GLR-6
GLR-6
    EATON(伊顿)
    FUSEIN-LINE300V6ACABLEWIRE
GLR-6 数据手册
Technical Data 2032 Effective August 2017 Supersedes December 2015 GLR (fuse) HLR (fuse holder) Non-rejecting, fast-acting fuse and in-line fuse holders Catalog symbol: GLR (fuse) HLR (fuse holder) Ampere Rating: 3/16 - 15 A Voltage Rating: 300 Volts AC or less Interrupting Rating: 10,000 A Agency information Fuse Product features • GLR fuse and knob are an integral one-piece unit. There are no replacement knobs (caps) • Units can be panel mounted with a separate steel clip. For knockout hole mounting (see dimensions), order catalog number BK/A-104. For the keyhole punch type hole mounting, order catalog number 6374 for panels 0.043” to 0.062” thick, or catalog number 4909 for panels 0.030” to 0.042” thick. • The HLR holder comes with 6 inches of red #18 insulated solid copper wire attached to the lineside terminal, customer inserts a #18 insulated solid copper wire into loadside terminal • Order holder catalog number HLR-2A to obtain 6 inches of black #18 insulated solid copper wire pre-installed in the loadside terminal • Order catalog number HLR-2L to obtain 6 inches of black #18 insulated solid copper wire packaged loose (uninstalled) • An alternative to the HLR fuse holder is the “A” fuse holder. The “A” fuse holder comes WITHOUT leads. The customer inserts #18 insulated solid copper wire into the lineside and the loadside terminals. The “A” fuse holder has the same body dimensions, utilizes the same mounting hole, and takes the same mounting clips as the HLR, HLR-2A and HLR-2L • Do not put tension on the fuse holder’s lineside terminal • UL® Listed, Std. 248-14, 3/16-15A/300Vac, Guide JDYX, File E19180 • CSA® Certified, C22.2 No. 248.14, 0-10A/300Vac, Class 1422-01, File 53787 Fuse holder HLR • UL Recognized, 12A, 300Vac, Guide IZLT2, File E14853 • CSA Certified, 12A, 300Vac, Class 6225-01, File 47235 HLR-2A and HRL-2L • UL Recognized, 15A, 300Vac, Guide IZLT2, File E14853 • CSA Certified, 15A, 300Vac, Class 6225-01, File 47235 A • CSA Certified, 10A, 300Vac, Class 6225-01, File 47235 GLR fuse catalog numbers Fuse (amps) GLR-3/16 GLR-1-6/10 GLR-1/2 GLR-2 GLR-1 GLR-3 GLR-1-1/2 GLR-4 GLR-5 GLR-6 GLR-7 GLR-8 GLR-9 GLR-10 GLR-12 GLR-15* * Must be used with the HLR-2A holder rated to 15A. HLR fuse holder catalog numbers Catalog No. Description Holder with installed linseide HLR terminal wire for 3/16 to 12 amp GLR fuses Holder with installed lineside and HLR-2A loadside terminal wires for 3/16 to 15 amp GLR fuses Holder with uninstalled lineside HLR-2L and loadside terminal wires for 3/16 to 15 amp GLR fuses Holder without lineside or loadside A termianl wires for for 3/16 to 15 amp GLR fuses GLR (fuse) HLR (fuse holder) Non-rejecting, fast-acting fuse and in-line fuse holders Technical Data 2032 Effective August 2017 Time-current characteristic curves — average melt 15 7 10 5 100 Amp 2 GLR fuse 1 1.5 Dimensions - in (mm): rating 0.63" (15.9) HLR fuse holder 2.250” (57.1) 0.850” (21.6) Lineside terminal lead Loadside terminal lead Mounting holes 0.255” (6.5) 0.635” (16.1) 0.740” 18.8) 0.410” (10.4) Keyhole punch Current in amps Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2032 BU-MC15051 August 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners. 200 0.01 100 0.1 0.1 Knockout hole 1 10 0.870” (22.1) 10 CL Time in seconds 0.850” 21.6) 1 0.720” (18.3)
GLR-6 价格&库存
很抱歉,暂时无法提供与“GLR-6”相匹配的价格&库存,您可以联系我们找货
