BASE STATION OMNI ANTENNAS
S8xxxB
800/900 MHz OMNIDIRECTIONAL ANTENNAS
Omnidirectional antennas are the right choice for situations where you need to
be in contact with sources that are in two directions or if you do not know what
direction the signals will be coming from.
Standard data transmission omnis are fully decoupled antennas built on a copper
laminate and housed in 0.100 inch wall fiberglass housings. They may be mounted right
side up or tipped upside down depending upon the desired pattern. They also feature a
very versatile clamp mounting system that will fit most every situation you will
encounter.
FEATURES
MARKETS
• Broadband performance
• Fiberglass enclosures
• DC grounded
• Plated copper laminated radiator
• Weatherproof designs with UltraLink pigtail • Omnidirectional
• WiMAX
• Two-way dispatch
ANTENNA PATTERNS
S8060B
S8063B
S8064B
SPECIFICATIONS
MODEL FREQ. MHz
VSWR
BANDWIDTH -3 dB BMWIDTH TYPE
E-PLANE
(FEMALE)
(NOMINAL) 1.5:1 MHz
HEIGHT
in(cm)
WEIGHT W/SUR AREA W/SURVIVAL
lb(kg)
ft2 (m2)
mph(kph)
42-1/8 (107) 1.56 (0.70)
0.22 (0.02)
PIGTAIL
in(cm)
S8964B
896-960
1.5:1
64
25°
N
125 (200)
23
S8963B
896-960
1.5:1
64
45°
N
30-3/4 (78) 1.19 (0.53) 0.176 (0.016)
125 (200)
23
S8960B
896-960
1.5:1
64
75°
N
17-1/2 (44.5) 0.56 (0.25) 0.083 (0.009)
125 (200)
17
S8804B
880-960
1.5:1
62
25°
N
125 (200)
23
S8803B
880-960
1.5:1
62
45°
N
125 (200)
23
S8800B
880-960
1.5:1
62
75°
N
125 (200)
17
S8244B
824-896
1.5:1
62
25°
N
125 (200)
23
S8243B
824-896
1.5:1
62
45°
N
125 (200)
23
S8240B
824-896
1.5:1
62
75°
N
125 (200)
17
S8064B
806-868
1.5:1
62
25°
N
125 (200)
23
S8063B
806-868
1.5:1
62
45°
N
125 (200)
23
S8060B
806-868
1.5:1
62
75°
N
125 (200)
17
0.22 (0.02)
0.22 (0.02)
0.22 (0.02)
Common speci ications: Power handling - 5 watts; Element material - plated copper laminate;
Enclosure material - fiberglass; Mounting style - tube end; Maximum mast diameter - 2 in (5.1 cm)
Americas: +1.847 839.6925
IAS‐AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS‐EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS‐AsiaSales@lairdtech.com
www.lairdtech.com
ANT-DS-S8xxxB 1215
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or
suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold
pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved.
Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names
may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“S8963B”相匹配的价格&库存,您可以联系我们找货
