AS72653-BLGM
AS72653-BLGM
    AMSOSRAM(艾迈斯半导体)
    BFLGA20
    AS72653-BLGM
AS72653-BLGM 数据手册
Product Document Published by ams OSRAM Group AS7265x Smart 18-Channel VIS to NIR Spectral_ ID 3-Sensor Chipset with Electronic Shutter General Description The AS7265x chipset consists of three sensor devices AS72651 with master capability, AS72652 and AS72653. The multispectral sensors can be used for spectral identification in a range from visible to NIR. Every of the three sensor devices has 6 independent on-device optical filters whose spectral response is defined in a range from 410nm to 940nm with FWHM of 20nm. The AS72651, combined with the AS72652 (spectral response from 560nm to 940nm) and the AS72653 (spectral response from 410nm to 535nm) form an AS7265x 18-channel multi-spectral sensor chip-set. Using the AS7265x chipset requires the use of firmware. It must be loaded into a serial flash via a UART interface. The list of ams tested serial flash memories can be found in Figure 56. The components AS72651, AS72652 and AS72653 are pre-calibrated with a specific light source. The information about the conditions of the performed calibration (for example light source, gain, integration time) can be found in the table of optical characteristics of the respective component. Any operation other than these conditions might require a new calibration in the application. Each AS7265x device has two integrated LED drivers with programmable current and can be timed for electronic shutter applications. The device family integrates Gaussian filters into standard CMOS silicon via nano-optic deposited interference filter technology in LGA packages that also provide built-in apertures to control the light entering the sensor array. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS7265x, Smart 18-Channel VIS to NIR Spectral_ID 3-Sensor Chipset with Electronic Shutter are listed below: ams Datasheet [v1-04] 2018-Jul-09 Page 1 Document Feedback AS7265x − General Description Figure 1: AS7265x Chip-Set Benefits and Features Benefits Features • 3 chip set including master device delivering 18 visible and NIR channels from 410nm to 940nm each with 20nm FWHM • Compact 18-channel spectrometry chip-set solution • UART or I²C slave digital Interface • Visible filter set realized by silicon interference filters • 16-bit ADC with digital access • No additional signal conditioning required • Programmable LED drivers • 2.7V to 3.6V with I²C interface • Small, robust package, with built-in aperture • 20-pin LGA package 4.5mm x 4.7mm x 2.5mm -40°C to 85°C temperature range Applications The AS7265x applications include: • Product/Brand authentication • Anti-counterfeiting • Portable spectroscopy • Product safety/adulteration detection • Horticultural and specialty lighting • Material analysis Page 2 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − General Description Block Diagram The functional blocks of this device are shown below: Figure 2: AS7265x Chip-Set Block Diagram VDD2 VDD1 AS72651 Communication Spectral_ID Sensor VDD VDD LED Drivers LED_IND I2C_ENB Micro Controller Unit (MCU) RX / SCL_S TX / SDA_S UART or I2C Slave INT Current Control R S T U V W VDD Firmware Interface SDA_M SCL_M LED_DRV I2C Master VDD °C MISO OSC 16MHz SLV1_RESN SLV2_RESN RESN SPI Master Serial Flash Memory MOSI SCK CSN GND VDD2 VDD1 VDD2 VDD1 AS72652 AS72653 Spectral_ID Sensor Spectral_ID Sensor Communication Communication LED Drivers VDD LED Drivers VDD VDD VDD LED_IND SCL_S I2C Slave SDA_S RESN G H I J K L Current Control LED_IND SCL_S LED_DRV SDA_S I2C Slave A B C D E F °C °C OSC 16MHz OSC 16MHz RESN GND Current Control LED_DRV GND Note(s): 1. Refer to the Application Diagram in Figure 60. ams Datasheet [v1-04] 2018-Jul-09 Page 3 Document Feedback AS7265x − Pin Assignments Pin Assignments The device pin assignments are described below. Figure 3: Pin Diagram of AS7265x (Top View) 20 16 1 15 5 11 6 10 Figure 4: AS72651 Pin Description Pin No. Pin Name 1 SLV1_RESN 2 Pin Type Description Digital Input and Output Reset pin for Slave 1 e.g. AS72652, active low RESN Digital Input Reset pin, active low (with internal pull-up to VDD) 3 SCK Digital Output SPI serial clock 4 MOSI Digital Input and Output SPI MOSI 5 MISO Digital Input and Output SPI MISO 6 CSN Digital Output Chip select for external flash 7 NC 8 I2C_ENB 9 10 Not functional, no connect Digital Input Selects UART (low) or I²C (high) operation SCL_M Digital Output I²C master clock for communication with AS72652 and AS72653 SDA_M Digital Input and Output I²C master data for communication with AS72652 and AS72653 Page 4 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Pin Assignments Pin No. Pin Name Pin Type Description 11 RX / SCL_S Digital Input and Output RX (UART) or SCL_S (I²C slave) depending on I2C_ENB setting 12 TX / SDA_S Digital Input and Output TX (UART) or SDA_S (I²C slave) depending on I2C_ENB setting 13 INT Digital Output INT is active low 14 VDD2 Voltage Supply Voltage supply 15 LED_DRV Analog Output LED driver output for driver LED, current sink 16 GND Supply Ground 17 VDD1 Voltage Supply Voltage supply 18 LED_IND Analog Output LED driver output for indicator LED, current sink 19 NC 20 SLV2_RESN Not functional, no connect Digital Output Reset pin for slave 2 e.g. AS72653, active low Note(s): 1. Pin out is valid for firmware versions from 11 and later. Figure 5: AS72652 and AS72653 Pin Description Pin No. Pin Name 1 NC 2 RESN 3 NC Not functional, no connect 4 NC Not functional, no connect 5 NC Not functional, no connect 6 NC Not functional, no connect 7 NC Not functional, no connect 8 NC Not functional, no connect 9 SCL_S Digital Input and Output I²C slave clock for communication with master AS72651 10 SDA_S Digital Input and Output I²C slave data for communication with master AS72651 ams Datasheet [v1-04] 2018-Jul-09 Pin Type Description Not functional, no connect Digital Input Reset pin, active low (with internal pull-up to VDD) Page 5 Document Feedback AS7265x − Pin Assignments Pin No. Pin Name 11 NC Not functional, no connect 12 NC Not functional, no connect 13 INT Digital Output INT is active low 14 VDD2 Voltage Supply Voltage supply 15 LED_DRV Analog Output LED driver output for driver LED, current sink 16 GND Supply Ground 17 VDD1 Voltage Supply Voltage supply 18 LED_IND Analog Output LED driver output for indicator LED, current sink 19 NC Not functional, no connect 20 NC Not functional, no connect Page 6 Document Feedback Pin Type Description ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings of AS7265x may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. The device is not designed for high energy UV (ultraviolet) environments, including upward looking outdoor applications, which could affect long term optical performance. Figure 6: Absolute Maximum Ratings of AS7265x Symbol Parameter Min Max Unit Comments Electrical Parameters VDD1_MAX Supply Voltage VDD1 -0.3 5 V Pin VDD1 to GND VDD2_MAX Supply Voltage VDD2 -0.3 5 V Pin VDD2 to GND Input/Output Pin Voltage -0.3 VDD+0.3 V Input/Output Pin to GND VDD_IO ISCR Input Current (latch-up immunity) ± 100 mA JESD78D Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ±1000 V JS-001-2014 ESDCDM Electrostatic Discharge CDM ±500 V JESD22-C101F Temperature Ranges and Storage Conditions TSTRG Storage Temperature Range TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level ams Datasheet [v1-04] 2018-Jul-09 -40 85 5 3 °C 260 °C 85 % IPC/JEDEC J-STD-020. The reflow peak soldering temperature (body temperature) is specified according IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices” Represents a 168 hour max. floor lifetime Page 7 Document Feedback AS7265x − Electrical Characteristics Electrical Characteristics All limits are guaranteed with VDD = VDD1 = VDD2 = 3.3V, T AMB = 25°C. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. VDD1 and VDD2 should be sourced from the same power supply output. Figure 7: Electrical Characteristics of AS7265x Symbol Parameter Conditions Min Typ Max Unit General Operating Conditions VDD1 /VDD2 Voltage Operating Supply UART Interface 2.97 3.3 3.6 V VDD1 /VDD2 Voltage Operating Supply I²C Interface 2.7 3.3 3.6 V -40 25 85 °C 5 mA 16.3 MHz 1.2 ns -8.5 8.5 °C 1 8 mA -30 30 % 0.3 VDD V TAMB Operating Temperature IVDD Operating Current Internal RC Oscillator FOSC tJITTER(1) Internal RC Oscillator Frequency Internal Clock Jitter 15.7 @25°C 16 Temperature Sensor DTEMP Absolute Accuracy of the Internal Temperature Measurement Indicator LED IIND LED Current IACC Accuracy of Current VLED Voltage Range of Connected LED Vds of current sink LED_DRV ILED1 LED Current 12.5 100 mA IACC Accuracy of Current -10 10 % VLED Voltage Range of Connected LED 0.3 VDD V Page 8 Document Feedback Vds of current sink ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit -1 1 μA Digital Inputs and Outputs IIH, IIL Logic Input Current Vin=0V or VDD VIH CMOS Logic High Input 0.7* VDD VDD V VIL CMOS Logic Low Input 0 0.3* VDD V VOH CMOS Logic High Output I=1mA VDD0.4 V VOL CMOS Logic Low Output I=1mA 0.4 V tRISE(1) Current Rise Time C(Pad)=30pF 5 ns tFALL(1) Current Fall Time C(Pad)=30pF 5 ns Note(s): 1. Guaranteed by design, not tested in production. ams Datasheet [v1-04] 2018-Jul-09 Page 9 Document Feedback AS7265x − Electrical Characteristics Timing Characteristics Figure 8: AS7265x I²C Slave Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 400 kHz I²C Interface fSCLK SCL Clock Frequency tBUF Bus Free Time Between a STOP and START 1.3 μs Hold Time (Repeated) START 0.6 μs tLOW LOW Period of SCL Clock 1.3 μs tHIGH HIGH Period of SCL Clock 0.6 μs tSU:STA Setup Time for a Repeated START 0.6 μs tHS:DAT Data Hold Time 0 tSU:DAT Data Setup Time 100 tR Rise Time of Both SDA and SCL 20 300 ns tF Fall Time of Both SDA and SCL 20 300 ns tSU:STO Setup Time for STOP Condition 0.6 tHS:STA CB Capacitive Load for Each Bus Line CI/O I/O Capacitance (SDA, SCL) Page 10 Document Feedback 0 CB - total capacitance of one bus line in pF 0.9 μs ns μs 400 pF 10 pF ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Electrical Characteristics Figure 9: I²C Slave Timing Diagram tR tF tLOW SCL P tHIGH S tHD:STA S tSU:DAT tHD:DAT P t SU:STA tSU:STO VIH SDA tBUF Stop VIL Start Figure 10: AS72651 SPI Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 16 MHz SPI Interface fSCK Clock Frequency 0 tSCK_H Clock High Time 40 ns tSCK_L Clock Low Time 40 ns tSCK_RISE SCK Rise Time 5 ns tSCK_FALL SCK Fall Time 5 ns tCSN_S CSN Setup Time Time between CSN high-low transition to first SCK high transition 50 ns tCSN_H CSN Hold Time Time between last SCK falling edge and CSN low-high transition 100 ns tCSN_DIS CSN Disable Time 100 ns tDO_S Data-Out Setup Time 5 ns tDO_H Data-Out Hold Time 5 ns tDI_V Data-In Valid 10 ns ams Datasheet [v1-04] 2018-Jul-09 Page 11 Document Feedback AS7265x − Electrical Characteristics Figure 11: SPI Master Write Timing Diagram t CS N_DIS CSN tSCK_RISE tCSN_S tCSN_H tSCK_FALL SCK t DO_S MOSI tDO_H MSB LSB HI-Z HI-Z MISO Figure 12: SPI Master Read Timing Diagram CSN_xx tSCK_H tSCK_L SCK tDI_V Dont care MOSI MISO Page 12 Document Feedback MSB LSB ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Typical Operating Characteristics Typical Operating Characteristics Optical Characteristics All optical characteristics are optimized for diffused light. When using a point light source or collimated light on the sensor, the sensor opening must be covered by a lambertian diffuser with achromatic characteristics. Diffusor of Tsujiden like D121UP have been successfully tested at ams. If in the application diffused light, e.g. used by a reflective surface, no additional diffuser is required. Figure 13: AS7265x LGA Average Field of View Diffused Light A=0.75mm β = 20.5° 20 5° 5 Lens Sensor ns sor H=2.5mm α = 12° DIE E LGA Package Substrate Figure 14: AS7265x 18-Channel Spectral Responsivity 18 Channel Spectral Response AS72651 + AS72652 + AS72653 410nm 1 435nm 0.9 460nm 485nm 0.8 Normalized Responsivity 510nm 535nm 0.7 560nm 0.6 585nm 610nm 0.5 645nm 680nm 0.4 705nm 0.3 730nm 760nm 0.2 810nm 860nm 0.1 900nm 0 350 372 394 416 438 460 482 504 526 548 570 592 614 636 658 680 702 724 746 768 790 812 834 856 878 900 922 944 966 988 940nm A B C D E F G H R I S J T U V W K L Wavelength (λ, nm) ams Datasheet [v1-04] 2018-Jul-09 Page 13 Document Feedback AS7265x − Typical Operating Characteristics Figure 15: AS72651 Spectral Responsivity AS72651, 6-Channel Spectral Response 1.2 R 610 S 680 T U 730 760 V 810 W 860 Normalized Responsivity 1 0.8 0.6 0.4 0.2 350 370 390 410 430 450 470 490 510 530 550 570 590 610 630 650 670 690 710 730 750 770 790 810 830 850 870 890 910 930 950 970 990 0 Wavelength (λ, nm) Figure 16: Optical Characteristics of AS72651 (Pass Band) (1) Symbol Parameter Test Conditions Channel (nm) Min Typ Max Unit R Channel R Incandescent(2),(4) 610 35(3),(4) counts/ (μW/cm2) S Channel S Incandescent(2),(4) 680 35(3),(4) counts/ (μW/cm2) T Channel T Incandescent(2),(4) 730 35(3),(4) counts/ (μW/cm2) U Channel U Incandescent(2),(4) 760 35(3),(4) counts/ (μW/cm2) V Channel V Incandescent(2),(4) 810 35(3),(4) counts/ (μW/cm2) W Channel W Incandescent(2),(4) 860 35(3),(4) counts/ (μW/cm2) 20 nm FWHM Wacc Full Width Half Max Wavelength Accuracy Page 14 Document Feedback +10 -10 nm ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Typical Operating Characteristics Symbol Parameter dark Dark Channel Counts AFOV Average Field of View Test Conditions Channel (nm) Min Typ Max Unit 5 counts GAIN=64, TAMB=25°C tint=165ms ±20.5 deg Note(s): 1. Calibration and measurements are made using diffused light. 