JP-25182-@
(Small Telecom Clip with Bed of Nails)
JP-25182/JP25182-S
JP-25182-N/JP25182-SN
JP-25182-J/JP-25182-TJ
• The JP-25182 is the smaller version of the JP-8783. Intended for
applications that do not require the single spike. Jaws open to a maximum
of 1.0” (25.4mm).
• Overall length 2.34” (59.4mm) (Except where noted)
• Material: Clip
Nickel Silver (Except where noted)
Hardware Brass
• RoHS 3 compliant
• The JP-25182 is sold as is or with the following suffixes:
Blank
Has wire mounting hardware installed
-N
No wire mounting (used if you want to solder wire to clip)
-L
Wire mounting hardware included but not installed
-J
4mm banana jack installed (increases length to 2.9” (74mm))
-TJ
8-32 threaded banana jack installed (Increases to 2.9” (74mm))
-S
Same as {Blank} except material is nickel-plated steel
-SN
Same as {-N} except material is nickel-plated steel
-SL
Same as {-L} except material is nickel-plated steel
Mueller Electric Company
2850 Gilchrist Rd. Bld 5A
Akron, OH 44305
www.muellerelectric.com
Toll Free: 800.955.2629
Phone: 330.780.2525
Fax: 330.780.2524
很抱歉,暂时无法提供与“JP-25182-J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+87.36168
- 15+85.93499
- 50+84.51871
- 国内价格
- 1+216.42611
- 2+195.31137
