D-SUBMINIATURE
D* KL Series
HTD/HPD Series
D* A Series
Overmold Kits
D* U Series
T* Series
Basic D Series
Series 1 - High Reliability
Series 3 - High Reliability
M24308 Series
Backshells/Junctionshells/Hoods
Accessories
Application Tooling
The D-subminiature is one of the most popular styles of connectors in the I/O category. It is used in computer,
telecom, datacom, medical, and test instrumentation applications as well as in the military and aerospace fields.
Types of D-subminiature connectors manufactured by Cinch
• Printed Circuit Board connectors:
- Vertical connectors for panel mounting with Dip Solder PC tails.
- Right-Angle connectors for board mounting with Dip Solder PC tails.
• Wire Termination connectors for cable assemblies or wire harnesses:
- Crimp and Poke connectors.
- Solder Cup connectors.
- Insulation Displacement connectors IDCS to terminate discrete wire or flat cable.
- Wire Wrap connectors.
How to read this section
• The information pages provide standard data common to all D-subminiature connectors. These include:
D-subminiature contact arrangements - see page 4-5.
Panel mounting specifications/hardware - see page 4-6.
D-subminiature shell dimensions - see page 4-7.
D-subminiature and combo D layouts - see pages 4-5, 4-8 thru 4-10, and 4-56.
General Performance Specifications - see page 4-2.
PCB thickness chart - see page 4-8.
• D-subminiature pages are grouped by series. A series is a family of connectors with a similar performance level.
Each series shares a set of features and specifications, from economical and commercial grade product to
high-reliability and military connectors. Each series begins with a page outlining general features and
specifications of connectors, followed by the pages on individual connectors with drawings or features specific
to that connector. Drawings reflect clarifications of dimensions not called out in the information pages of this
catalog. The features of each series can be found in the chart on page 4-4.
• Accessories including backshells, junction shells, and hoods as well as hardware can be found on pages 4-80
thru 4-99.
• Termination tooling for Cinch connectors can be found at the end of the D-subminiature section of this
catalog on pages 4-100 thru 4-104.
4-1
Call Toll Free: 1 (800) 323-9612
General Information
• All connectors are intermateable with any Cinch D-subminiature of comparable pin count and density, or the
D-sub connector of any other manufacturer complying dimensionally with MIL-C-24308.
• Solder terminations and boardlocks meet the requirements for solderability in accordance with MIL-STD-202,
Method 208.
• DURABILITY
- Mated connectors are subjected to cycles of insertions and withdrawals specified on the catalog
page. After the prescribed cycles the connectors will meet the Cinch requirements concerning insertionwithdrawal force, individual contact insertion-withdrawal force, and contact resistance.
• APPROVALS
- Most Cinch connectors have UL recognition and CSA approval; however, the specific approvals are listed
on the individual catalog pages.
• CONTACTS
Cinch connector contacts are generally offered in Gold Flash or 30µin. gold plating for commercial product,
and 50µin. gold plating for M24308 Series Military D-subminiature connectors.
Cinch connectors utilize economical stamped and formed contacts and/or screw machine contacts for
enhanced performance.
Standard density connectors utilize size 20 contacts.
Cinch 1.5 Density Series connectors utilize size 22 contacts for greater density in a standard size
D-subminiature outer shell.
• METAL SHELLS
Commercial-grade steel shells are usually available in zinc plating with yellow chromate finish or tin plating.
Tin-plated plugs have grounding indents.
Military grade M24308 Series connector shells are generally steel or in certain cases non-magnetic brass with
cadmium plating and yellow chromate finish.
Insulator materials are glass-filled polyester, glass-filled nylon, and diallyl phthalate.
• The connectors are usually available in plugs and sockets in 9, 15, 25, 37, and 50 position sizes.
4-2
Printed Circuit Board Connectors
• Cinch provides connectors in various footprints, contact diameters, and lengths in both vertical and right-angle
PC mount styles with dip solder tails.
• Cinch PCB connectors have metal shells.
Connectors for Terminating Cable Wire
• Wire Wrap connectors are available in two tail lengths for two-wrap and three-wrap terminations. The contact
is terminated by wrapping wire around it using a wire wrap gun. This connector is especially useful for
prototyping since the wire can be unwrapped and rewrapped if necessary.
• Solder Cup connectors allow reliable long-term termination by soldering the wire directly into the connector
contact. Cinch Solder Cups accommodate up to 20 AWG wire.
• Crimp and Poke connectors allow the wire to be terminated more economically than wire wrap or solder cup
styles. Contacts are crimped and inserted into the connector. In our D*U Series, the contact is crimped around
the conductor wire. In our D*A Series, the contact is crimped around the wire and the insulation. Crimp and Poke
connectors can be selectively loaded to save labor and material cost.
• IDC connectors are an alternative to other types of wire termination connectors. IDC is much faster and very
reliable when all contacts are terminated and the volume is high. IDC utilizes mass termination of the cable wire.
This can save considerable time and expense in the cable assembly process. The estimated time of terminating
two ends of a 25-conductor discrete wire cable with 25-position D-subminiature connectors is about 5-1/2 to 6
minutes less per cable assembly using IDC connectors and Cinch Auto-Clinch termination tooling versus using
Crimp and Poke connectors. This may vary considerably based on the operator, cable wire, and process.
Cinch offers IDC connectors in two versions-for discrete wire or flat ribbon termination.
4-3
Feature Guide
The chart below contains Cinch D-subminiature product features and styles grouped by series.
Performance Level
Series
Economical
D*KL
Termination Type
Vertical PCB
Right-Angle PCB
Crimp and Poke
Solder Cup
IDC
Wire Wrap
Insulator Material
G-F Nylon
G-F Polyester
Diallyl Phthalate
Shell Material
All Plastic
Steel Shell
Shell Plating
Tin-Lead Plating
Zinc Plating-Y/C finish
Cadmium Plating-Y/C finish
HPD/HTD
Commercial
D*A
4-12
4-12
D*U
T
4-26
4-16
4-16
4-26
4-20
4-26
4-34
4-34
High-Reliability
Basic D
Series 1
4-42
4-50
4-76
4-50
4-76
4-42
Series 3
Military
M24308
4-72
4-50
4-76
4-76
4-42
Contact Plating
Gold-Flash Plating
30µin. Gold Plating
50µin. Gold Plating
Contact Type
Stamped Contacts
Machined Contacts
Accessories information starts on page 4-80.
Tooling information starts on page 4-100.
* Applies to Combination Layout Only.
4-4
Standard Density Plug Inserts
NOTE: Mating face of plug is shown; socket is mirror image.
4-5
Panel Mounting Specifications
Dimensions
Shell
Size
E
A
B
C
D
Mounting Method
Front/
Positions
Rear Panel
in
Front
0.98
9
Rear
0.98
Front
1.31
15
Rear
1.31
Front
1.85
25
Rear
1.85
Front
2.50
37
Rear
2.50
Front
2.41
50
Rear
2.41
A
mm
24.89
24.89
33.27
33.27
46.99
46.99
63.50
63.50
61.21
61.21
B
in
0.49
0.49
0.66
0.66
0.93
0.93
1.25
1.25
1.20
1.20
mm
12.45
12.45
16.76
16.76
23.62
23.62
31.75
31.75
30.48
30.48
in
0.87
0.81
1.10
1.13
1.74
1.67
2.39
2.33
2.30
2.22
C
mm
22.10
20.57
27.94
28.70
44.20
42.42
60.71
59.18
58.42
56.39
D
in
0.44
0.40
0.60
0.57
0.87
0.84
1.20
1.16
1.15
1.11
E
mm
11.18
10.16
15.24
14.48
22.10
21.34
30.48
29.46
29.21
28.19
in
0.51
0.45
0.51
0.45
0.51
0.45
0.51
0.45
0.62
0.56
mm
12.95
11.43
12.95
11.43
12.95
11.43
12.95
11.43
15.75
14.22
F
in
0.26
0.23
0.26
0.23
0.26
0.23
0.26
0.23
0.31
0.28
mm
6.60
5.84
6.60
5.84
6.60
5.84
6.60
5.84
6.60
5.84
PANEL MOUNTING HARDWARE: Aids in alignment of plug and receptacle.
