2717
2717
    ADAFRUIT
    TCA9548A I2C MULTIPLEXER BOARD
2717 数据手册
Adafruit TCA9548A 1-to-8 I2C Multiplexer Breakout Created by lady ada https://learn.adafruit.com/adafruit-tca9548a-1-to-8-i2c-multiplexer-breakout Last updated on 2022-10-19 09:17:49 AM EDT ©Adafruit Industries Page 1 of 22 Table of Contents Overview 3 Pinouts 5 • Power Pins: • I2C Control-Side pins: • I2C Multiplexed-Side pins: Assembly 6 • Prepare the header strip: • Add the breakout board: • And Solder! Arduino Wiring & Test 9 • Example Multiplexing • Multiple Multplexers CircuitPython & Python • • • • • • • 14 CircuitPython Microcontroller Wiring Python Computer Wiring Python Installation of TCA9548A Library CircuitPython Usage Python Usage Simple Test Example Code Multi-Sensor Example Code Downloads 20 • Datasheets • Schematic • Fabrication Print ©Adafruit Industries Page 2 of 22 Overview You just found the perfect I2C sensor, and you want to wire up two or three or more of them to your Arduino when you realize "Uh oh, this chip has a fixed I2C address, and from what I know about I2C, you cannot have two devices with the same address on the same SDA/SCL pins!" Are you out of luck? You would be, if you didn't have this ultra-cool TCA9548A 1-to-8 I2C multiplexer! ©Adafruit Industries Page 3 of 22 Finally, a way to get up to 8 same-address I2C devices hooked up to one microcontroller - this multiplexer acts as a gatekeeper, shuttling the commands to the selected set of I2C pins with your command. Using it is fairly straight-forward: the multiplexer itself is on I2C address 0x70 (but can be adjusted from 0x70 to 0x77) and you simply write a single byte with the desired multiplexed output number to that port, and bam - any future I2C packets will get sent to that port. In theory, you could have 8 of these multiplexers on each of 0x70-0x77 addresses in order to control 64 of the same-I2C-addressed-part. ©Adafruit Industries Page 4 of 22 Like all Adafruit breakouts, we put this nice chip on a breakout for you so you can use it on a breadboard with capacitors, and pullups and pulldowns to make usage a snap. Some header is required and once soldered in you can plug it into a solderlessbreadboard. The chip itself is 1.8V - 5V compliant so you can use it with any logic level. We even wrote up a nice tutorial with wiring diagrams, schematics and examples to get you running in 10 minutes! (https://adafru.it/jhC) Pinouts Power Pins: • Vin - this is the power pin. Since the sensor chip uses 3-5 VDC. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V • GND - common ground for power and logic I2C Control-Side pins: • SCL - this is the I2C clock pin for the chip itself, connect to your microcontrollers I2C clock line. • SDA - this is the I2C data pin for the chip itself, connect to your microcontrollers I2C data line. ©Adafruit Industries Page 5 of 22 • RST - this is the reset pin, for resetting the multiplexer chip. Pulled high by default, connect to ground to reset • A0 A1 A2 - these are the address selection pins for the multiplexer. By default the multiplexer is at address 0x70 and these three pins are pulled low. Connect them to Vin to set the address to 0x71 - 0x77. • A0 is the lowest-significant bit (if it is pulled high, it will increase the address by 1). • A1 is the 2nd-lowest-significant bit (if it is pulled high, it will increase the address by 2). • A2 is the 3rd-lowest-significant bit (if it is pulled high, it will increase the address by 4). I2C Multiplexed-Side pins: • SDx and SCx:  There are 8 sets of SDx and SCx pins, from SD0/SC0 to SD7/SC7. These are the multiplexed pins. Each one is a completely seperate I2C bus set. So you can have 8 I2C devices with identical addresses, as long as they are on one I2C bus each. These pins do not have any pullups installed, so if you are using a chip or breakout without i2c pullups be sure to add them! Nicely, you can have Vin be 3.3V and have these pins pulled up to 5V (that is, they are 5V compliant) Assembly ©Adafruit Industries Page 6 of 22 Prepare the header strip: Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down Add the breakout board: Place the breakout board over the pins so that the short pins poke through the breakout pads ©Adafruit Industries Page 7 of 22 And Solder! Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https:// adafru.it/aTk)). ©Adafruit Industries Page 8 of 22 You're done! Check your solder joints visually and continue onto the next steps Arduino Wiring & Test The TCA9548A multiplexer is interesting in that it has an I2C address (0x70 by default) - and you basically send it a command to tell it which I2C multiplexed output you want to talk to, then you can address the board you want to address. We suggest using this little helper to help you select the port ©Adafruit Industries Page 9 of 22 #define TCAADDR 0x70 void tcaselect(uint8_t i) { if (i > 7) return; Wire.beginTransmission(TCAADDR); Wire.write(1 << i); Wire.endTransmission(); } You can then call tcaselect(0) thru tcaselect(7) to set up the multiplexer. Note that you if you happen to have I2C devices with I2C address 0x70, you will need to short one of the Addr pins on the TCA9548 breakout to Vin in order to make it not conflict. Given that you can have 0x70 thru 0x77, just find one that's free and you're good to go! Example Multiplexing For example, say we want to talk to two HMC5883 breakouts. These magnetometers have a fixed address of 0x1E so you cannot have two on one I2C bus. Wire up the TCA9548 breakout so that: • Vin is connected to 5V (on a 3V logic Arduino/microcontroller, use 3.3V) • GND to ground • SCL to I2C clock • SDA to I2C data Then wire up each of the other sensor breakouts to Vin, Ground and use one of the S Cn / SDn multiplexed buses: ©Adafruit Industries Page 10 of 22 On an Arduino, which is what we're using, we suggest running this handy scanner script which will tell you what the breakout detected /** * TCA9548 I2CScanner.ino -- I2C bus scanner for Arduino * * Based on https://playground.arduino.cc/Main/I2cScanner/ * */ #include "Wire.h" #define TCAADDR 0x70 void tcaselect(uint8_t i) { if (i > 7) return; Wire.beginTransmission(TCAADDR); Wire.write(1 << i); Wire.endTransmission(); } // standard Arduino setup() void setup() { while (!Serial); delay(1000); Wire.begin(); Serial.begin(115200); Serial.println("\nTCAScanner ready!"); for (uint8_t t=0; t<8; t++) { tcaselect(t); Serial.print("TCA Port #"); Serial.println(t); for (uint8_t addr = 0; addr<=127; addr++) { if (addr == TCAADDR) continue; ©Adafruit Industries Page 11 of 22 Wire.beginTransmission(addr); if (!Wire.endTransmission()) { Serial.print("Found I2C 0x"); } Serial.println(addr,HEX); } } Serial.println("\ndone"); } void loop() { } For example, running it on the above setup will give you: Next up you will have to adjust whatever code you have to select the correct multiplexed port! Make sure before you query from the sensor that you call tcaselect to get the right one #include <Wire.h> #include <Adafruit_Sensor.h> #include <Adafruit_HMC5883_U.h> #define TCAADDR 0x70 /* Assign a unique ID to this sensor at the same time */ Adafruit_HMC5883_Unified mag1 = Adafruit_HMC5883_Unified(1); Adafruit_HMC5883_Unified mag2 = Adafruit_HMC5883_Unified(2); void displaySensorDetails(Adafruit_HMC5883_Unified *mag) { sensor_t sensor; mag->getSensor(&sensor); ©Adafruit Industries Page 12 of 22 Serial.println("------------------------------------"); Serial.print ("Sensor: "); Serial.println(sensor.name); Serial.print ("Driver Ver: "); Serial.println(sensor.version); Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id); Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT"); Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT"); Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT"); Serial.println("------------------------------------"); Serial.println(""); delay(500); } void tcaselect(uint8_t i) { if (i > 7) return; Wire.beginTransmission(TCAADDR); Wire.write(1 << i); Wire.endTransmission(); } void setup(void) { Serial.begin(9600); Serial.println("HMC5883 Magnetometer Test"); Serial.println(""); /* Initialise the 1st sensor */ tcaselect(2); if(!mag1.begin()) { /* There was a problem detecting the HMC5883 ... check your connections */ Serial.println("Ooops, no HMC5883 detected ... Check your wiring!"); while(1); } /* Initialise the 2nd sensor */ tcaselect(6); if(!mag2.begin()) { /* There was a problem detecting the HMC5883 ... check your connections */ Serial.println("Ooops, no HMC5883 detected ... Check your wiring!"); while(1); } /* Display some basic information on this sensor */ tcaselect(2); displaySensorDetails(&mag1); tcaselect(6); displaySensorDetails(&mag2); } void loop(void) { /* Get a new sensor event */ sensors_event_t