DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - FEMALE - IP67
SPECIFICATIONS:
ELECTRICAL:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
SIGNAL CONTACT RESISTANCE:
POWER PINS:
SIGNAL PINS:
1.543 [39.20]
±0.010 [±0.25]
1.311 [33.30]
±0.010 [±0.25]
Ø 0.120 [Ø 3.05]
2-PLACES
0.969 [24.60]
±0.010 [±0.25]
6 5
4
A1
3
2 1
5 GΩ MIN.
1000 VAC FOR 1 MIN
250V
-55°C TO +125°C
1.0 mΩ MAX.
10 mΩ MAX.
40 AMPS
5 AMPS
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE:
4.5 Kg MAX.
0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SEAL:
SHELL:
HARDWARE:
F08 FLEXIBLE ADHESIVE
NICKEL PLATED STEEL
NICKEL PLATED BRASS
230°C PROCESS TEMP.
10 9
0.112 [2.84]
8
7
10°
SEE SHEET 2 FOR
PIN DIMENSIONS
0.311 [7.90]
±0.010 [±0.25]
681S11W1203LYYY
0.492 [12.50]
±0.010 [±0.25]
0 = 40 AMP
0 = NO HARDWARE
4 = 0.237" BOARDLOCK PCB SIDE
0.228 [5.80]
0.031 [0.80]
±0.008 [±0.20]
1 = GOLD FLASH
MEETS IP67 STANDARDS
0.421 [10.70]
(SEE PAGE 2 FOR SEALING DETAILS)
SEE SHEET 2
FOR DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
4
681S11W1203LYYY
2
DESCRIPTION: 681 SERIES CONTACTS
NOTE:
SIGNAL AND POWER CONTACTS
COME PRE-LOADED INTO INSULATORS
Ø 0.026
[0.65]
A
0.112
[2.84]
0.22 ± .012
[5.60 ± 0.30]
A
FRONT SEAL APPLIED BETWEEN
FRONT INSULATOR AND
FRONT METAL SHELL
SIGNAL CONTACTS
MIDDLE SEAL APPLIED BETWEEN
FRONT INSULATOR AND
BACK INSULATOR
0.209 ± 0.012
[5.30 ± 0.30]
0.031 ± 0.012
[0.80 ± 0.30]
DETAIL A-A
SHOWN FOR REFERENCE ONLY
Ø 0.148
[3.75]
0.059 ± 0.012
[1.50 ± 0.30]
POWER CONTACTS
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
4
681S11W1203LYYY
2
DESCRIPTION: PCB LAYOUT
1.311 [33.30]
0.381 [9.68]
0.381 [9.68]
0.272 [6.91]
0.272 [6.91]
0.163 [4.14]
0.163 [4.14]
0.112 [2.84]
Ø 0.130 [Ø3.30]
2-PLACES
0.218
[5.54]
0.218
[5.54]
0.327
[8.31]
0.327
[8.31]
Ø 0.043 [Ø1.10]
10-PLACES
Ø 0.165 [Ø4.20]
1-PLACE
RECOMMENDED PCB LAYOUT
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
4
681S11W1203LYYY
2
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
0 ..... NO HARDWARE
RoHS COMPLIANT
N
C
4 ..... 0.237" PCB SIDE
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
ALL DIMENSIONS ARE ±0.010
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
4
4
681S11W1203LYYY
2
很抱歉,暂时无法提供与“681S11W1203L001”相匹配的价格&库存,您可以联系我们找货