Float Bushing
Reverse Float Bushing
Rear panel mounting
Front panel mounting
Floating Dual Bushing
4-40 Clinch Nut
Rear panel mounting
Front and rear panel mounting
4-6
H
in
0.08
0.13
0.08
0.13
0.08
0.13
0.08
0.13
0.08
0.13
mm
2.03
3.30
2.03
3.30
2.03
3.30
2.03
3.30
2.03
3.30
Two Holes
.120 + .005 (3.05 + 0.13) Dia.
Termination Side
Mating Side
Shell
Connector
Size Positions Type
E
9
A +.015"
(0.38mm)
in
mm
B +.010"
(0.25mm)
in
mm
B1 +.005"
(0.13 mm)
in
mm
Plug
1.213
30.81
.666
Socket
1.213
30.81
.640
16.26
1.541
39.14
A
15
Plug
Socket
1.541
39.14
.968
24.59
B
25
Plug
2.088
53.04
1.534
Socket
2.088
53.04
1.508
38.30
C
37
Plug
2.729
69.32
Socket
2.729
69.32
2.156
54.76
D
50
Plug
2.635
66.93
2.079
Socket
2.635
66.93
2.062
52.34
Shell
Connector
Size Positions
Type
E
9
G +.010"
(0.25mm)
in
mm
H +.010"
(0.25mm)
in
mm
16.90
.994
25.30
-39.00
2.182
55.40
-52.80
J +.010"
(0.25 mm)
in
mm
C +.005"
(0.13mm)
in
mm
D +.010"
(0.25mm)
in
mm
D1 +.010"
(0.25mm)
in
mm
E +.010"
(0.25mm)
in
mm
0.984
24.99
.329
8.40
.494
0.984
24.99
.308
7.82
.494
12.55
1.312
33.32
.329
8.40
.494
12.55
1.312
33.32
.308
7.82
.494
12.55
1.852
47.04
.329
8.40
.494
12.55
1.852
47.04
.308
7.82
.494
12.55
2.500
63.50
.329
8.40
.494
12.55
2.500
63.50
.308
7.82
.494
12.55
2.406
61.11
.436
11.07
.605
15.37
2.406
61.11
.605
15.37
K +.005"
(0.25mm)
in
mm
.420 10.67
L +.010"
(0.25mm)
in
mm
M +.010"
(0.25mm)
in
mm
Plug
.759
19.28
.422 10.72
.030
0.76
.236
5.99
.045
1.14
.422
Socket
.759
19.28
.422 10.72
.030
0.76
.243
6.17
.045
1.14
.429
10.72
10.92
1.083
27.51
.422 10.72
.030
0.76
.236
5.99
.045
1.14
.422
10.72
A
15
Plug
Socket
1.083
27.51
.422 10.72
.030
0.76
.253
6.17
.045
1.14
.429
10.92
B
25
Plug
1.625
41.27
.422 10.72
.039
0.99
.231
5.87
.060
1.52
.426
10.82
Socket
1.625
41.27
.422 10.72
.030
0.76
.243
6.17
.045
1.14
.429
10.92
C
37
Plug
2.272
57.71
.422 10.72
.039
0.99
.231
5.87
.060
1.52
.426
10.82
Socket
2.272
57.71
.422 10.72
.030
0.76
.243
6.17
.045
1.14
.429
10.92
D
50
Plug
2.178
55.32
.534 13.56
.039
0.99
.231
5.87
.060
1.52
.426
10.82
Socket
2.178
55.32
.534 13.56
.030
0.76
.243
6.17
.045
1.14
.429
10.92
B and D are outside dimensions for socket. D and B are inside dimensions for plug.
4-7
12.55
Standard Density D-subminiature
Mounting Dimensions Board Layouts
Footprints (Component side shown)
9 Position
Shell Size E
25 Position
Shell Size B
15 Position
Shell Size A
PC Board Lead Hole Size
The footprints on this page are standard for all metal
shell D-subminiature connectors.
Terminal Dia. Hole
in
mm
.040
1.02
.030
0.76
.024-.025 0.61-0.64
On all right-angle D-subminiature connectors, the
short row of contacts is positioned closest to the
edge of the board.
4-8
Dia.
in
.055
.045
.039
mm
1.40
1.14
0.99
37 Position
Shell Size C
50 Position
Shell Size D
Terminal Dia. Hole
in
mm
.040
1.02
.030
0.76
.024-.025
0.61-0.64
edge of the board.
4-9
Dia.
in
.055
.045
.039
mm
1.40
1.14
0.99
1.5 Density D-subminiature
Recommended PCB Layout for
Footprint (Component side shown)
15 Position
Shell Size E
44 Position
Shell Size B
62 Position
Shell Size C
26 Position
Shell Size A
Terminal Dia. Hole
in
mm
.040
1.02
.030
0.76
.024-.025
0.61-0.64
edge of the board.
4-10
Dia.
in
.055
.045
.039
mm
1.40
1.14
0.99
■ Offered in right-angle or vertical PCB mount versions.
■ Available with gold flash or 30µin. gold plating.
■ Metal Shell provides grounding and shielding capability.
■ Approvals:
• UL Recognized: File E130965.
• CSA Approved: File LR97981.
■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel
mounting specifications.
Insulator Material: Glass-filled polyester (black),
UL 94V-O rated
Contact Material: Socket - Phosphor bronze (stamped)
Plug - Brass (stamped)
Contact Plating: Gold flash or 30µin. gold in mating area and
tin/lead on tails. All over nickel.
Metal Shell: Steel with tin plating (grounding indents on plug)
Operating Temperature: -55°C to +125°C
Shock: 50G peak per MIL-STD-202, Method 213, Condition G
Vibration: 12 cycles in three perpendicular directions @
10-2000Hz, per MIL-STD-202, Method 204,
Condition D
Moisture Resistance: 90-95% relative humidity @ 40°C for 96
hours per MIL-STD-202, Method 103
Withstanding Voltage:
Current Rating:
Contact Resistance:
Insulation Resistance:
Right Angle - minimum AC 1250V
RMS @ sea level, Vertical minimum AC
1000V RMS @ sea level
5 Amps
15 milliohms maximum
5000 megohms maximum (initial);
1000 megohms (minimum) after
environmental testing
Individual Contact Insertion and
Separation Force (minimum/maximum): 0.7 oz./12 oz.
Durability: 500 mating cycles
4-12
Right-Angle Connectors
0.318" footprint.
Available in 9, 15, and 25 position plugs and sockets.
Offered with 4-40 threaded inserts for secure mounting to panels or with female screwlocks.
Boardlocks to provide mechanical hold-down during wave soldering process.
• Materials:
Boardlock: Brass with tin plating.
Female Screwlock: Brass with nickel plating.
Ordering Information
Right-Angle Plugs
4-40 Threaded Inserts
Female Screwlocks
Size
Gold Flash
30µin. Gold
Gold Flash
9
30µin. Gold
DEKL-9PATI-E
DEKL-9PATI-E2
DEKL-9PATI-F
DEKL-9PATI-F2
15
DAKL-15PATI-E
DAKL-15PATI-E2
DAKL-15PATI-F
DAKL-15PATI-F2
25
DBKL-25PATI-E
DBKL-25PATI-E2
DBKL-25PATI-F
DBKL-25PATI-F2
Right-Angle Sockets
Female Screwlocks
Size
Gold Flash
30µin. Gold
Gold Flash
30µin. Gold
9
DEKL-9SAT-E
DEKL-9SAT-E2
DEKL-9SAT-F
DEKL-9SAT-F2
15
DAKL-15SAT-E
DAKL-15SAT-E2
DAKL-15SAT-F
DAKL-15SAT-F2
25
DBKL-25SAT-E
DBKL-25SAT-E2
DBKL-25SAT-F
DBKL-25SAT-F2
4-13
• Vertical Connectors:
Available in 9, 15, 25, 37, and 50 position plugs and sockets with straight dip solder tails.
0.024" contact diameter.
Offered with standard mounting holes.
