7C-48.000MBE-T
7C-48.000MBE-T
    TXC(台晶)
    SMD-4
    有源晶振 48MHz 3.3V SMD-4
7C-48.000MBE-T 数据手册
7C MHz CMOS Oscillator Features Applications Frequency range : 1MHz to 170MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.2 RoHS compliant & Pb free Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) Current Consumption (IDD) 7C 1MHz ~ 170MHz ±50 , ±25 ppm -10°C ~ +70°C; Note [1] ±50 , ±30 , ±25 , ±15 ppm -40°C ~ +85°C; Note [1] -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 2.8V, 3.3V 1MHz ~ 75MHz 20 mA Max. 75MHz ~ 170MHz CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Phase Jitter, RMS Aging (Faging) Storage Temperature Range (T STR) VDD ± 10% 10 mA Max. Output Type Duty Cycle Start-up Time Enable Voltage High, Logic "1" Enable Voltage Low, Logic "0" Conditions 40% ~ 60% 5 ms Max. 70% VDD Min. 30% VDD Max. 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C, first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.05-a Page 1 www.txccrystal.com 7C MHz CMOS Oscillator Dimensions (Unit: mm) B C F Ordering Information 7C - ± 50 ppm (-10˚C ~ +85˚C) ± 100 ppm (-10˚C ~ +70˚C) ± 100 ppm (-40˚C ~ +85˚C) 30.000M B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Supply Voltage B E C D Rev. 1.05-a Tape & Reel Frequency Stability A D E 3.3 V 2.8 V 2.5 V 1.8 V Page 2 ± 25 ppm (-10˚C ~ +70˚C) ± 25 ppm (-40˚C ~ +85˚C) ± 50 ppm (-40˚C ~ +85˚C) www.txccrystal.com 7C MHz CMOS Oscillator Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.05-a 60 sec Page 3 Time (sec) www.txccrystal.com
7C-48.000MBE-T
物料型号:7C MHz CMOS Oscillator
器件简介:该振荡器提供1MHz至170MHz的频率范围,采用SMD密封陶瓷封装,供电电压为1.8V至3.3V,具有CMOS输出和三态功能。
引脚分配:1号引脚为使能控制(ENABLE CONTROL),2号引脚为地(GND),3号引脚为输出(OUT),4号引脚为电源(VDD)。
参数特性: - 频率范围:1MHz至170MHz - 频率稳定性:在不同温度范围内,频率稳定性不同,例如在-10°C至+70°C范围内为±50ppm - 工作温度范围:-10°C至+70°C或-40°C至+85°C - 供电电压:1.8V、2.5V、2.8V、3.3V - 最大电流消耗:在1MHz至75MHz时为10mA,在75MHz至170MHz时为20mA - 输出类型:CMOS - 输出负载:15pF - 高电平输出电压:至少为供电电压的90% - 低电平输出电压:最多为供电电压的10% - 上升和下降时间:最大8ns - 占空比:40%至60% - 启动时间:最大5ms - 使能电压高/低:分别为供电电压的70%和30% - 相位抖动(RMS):最大1ps - 老化(Fang):第一年在25°C±3°C时为±3ppm - 存储温度范围:-55°C至+125°C
功能详解:文档提供了详细的电气特性表,包括频率稳定性、工作温度范围、供电电压、电流消耗等参数,并附有注释说明。
应用信息:适用于网络、服务器、存储、无线通信、PCI-E、USB、WLAN、xDSL、xPON光纤通道、以太网、SATA、SAS、图形卡、计算机外围设备、PC主板、笔记本电脑、硬盘驱动器、固态硬盘、音频、视频、游戏、打印机、DSC、IPCAM、消费产品等。
封装信息:提供了振荡器的外部尺寸、顶视图、侧视图和底视图,以及建议的布局图。
订购信息:提供了订购时需要的频率、供电电压、频率稳定性等信息,以及包装方法。
回流焊接曲线:提供了焊接时的熔点、峰值温度和时间等信息。
7C-48.000MBE-T 价格&库存
很抱歉,暂时无法提供与“7C-48.000MBE-T”相匹配的价格&库存,您可以联系我们找货
