6.70.00EMBOS/IPSWITCHBOARD 数据手册
embOS/IP
Switch Board
User Guide & Reference Manual
Document: UM06002
Software Version: 2.00
Revision: 0
Date: April 22, 2016
A product of SEGGER Microcontroller GmbH & Co. KG
www.segger.com
2
Disclaimer
Specifications written in this document are believed to be accurate, but are not guaranteed
to be entirely free of error. The information in this manual is subject to change for
functional or performance improvements without notice. Please make sure your manual
is the latest edition. While the information herein is assumed to be accurate, SEGGER
Microcontroller GmbH & Co. KG (SEGGER) assumes no responsibility for any errors or
omissions. SEGGER makes and you receive no warranties or conditions, express, implied,
statutory or in any communication with you. SEGGER specifically disclaims any implied
warranty of merchantability or fitness for a particular purpose.
Copyright notice
You may not extract portions of this manual or modify the PDF file in any way without the
prior written permission of SEGGER. The software described in this document is furnished
under a license and may only be used or copied in accordance with the terms of such a
license.
© 2016 SEGGER Microcontroller GmbH & Co. KG, Hilden / Germany
Trademarks
Names mentioned in this manual may be trademarks of their respective companies.
Brand and product names are trademarks or registered trademarks of their respective
holders.
Contact address
In den Weiden 11
D-40721 Hilden
Germany
Tel.
Fax.
E-mail:
Internet:
+49 2103-2878-0
+49 2103-2878-28
support@segger.com
www.segger.com
embOS/IP Switch Board User Guide & Reference Manual
3
Manual versions
This manual describes the current hardware version. If you find an error in the manual or a
problem in the hardware, please inform us and we will try to assist you as soon as possible.
Contact us for further information on topics or functions that are not yet documented.
Print date: April 22, 2016
Revision
Date
By
Description
1
16040x
OO
- Minor changes.
- Restructuring.
KB
Initial Release.
4
5
About this document
Assumptions
This document assumes that you already have a solid knowledge of the following:
The software tools used for building your application (assembler, linker, C compiler).
The C programming language.
The target processor.
DOS command line.
If you feel that your knowledge of C is not sufficient, we recommend The C Programming
Language by Kernighan and Richie (ISBN 0–13–1103628), which describes the standard in C
programming and, in newer editions, also covers the ANSI C standard.
How to use this manual
This manual explains all the functions and macros that the product offers. It assumes you have
a working knowledge of the C language. Knowledge of assembly programming is not required.
Typographic conventions for syntax
This manual uses the following typographic conventions:
Style
Used for
Body
Body text.
Keyword
Text that you enter at the command prompt or that appears on
the display (that is system functions, file- or pathnames).
Parameter
Parameters in API functions.
Sample
Sample code in program examples.
Sample comment
Comments in program examples.
Reference
Reference to chapters, sections, tables and figures or other
documents.
GUIElement
Buttons, dialog boxes, menu names, menu commands.
Emphasis
Very important sections.
6
7
Table of contents
1
Introduction to embOS/IP Switch Board ....................................................................... 8
1.1
1.2
2
Functional Description ................................................................................................ 11
2.1
2.2
2.3
2.4
3
Overview on hardware features and specifications ..............................................9
1.1.1 Board main features: .......................................................................... 9
1.1.2 Controller main features: ..................................................................... 9
1.1.3 Switch main features: ......................................................................... 9
Functional block diagram .............................................................................. 10
NXP Kinetis K66 MCU (MK66FN2M0VMD18) ..................................................... 12
Micrel/Microchip Managed Ethernet Switch (KSZ8794CNX) .................................13
Debug Access .............................................................................................. 14
USB/Power Supply ....................................................................................... 15
Quick Start .................................................................................................................. 17
8
Chapter 1
Switch Board
This section presents an overview of embOS/IP Switch Board, its structure, and its
capabilities.
The embOS/IP Switch Board is intended to be mainly a demonstrator board for the Tail
Tagging add-on of SEGGER’s embedded IP stack embOS/IP. Micrel/Microchip has developed
switches which can expand one physical port into 1+n ports, supported by the so-called
Tail Tagging mode. This enhancement allows to establish multiple physical external ports
when only one physical Ethernet port is available on the CPU - by choosing another PHY.
