nRF52820
Bluetooth 5.3 SoC supporting Bluetooth Low Energy, Bluetooth
mesh, Thread and Zigbee, qualified for up to 105°C.
Overview
The nRF52820 System-on-Chip (SoC) is the 6th addition to the industry-leading nRF52® Series. It augments the already extensive collection of wireless
SoCs with a lower-end option with built-in USB and a fully-featured multiprotocol radio. The nRF52 Series is truly the ideal platform for basing a product
portfolio upon. The common hardware and software architecture results in
excellent software portability, increasing software reusability and lowering
time-to-market and development cost.
The nRF52820 features an Arm® Cortex®-M4 processor, clocked at 64 MHz. It
has 256 KB Flash and 32 KB RAM, and a range of analog and digital interfaces such as an analog comparator, SPI, UART, TWI, QDEC, and last but not
least, USB. It can be supplied with a voltage from 1.7 to 5.5 V which enables
powering the device from sources such as rechargeable batteries or via USB.
The nRF52820 supports Bluetooth 5.3, in addition to the Direction Finding,
high-throughput 2 Mbps and Long Range features. It also capable of Bluetooth mesh, Thread and Zigbee mesh protocols.
For human interface device (HID) applications the built-in USB and +8 dBm
TX power make the nRF52820 a great single-chip option, while asset tracking
applications can leverage its Bluetooth Direction Finding capabilities. The extended temperature range of -40 to +105 °C makes it suitable for professional
lighting applications.
nRF52805
nRF52810
nRF52811
nRF52820
nRF52832
nRF52833
nRF52840
nRF5340
The built-in USB, fully-featured multiprotocol radio and +8 dBm output power
makes it the perfect network processor to be paired with an application MCU
in gateways and other smart home, commercial and industrial applications
requiring advanced wireless connectivity.
Bluetooth 5.3
X
X
X
X
X
X
X
X
Bluetooth
2 Mpbs
X
X
X
X
X
X
X
X
Bluetooth
Long Range
X
X
X
X
X
Bluetooth
Direction
Finding
X
X
X
Matter
1.7-5.5 V supply voltage range
Applications
Professional lighting
Industrial
Human Interface device
Wearables
Gaming
Smart home
Gateways
Asset tracking and RTLS
X
X
Bluetooth mesh
Zigbee
Arm processor
y 64 MHz Arm® Cortex-M4 with FPU
y 256 KB Flash + 32 KB RAM
Bluetooth 5.3 Radio
y Direction Finding
y Long Range
y Bluetooth mesh
y +8 dBm TX power
y -95 dBm sensitivity (1 Mbps)
IEEE 802.15.4 radio support
y Thread
y Zigbee
Full range of digital interfaces with
EasyDMA
y Full-speed USB 2.0
y 32 MHz high-speed SPI
128 bit AES/ECB/CCM/AAR accelerator
105 °C extended operating temperature
X
Bluetooth
LE Audio
Thread
Key features
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
For more information please visit: nordicsemi.com/nRF52820
nRF52820 SoC Product Brief Version 1.2
nRF52820 SoC
Specification
256 KB Flash
64 MHz Arm®
Cortex®-M4
32 KB RAM
Multiprotocol
2.4 GHz radio
Debug
AES
ACL
2×12C
System peripherals
4×TIMER
2×RTC
TEMP
WDT
QDEC
RNG
2×12C
Digital, analog I/F and GPIO
UART
2×SPI/TWI
HS-SPI
GPIOTE
USB
COMP
QDEC
18-GPIO crossbar
AHB / APB / EasyDMA / PPI
Security
Oscillators
32 MHz RC/XO
32 kHz RC/XO
Power supply
Two stage LDO
Buck DC/DC
POR
Microprocessor
CPU
Memory
Performance
Efficiency
Hardware security
128-bit AES CCM, ECB, AAR
Wireless protocol
support
Bluetooth Low Energy/Bluetooth mesh/
Thread/Zigbee/802.15.4/ANT/2.4 GHz proprietary
On-air data rate
