PT4211E23E
PT4211E23E
    POWTECH(华润矽威)
    SOT23-5
    PT4211E23E
PT4211E23E 数据手册
PT4211 30V 350mA Step-down HB LED Driver GENERAL DESCRIPTION FEATURES The PT4211 is a continuous conduction mode inductive              step-down converter, designed for driving single or multiple series connected LEDs from a voltage source higher than the LED voltage. The device operates from an input supply between 5V and 30V and provides an externally adjustable output current of up to 350mA. The PT4211 includes the output switch and a high-side output current sensing circuit, which uses an external resistor to set the nominal average output current, and a dedicated DIM input accepts a wide range of pulsed dimming. Applying a voltage of 0.4V or lower to the DIM pin turns the output off and switches the device into a low current standby state. Built-in Soft Over Temperature Protection protects the device from over temperature damage. Simple low parts count Wide input voltage range: 5V to 30V Up to 350mA output current PWM dimming 3% output current accuracy. Up to 1MHz switching frequency Typical 3% output current accuracy Inherent open-circuit LED protection High efficiency (up to 93%) Adjustable Constant LED Current High-Side Current Sense Hysteretic Control: No Compensation Soft Over Temperature Protection APPLICATION     Low voltage halogen replacement LEDs Automotive lighting LED back-up lighting Illuminated signs The PT4211 is available in SOT23-5 package. ORDERING INFORMATION TEMPERATURE ORDERING PART TRANSPORT RANGE NUMBER MEDIA SOT23-5 -40 oC 到 85 oC PT4211E23E SOT23-5 -40 oC 到 85 oC PT4211F23E PACKAGE MARKING Tape and Reel 4211 3000 units Tape and Reel 4211 3000 units TYPICAL APPLICATION CIRCUIT RS VIN 0.58Ω DC5-30V LED D 3*1W L=47uH L AC1218V China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, CIN 5 4 100uF VIN CSN PT4211 SW GND 1 2 WWW.CRPOWTECH.COM DIM 3 Page1 PT4211 30V 350mA Step-down HB LED Driver PIN ASSIGNMENT VIN CSN 5 4 4211 PIN DESCRIPTIONS 1 2 3 SW GND DIM ESOP8 PIN No. PIN NAMES DESCRIPTION 1 SW Switch Output. SW is the drain of the internal N-Ch MOSFET switch. 2 GND 3 DIM 4 CSN Current sense input 5 VIN Input Supply Pin. Must be locally bypassed. China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, Signal and power ground. Connect directly to ground plane. Logic level dimming input. Drive DIM low to turn off the current regulator. Drive DIM high to enable the current regulator. WWW.CRPOWTECH.COM Page2 PT4211 30V 350mA Step-down HB LED Driver ABSOLUTE MAXIMUM RATINGS (note1) SYMBOL ITEMS VALUE UNIT VIN Supply Voltage -0.3~40 V SW Drain of the internal power switch -0.3~40 V CSN Current sense input (Respect to VIN) +0.3~(-6.0) V DIM Logic level dimming input -0.3~5.5 V PDMAX Power Dissipation (Note 2) 260 θJA PTR Thermal Resistance, SOT23-5 TJ Operation Junction Temperature Range TSTG Storage Temperature HBM ESD Susceptibility (Note 3) 250 mW o C /W -40 to 150 o -55 to 150 o C C 2 kV VALUE UNIT RECOMMENDED OPERATING RANGE SYMBOL VIN ITEMS VDD Supply Voltage TOPT 0 ~ 30 Operating Temperature -40 to +85 V o C Note 1: Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Recommended Operating Range indicates conditions for which the device is functional, but do not guarantee specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which guarantee specific performance limits. This assumes that the device is within the Operating Range. Specifications are not guaranteed for parameters where no limit is given, however, the typical value is a good indication of device performance. Note 2: The maximum power dissipation must be derated at elevated temperatures and is dictated by TJMAX, θJA, and the ambient temperature TA. The maximum allowable power dissipation is PDMAX = (TJMAX - TA)/ θJA or the number given in Absolute Maximum Ratings, whichever is lower. Note 3: Human body model, 100pF discharged through a 1.5kΩ resistor. China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM Page3 PT4211 