2. Each channel is tested with GAIN = 16x, Integration Time (INT_T) = 166ms and VDD = VDD1 = VDD2 = 3.3V, TAMB =25°C. 3. The accuracy of the channel counts/μW/cm 2 is ±12%. 4. The light source is an incandescent light with an irradiance of ~1500μW/cm2 (300-1000nm). Figure 17: AS72652 Spectral Responsivity AS72652, 6-Channel Spectral Response (w/AS72651 as Controller) 1.2 G H 560 585 I 645 J 705 K 900 L 940 Normalized Responsivity 1 0.8 0.6 0.4 0.2 350 368 386 404 422 440 458 476 494 512 530 548 566 584 602 620 638 656 674 692 710 728 746 764 782 800 818 836 854 872 890 908 926 944 962 980 998 0 Wavelength (λ, nm) ams Datasheet [v1-04] 2018-Jul-09 Page 15 Document Feedback AS7265x − Typical Operating Characteristics Figure 18: Optical Characteristics of AS72652 (Pass Band) (1) Symbol Parameter Conditions Channel (nm) Min Typ Max Unit G Channel G 3300K White LED(2) 560 35(3) counts/ (μW/cm2) H Channel H 3300K White LED(2) 585 35(3) counts/ (μW/cm2) I Channel I 3300K White LED(2) 645 35(3) counts/ (μW/cm2) J Channel J 3300K White LED(2) 705 35(3) counts/ (μW/cm2) K Channel K Incandescent(2) 900 35(3) counts/ (μW/cm2) L Channel L 940nm LED(2) 940 35(3) counts/ (μW/cm2) FWHM Full Width Half Max 20 nm Wacc Wavelength Accuracy dark Dark Channel Counts AFOV Average Field of View -10 GAIN=64, TAMB=25°C tint = 165ms +10 nm 5 counts ±20.5 deg Note(s): 1. Calibration and measurements are made using diffused light. 2. Each channel is tested with GAIN = 16x, Integration Time (INT_T) = 166ms and VDD = VDD1 = VDD2 = 3.3V, TAMB =25°C. 3. The accuracy of the channel counts/μW/cm 2 is ±12%. Page 16 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Typical Operating Characteristics Figure 19: AS72653 Spectral Responsivity AS72653, 6-Channel Spectral Response (w/AS72651 as controller) Normalized Responsivity 1.2 D E B C F A 410 435 460 485 510 535 1 0.8 0.6 0.4 0.2 350 368 386 404 422 440 458 476 494 512 530 548 566 584 602 620 638 656 674 692 710 728 746 764 782 800 818 836 854 872 890 908 926 944 962 980 998 0 Wavelength (λ, nm) ams Datasheet [v1-04] 2018-Jul-09 Page 17 Document Feedback AS7265x − Typical Operating Characteristics Figure 20: Optical Characteristics of AS72653 (Pass Band)(1) Conditions Channel (nm) Symbol Parameter A Channel A 410 35(3) counts/ (μW/cm2) B Channel B 435 35(3) counts/ (μW/cm2) C Channel C 460 35(3) counts/ (μW/cm2) D Channel D 485 35(3) counts/ (μW/cm2) E Channel E 510 35(3) counts/ (μW/cm2) F Channel F 535 35(3) counts/ (μW/cm2) FWHM Full Width Half Max 20 nm Wacc Wavelength Accuracy dark Dark Channel Counts AFOV Average Field of View LED:(2) 395nm 415nm 428nm 5600K white Min Typ -10 GAIN=64, TAMB=25°C tint = 165ms Max Unit +10 nm 5 counts ±20.5 deg Note(s): 1. Calibration and measurements are made using diffused light. 2. Each channel is tested with GAIN = 16x, Integration Time (INT_T) = 166ms and VDD = VDD1 = VDD2 = 3.3V, TAMB =25°C. 3. The accuracy of the channel counts/μW/cm 2 is ±12%. Page 18 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Detailed Description AS7265x 18-Channel Spectral_ID Detector Overview Each of the three AS7265x Spectral_ID devices are next-generation digital 6-channel spectral sensor devices. Each of the 6 channels has a Gaussian filter characteristic with a full width half maximum (FWHM) bandwidth of 20nm. The filters use an interference topology design providing high stability in terms of drift in time and temperature. The drifts are so small that it is undetectable in the measurement. The temperature drift of the device is largely determined by the drift of the sensor and the electronics. To compensate for the temperature drift in the application, every device of the AS7265x chipset includes an integrated temperature sensor. Filter accuracy will be affected by the angle of incidence which itself is limited by integrated aperture and internal micro-lens structure. The aperture-limited average field of view is ±20.5° to deliver specified accuracy. All optical characteristics are optimized for using diffused light. Each device contains an analog-to-digital converter (16-bit resolution ADC) which integrates the current from each channel’s photodiode. Upon completion of the conversion cycle, the integrated result is transferred to the corresponding data registers. The transfers are double-buffered to ensure data integrity is maintained. The external MCU interface control via I²C registers or AT commands, transparently controls the AS72652 and/or AS72653. A serial flash is a required operating companion for this device and enables factory calibration/normalization of the filters. Supported device types are noted in Ordering & Contact Information at the end of this document. Required operating code can be downloaded at download.ams.com. Channel Data Conversion of the AS7265x Devices All three of these 6 channel devices use conversion implemented via two photodiode banks in each device. Refer to Figure 21and Figure 22. Bank 1 consists of register data from 4 of the 6 photodiodes, with 2 registers zeroed and Bank 2 consists of data from a different set of 4 of the 6 photodiodes, with 2 different registers zeroed. Spectral conversion requires the integration time (IT in ms) set to complete. If both photodiode banks are required to complete the conversion, the 2 nd bank requires an additional IT ms. Minimum IT for a single bank conversion is 2.8 ms. If data is required from all 6 photodiodes then the device must perform 2 full conversions (2 x Integration Time). ams Datasheet [v1-04] 2018-Jul-09 Page 19 Document Feedback AS7265x − Detailed Description This spectral data conversion process operates continuously, new data is available after each IT ms period. The conversion process is controlled with BANK Mode settings in the AS72651 as follows: BANK Mode 0 Registers: AS72651 data will be in S, T, U & V registers (R & W will be zero) AS72652 data will be in G, H, K & I registers (J & L will be zero) AS72653 