USB
C43
100nF
C44+
10uF/6.3V/T ANT
NA
C48
NA
P_OUT
HN1x2
2
1
2
1
#LCD_RES
EXT1-28
A_OUT
MSP430F5438IPZ
P8.7
P8.6/TA1.1
P8.5/TA1.0
P8.4/TA0.4
P8.3/TA0.3
P8.2/TA0.2
P8.1/TA0.1
P8.0/TA0.0
P9.7
P9.6
P9.5/UCA2RXD/UCA2SOMI
P9.4/UCA2TXD/UCA2SIMO
P9.3/UCB2CLK/UCA2STE
P9.2/UCB2SOMI/UCB2SCL
P9.1/UCB2SIMO/UCB2SDA
P9.0/UCB2STE/UCA2CLK
P10.7
P10.6
P10.5/UCA3RXD/UCA3SOMI
P10.4/UCA3TXD/UCA3SIMO
P10.3/UCB3CLK/UCA3STE
P10.2/UCB3SOMI/UCB3SCL
P10.1/UCB3SIMO/UCB3SDA
P10.0/UCB3STE/UCA3CLK
P7.7/A15
P7.6/A14
P7.5/A13
P7.4/A12
P7.3/TA1.2
P7.2/TB0OUTH/SVMOUT
P7.1/XOUT
P7.0/XIN
P6.7/A7
P6.6/A6
P6.5/A5
P6.4/A4
P6.3/A3
P6.2/A2
P6.1/A1
P6.0/A0
P5.7/UCA1RXD/UCA1SOMI
P5.6/UCA1TXD/UCA1SIMO
P5.5/UCB1CLK/UCA1STE
P5.4/UCB1SOMI/UCB1SCL
P5.3/XT2OUT
P5.2/XT2IN
P5.1/VREF-/VEREFP5.0/VREF+/VEREF+
P4.7/TB0CLK/SMCLK
P4.6/TB0.6
P4.5/TB0.5
P4.4/TB0.4
P4.3/TB0.3
P4.2/TB0.2
P4.1/TB0.1
P4.0/TB0.0
8
7
6
5
56
55
14
13
4
3
2
1
100
99
98
97
54
53
52
51
90
89
10
9
50
49
48
47
46
45
44
43
42
41
40
39
36
35
34
33
A_IN
QCT32768(2x6)/6pF
AGND
C27
EXT2-33
EXT2-34
3.3VA
39pF
39pF
C26
100k
100k
100k
C37
47uF/6.3V/TANT
CL470nH/0805/1.76R/250mA
R36
R37
R38
L2
UCB 0CLK
UCB0SO MI
6
4
5
7
8
1
UCB 0STE 2
UCB0SIMO3
R34
R35
AGND
3.3V
SD/MMC
MICRO
CD/DAT3/CS
CMD/DI
VSS
VDD
CLK/SCLK
DAT0/DO
DAT1/RES
DAT2/RES
10k
1M
C15
R12
47k
2
3
R22
560R
LED2
LED2
R39
33k
http://www.olimex.com/dev
COPYRIGHT(C), 2009
Rev. A
C14
R23
4.7k
UCA0TXD
UCA0RXD
UCB1SCL
UCB1SDA
UCA1SOMIR26
UCA1SIMO
UCA1CLK
UCA1STE
BUT(D)
DOWN
DOWN
C
E
Center push
B
A
RIGHT
D
Common
UP
LEFT
R42
33k
R46
R43
33k
330R
RIGHT BUT(R)
COMMON
UP BUT(U)
J1
JOYSTICK_MT5_F
BUT(L) LEFT
R41
33k
BH10S
BH10S
BH10S
BH10S
BH10S
BH10S
BH10S
BH10S
BH10S
BH10S
3.3V
UEXT-1
UEXT-2
UEXT-3
UEXT-4
UEXT-5
UEXT-6
UEXT-7
UEXT-8
UEXT-9
UEXT-10
USER JOYSTICK
220R
R24
4.7k
UEXT
AGND
3.3V
SCJ325P00XG0B02G
3-R
2
1-L
HEADPHONES
47uF/6.3V/TANT
C11
AGND
3.3V 3.3V 3.3V
BUT(C) R45 CENTER
330R
R40
33k
3.3V
MSP430-5438STK
R21
560R
LED1
LED1
USER LEDS
AGND
100nF
47uF/6.3V/TANT
5
8
3-R
2
1-L
MICROPHONE
AGND