Plug
Vertical PCB Connectors
Plugs
Sockets
Size
Gold Flash
30µin. Gold
9
Gold Flash
30µin. Gold
DEKL-9PUTI
DEKL-9PUTI-2
DEKL-9SUT
DEKL-9SUT-2
15
DAKL-15PUTI
DAKL-15PUTI-2
DAKL-15SUT
DAKL-15SUT-2
25
DBKL-25PUTI
DBKL-25PUTI-2
DBKL-25SUT
DBKL-25SUT-2
37
DCKL-37PUTI
DCKL-37PUTI-2
DCKL-37SUT
DCKL-37SUT-2
50
DDKL-50PUTI
DDKL-50PUTI-2
DDKL-50SUT
DDKL-50SUT-2
4-14
■ 1.5 Density means the connector uses small size #22 contacts for a higher pin count in a
standard size shell. Also accepts standard D-subminiature accessories (hoods, backshells, etc.)
per the following chart:
1.5 D-sub
Standard D-sub
Shell Size
No. of Pins
No. of Pins
E
15
9
A
26
15
B
44
25
C
62
37
■ Offered in cable plugs and right-angle PCB mount sockets.
■ Approvals:
Plugs: • UL Recognized - Files E170218 (UL1977) & E130965 (UL1863).
• CSA Approved - File LR31996-7.
Sockets: UL Recognized - File E170218.
Connector Shell: Steel with tin plating (grounding indents on plug)
Contact Material: Phosphor bronze (stamped)
Contact Plating:
• Sockets: Gold flash or 30µin. gold in mating area and tin/lead
• Plugs: Gold flash or 30µin. gold in mating area and gold flash on
remainder. All over nickel.
Vibration: 12 cycles in three perpendicular directions @10-2000Hz,
per MIL-STD-202, Method 204, Condition D
hours per MlL-STD-202, Method 103
Current Rating:
Contact Resistance:
Minimum 1000V RMS @ sea level
3 Amps
Durability:
• Plugs - 200 mating cycles
• Sockets - 200 mating cycles
4-16
Connectors:
Offered with .120 mounting holes.
Shells offered with tin plating and grounding indents.
These connectors are designed to accommodate one repair cycle.
Contacts: (Not included with connectors, order separately)
• Available with gold-flash plating or 30µin. gold.
Crimp and Poke versions are offered in reels of 15,000 or 300 contacts.
Solder and Poke contacts are packed loose.
Will accommodate 22-30 AWG wire.
Order contacts separately. See page 4-18.
Termination Tooling:
Semi-automatic Stripper Crimper Tool for 15,000 reels: #HTD-518. See page 4-102.
Crimp Contact Hand Tool for 300-piece reels: #HTD-266. See page 4-101.
Semi-automatic Hand Crimping Tool for individual contact termination: #HTD-544. See page 4-101.
Contact Insertion/Extraction Tool: Cinch #CIET-22-DF. See page 4-101.
Materials:
Insulator Material: Black UL 94 V-0 glass-filled nylon.
HTD Series 1. 5 Density Crimp and Poke Plug Connectors
Size
15
26
44
62
Shell Size
E
A
B
C
Catalog Number
HTDE-15PTI-FO
HTDA-26PTI-FO
HTDB-44PTI-FO
HTDC-62PTI-FO
4-17
• Use with HTD Series 1.5 D-Sub Crimp and Poke connectors and overmold kits.
All Crimp and Poke contacts are on right-hand feed reels.
Crimp and Poke Plug Contact
Solder and Poke Plug
HTD Series 1. 5 D-sub Male Crimp and Poke and Solder and Poke Contacts
Type of
Crimp and Poke
Packing
15,000 Reel
Plating
Gold Flash
30µin. Gold
Pin
HTD-CP-9-15000 HTD-CP-1-15000
Crimp and Poke
300 Reel
Gold Flash
30µin. Gold
HTD-CP-9-300 HTD-CP-1-300
4-18
Solder and Poke
Loose
Gold Flash
30µin. Gold
HTD-SP-9-10 Not Available
.350" footprint.
Offered with fixed 4-40 threaded inserts for secure mounting to panels or with assembled female screwlocks.
Boardlocks to maintain electrical continuity between shell and PC board ground and provide mechanical
Available in standard configuration sockets, sizes 15, 26, 44, and 62 with black insulator.
15 position socket also available with royal blue insulator in Windows ‘95® configuration with Pin #9
recessed 0.050".
Materials:
Insulator Material: Glass-filled polyester (standard configuration - black, -9R configuration - blue),
UL 94V-0 rated.
Female Screwlock: Brass with Nickel plating.
WITH #4-40 FEMALE SCREWLOCKS
(ASSEMBLED)
Dimensions
Positions
15
26
44
62
A
+.015 (+0.038)
in
mm
1.214
30.84
1.545
39.24
2.088
53.04
2.730
69.34
+.010
in
0.984
1.312
1.852
2.500
B
(+0.25)
mm
24.99
33.32
47.04
63.50
+.010
in
0.640
0.967
1.508
2.156
C
(+0.25)
mm
16.26
24.56
38.30
54.76
D
in
0.090
0.090
0.090
0.095
mm
2.29
2.29
2.29
2.41
HPD Series 1.5 Density Right-Angle Socket Connectors
Size
15
26
44
62
15
Shell
Size
E
A
B
C
E
Type
Standard
Standard
Standard
Standard
Windows ‘95®
Color
Black
Black
Black
Black
Blue
Gold Flash
30µin. Gold
HPDEB-15SAT-E
HPDEB-15SAT-E2
HPDAB-26SAT-E
HPDAB-26SAT-E2
HPDBB-44SAT-E
HPDBB-44SAT-E2
HPDCB-62SAT-E
HPDCB-62SAT-E2
HPDEB-15SAT-E-9R HPDEB-15SAT-E2-9R
Female Screwlocks
Gold Flash
30µin. Gold
HPDEB-15SAT-F
HPDEB-15SAT-F2
HPDAB-26SAT-F
HPDAB-26SAT-F2
HPDBB-44SAT-F
HPDBB-44SAT-F2
HPDCB-62SAT-F
HPDCB-62SAT-F2
HPDEB-15SAT-F-9R HPDEB-15SATF2-9R
Windows '95 is a registered trademark of Microsoft.
4-19
■ Offered in 9, 15 , 25, 37, and 50 position plugs and sockets.
■ Contacts:
- Available with gold flash or 30µin. gold plating.
- Offered in 15,000 contact reel or 300 contact reel, or in loose-piece bags of 100 or 1000 each.
- Accommodate 20-24 AWG wire or 26-30 AWG wire.
- Not included with connector - order stamped contacts separately.
■ Approvals:
- UL Recognized - Files E170218 (UL1977) and E130965 (UL1863).
- CSA Approved - File LR31996.
Insulator Material: Glass-filled nylon (black), UL 94 V-O rated
Connector Shell: Steel with zinc plating and yellow chromate finish or tin
plating (plug has grounding indents)
Contact Material:
• Plug - Brass (stamped)
• Socket - Phosphor bronze (stamped)
Contact Plating: Gold flash or 30µin. gold in mating area and gold flash
on the remainder. All over nickel.
4-40 Clinch Nut: Steel with cadmium plating and yellow chromate finish
Dual Float Bushing: Stainless steel, passivated
Operating Temperature: -65°C to + 125°C
Vibration: 12 cycles in three perpendicular directions @ 10-2000Hz, per
Moisture Resistance: 90-95% relative humidity @ 40°C for 96 hours per
Current Rating:
Contact Resistance:
5 Amps
2.7 milliohms maximum
4-20
Offered with .120 mounting holes or 4-40 clinch nuts.
.453 (11.51) MAX.
Termination Tools
Semi-Automatic Stripper Crimper Tool for 15K reels: #GSC-20-30. See page 4-102.
Contact Insertion/Extraction Tool: #CIET-20-HDB. See page 4-101.
Crimp Contact Hand Tool for 300-piece reels: #GHC-B (20-26 AWG wire) or Catalog #GHC-B1
(28-30 AWG wire). See page 4-101.
Crimp Contact Hand Tool for loose piece contacts: #HTD-544. See page 4-101.
