Effective December 2015
Supersedes April 2014
Technical Data 2021
BUSSMANN
SERIES
KAZ and MIS 13⁄32˝ x 2˝ 600Vac KAZ actuator
and MIS non time-delay pin indicating
supplemental fuses
Catalog symbol / color code:
KAZ
Black (600Vac max actuator - not a fuse)
0.25 Min. (Blown Position)
(6.35)
0.063 Max. (Unblown Position)
(1.60)
Black (600Vac max 1 to 12A)
Description:
Features:
KAZ is a non-fuse actuator (not a fuse) for use
in parallel with a 50 amp or greater fuse to
provide indication a fuse has opened by
opening at 10 or more amps. The KAZ can also
be applied in a 1-, 2- or 3-pole block with
miniature signaling switches to provide remote
status indication.
KAZ (not a fuse)
MIS fuses are non time-delay pin indicating
supplemental fuses used to provide a visual
indication of an open fuse condition.
Specification:
Ratings
Fuse
amp
range
MIS 1 to 12
KAZ* N/A
MIS Fuse
600Vac
1 to 12A
2.0 ±0.031
(50.8±0.79)
0.406
(10.31)
MIS
KAZ
Acutator
Dimensions - in (mm):
Interrutping rating
at rated voltage
600Vac
200kA
200kA
Agency
information
UL®
CSA®
X
Connects in parallel with fuses having a
rating of 50 amps or more
Opens at 10A or more
Use with Bussmann series signal blocks to
actuate a miniature switch that closes a
signal circuit when the KAZ pin indicator
ejects upon opening
Gives a direct visual indication of an open
fuse by the ejected, spring actuated pin
UL Listed as “fuse accessory”
Mounts in Bussman series signal blocks 2778
(1-pole), 2837 (2-pole) and 2838 (3-pole)
MIS (non time-delay fuse)
* KAZ is not a fuse.
Can be used in circuits of 600Vac or less
KAZ Agency information
200kA Interrupting rating
CE
UL Listed, Guide JDVS, File E58836
Typical applications
KAZ
KAZ Catalog number (not a fuse)
Large shunt-trip fused switches
KAZ
Fuse-protected circuits rated 50 amps or
more with shunt-trip devices
MIS Catalog numbers (amps)
MIS-1
MIS-2
MIS-3
MIS-4
MIS-5
MIS-8
MIS-10
MIS-12
MIS Electrical characteristics
Fuse amps
All
% of amp rating
110%
1-5A
6-12A
150%
150%
Opening time
4 kours
minimum
6 minutes max
12 minutes max
MIS
480V Control circuits
PLC Circuits
Recommended fuse blocks /
fuseclips:
Catalog No.
Description
2778
1-pole block (KAZ Only) *
2837**
2-pole block (KAZ Only) *
2838**
3-pole block (KAZ Only) *
1A3400, 5956
and 5960
PCB fuseclips
* See next page for details.
**Includes fuseclips to hold spare KAZ.
Data sheet No.
2132
Technical Data 2047
KAZ and MIS
600Vac Acutator (KAZ) and
Non time-delay pin indicating supplemental fuses (MIS)
Fuse block with miniature signaling switches for KAZ only
Voltage
600V
Agency information
UL Recognized, Guide QEUY2, File E61918
Dimensions ± 1/31” (0.8mm)
Cat. No.
Poles
2778
1
2837*
2
2838*
3
Inches/(mm’s)
A
B
1.75
(44.5)
5.31
4.81
(134.9)
(122.2)
6.63
6.125
(168.3)
(155.6)
C
2.5
(63.5)
3
(76.2)
3
(76.2)
Mounting data
Hole
C’Bore
Screw
1.73
0.328
#8
0.250
#12
* Includes fuseclips to hold spare KAZ.
3.75" C
0.250"
(6.4)
(95.3)
B
A
0.36"
1.94"
(9.1)
(49.2)
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 2011 – BU-SB14290
December 2015
Eaton, Bussmann and Low-Peak are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“MIS-12”相匹配的价格&库存,您可以联系我们找货
