MASONRY 1/4 BIT (POP)
1/4 MASONRY DRILL BIT (POP)
Cat No:
MAS-1/4
UPC No:
783310263227
Description
One piece hardened carbon steel body and hex shank for a stronger, more concentric bit that will
not disassemble whendrilling in deep or tough materials
Carbide grade tip for faster penetration and longer bit life
Hammer drill rated for usein either standard or hammer drills
1/4 IN quick-change hex for fast bit changes. Use in quick-change chucks, conventionaladjustable
drill chucks, and hex adapters for more versatility
Set includes diameters andlengths most commonly used byelectricians
Specifications
Application : For Use In Either Standard OrHammer Drills
Bit Diameter : 1/4 IN
Case Dimensions : 1.900 IN X 6.300 IN X 0.250 IN
Material : Hardened Carbon Steel With Carbide Tip
Package : 1/Box
Shank Type : Hexagonal
Weight : 0.100 LB
很抱歉,暂时无法提供与“MAS-1/4”相匹配的价格&库存,您可以联系我们找货