47uF/6.3V/TANT
C2
AGND SCJ325P00XG0B02G
C10
AGND
R6
NA
R3
10k
R2
560R
3.3VA
100nF
C6
47pF
R8
100k
C3
R1
100k
3.3VA
U3
TS4871(SO-8)
AGND
3
4
AGND
C7
1uF
R7
20k
AGND
3.3VA
AGND
A_OUT
R5
470k
C1
100nF
AGND
3.3VA
UCA1SOMI,UCA1SIMO,UCA1STE,UCA1CLK,UCB1SDA,UCB1SCL,UCA0RXD,UCA0TXD,CS_SD
3.3V
EXT2-14
EXT2-15
EXT2-16
EXT2-17
UCB 0CLK
UCB0SOMI
UCB 0S IMO
UCB0STE
6
C12
470pF
2.2uF
27k
SD/MMC
C13
2.2uF
AGND
R13
33nF
1k
1k
C9
R10
R9
33nF
C8
R11
20k AGND
R15
33k
R4
560R
Z1
BZV55C2V4
Z2
BZV55C2V4
AGND
47pF
C5
A_IN
UCB0STE,UCB0SIMO,UCB0CLK,UCB0SOMI
100nF
EXT1-34
EXT1-33
EXT1-32
EXT1-31 AGNDAGNDAGND
EXT1-30
EXT1-29
C28
10pF
Q2
C29
10pF
GND
C24
C25
Q18.000MHz/20pF
Q1
EXT2-26
EXT2-27
EXT2-28
EXT2-29
EXT2-30
EXT2-31
EXT2-32
UCA1SOMI
UCA1SIMO
UCA1STE
UCB1SCL
EXT2-18
EXT2-19
EXT2-20
EXT2-21
EXT2-22
EXT2-23
EXT2-24
EXT2-25
UCB1SDA
UCA1CLK
UCA0RXD
UCA0TXD
UCB0CLK
UCB0SOMI
UCB0SIMO
UCB0STE
EXT2-6
EXT2-7
EXT2-8
EXT2-9
EXT2-10
EXT2-11
EXT2-12
EXT2-13
RS232
DB9-F
6 PC_DSR
7 PC_RTS
8 PC_CTS
9
R32
G2
NA
G1
NA
U2
MCP601-I/SN
AUDIO
GYX-SD-TC0805SYC(YELLOW)
1uF/16V/TANT
ADG8448G(FPA-WZA-08-LF)
C36
67
66
65
61
60
59
58
57
75
74
73
72
71
70
69
68
83
82
81
80
79
78
77
76
P11.2/SMCLK
P11.1/MCLK
P11.0/ACLK
TEST/SBWTCK
#RST/NMI/SBW/TDIO
PJ.3/TCK
PJ.2/TMS
PJ.1/TDI/TCLK
PJ.0/TDO
P3.7/UCB1SIMO/UCB1SDA
P3.6/UCB1STE/UCA1CLK
P3.5/UCA0RXD/UCA0SOMI
P3.4/UCA0TXD/UCA0SIMO
P3.3/UCB0CLK/UCA0STE
P3.2/UCB0SOMI/UCB0SCL
P3.1/UCB0SIMO/UCB0SDA
P3.0/UCB0STE/UCA0CLK
32
31
30
29
28
27
26
25
0R(NA)
EXT1-22
EXT1-23
EXT1-24
EXT1-25
EXT1-26
EXT1-27
EXT1-19
EXT1-20
EXT1-21
LCD_D/#C
#LCD_RES
UCA2RXD
UCA2TXD
UCB2CLK
UCB2SOMI
UCB2SIMO
UCB2STE
LED1
LED2
UCA3RXD
UCA3TXD
91
96
TEST
#RST
86
85
84
95
94
93
92
TCK
TMS
TDI
TDO
AVSS
AVCC
P2.7/ADC12CLK/DMAE0
P2.6/ACLK
P2.5
P2.4/RTCCLK
P2.3/TA1.2
P2.2/TA1.1
P2.1/TA1.0
P2.0/TA1CLK/MCLK
EXT2-4
EXT2-5
EXT2-3
1
2
3
4
5
10uF/6.3V/TANT
UCB2CLK
UCB2SIMO
LCD_D/#C
UCB2STE
LCD
3.3V
TCK
TMS
TDI
TDO
EXT1-11
EXT1-12
EXT1-13
EXT1-14
EXT1-15
EXT1-16
EXT1-17
EXT1-18
EXT1-8
EXT1-9
EXT1-10
12
11