data will be in A, B, E & C registers (D & F will be zero) BANK Mode 1 Registers: AS72651 data will be in R, T, U & W registers (S & V will be zero) AS72652 data will be in G, H, J & L registers (I & K will be zero) AS72653 data will be in F, A, B & D registers (C & E will be zero) BANK Mode 2 Registers: AS72651 data will be in S, T, U, V, R & W registers AS72652 data will be in G, H, K, I, J & L registers AS72653 data will be in A, B, C, D, E & F registers For BANK Mode 2, care should be taken to assure prompt interrupt servicing so integration values from both banks are all derived from the same spectral conversion cycle. Figure 21: AS7265x Photo Diode Arrays AS72651 Photo Diode Array AS72652 Photo Diode Array AS72653 Photo Diode Array T U S G H I A B C R V W J K L D E F Page 20 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Figure 22: Bank Mode and Data Conversion BANK Mode 0 One Conversion S, T, U, V, I, G, H, K, C, A, B, E Integration Time BANK Mode 1 One Conversion R, T, U, W, L, G, H, J, F, A, B, D Integration Time BANK Mode 2 1st Conversion S, T, U, V, I, G, H, K, C, A, B, E 2nd Conversion Integration Time R, T, U, W, L, G, H, J, F, A, B, D Integration Time RC Oscillator The timing generation circuit consists of on-chip 16MHz, temperature compensated oscillators, which provide the individual master clocks of the AS7625x devices Temperature Sensor The AS7265x internal temperature sensors are constantly measuring on-chip temperature to enable temperature compensation procedures, and can be read via I²C registers or AT commands in the AS72651. ams Datasheet [v1-04] 2018-Jul-09 Page 21 Document Feedback AS7265x − Detailed Description Reset Pulling down the RESN pin for longer than 100ms resets the AS72651 which proceed to reset the AS72562 and the same RESN signal shown below can be used directly to reset the AS72653. Figure 23: Reset Circuit VDD Spectral_ID Engine Reset AS72651 RESN Push > 100ms AS7265x LED_IND Controls There are LED_IND pins on all AS7265x devices. An LED connected to LED_IND can be used as a general power indicator and will automatically be used to indicate a Flash firmware update is occurring. The LED_IND can then be setup as needed. Each AS7265x LED_ IND source can be turned on/off via AT commands or I²C register control, and LED_IND sink current is programmable to 1mA, 2mA, 4mA or 8mA. This LED_IND control can also be used in applications just like the LED_DRV control (described below), if the lower current sink of the LED_IND control is appropriate. Electronic Shutter with AS7265x LED_DRV Driver Control There are LED_DRV pins on all AS7265x devices. The LED_DRV pin can be used to control external LED sources as needed for sensor applications. LED_DRV can sink a programmable current of 12.5mA, 25mA, 50mA or 100mA. The control can be turned on/off via I²C registers or AT commands, and as such it provides the AS7265x device with an electronic shutter. Interrupt Operation Interrupt operation is only needed for AS72651 as it transparently controls data collection from the AS72652 (if used) or AS72653 (if used). Page 22 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description If BANK is set in the AS72651 to Mode 0 or Mode 1, data is ready after the 1 st integration time. If BANK is set to Mode 2, data is ready after two integration times. For interrupt operation using I²C registers, if interrupts are enabled and data is ready, the INT pin is set low and DATA_RDY is set to 1. Reading the raw or calibration data releases (returns high) the interrupt. For multi-byte sensor data (2 or 4 bytes), after the 1st byte is read the remaining bytes are shadow protected in case an integration cycle completes just after the 1st byte is read. The sensors continue to gather information at the rate of the integration time, hence if the sensor registers are not read when the interrupt line goes low, it will stay low and the next cycle’s sensor data will be available in the registers at the end of the next integration cycle. For interrupt operation using AT Commands, if interrupts are enabled and data is ready the INT pin is set low and is released (returns high) after any sensor data is read. Required Flash Memory Serial flash is a required operating companion for this device, and enables the I²C and UART interfaces, as well as enabling calibrated data results. Supported device types are noted in Ordering & Contact Information at the end of this document. Required operating code can be downloaded at download.ams.com. I²C Slave Interface If selected by the I2C_ENB pin setting, interface and control can be accomplished through an I²C compatible slave interface to a set of registers that provide access to device control functions and output data. These registers on the AS72651 are, in reality, implemented as virtual registers in software. The actual I²C slave hardware registers number only three and are described in the table below. The steps necessary to access the virtual registers defined in the following are explained in pseudocode for external I²C master writes and reads below. I²C Feature List • Fast mode (400kHz). • 7+1-bit addressing mode. • Write format: Byte. • Read format: Byte. • SDA input delay and SCL spike filtering by integrated RC-components. ams Datasheet [v1-04] 2018-Jul-09 Page 23 Document Feedback AS7265x − Detailed Description Figure 24: I²C Slave Device Address and Physical Registers Entity Description Note 8-bit slave address Byte = 1001001x (device address = 49 hex) • x= 1 for Master Read (byte = 93 hex) • x= 0 for Master Write (byte = 92 hex) I²C slave interface STATUS register. Read-only. Register Address = 0x00 Bit 1: TX_VALID • 0 - New data may be written to WRITE register • 1 -WRITE register occupied. Do NOT write. Bit 0: RX_VALID • 0 -No data is ready to be read in READ register. • 1 -Data byte available in READ register. WRITE Register I²C slave interface WRITE register. Write-only. Register Address = 0x01 • 8-Bits of data written by the I²C Master intended for receipt by the I²C slave. Used for both virtual register addresses and write data. READ Register I²C slave interface READ register. Read-only. Register Address = 0x02 • 8-Bits of data to be read by the I²C Master. Device Slave Address STATUS Register I²C Virtual Register Write Access I²C Virtual Resister Byte Write, detailed below, shows the pseudocode necessary to write virtual registers on the AS72651. Note that, because the actual registers of interest are realized as virtual registers, a means