DEMOBOARDPSE-3000
DEMOBOARDPSE-3000
    CUIDEVICES
    DEMOBOARDPSE-3000
DEMOBOARDPSE-3000 数据手册
Additional Resources: Product Page date 07/22/2015 page 1 of 19 SERIES: PSE-3000 │ DESCRIPTION: AC-DC HOT-SWAP POWER SUPPLY FEATURES redundant (N+1) operation blind mate connections for hot-swap constant power (CP) mode harmonic correction to EN61000-3-2, Class A DROOP current sharing single I/O connector for AC input, DC output & signals • remote on/off control • power good signal • optional 19” four slot power shelf US MODEL output voltage output current output power2,3 ripple and noise1 efficiency4 (Vdc) max (A) max (W) max (mVp-p) typ (%) 62.5 3000 480 94 62.5 3000 480 94 55.5 3000 540 94 55.5 3000 540 94 PSE-3000-48-F 48 PSE-3000-48-B 48 PSE-3000-54-F 54 PSE-3000-54-B 54 1. 2. 3. 4. 5. Measured at 20 MHz bandwidth at an oscilloscope jack on the output with 0.1 µF ceramic and 10 µF aluminum electrolyitc capacitors. At 90~180 Vac input, maximum of 1500 W. At 180~264 Vac input, maximum of 3000 W. At 230 Vac input, 3000 W. Meets 80 PLUS platinum efficiency requirements. All specifications measured at: Ta=25°C and 220 Vac input voltage unless otherwise specified. O PART NUMBER KEY N Notes: N h A ca meri TI rt , I nc o of N C . T Rheinla nd UV U up to 3000 W continuous power 80 PLUS Platinum Efficiency PoE output isolation; (1500 Vrms to ground) high power density - 33.48 W/in3 PMBusTM communication for monitoring & control • dual fan forced cooling with speed control • front to back (-F) and back to front (-B) airflow versions • power factor correction • 3.3 Vdc (2A) standby voltage ED • • • • • • • • • • • IS C PSE-3000 - XX - X - CXX Base Number Reserved for Custom Configurations Output Voltage D Airflow Direction: F = AC input connector to DC output connector B = DC output connector to AC input connector cui.com Additional Resources: Product Page CUI Inc │ SERIES: PSE-3000 │ DESCRIPTION: AC-DC HOT-SWAP POWER SUPPLY date 07/22/2015 │ page 2 of 19 INPUT parameter conditions/description min voltage typ 90 47 current at 90 Vac, 1500 W at 180 Vac, full load inrush current at 115 Vac, cold start at 230 Vac, cold start 63 20 40 at 230 Vac, full load A A U conditions/description min line regulation 1.5 mArms typ max units ±3 % ±3 N load regulation load capacitance 50% step load, 1A/µs slew rate, recovery to 1% within 1 ms transient response start-up time Hz Arms Arms 0.99 OUTPUT - V1 (MAIN OUTPUT) parameter Vac 20.2 18.5 leakage current power factor correction units 264 ED frequency max % 30,000 μF 3 % 5 at 230 Vac, full load remote sense between both output terminals 0.5 V current share accuracy (Droop) over 25% to 100% load ±10 % TI 12 s hold-up time ms AC OK: “green” to indicate AC above the lower limit that is required to sustain normal operation LED indicator N DC OK: “green” to indicate module in normal operating condition OUTPUT - V2 (STANDBY OUTPUT) output current ripple and noise1 line regulation min typ Vdc 2 A 33 mVp-p % ±5 % 50% step load, 1A/µs slew rate, recovery to 1% within 1 ms start-up time Notes: units ±5 load capacitance transient response max 3.3 0 IS C load regulation conditions/description O parameter output voltage 1000 µF 3 % 5 s max units 60 120 Vdc % 62.5 2.6 A A 1. Measured at 20 MHz bandwidth at an oscilloscope jack on the output with 0.1 µF ceramic and 10 µF aluminum electrolyitc capacitors. PROTECTIONS conditions/description min over voltage protection V1: latch off V2: latch off 110 D parameter over current protection V1: constant current inception V2: hiccup over temperature protection at full load, auto recovery typ 55 cui.com °C Additional Resources: Product Page CUI Inc │ SERIES: PSE-3000 │ DESCRIPTION: AC-DC HOT-SWAP POWER SUPPLY date 07/22/2015 │ page 3 of 19 SAFETY & COMPLIANCE conditions/description min input to output, reinforced input to chassis, basic 3,000 1,500 Vrms Vrms isolation voltage output to output output to chassis signals to chassis/ground V2 to chassis/ground 1,500 1,500 1,500 100 Vrms Vrms Vdc Vdc grounding The main output V1 is “floating” and not referenced to chassis/ground.The output control and status signals are referenced to the V2 output return connection. safety approvals EN60950-1:2006+A11+A1+A12, IEC609501:2005+Amd 1, CAN/CSA-C22.2 