D*A Series Crimp and Poke Connectors - Plugs
Zinc-plated shell with yellow chromate finish
Positions
9
Tin-plated shell with grounding indents
Mounting Holes
4-40 Clinch Nuts
Mounting Holes
4-40 Clinch Nuts
DEA-9P-FO
DEAE-9P-FO
DEA-9PTI-FO
DEAE-9PTI-FO
15
DAA-15P-FO
DAAE-15P-FO
DAA-15PTI-FO
DAAE-15PTI-FO
25
DBA-25P-FO
DBAE-25P-FO
DBA-25PTI-FO
DBAE-25PTI-FO
37
DCA-37P-FO
DCAE-37P-FO
DCA-37PTI-FO
DCAE-37PTI-FO
50
DDA-50P-FO
DDAE-50P-FO
DDA-50PTI-FO
DDAE-50PTI-FO
D*A Series Crimp and Poke Connectors - Sockets
Positions
Tin-plated shell
Mounting Holes
4-40 Clinch Nuts
Mounting Holes
4-40 Clinch Nuts
DEA-9S-FO
DEAE-9S-FO
DEA-9ST-FO
DEAE-9ST-FO
15
DAA-15S-FO
DAAE-15S-FO
DAA-15ST-FO
DAAE-15ST-FO
25
DBA-25S-FO
DBAE-25S-FO
DBA-25ST-FO
DBAE-25ST-FO
37
DCA-37S-FO
DCAE-37S-FO
DCA-37ST-FO
DCAE-37ST-FO
50
DDA-50S-FO
DDAE-50S-FO
DDA-50ST-FO
DDAE-50ST-FO
9
4-21
Contacts
Pin
Socket
D*A Series Crimp and Poke Contacts on Reels
Contacts per Reel
Wire Gauge
Plating
15,000
15,000
20-24 AWG
Gold Flash 30µin. Gold
DGP-15-1
DGP-15-2
Pin
DGS-15-1
Socket
DGS-15-2
300
300
26-30 AWG
20-24 AWG
26-30 AWG
DGP-15-3
DGP-15-4
DGP-3-1
DGP-3-2
DGP-3-3
DGP-3-4
DGS-15-3
DGS-15-4
DGS-3-1
DGS-3-2
DGS-3-3
DGS-3-4
D*A Series Crimp and Poke Loose-Piece Contacts
Contacts per Bag
Wire Gauge
100
100
20-24 AWG
30µin Gold
1000
26-30 AWG
Gold Flash
20-24 AWG
26-30 AWG
Gold Flash
30µin. Gold
Gold Flash
Pin
DGP-100L-1 DGP-100L-2
DGP-100L-3 DGP-100L-4
DGP-1000L-1 DGP-1000L-2 DGP-1000L-3 DGP-100L-4
Socket
DGS-100L-1 DGS-100L-2
DGS-100L-3 DGS-100L-4
DGS-1000L-1 DGS-1000L-2 DGS-1000L-3 DGS-100L-4
4-22
Gold Flash
30µin. Gold
Plating
30µin Gold
1000
■ Cinch overmold kits enable you to overmold the connector of the cable assembly for less
material and process cost (versus a metal backshell), improved appearance, and improved
shielding of the connector to help meet RFI/EMI requirements.
■ An Overmold Kit catalog number consists of:
- D*A or HTD Crimp and Poke connector.
- Inside shielding cover.
- Outside shielding cover.
■ You will also need to order the following:
- Crimp and Poke stamped contacts must be ordered separately on page 4-22 for D*A
and page 4-18 for HTD connectors.
- Ferrules are required, but must be ordered separately according to the size necessary to
accommodate the wire. See page 4-25.
- Termination tooling is required to crimp the wires on the connector.
- A hand tool and appropriate crimping die are required for crimping the ferrule.
■ All specifications on the connector portion of the overmold kit can be found on pages 4-16 thru
4-17 for HPD 1.5 density and pages 4-20 thru 4-21 for D*A series.
Shield Covers: Steel (stamped) with tin/lead finish
Ferrule: Brass
Dimensions
Overmold Shielding Kits
C
Positions
9 Plug
9 Socket
15 Plug
15 Socket
25 Plug
25 Socket
37 Plug
37 Socket
in
0.270
0.285
0.270
0.285
0.275
0.285
0.275
0.285
D
mm
6.86
7.24
6.86
7.24
6.99
7.24
6.99
7.24
in
0.705
0.705
1.050
1.050
1.590
1.590
2.240
2.240
E
mm
17.91
17.91
26.67
26.67
40.39
40.39
56.90
56.90
4-24
in
1.320
1.320
1.320
1.320
1.320
1.320
1.620
1.620
mm
33.53
33.53
33.53
33.53
33.53
33.53
41.15
41.15
F
in
0.520
0.520
0.520
0.520
0.520
0.520
0.750
0.750
mm
13.21
13.21
13.21
13.21
13.21
13.21
19.05
19.05
G
Deg.
75°
75°
58°
58°
40°
40°
32°
32°
H
in
0.440
0.440
0.440
0.440
0.440
0.440
0.520
0.520
mm
11.18
11.18
11.18
11.18
11.18
11.18
13.21
13.21
Overmold Kits (Cont’d)
D*A Series Crimp and Poke Overmold Kits
Tin-plated
Plugs
DEAO-9PTI-FO1
DAAO-15PTI-FO1
DBAO-25PTI-FO1
DCAO-37PTI-FO1
Positions
9
15
25
37
shell
Sockets
DEAO-9ST-FO1
DAAO-15ST-FO1
DBAO-25ST-FO1
DCAO-37ST-FO1
HTD Series 1. 5 Density Plugs Overmold Kits
Size
15
26
44
Shell Size
E
A
B
Catalog Number
HTDEO-15PTI-FO1
HTDAO-26PTI-FO1
HTDBO-44PTI-FO1
Crimp Ferrule
Catalog
Number
CF-51
CF-42
CF-43
CF-44
CF-45
CF-46
CF-47
CF-50
J
Type
1
1
1
1
1
1
2
2
in
.437
.437
.437
.437
.437
.437
.437
.460
mm
11.10
11.10
11.10
11.10
11.10
11.10
11.10
11.68
K
in
.200
.235
.250
.325
.350
375
.437
.460
L
mm
5.08
5.97
6.35
8.26
8.89
9.53
11.10
11.68
in
.450
.450
.450
.450
.450
.450
.450
.450
mm
11.43
11.43
11.43
11.43
11.43
11.43
11.43
11.43
Crimp Die
Catalog No.
CD-07
CD-00
CD-01
CD-02
CD-03
CD-04
CD-05
CD-06
• Pneumatic Bench Top Press for Crimping Ferrules #FCT-551. See page 4-103.
• Hand Tool for Crimping Ferrules #FCT-552. See page 4-103.
4-25
■ Offered in 9, 15, 25, 37, and 50 position plugs and sockets (except right-angle PCB connectors9 , 15, and 25 positions).
■ Offered with .120 mounting holes, optional 4-40 clinch nuts, or dual float bushings (except rightangle PCB connectors-mounting holes only).
■ Approvals:
• UL Recognized - Files E170218 (UL1977) and E130965 (UL1863).
• CSA Approved - File LR31996.
finish or tin plating (grounding indents
on plug)
chromate finish
Condition D
96 hours per MIL-STD-202, Method 103
Current Rating:
Contact Resistance:
5 Amps
(initial); 1000 megohms (minimum)
after environmental testing
4-26
Machined contacts supplied loose with connector or can be ordered separately. Use with 20-24 AWG wire.
Stamped Contacts (order separately) for use when ordering connector with contacts not included (-FO option). Use with
20-28 AWG wire.
Available in 10K reel.
Order reels of stamped contacts separately.
Materials
Contact Material: Plug - Brass (stamped) or copper alloy (machined). Socket - Phosphor bronze (stamped) or copper
alloy (machined).
Contact Plating:
Stamped Plugs and Sockets: Gold flash or 30µin. gold and gold flash on the remainder. All over nickel.
Machined Plugs and Sockets: Gold flash or 30µin. gold. All over nickel.
Termination Tooling
• Semi-Automatic Stripper Crimper for Stamped Contacts on 10K PC reels: #ESC-20-3. See page 4-102.
Contact Insertion/Extraction: #CIET-20-HDB. See page 4-101.
Loose Contact Crimp Tool:
Machined Contact - #M22520/2-01. See page 4-103.
For Positioner as required see page 4-103.
Stamped Contacts #BT-20-HC see page 4-101.
No positioner required.