of indicating whether there is a pending read or write operation of a given virtual register is needed. To convey this information, the most significant bit of the virtual register address is used as a marker. If it is 1, then a write is pending, otherwise the slave is expecting a virtual read operation. The pseudocode illustrates the proper technique for polling of the I²C slave status register to ensure the slave is ready for each transaction. Page 24 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description I²C Virtual Register Byte Write Pseudocode Poll I²C slave STATUS register; If TX_VALID bit is 0, a write can be performed on the interface; Send a virtual register address and set the MSB of the register address to 1 to indicate the pending write; Poll I²C slave STATUS register; If TX_VALID bit is 0, the virtual register address for the write has been received and the data may now be written; Write the data. Sample Code: #define I2C_AS72XX_SLAVE_STATUS_REG 0x00 #define I2C_AS72XX_SLAVE_WRITE_REG 0x01 #define I2C_AS72XX_SLAVE_READ_REG 0x02 #define I2C_AS72XX_SLAVE_TX_VALID 0x02 #define I2C_AS72XX_SLAVE_RX_VALID 0x01 void i2cm_AS72xx_write(uint8_t virtualReg, uint8_t d) { volatile uint8_tstatus; while (1) { // Read slave I²C status to see if the write buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG); if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write now. break ; } // Send the virtual register address (enabling bit 7 to indicate a write). i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, (virtualReg | 0x80)) ; while (1) { // Read the slave I²C status to see if the write buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG) ; if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write data now. break ; } // Send the data to complete the operation. i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, d) ; } I²C Virtual Register Read access ams Datasheet [v1-04] 2018-Jul-09 Page 25 Document Feedback AS7265x − Detailed Description I²C Virtual Register Byte Read, detailed below, shows the pseudocode necessary to read virtual registers on the AS72651. Note that in this case, reading a virtual register, the register address is not modified. I²C Virtual Register Byte Read Pseudocode Poll I²C slave STATUS register; If TX_VALID bit is 0, the virtual register address for the read may be written; Send a virtual register address; Poll I²C slave STATUS register; If RX_VALID bit is 1, the read data is ready; Read the data. Sample Code uint8_t i2cm_AS72xx_read(uint8_t virtualReg) { volatile uint8_t status, d; while (1) { // Read slave I²C status to see if the read buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG) ; if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write now. break; } // Send the virtual register address (disabling bit 7 to indicate a read). i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, virtualReg); while (1) { // Read the slave I²C status to see if our read data is available. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG); if ((status & I2C_AS72XX_SLAVE_RX_VALID)!= 0) // Read data is ready. break; } // Read the data to complete the operation. d = i2cm_read(I2C_AS72XX_SLAVE_READ_REG) ; return d;s } The details of the i2cm_read() and i2cm_write() functions in previous figures are dependent upon the nature and implementation of the external I²C master device. Page 26 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description 4-Byte Floating-Point (FP) Registers Several 4 byte registers (hex) are used by the AS72651. Here is an example of how these registers are used to represent floating point data (based on the IEEE 754 standard). Figure 25: Example of the IEEE 754 Standard byte 3 byte 2 byte 1 byte 0 3E (hex) 20 (hex) 00 (hex) 00 (hex) 0 0 1 1 1 1 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 24 23 16 15 8 7 0 31 sign exponent (8 bits) fraction (23 bits) 0 0 1 1 1 1 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 = 0.15625 31 30 23 22 0 The floating point (FP) value assumed by 32 bit binary32 data with a biased exponent e (the 8 bit unsigned integer) and a 23 bit fraction is (for the above example): (EQ1) FPvalue = ( – 1 ) sign 23   –i ( e – 127 )  ⋅ 1 +  b 23 – i ⋅ 2  ⋅ 2     i–1 23   0 –i ( 124 – 127 ) FPvalue = ( – 1 ) ⋅  1 +  b 23 – i ⋅ 2  ⋅ 2     i–1 –2 –3 FPvalue = 1 ⋅ ( 1 + 2 ) ⋅ 2 = 0.15625 ams Datasheet [v1-04] 2018-Jul-09 Page 27 Document Feedback AS7265x − Detailed Description I²C Virtual Register Set The figure below provides a summary of the AS72651 I²C register set for the AS72651 which serves as the master interface of the 3 device AS7265x set. Figures after that provide additional register details. All register data is hex, and all multi-byte entities are Big Endian (most significant byte is situated at the lowest register address). Multiple byte registers (2 byte integer, or, 4 byte floating point) must be read in the order of ascending register addresses (low to high) and if capable of being written to, must also be written in the order ascending register addresses. Figure 26: AS72651 I²C Master Device Virtual Register Set Overview Addr Name 0x00 HW Version H HW Version 0x01 HW Version L 0x02 FW Version H FW Version 0x03 FW Version L 0x04 Configuration 0x05 Integration Time Integration Time 0x06 Temperature Temperature 0x07 LED Configuration 0x08 RAW value R, G, A RAW value H 0x09 RAW value R, G, A RAW value L 0x0A RAW value S, H, B RAW value H 0x0B RAW value S, H, B RAW value L 0x0C RAW value T, I, C RAW value H 0x0D RAW value T, I, C RAW value L 0x0E RAW value U, J, D RAW value H 0x0F RAW value U, J, D RAW value L 0x10 RAW value V, K, E RAW value H 0x11 RAW value V, K, E RAW value L 0x12 RAW value W, L, F RAW value H 0x13 RAW value W, L, F RAW value L Page 28 Document Feedback SRST READ_ ERR INT LED_ DRV GAIN BANK ENABLELED _DRV DATA_RDY FRST LED_INT ENABL E LED_ INT ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Addr Name 0x14 Calibrated value channel R, G, A CAL CHAN0_0 0x15 Calibrated value channel R, G, A CAL CHAN0_1 0x16 Calibrated value channel R, G, A CAL CHAN0_2 0x17 Calibrated value channel R, G, A CAL CHAN0_3 0x18 Calibrated value channel S, H, B CAL CHAN0_0 0x19 Calibrated value channel S, H, B CAL CHAN0_1 0x1A Calibrated value channel S, H, B CAL CHAN0_2 0x1B Calibrated value channel S, H, B CAL CHAN0_3 0x1C Calibrated value channel T, I, C CAL CHAN0_0 0x1D Calibrated value channel T, I, C CAL CHAN0_1 0x1E Calibrated value channel T, I, C CAL CHAN0_2 0x1F Calibrated value channel