No.60950-107+A1:2011, UL 60950-1:2007 R12.11(NRTL Route), EEC/93/68/LVD, 2006/95/EC LVD conducted emissions FCC 15 Sub Part B, EN55022, Class A: 3dB margin tested with resistive load radiated emissions FCC 15 Sub Part B, EN55022, Class A: 3dB margin tested with resistive load harmonic compliance EN/IEC 61000-3-2:2009, Class A Harmonic Limits Compliance Level: 230 Vac line voltage; 100% output load flicker EN/IEC 61000-3-3:2009 limits as specified in the standard: flicker and voltage fluctuations electrostatic discharge EN/IEC 61000-4-2, ±8 kV operational air discharge, ±8 kV contact discharge: all parameters to remain within limits, test set up to be defined RF electro-magnetic field. amplitude modulated EN/IEC 61000-4-3 80~1000 MHz, 10V/m, 80% AM Modulation (1 kHz): all parameters to remain within limits, test set up to be defined immunity to fast transients EN/IEC 61000-4-4 Power lines: ±2 kV: all parameters to remain within limits, test set up to be defined units U N TI N EN/IEC 61000-4-5 ±1 kV line to line, ±2 kV line to earth, Criteria A: all parameters to remain within limits, test set up to be defined EN/IEC 61000-4-6 150 kHz~80 MHz 3Vrms 80% AM (1 kHz), Criteria A: all parameters to remain within limits, test set up to be defined IS C RF continuous conducted max O surges (mains) typ ED parameter insulation safety rating / test voltage voltage dips/ interruptions IEC 61000-4-11 30% reduction for 10 ms, 60% reduction for 100 ms: Reset is permitted must be selfrecovering. Additionally, the PSU shall not latch up during any brownout condition. MTBF as per Telcordia SR-332, Issue 2, Sept 2006 component stress method at Ta=25°C RoHS 2011/65/EU WEEE 2012/19/EU 916,000 hours D ENVIRONMENTAL parameter conditions/description operating temperature full load, no derating storage temperature operating humidity min max units 0 50 °C non-condensing -40 70 °C non-condensing 10 90 % 5 90 % storage humidity cui.com typ Additional Resources: Product Page CUI Inc │ SERIES: PSE-3000 │ DESCRIPTION: AC-DC HOT-SWAP POWER SUPPLY date 07/22/2015 │ page 4 of 19 ENVIRONMENTAL (CONTINUED) cold1 IEC 68 Part 2 – 1: at -10°C minimum for 4 hours dry heat IEC 68 Part 2 – 2: at 50°C minimum for 4 hours damp heat, cyclic IEC 68 Part 2 – 30: at 20~45°C, 30~95 %RH low air pressure (operating) IEC 68 Part 2 – 13: at 10,000 feet, 697 mbar vibration (sinusoidal) IEC 68 Part 2 – 6: at 10~58 Hz, 0.075 mm; 58~500 Hz, 10 m/s2, 1 octave/minute, 10 cycles/ main axis shock IEC 68 Part 2 – 27: at 300 m/s2, 11 ms, half sine wave 3 shocks/main axis bump IEC 68 Part 2 – 29: at 150 m/s2, 6 ms, half sine wave 900 bumps/main axis Notes: min typ max units 60 dB LpAm ED conditions/description ISO 7779-1999 1 G 30 G U parameter acoustic 15 G 1. The module shall start up at -10°C, however it is not required that the full specification is achieved until the operational internal temperature has risen to 0°C. N MECHANICAL parameter conditions/description dimensions 14.00 x 4.00 x 1.60 (355.6 x 101.6 x 40.6 mm) min weight integral fans material flammability UL 94V-0 AC input IEC320/C14 DC output FCI PwrBlade P/N 51939-661LF mates with FCI P/N 51915-351LF N D IS C units: inches [mm] tolerance: X.XX ±0.02 [0.50] X.XXX ±0.010 [0.25] O MECHANICAL DRAWING TI cooling / airflow D1 D2 D3 D4 D5 D6 C1 C2 C3 C4 C5 C6 B1 B2 B3 B4 B5 B6 P1 P2 P3 P4 P5 A1 A2 A3 A4 A5 A6 cui.com P6 P7 P8 P9 typ max units inches 2.01 kg Additional Resources: Product Page CUI Inc │ SERIES: PSE-3000 │ DESCRIPTION: AC-DC HOT-SWAP POWER SUPPLY date 07/22/2015 │ page 5 of 19 DC PIN ASSIGNMENTS DESCRIPTION V1 (-VE) output terminal P4, P5, P6 V (+VE) V1 (+VE) output terminal P7 earth/chassis ground protective/safety earth P8 neutral neutral or AC line#2 P9 hot/AC line#1 I2C address A0 I2C address - LSB B1 I2C address A1 I2C address bit C1 I2C address A2 I2C address - MSB D1 REMOTE_ON_L signal pin status output status open circuit “off” logic “1” logic “0” B2 AC_OK_L “L” to indicate AC above lower limit that is required for sustain normal operation, there is no internal pull up resistor and it should be provided externally to support VCEO ≤ 20 Vdc, Ic ≤ 5 mA dc >2.1 V 2.1 V 2.1 V 2.1 V 2.1 V
DEMOBOARDPSE-3000 价格&库存
很抱歉,暂时无法提供与“DEMOBOARDPSE-3000”相匹配的价格&库存,您可以联系我们找货