30V 350mA Step-down HB LED Driver ELECTRICAL CHARACTERISTICS (Note 4, 5) The following specifications apply for V IN=12V, TA=25 oC, unless specified otherwise. Symbol Parameter Test condition VIN VIN supply voltage FSW Maximum operating frequency VCSN Current sense Reference voltage VCSN_hys Current sense Hysteretic voltage ICSN CSN pin bias current IOFF Min Typ 5 VIN- VCSN 194 200 Max Unit 30 V 1 MHz 206 mV ±15 % VIN-VCSN=50mV 8 µA Off state operating current VDIM 230mV, the output of CS reference remain powered during shutdown to provide comparator switches low and the switch turns off. The the reference for the shutdown circuit. Quiescent supply current flowing on the RS decreases at another rate. current during shutdown is nominally 95uA and switch When (VIN-VCSN) < 170mV, the switch turns on again leakage is below 5uA. and the mean current on the LED is determined by I OUT 0.17  0.23   0.2 / Rs . 2  Rs Additionally, to ensure the reliability, the PT4211 is built with a thermal shutdown (TSD) protection. The TSD protests the IC from over temperature, when The high-side current-sensing scheme and on-board junction temperature more than 135℃ the output current-setting circuitry minimize the number of current begins to decrease until to zero at 150℃. TYPICAL PERFORMANCE CHARACTERISTICS China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM Page5 PT4211 30V 350mA Step-down HB LED Driver Efficiency vs. input voltage L=47uH,ILED=350mA 100.0% DIM pin voltage vs. VIN DIM floating Efficiency vs. Vin L=47uH ILED =350mA Vdim vs Vin DIM Floating 5.00 Vdim 95.0% 4.95 90.0% 4.90 Vdim(V) Eff(%) 85.0% 80.0% 75.0% 4.85 4.80 70.0% 4.75 7 31 .0 29 .0 27 .0 25 .0 23 .0 21 .0 19 .0 17 .0 4.70 15 .0 9. 0 11 .0 7. 0 60.0% 13 .0 1LED 2LEDs 3LEDs 65.0% 9 11 13 15 17 19 21 23 25 27 29 31 Vin(V) Vin(V) VCS vs. Temperature Vin=12V,L=47uH Vdim vs. Temp Vin=12V 4.950 4.940 4.930 4.920 4.910 4.900 4.890 4.880 4.870 4.860 4.850 4.840 4.830 4.820 4.810 4.800 Vcs vs. Temp Vin=12V L=47uH 220.0 Vdim Vcs 200.0 180.0 160.0 140.0 Vcs (mV) Vdim(V) DIM pin voltage vs. temperature Vin=12V 120.0 100.0 80.0 60.0 40.0 20.0 0.0 -40 -20 0 20 40 60 Temp(℃) 80 100 120 -40 0 Rsw vs. temperature Vin=12V/24V 120 124 128 132 136 140 144 148 Temp (C) Rsw vs. Vin 1.1 Vin=12V Vin=24V Rsw 1 1.100 1.000 0.900 0.800 0.9 0.8 Rsw(Ω ) Rsw(Ω ) 80 Rsw vs. VIN Rsw vs Temp 1.400 1.300 1.200 40 0.700 0.600 0.500 0.400 0.300 0.7 0.6 0.5 0.200 0.100 0.000 0.4 0.3 -40 -20 0 20 40 60 80 100 120 China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, 12 18 24 30 Vin(V) Temp(℃) WWW.CRPOWTECH.COM Page6 PT4211 30V 350mA Step-down HB LED Driver Shut down current vs. VIN. VDIM=0 Iout vs. PWM duty cycle. Vin=12V, L=47uH IOFF (mA) vs. Vin IOFF (mA) 0.160 350 0.140 300 0.120 250 I LED(mA) Ioff (mA) I LED vs DIM L=47uH LED=1 Rcs=0.57ohm 400 0.180 0.100 0.080 Fdim=100Hz Fdim=20kHz 200 z 150 0.060 100 0.040 50 0.020 0 0.000 1 3 5 7 9 5 11 13 15 17 19 21 23 25 27 29 15 Vin (V) Iout vs. VIN. L=47uH, Rcs=0.57 ohm 1LED 2LEDs 3LEDs 370 367 361 Duty(%) ILED (mA) 364 358 355 352 349 346 343 340 7 9 11 13 15 17 19 21 Vin(V) 23 25 27 29 9 11 13 15 17 19 21 23 25 27 Vin(V) 95 29 31 I LED vs Vin L=68uH Rcs=0.57ohm 362 1LED 2LEDs 3LEDs 360 358 550 356 500 354 450 I LED(mA) Frequency(kHz) 85 输出电流随 VIN 变化 L=68uH,Rcs=0.57 ohm Frequency vs Vin L=47uH Rcs=0.57ohm 600 75 1LED 2LEDs 3LEDs 7 31 1LED 2LEDs 3LEDs 650 45 55 65 Duty(%) Duty vs Vin L=47uH Rcs=0.57ohm 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 工作频率随 VIN 变化 L=47uH,Rcs=0.57 ohm 700 35 Duty cycle vs. VIN L=47uH, Rcs=0.57 ohm I LED vs Vin L=47uH Rcs=0.57ohm 373 25 400 350 352 350 300 348 250 346 200 344 150 342 340 100 7 9 11 13 15 17 19 21 23 25 27 29 31 7 Vin(V) China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM 9 11 13 15 17 19 21 23 25 27 Vin(V) 29 31 Page7 PT4211 30V 350mA Step-down HB LED Driver L=68uH, Rcs=0.57 ohm Frequency vs. VIN. L=68uH, Rcs=0.57ohm Duty vs Vin L=68uH Rcs=0.57ohm 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 