1300 Henley Court
Pullman, WA 99163
509.334.6306
www.digilentinc.com
PmodNIC100™ Reference Manual
Revised May 26, 2016
This manual applies to the PmodNIC100 rev. B
Overview
The Digilent PmodNIC100 is a standalone Ethernet Controller to provide Ethernet functionality to any system
board.
Features include:
IEEE 802.3 compatible Ethernet controller
10/100 Mb/s data rates
MAC and PHY support
10BASE-T support and 100Base-TX support
Small PCB size for flexible designs 1.8“ × 0.8” (4.6 cm ×
2.0 cm)
12-pin Pmod connector with SPI interface
Follows Digilent Pmod Interface Specification Type 2A
The PmodNIC100.
1
Functional Description
The PmodNIC100 utilizes Microchip's ENC424J600 Stand-Alone 10/100 Ethernet Controller. By providing both MAC
and PHY support, Ethernet functionality at data rates up to 10 Mbit/s is achievable for any system board.
2
Interfacing with the Pmod
The PmodNIC100 communicates with the host board via the SPI protocol. By leaving the Interrupt/SPI Select
(INT/SPISEL) pin floating or at a logic level high voltage within the first 1 to 10 μS, the SPI mode is enabled. Users
may then bring the Chip Select (CS) line to a logic low voltage state to initiate communication with the Ethernet
Controller.
Note that this Pmod only provides the hardware at the physical layer (PHY) and the media access control (MAC) for
a network interface. Users must provide their own protocol stack software (such as TCP/IP). Digilent provides a set
of libraries providing Ethernet support that is available for download on the PmodNIC100 product page.
DOC#: 502-208
Copyright Digilent, Inc. All rights reserved.
Other product and company names mentioned may be trademarks of their respective owners.
Page 1 of 2
2.1
Pinout Description Table
Pin
1
2
3
4
5
6
7
8
9
10
11
12
Signal
CS
MOSI
MISO
SCLK
GND
VCC
~INT/SPISEL
NC
NC
NC
GND
VCC
Description
Chip Select
Master-Out-Slave-In
Master-In-Slave-Out
Serial Clock
Power Supply Ground
Power Supply (3.3V)
Interrupt Signal/SPI Enable
Not Connected
Not Connected
Not Connected
Power Supply Ground
Power Supply (3.3V)
Table 1. Header J1 pinouts on the PmodNIC100.
Any external power applied to the PmodNIC100 must be within 3V and 3.6V; however, it is strongly recommended
that the Pmod is operated at 3.3V.
3
Physical Dimensions
The pins on the pin header are spaced 100 mil apart. The PCB is 1.8 inches long on the sides parallel to the pins on
the pin header (2.05 inches long including the Ethernet port) and 0.8 inches long on the sides perpendicular to the
pin header.
Page 2 of 2
很抱歉,暂时无法提供与“410-208”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+175.991511+22.78027