T, I, C CAL CHAN0_3 0x20 Calibrated value channel U, J, D CAL CHAN0_0 0x21 Calibrated value channel U, J, D CAL CHAN0_1 0x22 Calibrated value channel U, J, D CAL CHAN0_2 0x23 Calibrated value channel U, J, D CAL CHAN0_3 0x24 Calibrated value channel V, K, E CAL CHAN0_0 0x25 Calibrated value channel V, K, E CAL CHAN0_1 0x26 Calibrated value channel V, K, E CAL CHAN0_2 ams Datasheet [v1-04] 2018-Jul-09 Page 29 Document Feedback AS7265x − Detailed Description Addr Name 0x27 Calibrated value channel V, K, E CAL CHAN0_3 0x28 Calibrated value channel W, L, F CAL CHAN0_0 0x29 Calibrated value channel W, L, F CAL CHAN0_1 0x2A Calibrated value channel W, L, F CAL CHAN0_2 0x2B Calibrated value channel W, L, F CAL CHAN0_3 0x48 FW control 0x49 FW byte count FW_BYTE_COUNT_H 0x4A FW byte count FW_BYTE_COUNT_L 0x4B FW payload HW version H 0x4F DEV SEL 0x50 COEF DATA COEF_DATA_0 0x51 COEF DATA COEF_DATA_1 0x52 COEF DATA COEF_DATA_2 0x53 COEF DATA COEF_DATA_3 0x54 COEF READ COEF_READ 0x55 COEF WRITE COEF_WRITE Page 30 Document Feedback START STOP BYTES_ TRANSF ERRED Second Slave LOCK SWITC H First Slave BANK1 ERROR CHKSU M SELECT DATA ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Detailed Register Descriptions Figure 27: HW Version Registers Addr: 0x00,0x01 HW Version Bit Bit Name Default Access Bit Description 15:8 HW version H 0x40 R Device type 7:0 HW version L 0x41 R HW version Figure 28: FW Version Registers Addr: 0x02,0x03 FW Version Bit Bit Name Default Access 15:8 FW version H 0 R/W 7:0 FW version L 0 R/W Bit Description Set register 0x02, 0x03 to 0x01 to 0x03 to get each firmware positions high byte 0x01: MAJOR version [15..8] 0x02: PATCH version [15..8] 0x03: BUILD version [15..8] Figure 29: Configuration Register Addr: 0x04 Configuration Bit Bit Name Default Access Bit Description 7:0 SRST 0 W 6 INT 0 R/W Enable interrupt pin 5:4 GAIN 01 R/W Gain configuration: b00=1x; b01=3.7x; b10=16x; b11=64x Measurement mode: b00=Mode 0: 4 channels b01=Mode 1: 4 channels b10=Mode 2: All 6 channels b11=Mode 3: One-Shot operation of mode 2 [W] software reset [R] gain error 3:2 BANK 10 R/W 1 DATA_RDY 0 R Data ready to read 0 FRST 0 W Factory reset ams Datasheet [v1-04] 2018-Jul-09 Page 31 Document Feedback AS7265x − Detailed Description The maximum sensitivity value depends on the integration time. For every 2.78ms of integration time, the maximum sensitivity value increases by 1024 counts. This means that to be able to reach the full sensitivity scale, the sensitivity has to be at least 64*2.78ms. Figure 30: Integration Time Register Addr: 0x05 Bit Bit Name Integration Time Default Access Bit Description Integration time = * 2.8ms (applies to all channels); value: 1-255;Return 0 - read error 7:0 INTEGRATION_ TIME 20 R/W Value Integration Cycles Integration Time Maximum ADC Value 0x00 1 2.78ms 1023 0x01 2 5.56ms 2047 ... ... ... ... 0x11 18 50ms 18431 0x40 65 181ms 65535 ... ... ... ... 0xFF 256 711ms 65535 Figure 31: Temperature Register Addr: 0x06 Bit 7:0 Bit Name Temperature Page 32 Document Feedback Temperature Default - Access Bit Description R Temperature of the device in °C Read value from every device in dependency of register DEV_SEL From -127 to 127 Return -128: Means error ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Figure 32: LED Configuration Register Addr: 0x07 LED Configuration Bit Bit Name Default Access Bit Description 7 READ_ERR 0 R 5:4 LED_DRV 00 R/W LED_DRV current limit: b00=12.5mA; b01=25mA; b10=50mA; b11=100mA Device depends on register DEV_SEL 3 ENABLE LED_ DRV 0 R/W Enable LED DRV Device depends on register DEV_SEL 2:1 LED_INT 01 R/W Current limit: b00=1mA; b01=2mA; b10=4mA; b11=8mA Device depends on register DEV_SEL 0 ENABLE LED_ INT 0 R/W Enable LED IND Device depends on register DEV_SEL Error while reading status Figure 33: RAW Value Channel R,G,A Register Addr: 0x08,0x09 RAW Value Channel R,G,A Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Bit Description Channel R or J or D depends on register DEV_SEL Figure 34: RAW Value Channel S,H,B Register Addr: 0x0A,0x0B RAW Value Channel S,H,B Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Bit Description Channel S or I or C depends on register DEV_SEL ams Datasheet [v1-04] 2018-Jul-09 Page 33 Document Feedback AS7265x − Detailed Description Figure 35: RAW Value Channel T,I,C Register Addr: 0x0C/0x0D RAW Value Channel T,I,C Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Bit Description Channel T or G or A depends on register DEV_ SEL Figure 36: RAW Value Channel U,J,D Register Addr: 0x0E,0x0F RAW Value Channel U,J,D Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Bit Description Channel U or H or B depends on register DEV_ SEL Figure 37: RAW Value Channel V,K,E Register Addr: 0x10,0x011 RAW Value Channel V,K,E Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Bit Description Channel V or K or E depends on register DEV_SEL Figure 38: RAW Value Channel W,L,F Register Addr: 0x12,0x013 RAW Value Channel W,L,F Bit Bit Name Default Access 15:8 RAW value H - R 7:0 Raw value L - R Page 34 Document Feedback Bit Description Channel W or L or F depends on register DEV_ SEL ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Figure 39: Calibrated Value Channel R,G,A Register Addr: 0x17,0x016,0x15,0x014 Calibrated Value Channel R,G,A Bit Bit Name Default Access 31:24 CAL CHAN0_3 FF R 23:16 CAL CHAN0_2 FF R 15:8 CAL CHAN0_1 FF R 7:0 CAL CHAN0_0 FF R Bit Description Channel R or J or D depends on register DEV_ SEL Figure 40: Calibrated Value Channel S, H, B Register Addr: 0x1B,0x01A,0x19,0x018 Calibrated Value Channel S,H,B Bit Bit Name Default Access 31:24 CAL CHAN1_3 FF R 23:16 CAL CHAN1_2 FF R 15:8 CAL CHAN1_1 FF R 7:0 CAL CHAN1_0 FF R Bit Description Channel S or I or C depends on register DEV_ SEL Figure 41: Calibrated Value Channel T, I, C Register Addr: 0x1F,0x01E,0x1D,0x01C Calibrated Value Channel T,I,C Bit Bit Name Default Access 31:24 CAL CHAN2_3 FF R 23:16 CAL CHAN2_2 FF R 15:8 CAL CHAN2_1 FF R 7:0 CAL CHAN2_0 FF R ams Datasheet [v1-04] 2018-Jul-09 Bit Description Channel T or G or A depends on register DEV_ SEL Page 35 Document Feedback AS7265x − Detailed Description Figure 42: Calibrated Value Channel U, J, D Register Addr: 0x23,0x022,0x21,0x20 Calibrated Value Channel U,J,D Bit Bit Name Default Access 31:24 CAL CHAN3_3 FF R 23:16 CAL CHAN3_2 FF R 15:8 CAL CHAN3_1 FF R 7:0 CAL CHAN3_0 FF R Bit Description Channel U or H or B depends on register DEV_ SEL Figure 43: Calibrated Value Channel V, K, E Register Addr: 