Frequency vs Vin L=68uH Rcs=0.57ohm 550 1LED 2LEDs 3LEDs 1LED 2LEDs 3LEDs 500 450 Frequency(kHz) Duty(%) Dyty cycle vs.VIN. 400 350 300 250 200 150 100 50 0 7 9 11 13 15 17 19 21 Vin(V) 23 25 27 29 31 7 Iout vs. VIN. L=100uH, Rcs=0.57 ohm 9 Duty cycle vs. VIN. 9 29 31 L=100uH, Rcs=0.57 ohm Duty vs Vin L=100uH Rcs=0.57ohm 1LED 2LEDs 3LEDs Duty(%) I LED(mA) I LED vs Vin L=100uH Rcs=0.57ohm 359 357 355 353 351 349 347 345 343 341 339 337 335 7 11 13 15 17 19 21 23 25 27 Vin(V) 11 13 15 17 19 21 23 25 27 29 31 Vin(V) 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 0 1LED 2LEDs 3LEDs 7 9 11 13 15 17 19 21 23 25 27 29 31 Vin(V) Frequency vs. VIN. L=100uH, Rcs=0.57ohm Frequency vs Vin L=100uH Rcs=0.57ohm 500 1LED 2LEDs 3LEDs 450 Frequency (kHz) 400 350 300 250 200 150 100 50 0 7 9 11 13 15 17 19 21 Vin(V) 23 25 China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, 27 29 31 WWW.CRPOWTECH.COM Page8 PT4211 30V 350mA Step-down HB LED Driver Dimming waveform Vin=24V,Fdim=100Hz,Duty=1% Dimming waveform Vin=24V,Fdim=100Hz,Duty=99% L=47uH,Rcs=0.57Ohm L=47uH,Rcs=0.57Ohm CH1:Iout CH2 :DIM pin voltage CH1:Iout CH2:DIM pin voltage Dimming waveform. Vin=24V,Fdim=20KHz,Duty=10% Dimming waveform. Vin=24V,Fdim=20KHz,Duty=90% L=47uH,Rcs=0.57Ohm L=47uH,Rcs=0.57Ohm CH1 :Iout CH2 :DIM pin voltage CH1 :Iout China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM CH2 :DIM pin voltage Page9 PT4211 30V 350mA Step-down HB LED Driver APPLICATION NOTES Setting nominal average output current with external resistor RS The nominal average output current is determined by the value of the external current sense resistor (RS) connected between VIN and CSN and is given by: I OUT  0.2 / Rs ( Rs  0.17) This equation is valid when DIM pin is logic high. Output current adjustment by PWM control A Pulse Width Modulated (PWM) signal with duty cycle PWM can be applied to the DIM pin, as shown below, to adjust the output current to a value below the nominal average value set by resistor RS: I OUT  0.2  D (0  D  100%) Rs RS VIN 0.58Ω LED 1W L 68uH D VIN CSN DIM PT4211 SW GND PWM dimming provides reduced brightness by modulating the LED’s forward current between 0% and 100%. The LED brightness is controlled by adjusting the relative ratios of the on time to the PWM signal cycle time. A 25% brightness level is achieved by turning the LED on at full current for 25% of one cycle. To ensure this switching process between on and off state is invisible by human eyes, the switching frequency must be greater than 100 Hz. Above 100 Hz, the human eyes average the on and off times, seeing only an effective brightness that is proportional to the LED’s on-time duty cycle. The advantage of PWM dimming is that the forward current is constant; therefore the LED color does not vary with brightness as it does with analog dimming. Pulsing the current provides precise brightness control while preserving the color purity. The dimming frequency of PT4211 is China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, depending on the operating frequency. To achieve the best dimming linearity, the dimming frequency is recommended to limited less than 1% of operating frequency. Shutdown mode Taking the DIM pin to a voltage below 0.4V will turn off the output and the supply current will fall to a low standby level of 95μA nominal. Inherent open-circuit LED protection If the connection to the LED(s) is open-circuited, the coil is isolated from the SW pin of the chip, so the device and LED will not be damaged. When the LED(s) load is connected the device will enter normal operation. Capacitor selection A low ESR capacitor should be used for input decoupling, as the ESR of this capacitor appears in series with the supply source impedance and lowers overall efficiency. This capacitor has to supply the relatively high peak current to the coil and smooth the current ripple on the input supply. A minimum value of 4.7uF is acceptable if the DC