Connectors
Base Mount Double Row Terminal Blocks
Series KU
Specifications
Description: Base mount double row terminal blocks.
Ratings:
Volts: — 600V
Amps: — 60A*
Center Spacing: 0.625” (15.88mm)
Number of Poles: 2- to 12-poles
Wire Range: #6-22 AWG Cu
Screw Size: #10-32
Torque Rating: 20 lb-in.
Distance Between Barriers: 0.437” (11.09mm)
Mounting: Base mount
Material: Molded base: Black, UL rated 94V1 Nuclear
Grade Noryl
Terminal plating: Nickel over brass
Operating Temperature: 105°C max.
Agency Information: UL File E62622, CSA File 47235
Series KU - in (mm)
B
0.62
(15.9)
* 60A rating achieved with #6 copper wire crimped to ring terminal.
KU
A
2.50
3.12
3.75
4.37
5.00
5.62
6.25
6.87
7.50
8.12
8.75
B
1.62
2.25
2.87
3.50
4.12
4.75
5.37
6.00
6.62
7.25
7.87
KUX Only
A
2.00
2.62
3.25
3.87
4.50
5.12
5.75
6.37
7.00
7.62
8.25
#10 screw
clearance
1.25
(31.8)
0.43
(11.1)
0.50
(12.7)
A
Connectors
Poles
02
03
04
05
06
07
08
09
10
11
12
1.50
(38.1)
2.00
(50.8)
Dimensions - in
1” = 25.4mm.
Catalog Number Build-A-Code
Series
Poles
Screw Options
Covers
Marking Strip
02 to 12
00 = Screws shipped bulk
W = Brass washer head,
nickel-plated
P = Steel screw w/pressure plate
zinc-plated
B = Brass washer head, no plating
BP = Brass philslot, nickel-plated
WC = Top cover &
2 end plates
MT = Matte finish
NU = Numbered 1 to 12, horizontal
NUV = Numbered 1 to 12, vertical
PT = Marker strip for cover
02 to 12
nickel-plated
zinc-plated
WC = Top cover &
2 end plates
PT* = Marker strip for cover
KU = Standard block
KUH = Block
KUX = Short block
KURL = Standard w/removable link
KUXRL = Short block w/removable link
Catalog Number - SC Series
KUSC = Standard w/shorting strap
& 4 shorting screws
KUXSC = Short block w/shorting strap
& 4 Shorting screws
*Requires WC cover option
Accessories
MTMU##
Molded Marking Tape
Matte Finish
NUM##
Molded Marking Tape
JU12
Jumper
12 Circuits
NUE
End Piece for NUC
NUC##
Cover
For more information, visit www.cooperbussmann.com
321
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
JU12 KUSC6BPWCPT KUH6B KUX4-W KUXSC6-WC KU2 KU8-NLMT KUSC4 KUSC6-WCPT KUXSC4-W
KUXSC6-WWCPT KUX6-WWCMT KUXSC8 KUX4 KU3 KUSC2 KUSC2-WC KUX8 KU6 KUX6 KUSC6 KUSC8WC KUXSC4 KUX12-MT KUX4-MT KUX4-WMT KUSC6-W KUXSC6 NUM12 KUSC8 KUXRL4 KUXSC6-W
KU12-WC-MT NUE NUC4 KUXSC8-WWCPT KUXRL2-BP KUSC02-WWCMT KUSC4-PWC KUXSC6-PWC KUX03P KURL4-BP KU4-MT KUX-12P KUXRL6-00WCNUV KUX12-W KUH12A KUX8-WNUV KUXSC6-B KU6NLMT KU8-WMT KUTH KUXSC4-00 KU12-NLMT KUSC8-W KU8 KU06-WC-MT KU4 KUXSC4-GE KU12-MT
KU10-WC-MT KUH12C KUSC4-WCNL KUSC6-00W KURL8 KUX12-WC KUSC4-W KUX12-00 KUH12B KUX8-W
KUH6C KUXSC4-WPT KUXRL2 KUXRL6-BP KU4-BPWCMT KUXSC8-BPWC KUX8-MT KU10WWC KURL12BP KU6-WC KU8-MT KU12-WNUV KUXSC6-00 KU4-WMT KU12-WC KUH6A KUX6-MT KU6-WWCNUV
KUSC6-WC KUX-06P KUXSC6-WPT KUX6-W KU12-WMT KU6-BPWCMT KUX8-BP KUXSC8-WPT KUX8-WMT
KUXRL4-BP KUX12-BP KUSC4-WC
很抱歉,暂时无法提供与“KU4-BPWCMT”相匹配的价格&库存,您可以联系我们找货