4-27
D*U Crimp and Poke Plugs
Zinc-Plated Shell with Yellow Chromate Finish
Position
9
15
25
37
50
Mounting Holes
Contacts
Without
Included
Contacts
DEU-9P
DEU-9P-FO
DAU-15P
DAU-15P-FO
DBU-25P
DBU-25P-FO
DCU-37P
DCU-37P-FO
DDU-50P
DDU-50P-FO
4-40 Clinch Nuts
Contacts
Without
Included
Contacts
DEUE-9-P
DEUE-9P-FO
DAUE-15-P
DAUE-15-P-FO
DBUE-25-P
DBUE-25P-FO
DCUE-37-P
DCUE-37P-FO
DDUE-50-P
DDUE-50P-FO
Dual Float
Contacts
Included
DEUY-9P
DAUY-15P
DBUY-25P
DCUY-37P
DDUY-50P
Bushings
Without
Contacts
DEUY-9P-FO
DAUY-15P-FO
DBUY-25P-FO
DCUY-37P-FO
DDUY-50P-FO
4-40 Clinch Nuts
Contacts
Without
Included
Contacts
DEUE-9PTI
DEUE-9PTI-FO
DAUE-15PTI
DAUE-15PTI-FO
DBUE-25PTI
DBUE-25PTI-FO
DCUE-37PTI
DCUE-37PTI-FO
DDUE-50PTI
DDUE-50PTI-FO
Dual Float
Contacts
Included
DEUY-9PTI
DAUY-15PTI
DBUY-25PTI
DCUY-37PTI
DDUY-50PTI
Bushings
Without
Contacts
DEUY-9PTI-FO
DAUY-15PTI-FO
DBUY-25PTI-FO
DCUY-37PTI-FO
DDUY-50PTI-FO
4-40 Clinch Nuts
Contacts
Without
Included
Contacts
DEUE-9S
DEUE-9S-FO
DAUE-15S
DAUE-15S-FO
DBUE-25S
DBUE-25S-FO
DCUE-37S
DCUE-37S-FO
DDUE-50S
DDUE-50S-FO
Dual Float
Contacts
Included
DEUY-9S
DAUY-15S
DBUY-25S
DCUY-37S
DDUY-50S
Bushings
Without
Contacts
DEUY-9S-FO
DAUY-15S-FO
DBUY-25S-FO
DCUY-37S-FO
DDUY-50S-FO
Mounting Holes
Contacts
Without
Included
Contacts
DEU-9ST
DEU-9ST-FO
DAU-15ST
DAU-15ST-FO
DBU-25ST
DBU-25ST-FO
DCU-37ST
DCU-37ST-FO
DDU-50ST
DDU-50ST-FO
4-40 Clinch Nuts
Contacts
Without
Included
Contacts
DEUE-9ST
DEUE-9ST-FO
DAUE-15ST
DAUE-15ST-FO
DBUE-25ST
DBUE-25ST-FO
DCUE-37ST
DCUE-37ST-FO
DDUE-50ST
DDUE-50ST-FO
Dual Float
Contacts
Included
DEUY-9ST
DAUY-15ST
DBUY-25ST
DCUY-37ST
DDUY-50ST
Bushings
Without
Contacts
DEUY-9ST-FO
DAUY-15ST-FO
DBUY-25ST-FO
DCUY-37ST-FO
DDUY-50ST-FO
4-28
Tin-Plated Shell with Grounding Indents
Position
9
15
25
37
50
Mounting Holes
Contacts
Without
Included
Contacts
DEU-9PTI
DEU-9PTI-FO
DAU-15PTI
DAU-15PTI-FO
DBU-25PTI
DBU-25PTI-FO
DCU-37PTI
DCU-37PTI-FO
DDU-50PTI
DDU-50PTI-FO
D*U Crimp and Poke Sockets
Position
9
15
25
37
50
Mounting Holes
Contacts
Without
Included
Contacts
DEU-9S
DEU-9S-FO
DAU-15S
DAU-15S-FO
DBU-25S
DBU-25S-FO
DCU-37S
DCU-37S-FO
DDU-50S
DDU-50S-FO
Tin-Plated Shell
Position
9
15
25
37
50
Machined Contacts • 20-24 AWG Wire
Plug
Socket
Dimensions
A
Description
Pin
Socket
Wire
AWG
#20, 22, 24
#20, 22, 24
in
.066
.066
B
mm
1.67
1.67
in
.045
.045
C Max.
mm
1.14
1.14
in
.537
.523
mm
13.64
13.28
D*U Series Loose-Piece Machined Contacts
Pin
Socket
Gold Flash
030-1952-000
030-1953-000
30µin. Gold
030-1952-030
030-1953-030
Stamped Contacts • 20-28 AWG Wire
Plug
Socket
D*U Series Stamped Contacts on 10K Reels
Pin
Socket
Gold Flash
BCL-1964-20P
BCL-1963-20S
30µin. Gold
D110238-034
D110238-035
4-29
.445" footprint.
Materials
Contact Material: Socket - Copper alloy (machined), Plug - Brass (machined).
Contact Plating: Gold flash or 30µin. gold. All over nickel.
Mounting bracket: Black nylon. Can be removed if necessary.
yp.
D*U Right-Angle Plugs
Positions
9
15
25
Gold Flash
DEU-9PAD
DAU-15PAD
DBU-25PAD
30µin. Gold
DEU-9PAD-30
DAU-15PAD-30
DBU-25PAD-30
Gold Flash
DEU-9PADTI
DAU-15PADTI
DBU-25PADTI
30µin. Gold
DEU-9PADTI-30
DAU-15PADTI-30
DBU-25PADTI-30
D*U Right-Angle Sockets
Positions
9
Gold Flash
DEU-9SAD
15
25
Tin-Plated Shell
30µin. Gold
DEU-9SAD-30
Gold Flash
DEU-9SADT
DAU-15SAD
DAU-15SAD-30
DAU-15SADT
DAU-15SADT-30
DBU-25SAD
DBU-25SAD-30
DBU-25SADT
DBU-25SADT-30
4-30
30µin. Gold
DEU-9SADT-30
Longer rear insulator provides integral standoff from PCB.
Materials
Contact Material: Plug - Brass (machined), Socket - Copper alloy (machined).
Vertical Plugs
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
Positions Gold Flash
9
DEU-9PBF
DEU-9PBF-30
DEUE-9PBF
DEUE-9PBF-30
15
DAU-15PBF DAU-15PBF-30
DAUE-15PBF DAUE-15PBF-30
25
DBU-25PBF DBU-25PBF-30
DBUE-25PBF DBUE-25PBF-30
37
DCU-37PBF DCU-37PBF-30
DCUE-37PBF DCUE-37PBF-30
50
DDU-50PBF DDU-50PBF-30
DDUE-50PBF DDUE-50PBF-30
Dual Float
Gold Flash
DEUY-9PBF
DAUY-15PBF
DBUY-25PBF
DCUY-37PBF
DDUY-50PBF
Mounting Holes
30µin. Gold
9
DEU-9PBFTI DEU-9PBFTI-30
15
DAU-15PBFTI DAU-15PBFTI-30
25
DBU-25PBFTI DBU-25PBFTI-30
37
DCU-37PBFTI DCU-37PBFTI-30
50
DDU-50PBFTI DDU-50PBFTI-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEUY-9PBFTI DEUY-9PBFTI-30
DAUY-15PBFTI DAUY-15PBFTI-30
DBUY-25PBFTI DBUY-25PBFTI-30
DCUY-37PBFTI DCUY-37PBFTI-30
DDUY-50PBFTI DDUY-50PBFTI-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEUE-9PBFTI
DEUE-9PBFTI-30
DAUE-15PBFTI DAUE-15PBFTI-30
DBUE-25PBFTI DBUE-25PBFTI-30
DCUE-37PBFTI DCUE-37PBFTI-30
DDUE-50PBFTI DDUE-50PBFTI-30
4-31
Bushings
30µin. Gold
DEUY-9PBF-30
DAUY-15PBF-30
DBUY-25PBF-30
DCUY-37PBF-30
DDUY-50PBF-30
Ordering Information (Cont’d)
Vertical Sockets
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DEU-9SBF
DEU-9SBF-30
DEUE-9SBF
DEUE-9SBF-30
15
DAU-15SBF DAU-15SBF-30
DAUE-15SBF DAUE-15SBF-30
25
DBU-25SBF DBU-25SBF-30
DBUE-25SBF DBUE-25SBF-30
37
DCU-37SBF DCU-37SBF-30
DCUE-37SBF DCUE-37SBF-30
50
DDU-50SBF DDU-50SBF-30
DDUE-50SBF DDUE-50SBF-30
Dual Float
Gold Flash
DEUY-9SBF
DAUY-15SBF
DBUY-25SBF
DCUY-37SBF
DDUY-50SBF
Bushings
30µin. Gold
DEUY-9SBF-30
DAUY-15SBF-30
DBUY-25SBF-30
DCUY-37SBF-30
DDUY-50SBF-30
Dual Float
Gold Flash
DEUY-9SBFT
DAUY-15SBFT
DBUY-25SBFT
DCUY-37SBFT
DDUY-50SBFT
Bushings
30µin. Gold
DEUY-9SBFT-30
DAUY-15SBFT-30
DBUY-25SBFT-30
DCUY-37SBFT-30
DDUY-50SBFT-30
Tin-Plated Shell
Positions
9
15
25
37
50
Mounting Holes
Gold Flash
30µin. Gold
DEU-9SBFT DEU-9SBFT-30
DAU-15SBFT DAU-15SBFT-30
DBU-25SBFT DBU-25SBFT-30
DCU-37SBFT DCU-37SBFT-30
DDU-50SBFT DDU-50SBFT-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEUE-9SBFT DEUE-9SBFT-30
DAUE-15SBFT DAUE-15SBFT-30
DBUE-25SBFT DBUE-25SBFT-30
DCUE-37SBFT DCUE-37SBFT-30
DDUE-50SBFT DDUE-50SBFT-30
4-32
■ Offered in 9, 15, 25, and 37 position plugs and sockets.