The board features an NXP Kinetis K66 CPU, Micrel/Microchip switch PHY KSZ8794CNX with
three usable Ethernet ports and a J-Link OB debug probe.
The eval package is available for download and can be found here: https://
www.segger.com/embos-ip-switch-board.html
This document is designed to give a quick overview on the features and specifications of
the embOS/IP Switch Board. If you are looking for a detailed description of the embOS/
IP Tail Tagging add-on, please refer to the product site at https://www.segger.com/embosip-tail-tagging.html
9
1.1
1.1.1
1.1.2
1.1.3
Micrel/Microchip KSZ8794CNX managed Ethernet switch with 3 external 10/100 ports
and one Gigabit RGMII/MII/RMII uplink port
3 RJ45 Ethernet connectors
On-board debug probe J-Link-OB with Drag & Drop (STM32F072, mini A/B-type
connector)
USB device: High speed, B-type connector
LEDs: 2x BiColor red/green
No jumpers or solder jumpers
Rubber feet
Dimensions 80 mm x 60 mm
180 MHz ARM Cortex-M4 based core with DSP instructions and Single Precision Floating
Point unit
2 MB program flash memory, 256 KB RAM, 4 KB FlexRAM
Memory protection unit with multi-master protection
Ethernet controller with RMII interface to external PHY and hardware IEEE 1588
capability
USB high-/full-/low-speed On-the-Go with on-chip high speed transceiver
Layer 2 managed 4-port switch
3 10/100 Mbps copper ports + 1 10/100/1000 Mbps uplink port
Internal biasing, on-chip termination
Enhanced power management features incl. Energy Efficient Ethernet (EEE), PME, WoL
Programmable rate limiting and priority ratio
Tagged and port-based VLAN
Port based security and ACL-rule based packet filtering technology
QoS priority with four queues
High-performance memory bandwidth and a shared memory-based switch fabric with
non-blocking support
10
1.2
CHAPTER 1
11
Chapter 2
This section describes the hardware features from a functional point of view.
12
2.1
CHAPTER 2
As microcontroller an NXP Kinetis K66 is used. It is clocked at 180 MHz and comes with 256
KB SRAM as well as 2 MB Flash memory. Main peripheral functions used in this application
are the USB2.0 controller with an integrated HS USB PHY and one Ethernet controller.
13
2.2
(KSZ8794CNX)
The KSZ8794CNX is a highly integrated, Layer 2 managed, four-port switch. This switch
has three MACs, one GMAC (for uplink) and three PHYs that are fully compliant with the
IEEE 802.3u standard. It is intended for applications requiring three 10/100Mbps copper
ports and one 10/100/1000Mbps Gigabit uplink port. The KSZ8794CNX incorporates a small
package outline, lowest power consumption with internal biasing, and on-chip termination.
Its extensive features set includes enhanced power management, programmable rate
limiting and priority ratio, tagged and port-based VLAN, port-based security and ACL rulebased packet filtering technology, QoS priority with four queues, management interfaces,
enhanced MIB counters, high-performance memory bandwidth, and a shared memorybased switch fabric with non-blocking support. The KSZ8794CNX provides support for
multiple CPU data interfaces to effectively address both current and emerging fast Ethernet
and Gigabit Ethernet applications where the GMAC interface can be configured to any of
RGMII, MII and RMII modes.
14
2.3
CHAPTER 2
Debug Access
Debug Access
Quick and easy debug access to the Kinetis core MCU can be achieved by the J-Link OB,
SEGGER’s on-board debug probe. It connects to the debug host through a USB2.0 FS
interface. Alternatively regular debug probes from the J-Link series (J-Link BASE/PLUS/
ULTRA+/PRO) can be used by means of a TagConnect debug footprint for use with SEGGER’s
J-Link Needle Adapter. Details can be found here: https://www.segger.com/jlink-needleadapter.html
15
2.4
USB/Power Supply
The embOS/IP Switch board is powered by the USB device connector (B-type connector).
Current consumption drawn depends on the configuration and connected Ethernet links.
Idle consumption is approx. 140 mA. This USB interface can be used for a connection to a
host providing High Speed USB2.0 device functionality (if provided by the application).
16
CHAPTER 2
USB/Power Supply
17
Chapter 3
Quick Start
For quick start instructions for your new embOS/IP Switch Board please refer to the following
location: https://www.segger.com/start-embos-ip-switch-board.html
18
CHAPTER 3