input source is close to the device, but higher values will improve performance at lower input voltages, especially when the source impedance is high. For the rectified AC input, the capacitor should be higher than 100uF and the tantalum capacitor is recommended. The input capacitor should be placed as close as possible to the IC. For maximum stability over temperature and voltage, capacitors with X7R, X5R, or better dielectric are recommended. Capacitors with Y5V dielectric are not suitable for decoupling in this application and should NOT be used. A suitable Murata capacitor would be GRM42-2X7R475K-50. The following web sites are useful when finding alternatives: www.murata.com www.t-yuden.com www.avxcorp.com Inductor selection Recommended inductor values for the PT4211 are in the range 47uH to 100uH. Higher values of inductance are recommended at lower output current in order to minimize errors due to switching delays, which result in increased ripple and WWW.CRPOWTECH.COM Page10 PT4211 30V 350mA Step-down HB LED Driver lower efficiency. Higher values of inductance also result in a smaller change in output current over the supply voltage range. (See graphs). The inductor should be mounted as close to the device as possible with low resistance connections to the SW and VIN pins. The chosen coil should have a saturation current higher than the peak output current and a continuous current rating above the required mean output current. Following table gives the guideline on inductor selection: Saturation 1LED Vin 2LEDs 5V-10V 47uH 68uH 10V-20V 68uH 68uH 100uH 68uH 20V-30V 3LEDs current 1.3-1.5 47uH times of load 47uH current Suitable coils for use with the PT4211 are listed in the table below: Part L DCR ISAT No. (uH) (Ω) (A) MSS1038-473 47 0.128 2 MSS1038-683 68 0.213 1.6 www.coilcraft.co MSS1038-104 100 0.304 1.3 m Manufacturer CoilCraft The inductor value should be chosen to maintain operating duty cycle and switch 'on'/'off' times within the specified limits over the supply voltage and load current range. The following equations can be used as a guide. SW Switch 'On' time TON  VIN  VLED L  I  I avg  ( Rs  rL  Rsw ) VLED VLED is the total LED forward voltage (V) RSW is the switch resistance (Ω ) {=1Ω nominal} VD is the diode forward voltage at the required load current (V) Diode selection For maximum efficiency and performance, the rectifier (D) should be a fast low capacitance Schottky diode with low reverse leakage at the maximum operating voltage and temperature. They also provide better efficiency than silicon diodes, due to a combination of lower forward voltage and reduced recovery time. It is important to select parts with a peak current rating above the peak coil current and a continuous current rating higher than the maximum output load current. It is very important to consider the reverse leakage of the diode when operating above 85°C. Excess leakage will increase the power dissipation in the device and if close to the load may create a thermal runaway condition. The higher forward voltage and overshoot due to reverse recovery time in silicon diodes will increase the peak voltage on the SW output. If a silicon diode is used, care should be taken to ensure that the total voltage appearing on the SW pin including supply ripple, does not exceed the specified maximum value. The following web sites are useful when finding alternatives: www.onsemi.com Reducing output ripple Peak to peak ripple current in the LED(s) can be reduced, if required, by shunting a capacitor CLED across the LED(s) as shown below: RS VIN SW Switch 'Off' time TOFF  VIN is the supply voltage (V) 0.58Ω LED 1W L  I  VD  I avg  ( Rs  rL) L 68uH D Where: L is the coil inductance (H) VIN CSN DIM PT4211 rL is the coil resistance (Ω ) RS is the current sense resistance (Ω ) SW GND Iavg is the required LED current (A) Δ I is the coil peak-peak ripple current (A) {Internally set to 0.3 x Iavg} China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM Page11 PT4211 30V 350mA Step-down HB LED Driver A value of 1uF will reduce the supply ripple current by a factor three (approx.). Proportionally lower ripple can be achieved with higher capacitor values. Note that the capacitor will not affect operating frequency or efficiency, but it will increase start-up delay and reduce the frequency of dimming, by reducing the rate of rise Operation at low supply voltage With the supply voltage below the output voltage, the switch duty cycle will be high and the device power dissipation will be at a maximum. Care should be taken to avoid operating the device under such conditions in the application, in order to minimize the risk of exceeding the maximum allowed die temperature. Thermal considerations When operating the device at high ambient temperatures, or when driving maximum load, care must be taken to avoid exceeding the package power dissipation limits. Note that the device power dissipation will most often be a maximum at minimum supply voltage. It will also increase if the efficiency of the circuit is low. This may result from the use of unsuitable coils, or excessive parasitic output capacitance on the switch output. Thermal shutdown protection To ensure the reliability, the PT4211 is built with a soft over temperature protection function. When junction temperature excess 135℃ the output current begin to decrease until to zero at 150℃. The soft over temperature function protects the IC and avoid the flicker when operation at high temperature. Layout considerations China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, of LED voltage. By adding this capacitor the current waveform through the LED(s) changes from a triangular ramp to a more sinusoidal version without altering the mean current value. Careful PCB layout is critical to achieve low switching losses and stable operation. Use a multilayer board whenever possible for better noise immunity. Minimize ground noise by connecting high-current ground returns, the input bypass-capacitor ground lead, and the output-filter ground lead to a single point (star ground configuration). SW pin The SW pin of the device is a fast switching node, so PCB tracks should be kept as short as possible. To minimize ground 'bounce', the ground pin of the device should be soldered directly to the ground plane. Coil and decoupling capacitors and current sense resistor It is particularly important to mount the coil and the input decoupling capacitor as close to the device pins as possible to minimize parasitic resistance and inductance, which will degrade efficiency. It is also important to minimize any track resistance in series with current sense resistor RS. It’s best to connect VIN directly to one end of RS and CSN directly to the opposite end of RS with no other currents flowing in these tracks. It is important that the cathode current of the Schottky diode does not flow in a track between RS and VIN as this may give an apparent higher measure of current because of track resistance. WWW.CRPOWTECH.COM Page12 PT4211 30V 350mA Step-down HB LED Driver TYPICAL APPLICATION CIRCUIT RS VIN 0.58Ω DC5-30V D LED 1W L=100uH 5 AC1218V CIN 4 100uF VIN CSN PT4211 SW GND 1 2 DIM 3 Fig1 :1W application RS VIN 0.58Ω DC5-30V D LED 1W L=100uH 5 AC1218V CIN 4 100uF VIN CSN PT4211 SW GND 1 2 DIM 3 Fig 2: 3W application China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, WWW.CRPOWTECH.COM Page13 PT4211 30V 350mA Step-down HB LED Driver PACKAGE INFORMATION SOT23-5 SYMBOL A A1 A2 A3 b b1 c c1 D E E1 e e1 L L1 L2 R R1 θ θ1 θ2 China Resources Powtech (Shanghai) Limited PT4211_DS Rev EN_1.1, MIN 0 1.00 0.60 0.36 0.36 0.14 0.14 2.826 2.60 1.526 0.35 0.10 0.10 0° 3° 6° MILLIMETERS TYP 1.10 0.65 0.38 0.15 2.926 2.80 1.626 0.95BSC 1.90BSC 0.45 0.59REF 0.25BSC 5° 8° WWW.CRPOWTECH.COM MAX 1.25 0.15 1.20 0.70 0.50 0.45 0.20 0.16 3.026 3.00 1.726 0.60 0.25 8° 7° 10° Page14
PT4211E23E 价格&库存
很抱歉,暂时无法提供与“PT4211E23E”相匹配的价格&库存,您可以联系我们找货