■ Available in Solder Cup and IDC (insulation displacement) terminations for discrete wire.
■ Offered with .120 mounting holes.
■ Approvals:
Insulator Material: Glass-filled polyester (black), UL 94 V-O rated
Current Rating:
Contact Resistance:
3 Amps
4-34
Solder channels between barriers permit single-pass soldering of each row without solder bridging.
Will accommodate up to 22 AWG wire.
Solder Cup Plugs
Positions
9
15
25
37
Zinc-Plated Shell
TE-9PS
TE-9PS-30
TA-15PS
TA-15PS-30
TB-25PS
TB-25PS-30
TC-37PS
TC-37PS-30
Tin-Plated Shell
Gold Flash
30µin. Gold
TE-9PTIS
TE-9PTIS-30
TA-15PTIS
TA-15PTIS-30
TB-25PTIS
TB-25PTIS-30
TC-37PTIS
TC-37PTIS-30
Solder Cup Sockets
Positions
9
15
25
37
Zinc-Plated Shell
TE-9SS
TE-9SS-30
TA-15SS
TA-15SS-30
TB-25SS
TB-25SS-30
TC-37SS
TC-37SS-30
Tin-Plated Shell
Gold Flash
TE-9STS
TA-15STS
TB-25STS
TC-37STS
4-35
30µin. Gold
TE-9STS-30
TA-15STS-30
TB-25STS-30
TC-37STS-30
Will accommodate 24-26 AWG solid or stranded PVC wire.
IDC Plugs
Positions
9
15
25
37
Zinc-Plated Shell
TE-9PSH
TE-9PSH-30
TA-15PSH
TA-15PSH-30
TB-25PSH
TB-25PSH-30
TC-37PSH
TC-37PSH-30
Tin-Plated Shell
Gold Flash
30µin. Gold
TES-9PTI
TES-9PTI-30
TAS-15PTI
TAS-15PTI-30
TBS-25PTI
TBS-25PTI-30
TCS-37PTI
TCS-37PTI-30
IDC Sockets
Positions
9
15
25
37
Zinc-Plated Shell
TE-9SSH
TE-9SSH-30
TA-15SSH
TA-15SSH-30
TB-25SSH
TB-25SSH-30
TC-37SSH
TC-37SSH-30
Tin-Plated Shell
Gold Flash
TES-9ST
TAS-15ST
TBS-25ST
TCS-37ST
30µin. Gold
TES-9ST-30
TAS-15ST-30
TBS-25ST-30
TCS-37ST-30
4-36
Auto-Clinch D Semi-Automatic Termination Tool #ACD-432: See page 4-100.
Certi-Clinch D Manual Termination Tool #SD-CCWN: For 24-26 AWG wire: See page 4-100.
Uni-Clinch D Single-Wire Hand Insertion Tool #SD-UC: See page 4-100.
Super D Manual Stay Band Tool #SD-MSBT: See page 4-100.
Optional strain relief covers for connectors when backshell is not required.
Positions
9
15
25
37
Catalog No.
SSD-WC9
SSD-WC15
SSD-WC25
SSD-WC37
• One-piece cover for 9 contact size. Order one per connector. Two-piece cover for other sizes. Order two per connector.
• Cover fits both plug and socket.
4-37
For use only with SDH Series Gray Backshell on pages 4-89 thru 4-90.
Connector will accommodate 24-28 AWG wire.
Offered with plain flanges and .120 mounting holes, threaded bushings, latch blocks, or latch blocks and
threaded bushings.
Certi-Clinch D Manual Termination Tool #SD-CC for 24-28 AWG wire: See page 4-100.
Dimensions
A
Positions
9
15
25
37
in
1.209
1.536
2.079
2.724
A
mm
30.71
39.01
52.81
69.19
in
1.309
1.636
2.179
2.824
mm
33.25
41.55
55.35
71.73
B
in
.984
1.312
1.852
2.500
mm
24.99
33.32
47.04
63.50
CP
in
mm
.668 16.96
.995 25.28
1.535 38.99
2.183 55.45
4-38
CS
in
mm
.642 16.31
.970 24.64
1.512 38.40
2.158 54.81
D
in
.592
.918
1.462
2.114
mm
15.04
23.31
37.13
53.70
IDC All-Plastic Plugs
Plain Flange
Positions
9
15
25
37
Mounting Holes
Gold Flash
30µin. Gold
TE-9P
TE-9P-30
TA-15P
TA-15P-30
TB-25P
TB-25P-30
TC-37P
TC-37P-30
Flange with Latch Block
Mounting Holes
30µin. Gold
9
TE-9PLB
TE-9PLB-30
15
TA-15PLB
TA-15PLB-30
25
TB-25PLB
TB-25PLB-30
37
TC-37PLB
TC-37PLB-30
4-40 Threaded Bushings
Gold Flash
30µin. Gold
TE-9PTB
TE-9PTB-30
TA-15PTB
TA-15PTB-30
TB-25PTB
TB-25PTB-30
TC-37PTB
TC-37PTB-30
Gold Flash
30µin. Gold
TE-9PLB-1
TE-9PLB-1-30
TA-15PLB-1
TA-15PLB-1-30
TB-25PLB-1
TB-25PLB-1-30
TC-37PLB-1
TC-37PLB-1-30
IDC All-Plastic Sockets
Plain Flange
Positions
9
15
25
37
Mounting Holes
Gold Flash
30µin. Gold
TE-9S
TE-9S-30
TA-15S
TA-15S-30
TB-25S
TB-25S-30
TC-37S
TC-37S-30
Mounting Holes
30µin. Gold
9
TE-9SLB
TE-9SLB-30
15
TA-15SLB
TA-15SLB-30
25
TB-25SLB
TB-25SLB-30
37
TC-37SLB
TC-37SLB-30
Gold Flash
30µin. Gold
TE-9STB
TE-9STB-30
TA-15STB
TA-15STB-30
TB-25STB
TB-25STB-30
TC-37STB
TC-37STB-30
Gold Flash
30µin. Gold
TE-9SLB-1
TE-9SLB-1-30
TA-15SLB-1
TA-15SLB-1-30
TB-25SLB-1
TB-25SLB-1-30
TC-37SLB-1
TC-37SLB-1-30
4-39
■ Offered in Wire Wrap and Solder Cup styles for wire termination and vertical style for
PCB mount.
■ Offered with .120 mounting holes, 4-40 clinch nuts, and dual float bushings.
■ Offered in 9, 15, 25, 37, and 50 position plugs and sockets.
■ Approvals:
Insulator Material: Glass-filled polyester (white), UL 94V-O rated
finish or tin plating (grounding indents on plug)
chromate finish
Condition D
Current Rating:
Contact Resistance:
Minimum 1250V RMS @ sea level
5 Amps
4-40
Available with stamped or machined contacts.
Will accommodate up to 20 AWG wire.
Materials
Contact Material: Copper Alloy
Contact Plating:
- Stamped contacts with gold flash or 30µin. gold in mating area, gold flash or tin/lead on remainder. All over nickel.
- Screw machine contacts with gold flash or 30µin. gold. All over nickel.
