PESDxL2BT series
Low capacitance double bidirectional ESD protection diodes
in SOT23
Rev. 02 — 25 August 2009
Product data sheet
1. Product profile
1.1 General description
Low capacitance double bidirectional ElectroStatic Discharge (ESD) protection diodes in a
SOT23 small Surface Mounted Device (SMD) plastic package designed to protect two
signal lines from the damage caused by ESD and other transients.
1.2 Features
n
n
n
n
ESD protection of two lines
Max. peak pulse power: PPP = 350 W
Low clamping voltage: VCL = 26 V
Small SMD plastic package
n
n
n
n
Ultra low leakage current: IRM < 90 nA
ESD protection up to 23 kV
IEC 61000-4-2, level 4 (ESD)
IEC 61000-4-5 (surge); IPP = 15 A
1.3 Applications
n Computers and peripherals
n Audio and video equipment
n Cellular handsets and accessories
n Communication systems
n Portable electronics
n Subscriber Identity Module (SIM) card
protection
1.4 Quick reference data
Table 1.
Symbol
Parameter
VRWM
reverse standoff voltage
Cd
Min
Typ
Max
Unit
PESD3V3L2BT
3.3
V
PESD5V0L2BT
5.0
V
PESD12VL2BT
12
V
PESD15VL2BT
15
V
PESD24VL2BT
24
V
PESD3V3L2BT
101
pF
PESD5V0L2BT
75
pF
PESD12VL2BT
19
pF
PESD15VL2BT
16
pF
PESD24VL2BT
11
pF
diode capacitance
Conditions
VR = 0 V;
f = 1 MHz
PESDxL2BT series
Nexperia
Low capacitance double bidirectional ESD protection diodes in SOT23
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode 1
2
cathode 2
3
double cathode
Simplified outline
Symbol
3
1
3
1
2
2
006aaa155
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
PESD3V3L2BT
plastic surface mounted package; 3 leads
SOT23
PESD5V0L2BT
PESD12VL2BT
PESD15VL2BT
PESD24VL2BT
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PESD3V3L2BT
V3*
PESD5V0L2BT
V4*
PESD12VL2BT
V5*
PESD15VL2BT
V6*
PESD24VL2BT
V7*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
PESDXL2BT_SER_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 14
PESDxL2BT series
Nexperia
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Min
Max
Unit
PESD3V3L2BT
350
W
PESD5V0L2BT
350
W
PESD12VL2BT
200
W
PESD15VL2BT
200
W
200
W
PESD3V3L2BT
15
A
PESD5V0L2BT
13
A
PESD12VL2BT
5
A
PESD15VL2BT
5
A
PESD24VL2BT
3
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
PPP
Parameter
Conditions
peak pulse power
tp = 8/20 µs
[1][2]
PESD24VL2BT
peak pulse current
IPP
tp = 8/20 µs
[1][2]
[1]
Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5.
[2]
Measured from pin 1 to 3 or 2 to 3.
Table 6.
Symbol
VESD
ESD maximum ratings
Parameter
electrostatic discharge
voltage
Conditions
IEC 61000-4-2
(contact discharge)
Min
Max
Unit
30
kV
23
kV
10
kV
[1][2]
PESD3V3L2BT
PESD5V0L2BT
PESD12VL2BT
PESD15VL2BT
PESD24VL2BT
PESDxL2BT series
HBM MIL-STD883
[1]
Device stressed with ten non-repetitive ESD pulses.
[2]
Table 7.
ESD standards compliance
ESD Standard
Conditions
> 15 kV (air); > 8 kV (contact)
HBM MIL-STD883, class 3
> 4 kV
PESDXL2BT_SER_2
Product data sheet
3 of 14
PESDxL2BT series
Nexperia
001aaa631
IPP
001aaa630
120
100 %
90 %
100 % IPP; 8 µs
IPP
80
e−t
50 % IPP; 20 µs
40
10 %
30 ns
40
t (µs)
Fig 1.
t
tr = 0.7 ns to 1 ns
60 ns
8/20 µs pulse waveform according to
IEC 61000-4-5
Fig 2.
ESD pulse waveform according to
IEC 61000-4-2
PESDXL2BT_SER_2
Product data sheet
4 of 14
PESDxL2BT series
Nexperia
6. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
VRWM
IRM
VBR
Conditions
Min
Typ
Max
Unit
PESD3V3L2BT
3.3
V
PESD5V0L2BT
5.0
V
PESD12VL2BT
12
V
PESD15VL2BT
15
V
PESD24VL2BT
24
V
reverse leakage current
PESD3V3L2BT
VRWM = 3.3 V
0.09
2
µA
PESD5V0L2BT
VRWM = 5.0 V
0.01
1
µA
PESD12VL2BT
VRWM = 12 V
很抱歉,暂时无法提供与“PESD15VL2BT215”相匹配的价格&库存,您可以联系我们找货