0x27,0x026,0x25,0x24 Calibrated Value Channel V,K,E Bit Bit Name Default Access 31:24 CAL CHAN4_3 FF R 23:16 CAL CHAN4_2 FF R 15:8 CAL CHAN4_1 FF R 7:0 CAL CHAN4_0 FF R Bit Description Channel V or K or E depends on register DEV_ SEL Figure 44: Calibrated Value Channel W, L, F Register Addr: 0x2B,0x02A,0x29,0x28 Calibrated Value Channel W,L,F Bit Bit Name Default Access 31:24 CAL CHAN5_3 FF R 23:16 CAL CHAN5_2 FF R 15:8 CAL CHAN5_1 FF R 7:0 CAL CHAN5_0 FF R Page 36 Document Feedback Bit Description Channel W or L or F depends on register DEV_ SEL ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Figure 45: FW Control Register Addr: 0x48 FW Control Bit Bit Name Default Access Bit Description 7 START R/W 6 STOP W Reset firmware update state machine 5 BYTES_ TRANSFERRED R All 56kbytes are transferred 4 LOCK R/W 3 SWITCH W Switch between both firmware 2 BANK1 R Set if bank 1 is active, else bank 2 1 ERROR R Error occurred while firmware update 0 CHKSUM R Checksum of other bank is valid Set bit once to configure the device update Lock this firmware for the next start Figure 46: FW Byte Count Register Addr: 0x49,0x4A FW Byte Count Bit Bit Name Default Access 15:8 FW_BYTE_ COUNT_H 0 R 7:0 FW_BYTE_ COUNT_L Bit Description Byte counter of transferred image R Figure 47: FW Payload Register Addr:0x4B FW Payload Bit Bit Name Default Access 7:0 HW version H 0 R/W ams Datasheet [v1-04] 2018-Jul-09 Bit Description Transfer of firmware byte Page 37 Document Feedback AS7265x − Detailed Description Figure 48: DEV SEL Register Addr: 0x4F DEV SEL Bit Bit Name Default Access Bit Description 5 SECOND SLAVE 0 R Second slave Available 5 FIRST SLAVE 0 R First slave available 1:0 SELECT DATA 00 R/W 0x00: Select master data 0x01: Select first slave data 0x02: Select second slave data Figure 49: COEF DATA Register Addr: 0x53,0x52,0x51,0x50 COEF DATA Bit Bit Name Default Access 31:24 COEF_DATA_ 3 R/W 23:16 COEF_DATA_ 2 R/W 15:8 COEF_DATA_ 1 R/W 7:0 COEF_DATA_ 0 R/W Bit Description Data heap to read and write calibration data Figure 50: COEF READ Register Addr:0x54 Bit Bit Name 7:0 COEF_READ Page 38 Document Feedback COEF READ Default Access R/W Bit Description Set sub addresses to read different calibration data from COEF_DATA register ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Figure 51: COEF WRITE Register Addr:0x55 Bit Bit Name 7:0 COEF_WRITE COEF WRITE Default Access R/W Bit Description Set sub addresses to write different calibration data from COEF_DATA register to persistent memory AS72651 I 2 C Firmware (FW) Update Procedure • In the FW Update Control register set the Start_XFR bit to 1. • Write 56k of data to the FW Download register starting with the first byte in the ams file, then proceed the end of the ams 56k file with consecutive writes. • If desired read the FW Byte Count registers to see which byte is expected to be written next into the FW Download register. • When the download file is completely written, confirm the action by using the FW Update Control register bit XFR_ 56k (should =1 if 56k has been downloaded). • In the FW Update Control register, set the Toggle bit to 1 which will reboot the AS72651 with the new FW after checking the new FW for correct CRC. If the CRC is incorrect the toggle bit will not change and the new FW will not be used. Figure 52: Firmware Byte Count High Byte Addr: 0x60/0xE0 Control_Setup Bit Bit Name Default Access 7 Start_XFR 0 R/W Set to 1 to start firmware update 6 Kill_XFR 0 R/W Set to 1 to stop firmware update. 5 XFR_56K 0 R 4 Reserved 3 Toggle 2:0 Reserved ams Datasheet [v1-04] 2018-Jul-09 Bit Description Set to 1 when 56k bytes have been downloaded. Reserved, do not use. 0 R/W Set to 1 to toggle firmware image partition. Reserved, do not use. Page 39 Document Feedback AS7265x − Detailed Description Figure 53: Firmware Byte Count, High Byte Register Addr: 0x61/0xE1 Bit Bit Name 7:0 FWBC_HIGH Firmware Byte Count, High Byte Default Access Bit Description R Firmware byte address to be downloaded next, High Byte Figure 54: Firmware Byte Count, Low Byte Register Addr: 0x62/0xE2 Bit Bit Name 7:0 FWBC_LOW Firmware Byte Count, Low Byte Default Access R Bit Description Firmware byte address to be downloaded next, Low Byte Figure 55: Firmware Download Register Addr: 0x63/0xE3 Bit Bit Name 7:0 FWLOAD Page 40 Document Feedback Firmware Download Default Access R/W Bit Description Firmware byte to be downloaded ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description UART Command Interface If selected by the I2C_ENB pin setting, the UART module implements the TX and RX signals as defined in the RS-232 / V.24 standard communication protocol. Serial flash EPROM is a required operating companion device to enable the UART command interface. Figure 56: Flash Memory Overview Serial Flash Manufacturer AT25SF041xx Adesto Technologies AT25DF041xx Adesto Technologies MX25L4006ExxI-12G Macronix SST25PF040C Microchip Technology W25X40CLSNIG Winbond Electronics LE25U40CMD ON Semiconductor Note(s): 1. Where xx= alternative packages. UART Feature List • Full duplex operation (independent serial receive and transmit registers). • Factory set to 115.2k Baud • Supports serial frames with 8 Data Bits, no Parity and 1 Stop Bit. Operation Transmission If data is available in the transmit FIFO, it will be moved into the output shift register and the data will be transmitted at the configured Baud Rate, starting with a Start Bit (logic zero) and followed by a Stop Bit (logic one). Reception At any time, with the receiver being idle, if a falling edge of a start bit is detected on the input, a byte will be received and stored in the receive FIFO. The following Stop Bit will be checked to be logic one. ams Datasheet [v1-04] 2018-Jul-09 Page 41 Document Feedback AS7265x − Detailed Description Figure 57: UART Protocol Data Bits TX D0 D1 Start Bit D2 D3 D4 D5 D6 D7 Stop Bit Tbit=1/Baude Rate Always Low RX D0 Next Start Always High D0 D1 D2 D3 D4 D5 D6 D7 D0 Start Bit detected After Tbit/2: Sampling of Start Bit After Tbit: Sampling of Data Sample Points AT Command Interface The microprocessor interface to control the AS72651 Spectral_ ID sensor(s) is via AT Commands across the UART interface. The AS72651 provides a text-based serial command interface borrowed from the “AT Command” model used in early Hayes modems. For example: Read DATA value: ATDATA → OK Set the gain of the sensor to 1x: ATGAIN=0→ OK The AT Command Interface, shown below provides access to the Spectral_ID engine’s control and configuration