Solder Cup Plugs
Stamped Contact with Gold Flash in Solder Cup
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9P
DE-9P-30
DEE-9P
DEE-9P-30
15
DA-15P
DA-15P-30
DAE-15P
DAE-15P-30
25
DB-25P
DB-25P-30
DBE-25P
DBE-25P-30
37
DC-37P
DC-37P-30
DCE-37P
DCE-37P-30
50
DD-50P
DD-50P-30
DDE-50P
DDE-50P-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9P
DEY-9P-30
DAY15P
DAY-15P-30
DBY-25P
DBY-25P-30
DCY-37P
DCY-37P-30
DDY-50P
DDY-50P-30
Stamped Contact with Tin/Lead in Solder Cup
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9P-II
DE-9P-II-30
DEE-9P-II
DEE-9P-II-30
15
DA-15P-II
DA-15P-II-30
DAE-15P-II
DAE-15P-II-30
25
DB-25P-II
DB-25P-II-30
DBE-25P-II
DBE-25P-II-30
37
DC-37P-II
DC-37P-II-30
DCE-37P-II
DCE-37P-II-30
50
DD-50P-II
DD-50P-II-30
DDE-50P-II
DDE-50P-II-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9P-II
DEY-9P-II-30
DAY-15P-II
DAY-15-PII-30
DBY-25P-II
DBY-25-PII-30
DCY-37-P-II
DCY-37-PII-30
DDY-50-P-II
DDY-50-PII-30
Screw Machine Contact
Mounting Holes
30µin. Gold
9
DE-9P-SM
DE-9P-SM-30
15
DA-15P-SM
DA-15P-SM-30
25
DB-25P-SM
DB-25P-SM-30
37
DC-37P-SM
DC-37P-SM-30
50
DD-50P-SM
DD-50P-SM-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9P-SM
DEY-9P-SM-30
DAY-15P-SM
DAY-15P-SM-30
DBY-25P-SM
DBY-25P-SM-30
DCY-37P-SM
DCY-37P-SM-30
DDY-50P-SM
DDY-50P-SM-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9P-SM
DEE-9P-SM-30
DAE-15P-SM
DAE-15P-SM-30
DBE-25P-SM
DBE-25P-SM-30
DCE-37P-SM
DCE-37P-SM-30
DDE-50P-SM
DDE-50P-SM-30
4-41
Solder Cup Plugs (Cont’d)
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9PTI
DE-9PTI-30
DEE-9PTI
DEE-9PTI-30
15
DA-15PTI
DA-15PTI-30
DAE-15PTI
DAE-15PTI-30
25
DB-25PTI
DB-25PTI-30
DBE-25PTI
DBE-25PTI-30
37
DC-37PTI
DC-37PTI-30
DCE-37PTI
DCE-37PTI-30
50
DD-50PTI
DD-50PTI-30
DDE-50PTI
DDE-50PTI-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PTI
DEY-9PTI-30
DAY-15PTI
DAY-15PTI-30
DBY-25PTI
DBY-25PTI-30
DCY-37PTI
DCY-37PTI-30
DDY-50PTI
DDY-50PTI-30
Mounting Holes
4-40 Clinch Nuts
Positions
Gold Flash
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9PTI-II
DE-9PTI-II-30
DEE-9PTI-II
DEE-9PTI-II-30
15
DA-15PTI-II
DA-15PTI-II-30
DAE-15PTI-II
DAE-15PTI-II-30
25
DB-25PTI-II
DB-25PTI-II-30
DBE-25PTI-II
DBE-25PTI-II-30
37
DC-37PTI-II
DC-37PTI-II-30
DCE-37PTI-II
DCE-37PTI-II-30
50
DD-50PTI-II
DD-50PTI-II-30
DDE-50PTI-II
DDE-50PTI-II-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PTI-II
DEY-9PTI-II-30
DAY-15PTI-II
DAY-15PTI-II-30
DBY-25PTI-II
DBY-25PTI-II-30
DCY-37PTI-II
DCY-37PTI-II-30
DDY-50PTI-II
DDY-50PTI-II-30
Mounting
Positions
Gold Flash
9
DE-9PTI-SM
15
DA-15PTI-SM
25
DB-25PTI-SM
37
DC-37PTI-SM
50
DD-50PTI-SM
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PTI-SM
DEY-9PTI-SM-30
DAY-15PTI-SM DAY-15PTI-SM-30
DBY-25PTI-SM DBY-25PTI-SM-30
DCY-37PTI-SM DCY-37PTI-SM-30
DDY-50PTI-SM DDY-50PTI-SM-30
Holes
30µin. Gold
DE-9PTI-SM-30
DA-15PTI-SM-30
DB-25PTI-SM-30
DC-37PTI-SM-30
DD-50PTI-SM-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9PTI-SM
DEE-9PTI-SM-30
DAE-15PTI-SM DAE-15PTI-SM-30
DBE-25PTI-SM DBE-25PTI-SM-30
DCE-37PTI-SM DCE-37PTI-SM-30
DDE-50PTI-SM DDE-50PTI-SM-30
4-42
Solder Cup Sockets
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9S
DE-9S-30
DEE-9S
DEE-9S-30
15
DA-15S
DA-15S-30
DAE-15S
DAE-15S-30
25
DB-25S
DB-25S-30
DBE-25S
DBE-25S-30
37
DC-37S
DC-37S-30
DCE-37S
DCE-37S-30
50
DD-50S
DD-50S-30
DDE-50S
DDE-50S-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9S
DEY-9S-30
DAY-15S
DAY-15S-30
DBY-25S
DBY-25S-30
DCY-37S
DCY-37S-30
DDY-50S
DDY-50S-30
Stamped Contact Tin/Lead in Solder Cup
Mounting Holes
30µin. Gold
9
DE-9S-II
DE-9S-II-30
15
DA-15S-II
DA-15S-II-30
25
DB-25S-II
DB-25S-II-30
37
DC-37S-II
DC-37S-II-30
50
DD-50S-II
DD-50S-II-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9S-II
DEE-9S-II-30
DAE-15S-II
DAE-15S-II-30
DBE-25S-II
DBE-25S-II-30
DCE-37S-II
DCE-37S-II-30
DDE-50S-II
DDE-50S-II-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9S-II
DEY-9S-II-30
DAY-15S-II
DAY-15S-II-30
DBY-25S-II
DBY-25S-II-30
DCY-37S-II
DCY-37S-II-30
DDY-50S-II
DDY-50S-II-30
Mounting
9
DE-9S-SM
15
DA-15S-SM
25
DB-25S-SM
37
DC-37S-SM
50
DD-50S-SM
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9S-SM
DEE-9S-SM-30
DAE-15S-SM
DAE-15S-SM-30
DBE-25S-SM
DBE-25S-SM-30
DCE-37S-SM
DCE-37S-SM-30
DDE-50S-SM
DDE-50S-SM-30
Holes
30µin. Gold
DE-9S-SM-30
DA-15S-SM-30
DB-25S-SM-30
DC-37S-SM-30
DD-50S-SM-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9S-SM
DEY-9S-SM-30
DAY-15S-SM
DAY-15S-SM-30
DBY-25S-SM
DBY-25S-SM-30
DCY-37S-SM
DCY-37S-SM-30
DDY-50S-SM
DDY-50S-SM-30
Tin-Plated Shell
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9ST
DE-9ST-30
DEE-9ST
DEE-9ST-30
15
DA-15ST
DA-15ST-30
DAE-15ST
DAE-15ST-30
25
DB-25ST
DB-25ST-30
DBE-25ST
DBE-25ST-30
37
DC-37ST
DC-37ST-30
DCE-37ST
DCE-37ST-30
50
DD-50ST
DD-50ST-30
DDE-50ST
DDE-50ST-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9ST
DEY-9ST-30
DAY-15ST
DAY-15ST-30
DBY-25ST
DBY-25ST-30
DCY-37ST
DCY-37ST-30
DDY-50ST
DDY-50ST-30
Mounting Holes
4-40 Clinch Nuts
30µin. Gold
Gold Flash
30µin. Gold
9
DE-9ST-II
DE-9ST-II-30
DEE-9ST-II
DEE-9ST-II-30
15
DA-15ST-II
DA-15ST-II-30
DAE-15ST-II
DAE-15ST-II-30
25
DB-25ST-II
DB-25ST-II-30
DBE-25ST-II
DBE-25ST-II-30
37
DC-37ST-II
DC-37ST-II-30
DCE-37ST-II
DCE-37ST-II-30
50
DD-50ST-II
DD-50ST-II-30
DDE-50ST-II
DDE-50ST-II-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9ST-II
DEY-9ST-II-30
DAY-15ST-II
DAY-15ST-II-30
DBY-25ST-II
DBY-25ST-II-30
DCY-37ST-II
DCY-37ST-II-30
DDY-50ST-II
DDY-50ST-II-30
Mounting
Positions
Gold Flash
9
DE-9ST-SM
15
DA-15ST-SM
25
DB-25ST-SM
37
DC-37ST-SM
50
DD-50ST-SM
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9ST-SM
DEY-9ST-SM-30
DAY-15ST-SM
DAY-15ST-SM-30
DBY-25ST-SM
DBY-25ST-SM-30
DCY-37ST-SM
DCY-37ST-SM-30
DDY-50ST-SM
DDY-50ST-SM-30
Holes
30µin. Gold
DE-9ST-SM-30
DA-15ST-SM-30
DB-25ST-SM-30
DC-37ST-SM-30
DD-50ST-SM-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9ST-SM
DEE-9ST-SM-30
DAE-15ST-SM
DAE-15ST-SM-30
DBE-25ST-SM
DBE-25ST-SM-30
DCE-37ST-SM
DCE-37ST-SM-30
DDE-50ST-SM
DDE-50ST-SM-30
4-43
• .040" contact diameter.