100nF
AGND
C23
VCORE
DVSS1
DVSS2
DVSS3
DVSS4
BUT(L)
BUT(R)
BUT(C)
BUT(U)
BUT(D)
PC_RXD
PC_TXD
PC_DTR
C32
100nF
C34
100nF
R33
0R
1
2
3
4
5
6
7
8
NA
#RST
EXT1-4
EXT1-5
EXT1-6
EXT1-7
C22
10uF/6.3V/TANT
62
15
63
37
88
24
23
22
21
18
17
13
8
14
7
6
2
0R
VDD
SCK
SDIN
D/#C
#SCE
GND
VOUT
#RES
R29
33k
R18
100nF
100nF
R1IN
R2IN
T1OUT
T2OUT
ST3232(SO16)
R1OUT
R2OUT
P1.7
P1.6/SMCLK
P1.5/TA0.4
P1.4/TA0.3
P1.3/TA0.2
P1.2/TA0.1
P1.1/TA0.0
P1.0/TA0CLK/ACLK
12
9
T1IN
T2IN
C2-
V-
V+
0R(NA)
LCD
R28
33k
13
11
9
7
5
3
1
L1
C19
C18
C21
470nF
100nF
C17
FB0805/600R/200mA(201209-601)
3.3VA
100nF
C16
DVCC4
DVCC3
DVCC2
DVCC1
5
11
10
C2+
C1-
C1+
R19
R27
33k
BH14S
JTAG
23
22
13
14
12
1
5
3
11
2
9
10
6
R30
330R
87
38
64
16
U1
560R
UCA2RXD R31
UCA2TXD
C35 4
100nF
3
C33
100nF
GND15
U4PWR
16VCC
R20
100nF
P_IN
HN1x2
14
12
10
8
6
4
2
TEST
100nF
33k
7
25
R17
GND1
AGND
TDI,TDO,TMS,TCK,#RST,TEST
18
DEBUG INTERFACE:
GND2
3.3V
CBUS0
CBUS1
CBUS2
CBUS3
CBUS4
26
21
C30
C45
3V3OUT
NC1
#RESET
NC2
OSCI
OSCO
USBDM
USBDP
TXD
RXD
RTS#
CTS#
DTR#
DSR#
DCD#
RI#
TEST
GND3
3.3V
C49
17
8
19
24
27
28
16
15
VCCIO
VCC
FT232RL
R53
NA
R52
USB to RS232
10nF
USB_B C50
0R(NA)
0R(NA)
UCA3TXD
UCA3RXD
FT232RL/SSOP28
PWREN
#RST
T1107A(6x3.8x2.5mm)
RESET
220R
C31 1
100nF
U4
3.3V
2
7
S H IE L D
0R
0R
10k
1k
VDD_E
CLOSE
2
GND
FB /6 0 0 OH M /1 2 0 6 (3 2 1 6 1 1 C -6 0 1 )
IRLML6402
VCC
1
2 R50
3 R51
4
10uF/6.3V(NA)
R49
U5
GYX-SD-T C0805SURK(RED)
10uF/6.3V/TANT
3.3V
AGND
C20 2.2nF
4
GND
C46
2
CLOSE
1
AGND_E EXT2-2
100nF
EXT1-2
47uF/6.3V/TANT
+5V_USB
C47
1
1
6
L3
47pF
100nF
560R
R47
C40
C38
EXT2-1
R14
33k
R16
RS232
4
FET
C42
PWR
2
1N4148
390R/1%
R44
240R/1%
1
C4
R48
C41
100nF
1
CLOSE
3.3VA_E
RESET CIRCUIT
3.3V 3.3V
7
USB
DB104(SMD)
C39
470uF/16VDC
OUT
ADJ/GND
3.3V_E
CLOSE
2
IN
VR1(3.3V)
LM1117IMPX-ADJ
EXT1-1
3.3VA
D1
6VAC
9VDC
1N5819S
G1
3.3V
EXT1-3
YDJ-1134
PWR_JACK
+5V_USB
D2
POWER SUPPLY
R25
33k
GYX-SD-TC0805SGC(GREEN)
UCB2CLK,UCB2SIMO,UCB2SOMI,UCB2STE,LCD_D/#C,#LCD_CS,#LCD_RES
很抱歉,暂时无法提供与“MSP430-5438STK”相匹配的价格&库存,您可以联系我们找货