Bluetooth LE:
802.15.4:
TX power
Programmable from +8 to -20 dBm in 4 dB
steps
RX sensitivity
Bluetooth LE:
802.15.4:
Radio current
consumption
DC/DC at 3 V
+8 dBm TX power
+4 dBm TX power
0 dBm TX power,
RX at 1 Mbps
Oscillators
64 MHz from 32 MHz external crystal or internal 32 kHz from crystal, RC or synthesized
System current
consumption
DC/DC at 3 V
0.6 μA in System OFF
1.1 μA in System OFF
2.6 μA in System ON, full RAM retention and
RTC
Digital interfaces
USB 2.0
1x UART
2xSPI/TWI
QDEC
Analog interfaces
General-purpose comparator
Other peripherals
4 x 32 bit timer/counter
2 x 24 bit real-time counter
PPI
GPIOTE
Temperature sensor
Watchdog timer
Random Number generator
Temperature range
-40°C to 105°C
Supply voltage
1.7 to 5.5 V
Package options
5x5 mm QFN40 with 18 GPIOs
2.5x2.5 mm WLCSP with 18 GPIOs
BOR
VBUS 3.3 V REG
Built-in USB for communication, DFU and power supply
The nRF52820’s USB peripheral implements a Full Speed USB
2.0 device that offers a widely-used interface that enables
low-latency and high-bandwidth communication with a range
of hosts, such as PCs, tablets, smartphones, and gateways. It
also adds the option of performing device firmware updates
(DFU) over USB.
When connected to a USB host, the nRF52820 can be directly
powered by the always-present 5 V VBUS signal. Nordic
provides a reference layout for this configuration. In addition
to the main supply regulators, the USB peripheral in the
nRF52820 integrates a dedicated regulator for converting the
5 V VBUS signal to the 3.3 V needed for supplying the USB
signaling interface, removing the cost and space for an external regulator.
nRF Connect SDK
The nRF Connect SDK is our software development kit for
the nRF52820 SoC. It supports development of Bluetooth
Low Energy, Thread and Zigbee applications. It integrates
the Zephyr RTOS, protocol stacks, samples, hardware drivers
and much more.
Our nRF Connect SDK also supports the nRF9160, our
LTE-M/NB-IoT/GPS SiP, and the nRF53 Series. It is a common
platform for both cellular IoT and short-range development.
nRF52833 DK
The nRF52833 DK is the affordable development kit for
the nRF52820 SoC. The nRF52833 has a superset of the
nRF52820’s features. The DK has everything needed for
development on a single board. All features and GPIOs of
the SoC are made available to the developer, and it comes
with an on-board SEGGER J-Link debugger enabling both
programming and debugging of the nRF52833. The kit is
compatible with the Arduino Uno Rev3 standard, has access
to all I/Os (42) and interfaces via connectors, and there is
an integrated PCB trace antenna and an RF connector for
direct RF test measurements.
64 MHz Arm Cortex-M4
144 CoreMark
39 CoreMark/mA
6x6 mm
2 Mbps/1 Mbps/125 kbps
250 kbps
-103 dBm at 125 kbps
-95 dBm at 1 Mbps
-89 dBm at 2 Mbps
-99 dBm at 250 kbps
14.40 mA
9.40 mA
6 mA at
4.7 mA
2.5 mm x 2.5 mm
Related Products
nRF52833 DK
Development kit for the nRF52820 SoC
nRF Connect SDK
Software development kit for the nRF52820
The nRF52820 SoC and the nRF52833 DK are available for
purchase through our distribution network.
很抱歉,暂时无法提供与“NRF52820-QDAA-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+32.929911+4.25999
- 10+28.4595610+3.68168
- 25+26.8985625+3.47974
- 100+24.75529100+3.20248
- 250+23.46860250+3.03603
- 500+22.56010500+2.91850
- 1000+21.703581000+2.80769
- 国内价格 香港价格
- 4000+18.802204000+2.43236
