye Mask 0.4 UI Eye Mask 150 mV Eye Mask 550 mV Output Differential Voltage 600 800 1100 mV Minimum TX Eye Width 0.6 UI Output Jitter 0.3 UI Output Rise Time 0.15 UI Output Fall Time 0.15 UI Differential Resistance 80 100 120 ohm CTX AC Coupling capacitor 75 100 200 nF - LTX Transmit Length in PCB - - 10 inch - Notes 400ps±300ppm - TTX-EYE-MIN T_Y2 T_Y1 Amplitude 0V VTX-DIFFp-p-MIN VTX-DIFFp-p-MAX -T_Y1 -T_Y2 0.0 T_X1 T_X2 1-T_X2 1-T_X1 1.0 Time UI Figure 36. RSGMII Differential Transmitter Eye Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 84 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.4. RSGMII Differential Receiver Characteristics Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE TRX-JITTER RRX Table 57. RSGMII Differential Receiver Characteristics Parameter Min Typical Max Units Unit Interval Eye Mask Eye Mask Eye Mask Input Differential Voltage Minimum RX Eye Width Input Jitter Tolerance Differential Resistance 399.88 60 120 0.4 80 400 100 400.12 0.3 600 1200 0.6 120 ps UI mV mV mV UI UI ohm Notes 400ps±300ppm TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 37. RSGMII Differential Receiver Eye Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 85 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.5. SGMII Differential Transmitter Characteristics Symbol UI T_X1 T_X2 T_Y1 T_Y2 VTX-DIFFp-p TTX-EYE TTX-JITTER RTX Table 58. SGMII Differential Transmitter Characteristics Parameter Min Typical Max Units Unit Interval 799.76 800 800.24 ps Eye Mask 0.1875 UI Eye Mask 0.4 UI Eye Mask 125 mV Eye Mask 500 mV Output Differential Voltage 400 700 900 mV Minimum TX Eye Width 0.625 UI Output Jitter 0.375 UI Differential Resistance 80 100 120 ohm CTX AC Coupling capacitor 75 100 200 nF - LTX Transmit Length in PCB - - 10 inch - Notes 800ps±300ppm - Figure 38. SGMII Differential Transmitter Eye Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 86 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.6. SGMII Differential Receiver Characteristics Table 59. SGMII Differential Receiver Characteristics Parameter Min Typical Max Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE TRX-JITTER RRX Unit Interval Eye Mask Eye Mask Eye Mask Input Differential Voltage Minimum RX Eye Width Input Jitter Tolerance Differential Resistance 799.76 50 100 0.375 80 800 100 Units 800.24 0.3125 600 1200 0.625 120 ps UI mV mV mV UI UI ohm Notes 800ps±300ppm TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 39. SGMII Differential Receiver Eye Diagram 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 87 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.7. DDR2 Characteristics Figure 40. DDR2 Timing Characteristics Table 60. DDR2 SDRAM Timing Characteristics Symbol Description Min fCK, fCK# Clock Frequency of the CK and CK# Duty Duty Cycle of the CK and CK# 48 tJITper Clock period jitter -110 tJITcc Cycle-to-cycle jitter -220 tDS DQ and DM Output Setup Time 450 tDH DQ and DM Output Hold Time 450 tIS Address and Control Output Setup Time 600 tIH Address and Control Output Hold Time 600 tDQSQ Input DQS–DQ Skew, DQS to Last DQ Valid tQH Input DQ–DQS Hold, DQS to First DQ to Go Non-Valid 0.3 Note: Test Condition, fDDR_CK=300MHz. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 88 Typical 300 50 - - Max 52 110 220 300 - Track ID: Units MHz % ps ps ps ps ps ps ps CK Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.8. DDR3 Characteristics Figure 41. DDR3 Timing Characteristics Symbol fCK, fCK# Duty tJITper tJITcc tDS tDH tIS tIH tDQSQ Table 61. DDR3 SDRAM Timing Characteristics Description Min Clock Frequency of the CK and CK# Duty Cycle of the CK and CK# 47 Clock period jitter -90 Cycle-to-cycle jitter -165 DQ and DM Output Setup Time 450 DQ and DM Output Hold Time 400 Address and Control Output Setup Time 750 Address and Control Output Hold Time 550 Input DQS–DQ Skew, DQS to Last DQ Valid - 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 89 Typical 300 50 - - Max 53 90 165 300 Track ID: Units MHz % ps ps ps ps ps ps ps Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet Symbol Description tQH Input DQ–DQS Hold, DQS to First DQ to Go Non-Valid Note: Test Condition, fDDR_CK=300MHz. Min 0.3 Typical - Max - Units CK 11.4.9. SPI Interface Characteristics Figure 42. SPI Interface Timing Table 62. SPI Interface Timing Characteristics Symbol Description Min fSPI_SCK Clock Frequency of the SPI_SCK 49.5 Duty Duty Cycle of the SPI_SCK 45 tSLCH CS# Active Setup Time 7 tCHSH CS# Active Hold Time 8 tsetup:O Data Output Setup Time 4 thold:O Data Output Hold Time 6 tsetup:I Data Input Setup Time 4 thold:I Data Input Hold Time 0 Note: Test Condition, fSPI_SCK=50MHz. 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 90 Typical 50 50 8.1 9.65 8.3 9.65 - Max 50.5 55 - Track ID: Units MHz % ns ns ns ns ns ns Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 11.4.10. SMI (MDC/MDIO) Interface Characteristics Figure 43. SMI (MDC/MDIO) Timing Symbol t1 t2 t3 t4 t5 t6 t7 Table 63. SMI (MDC/MDIO) Timing Characteristics Description Min Typ 380 MDC Clock Period 190 MDC High Time 190 MDC Low Time 190 MDIO to MDC Rising Setup Time (Write Data) 190 MDIO to MDC Rising Hold Time (Write Data) 10 MDIO to MDC Rising Setup Time (Read Data) 10 MDIO to MDC rising hold time (Read Data) 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 91 Max - Units ns ns ns ns ns ns ns Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 12. Package Information 12.1. LQFP216-E-PAD (24*24mm) 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 92 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 93 Track ID: Rev. 0.7 RTL8380M/RTL8382M/RTL8382L Datasheet 13. Ordering Information Table 64. Ordering Information Part Number Package Status RTL8380M-CG LQFP 216-Pin E-PAD (24*24mm) ‘Green’ Package (Managed) RTL8382M-CG LQFP 216-Pin E-PAD (24*24mm) ‘Green’ Package (Managed) RTL8382L-CG LQFP 216-Pin E-PAD (24*24mm) ‘Green’ Package (Un-Managed) Note: See page 11 (RTL8380M), page 25 (RTL8382M), and page 40 (RTL8382L) for package identification. Realtek Semiconductor Corp. Headquarters No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan, R.O.C. Tel: 886-3-5780211 Fax: 886-3-5776047 www.realtek.com 18-Port & 28-Port & 26-Port 10/100/1000M Switch Controllers 94 Track ID: Rev. 0.7
RTL8382L-VB-CG 价格&库存
很抱歉,暂时无法提供与“RTL8382L-VB-CG”相匹配的价格&库存,您可以联系我们找货