event; tcaselect(2); mag1.getEvent(&event); /* Display the results (magnetic vector values are in micro-Tesla (uT)) */ Serial.print("Sensor #1 - "); Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" "); Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" "); Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" ");Serial.println("uT"); ©Adafruit Industries Page 13 of 22 tcaselect(6); mag2.getEvent(&event); /* Display the results (magnetic vector values are in micro-Tesla (uT)) */ Serial.print("Sensor #2 - "); Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" "); Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" "); Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" ");Serial.println("uT"); delay(500); } However, once you add all the tcaselect()'s you will be able to talk to both sensors! Multiple Multplexers Since the TCA9548 is addressible, you can have more than one multiplexer on the bus.  With 8 possible adresses, that means you can control as many as 64 separate i2c buses.  To avoid conflict between devices with the same address on different multiplexers, you can disable all channels on a multiplexer with the following code: Wire.beginTransmission(TCAADDR1); Wire.write(0); // no channel selected Wire.endTransmission(); CircuitPython & Python It's easy to use the TCA9548A with Python or CircuitPython, and the Adafruit_CircuitP ython_TCA9548A (https://adafru.it/ZYD) module. This module allows you to easily write Python code that allows you to multiplex up to 8 STEMMA boards with the TCA9 548A I2C multiplexer. You can use this multiplexer with any CircuitPython microcontroller board or with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-for-Python compatibility library (https://adafru.it/ BSN). If you're curious why you'd need an I2C multiplexer, be sure to check out this guide (h ttps://adafru.it/-af) that goes in depth on working with multiple copies of the same I2C device, which most likely have the same I2C address. Working with Multiple Same Address I2C Devices Learn Guide https://adafru.it/-af ©Adafruit Industries Page 14 of 22 CircuitPython Microcontroller Wiring First, wire up a TCA9548A to your board exactly as shown below. Here's an example of wiring a Feather M4 to the TCA9548A with I2C using one of the handy STEMMA QT (https://adafru.it/Ft4) connectors. Then, plug two TSL2591 STEMMA boards into the TCA9548A via STEMMA plug 0 and STEMMA plug 1: Board 3V to mux VIN (red wire) Board GND to mux GND (black wire) Board SCL to mux SCL (yellow wire) Board SDA to mux SDA (blue wire)   TSL2591 1 SDA to mux SD0 TSL2591 1 SCL to mux SC0 TSL2591 1 VIN to mux VIN TSL2591 1 GND to mux GND   TSL2591 2 SDA to mux SD1 TSL2591 2 SDA to mux SC1 TSL2591 2 VIN to mux VIN TSL2591 2 GND to mux GND You can also use standard 0.100" pitch headers to wire it up on a breadboard: Board 3V to mux VIN (red wire) Board GND to mux GND (black wire) Board SCL to mux SCL (yellow wire) Board SDA to mux SDA (blue wire)   TSL2591 1 SDA to mux SD0 TSL2591 1 SCL to mux SC0 TSL2591 1 VIN to mux VIN TSL2591 1 GND to mux GND   TSL2591 2 SDA to mux SD1 TSL2591 2 SDA to mux SC1 TSL2591 2 VIN to mux VIN TSL2591 2 GND to mux GND ©Adafruit Industries Page 15 of 22 Python Computer Wiring Since there's dozens of Linux computers/boards you can use, below shows wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  Here's the Raspberry Pi wired to the I2C multiplexer using I2C and a STEMMA QT (htt ps://adafru.it/Ft4) connector: Pi 3V to mux VIN (red wire) Pi GND to mux GND (black wire) Pi SCL to mux SCL (yellow wire) Pi SDA to mux SDA (blue wire) TSL2591 1 SDA to mux SD0 TSL2591 1 SCL to mux SC0 TSL2591 1 VIN to mux VIN TSL2591 1 GND to mux GND   TSL2591 2 SDA to mux SD1 TSL2591 2 SDA to mux SC1 TSL2591 2 VIN to mux VIN TSL2591 2 GND to mux GND Finally here is an example of how to wire up a Raspberry Pi to the I2C multiplexer using a solderless breadboard: Pi 3V to mux VIN (red wire) Pi GND to mux GND (black wire) Pi SCL to mux SCL (yellow wire) Pi SDA to mux SDA (blue wire) TSL2591 1 SDA to mux SD0 TSL2591 1 SCL to mux SC0 TSL2591 1 VIN to mux VIN TSL2591 1 GND to mux GND   TSL2591 2 SDA to mux SD1 TSL2591 2 SDA to mux SC1 TSL2591 2 VIN to mux VIN TSL2591 2 GND to mux GND ©Adafruit Industries Page 16 of 22 Python Installation of TCA9548A Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require enabling I2C on your platform and verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https: //adafru.it/BSN)! Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-tca9548a If your default Python is version 3, you may need to run  pip  instead. Make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! CircuitPython Usage To use with CircuitPython, you need to first install the TCA9548A library, and its dependencies, into the lib folder on your CIRCUITPY drive. Then you need to update code.py with the example script. Thankfully, we can do this in one go. In the example below, click the Download Project Bundle button below to download the necessary libraries and the code.py file in a zip file. Extract the contents of the zip file, and copy the entire lib folder and the c ode.py file to your CIRCUITPY drive. Your CIRCUITPY/lib folder should contain the following folders and file: • adafruit_bus_device/ • adafruit_tca9548a.mpy • adafruit_tsl2591.mpy ©Adafruit Industries Page 17 of 22 Python Usage Once you have the library  pip3  installed on your computer, copy or download the following example to your computer, and run the following, replacing code.py with whatever you named the file: python3 code.py Simple Test Example Code # SPDX-FileCopyrightText: 2021 Carter Nelson for Adafruit Industries # SPDX-License-Identifier: MIT # This example shows using TCA9548A to perform a simple scan for connected devices import board import adafruit_tca9548a # Create I2C bus as normal i2c = board.I2C() # uses board.SCL and board.SDA # Create the TCA9548A object and give it the I2C bus tca = adafruit_tca9548a.TCA9548A(i2c) for channel in range(8): if tca[channel].try_lock(): print("Channel {}:".format(channel), end="") addresses = tca[channel].scan() print([hex(address) for address in addresses if address != 0x70]) tca[channel].unlock() If running CircuitPython: Once everything is saved to the CIRCUITPY drive, connect to the serial console (https://adafru.it/Bec) to see the data printed out! If running Python: The console output will appear wherever you are running Python. ©Adafruit Industries Page 18 of 22 In this simple test for the TCA9548A, an I2C scan is performed for all eight of its ports. If any devices are connected, then the I2C address will be printed to the REPL next to the channel number. If no device is connected, then the port will print with empty brackets ( [] ). Multi-Sensor Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT # This example shows using two TSL2491 light sensors attached to TCA9548A channels 0 and 1. # Use with other I2C sensors would be similar. import time import board import adafruit_tsl2591 import adafruit_tca9548a # Create I2C bus as normal i2c = board.I2C() # uses board.SCL and board.SDA # Create the TCA9548A object and give it the I2C bus tca = adafruit_tca9548a.TCA9548A(i2c) # For each sensor, create it using the TCA9548A channel instead of the I2C object tsl1 = adafruit_tsl2591.TSL2591(tca[0]) tsl2 = adafruit_tsl2591.TSL2591(tca[1]) # After initial setup, can just use sensors as normal. while True: print(tsl1.lux, tsl2.lux) time.sleep(0.1) In the multi-sensor example, the TCA9548A is used as an I2C multiplexer with two TSL2591 light sensors. When the connected sensors are instantiated over I2C, the I2C pins declared are the ports from 0 and 1 on the TCA9548A. In the example, the first TSL2591 light sensor, instantiated as tsl1 , is plugged into port 0 ( tca[0] ) and the second TSL2591 light sensor, instantiated as tsl2 , is plugged into port 1 ( tca[1] ). ©Adafruit Industries Page 19 of 22 # Create the TCA9548A object and give it the I2C bus tca = adafruit_tca9548a.TCA9548A(i2c) # For each sensor, create it using the TCA9548A channel instead of the I2C object tsl1 = adafruit_tsl2591.TSL2591(tca[0]) tsl2 = adafruit_tsl2591.TSL2591(tca[1]) In the loop, the readings from the two light sensors are printed to the REPL every 0.1 seconds.  while True: print(tsl1.lux, tsl2.lux) time.sleep(0.1) Downloads Datasheets • TCA9548A datasheet (https://adafru.it/id8) • Fritzing object in the Adafruit Fritzing Library (https://adafru.it/aP3) • EagleCAD PCB files on GitHub (https://adafru.it/rzF) Schematic Click to embiggen ©Adafruit Industries Page 20 of 22 Fabrication Print Dimensions in Inches ©Adafruit Industries Page 21 of 22 ©Adafruit Industries Page 22 of 22
很抱歉,暂时无法提供与“2717”相匹配的价格&库存,您可以联系我们找货
  • 1+66.380001+8.51457
库存:514