functions. Figure 58: AT Command Interface Block Diagram RX MCU AT Commands TX AT Command Interface Spectral_ID Engine AT Command Interface AS72651 Page 42 Document Feedback ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description In the AT Commands figure below, numeric values may be specified with no leading prefix, in which case they will be interpreted as decimals, or with a leading “0x” to indicate that they are hexadecimal numbers. The commands are loosely grouped into functional areas. Texts appearing between angle brackets (‘‘) are commands or response arguments. A carriage return character, a linefeed character, or both may terminate commands and responses. Note that any command that encounters an error will generate the “ERROR” response shown, for example, in the NOP command at the top of the first table, but has been omitted elsewhere in the interest of readability and clarity. Note(s): The Figure 59 shows the complete list of all AS7265x AT commands. Figure 59: AS7265x AT Commands Commands Direction Description Format Value Range Default - - - Status AT R ATVERSW R Return the current software version number DEC ATVERHW R Returns the system hardware as a HEX value of the form PRDTx where P=PartID and R=ChipRevision and DT= DeviceType HEX PR = 40 DT = 15 ATTEMP R Read the current device temperature in degrees Celsius DEC Send three temperature values (Format: A, B, C) - ATDATA R Read all six raw vales per device( - R Read all six calibrated values per device. Returns commaseparated 32-bit floating point values. DEC < R, S, T, U, V, W, G, H, I, J, K, L, A, B, C, D, E, F> - ATCDATA ams Datasheet [v1-04] 2018-Jul-09 NOP - 0x4041 Page 43 Document Feedback AS7265x − Detailed Description Commands Direction Description Format Value Range Default Control ATINTTIME R/W Set sensor integration time. Integration time = * ~2.8ms. ATGAIN R/W Set sensor gain: 0=1x gain, 1=3.7x, 2=16x, 3=64x DEC 0-3 1 ATINTRP R/W Enable/Disable interrupt pin DEC 0 - Disable 1 - Enable Interrupt pin functionality 0 2 1 ATTCSMD ATINTRVL Page 44 Document Feedback DEC 1-255 20 R/W Set measurement mode DEC 0: Captures bank0 (1 integration period) 1: Captures bank1 (1 integration period) 2: Captures bank0+ bank1(2 integration period) 3:Captures bank0+ bank1 in one shot mode (2 integration period) R/W Set the sampling interval as an integer multiple of the integration time. The is an integer between [1...255]. A sampling interval=1 implies a sampling rate of 1x the current integration time. A sampling interval=255 implies a slow sampling rate of 255 times the current integration time DEC 1…255 ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Commands ATBURST Direction R/W Description Format Value Range Default Sends a number of calibrated data without separate requests second parameter for the burst mode is optionally format: Send: ATBURST=10,0 or ATBURST=10 Read: ATBURST ≥ 10,0 OK DEC BURST NUMBER: 0 - Burst mode is deactivated 1-254 - Number of burst transfers 255 - Send unlimited bursts (stops with ATBURST=0) 0 BURST MODE: 0 - Raw values (default, like ATDATA) 1 - Calibrated values (like ATCDATA) ATLED0 R/W Enables or disables the indication LED DEC 0 - LED off 1 - LED on 1 ATLED1 R/W Enables or disables the driver LED DEC 0 - LED off 1 - LED on 0 ATLED2 R/W Enables or disables the indication LED for first I2C slave DEC 0 - LED off 1 - LED on 1 ATLED3 R/W Enables or disables the driver LED for first I2C slave DEC 0 - LED off 1 - LED on 0 ATLED4 R/W Enables or disables the indication LED for second I2C slave DEC 0 - LED off 1 - LED on 1 R/W Enables or disables the driver LED for second I2C slave DEC 0 - LED off 1 - LED on 0 HEX [1...0] LED_IND: b00=1mA; b01=2mA; b10=4mA; b11=8mA [5...4] LED_DRV: b00=12.5mA; b01=25mA; b10=50mA; b11=100mA ATLED5 ATLEDC ams Datasheet [v1-04] 2018-Jul-09 R/W Sets LED_IND and LED_DRV current (for master only) 0x00 Page 45 Document Feedback AS7265x − Detailed Description Commands Format Value Range Default HEX [1...0] LED_IND: b00=1mA; b01=2mA; b10=4mA; b11=8mA [5...4] LED_DRV: b00=12.5mA; b01=25mA; b10=50mA; b11=100mA 0x00 R/W Sets LED_IND and LED_DRV current for second I2C slave HEX [1...0] LED_IND: b00=1mA; b01=2mA; b10=4mA; b11=8mA [5...4] LED_DRV: b00=12.5mA; b01=25mA; b10=50mA; b11=100mA 0x00 ATFRST W Factory Reset. Stored values are reset to ‘Factory’ defaults. Afterwards a software reset is started. - - - ATSRST W Software reset - - - ATLEDD ATLEDE Direction R/W Description Sets LED_IND and LED_DRV current for first I2C slave Calibration Values ATSCLx R/W Read/Write scalar for the raw values (x=0...17) p2ram value DEC Firmware Update ATFWU ATFW Page 46 Document Feedback W Starts firmware update process and transfer the bin file checksum - - - W Download new firmware. Up to 7 bytes of FW image at a time (14 hex bytes with no leading or trailing 0x). Repeat command till all 56kBytes of firmware are downloaded - HEX STRING (without 0x), max. 7 bytes - ams Datasheet [v1-04] 2018-Jul-09 AS7265x − Detailed Description Commands ATFWS ATFWL ATFWC ATFWA ams Datasheet [v1-04] 2018-Jul-09 Direction Description Format Value Range Default W Tests the checksum on the non-active FW partition and, if correct, switches active partition. This is a toggle and used to toggle between the 2 FW partitions. Note: The first 5 bytes in page 0 are not touched. It is only a temporary switch and must be used to check the new firmware whether the communication works! - - - W This command locks the current firmware to starts on power cycles. It rewrites the first five bytes in page0! - - - R This command gives information about the current firmware state - Bit0 - Checksum of non-active firmware OK Bit1 - Error occurred Bit2 - Bank 1 active Bit3 - Not used Bit4 - Current firmware is locked Bit5 - 56kBytes transferred Bit6 - Not used Bit7 - Firmware update active - W Only for backward compatibility to support old firmware, update mechanism. Always returns with OK. Because of flash devices, it is not possible to increment the address separately (page erase necessary!) - - - Page 47 Document Feedback AS7265x − Application Information Application Information Figure 60: Typical AS7265x 18-Channel Application Circuit 3V3 U3 +5V 3V3 D9 LED 17 C7 100nF C8 1u0 14 RESN TP9 R10 10k GND 2 RESN 16 R11 200R D11 3V3 CSN VDD2 MISO RESN MOSI GND SCK AS72651 GND LED_651 15 LED_IND 18 I2C_ENB LED_DRV LED_IND NC GRN SLV2_RESN ---> COMM_RX 11
AS72653-BLGM 价格&库存
很抱歉,暂时无法提供与“AS72653-BLGM”相匹配的价格&库存,您可以联系我们找货
AS72653-BLGM
    • 500+46.26783500+5.61204