• Short rear insulator provides low profile on PCB.
• Offered with .120 mounting holes, dual float bushings, or optional 4-40 clinch nuts.
Materials
• Contact Material: Socket - Phosphor bronze (machined), Plug - Brass (machined).
• Contact Plating: Gold flash or 30µin. gold over nickel.
07)
97)
Vertical PCB Plugs
Mounting Holes
30µin. Gold
9
DE-9PV
DE-9PV-30
15
DA-15PV
DA-15PV-30
25
DB-25PV
DB-25PV-30
37
DC-37PV
DC-37PV-30
50
DD-50PV
DD-50PV-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9PV
DEE-9PV-30
DAE-15PV
DAE-15PV-30
DBE-25PV
DBE-25PV-30
DCE-37PV
DCE-37PV-30
DDE-50PV
DDE-50PV-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PV
DEY-9PV-30
DAY-15PV
DAY-15PV-30
DBY-25PV
DBY-25PV-30
DCY-37PV
DCY-37PV-30
DCY-50PV
DDY-50PV-30
Mounting Holes
30µin. Gold
9
DE-9PVTI
DE-9PVTI-30
15
DA-15PVTI
DA-15PVTI-30
25
DB-25PVTI
DB-25PVTI-30
37
DC-37PVTI
DC-37PVTI-30
50
DD-50PVTI
DD-50PVTI-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9PVTI
DEE-9PVTI-30
DAE-15PVTI
DAE-15PVTI-30
DBE-25PVTI
DBE-25PVTI-30
DCE-37PVTI
DCE-37PVTI-30
DDE-50PVTI
DDE-50PVTI-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PVTI
DEY-9PVTI-30
DAY-15PVTI
DAY-15PVTI-30
DBY-25PVTI
DBY-25PVTI-30
DCY-37PVTI
DCY-37PVTI-30
DCY-50PVTI
DDY-50PVTI-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9SV
DEE-9SV-30
DAE-15SV
DAE-15SV-30
DBE-25SV
DBE-25SV-30
DCE-37SV
DCE-37SV-30
DDE-50SV
DDE-50SV-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9SV
DEY-9SV-30
DAY-15SV
DAY-15SV-30
DBY-25SV
DBY-25SV-30
DCY-37SV
DCY-37SV-30
DCY-50SV
DDY-50SV-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9SVT
DEE-9SVT-30
DAE-15SVT
DAE-15SVT-30
DBE-25SVT
DBE-25SVT-30
DCE-37SVT
DCE-37SVT-30
DDE-50SVT
DDE-50SVT-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9SVT
DEY-9SVT-30
DAY-15SVT
DAY-15SVT-30
DBY-25SVT
DBY-25SVT-30
DCY-37SVT
DCY-37SVT-30
DDY-50SVT
DDY-50SVT-30
Vertical PCB Sockets
Mounting Holes
30µin. Gold
9
DE-9SV
DE-9SV-30
15
DA-15SV
DA-15SV-30
25
DB-25SV
DB-25SV-30
37
DC-37SV
DC-37SV-30
50
DD-50SV
DD-50SV-30
Tin-Plated Shell
Positions
9
15
25
37
50
Mounting
Gold Flash
DE-9SVT
DA-15SVT
DB-25SVT
DC-37SVT
DD-50SVT
Holes
30µin. Gold
DE-9SVT-30
DA-15SVT-30
DB-25SVT-30
DC-37SVT-30
DD-50SVT-30
4-44
• Reliable wire wrap termination.
Two contact lengths: .375" or .585".
.025" square contact tails.
Materials
Contact Material: Copper alloy (machined).
(9.53) or
(14.86)
EF.
Wire Wrap Plugs
.375" Tail Length
Positions
Mounting Holes
Gold Flash
30µin. Gold
4-40 Clinch Nuts
Gold Flash
30µin. Gold
Dual Float Bushings
Gold Flash
30µin. Gold
9
DE-9P-F179
DE-9P-F179-30
DEE-9P-F179
DEE-9P-F179-30
DEY-9P-F179
DEY-9P-F179-30
15
DA-15P-F179
DA-15P-F179-30
DAE-15P-F179
DAE-15P-F179-30
DAY-15P-F179
DAY-15P-F179-30
25
DB-25P-F179
DB-25P-F179-30
DBE-25P-F179
DBE-25P-F179-30
DBY-25P-F179
DBY-25P-F179-30
37
DC-37P-F179
DC-37P-F179-30
DCE-37P-F179
DCE-37P-F179-30
DCY-37P-F179
DCY-37P-F179-30
50
DD-50P-F179
DD-50P-F179-30
DDE-50P-F179
DDE-50P-F179-30
DDY-50P-F179
DDY-50P-F179-30
Positions
Mounting Holes
Gold Flash
30µin. Gold
4-40 Clinch Nuts
Gold Flash
30µin. Gold
Dual Float Bushings
Gold Flash
30µin. Gold
9
DE-9PTI-F179
DE-9PTI-F179-30
DEE-9PTI-F179
DEE-9PTI-F179-30
DEY-9PTI-F179
DEY-9PTI-F179-30
15
DA-15PTI-F179
DA-15PTI-F179-30
DAE-15PTI-F179
DAE-15PTI-F179-30
DAY-15PTI-F179
DAY-15PTI-F179-30
25
DB-25PTI-F179
DB-25PTI-F179-30
DBE-25PTI-F179
DBE-25PTI-F179-30
DBY-25PTI-F179
DBY-25PTI-F179-30
37
DC-37PTI-F179
DC-37PTI-F179-30
DCE-37PTI-F179
DCE-37PTI-F179-30
DCY-37PTI-F179
DCY-37PTI-F179-30
50
DD-50PTI-F179
DD-50PTI-F179-30
DDE-50PTI-F179
DDE-50PTI-F179-30
DDY-50PTI-F179
DDY-50PTI-F179-30
4-45
Wire Wrap Plugs (Cont’d)
.585" Tail Length
Positions
Mounting Holes
Gold Flash
30µin. Gold
4-40 Clinch Nuts
Gold Flash
30µin. Gold
Dual Float Bushings
Gold Flash
30µin. Gold
9
DE-9P-F179C
DE-9P-F179C-30
DEE-9P-F179C
DEE-9PF-179C-30
DEY-9P-F179C
15
DA-15P-F179C
DA-15P-F179C-30
DAE-15P-F179C
DAE-15PF-179C-30
DAY-15P-F179C
DEY-9P-F179C-30
DAY-15P-F179C-30
25
DB-25P-F179C
DB-25P-F179C-30
DBE-25P-F179C
DBE-25PF-179C-30
DBY-25P-F179C
DBY-25P-F179C-30
37
DC-37P-F179C
DC-37P-F179C-30
DCE-37P-F179C
DCE-37PF-179C-30
DCY-37P-F179C
DCY-37P-F179C-30
50
DD-50P-F179C
DD-50P-F179C-30
DDE-50P-F179C
DDE-50PF-179C-30
DDY-50P-F179C
DDY-50P-F179C-30
Positions
9
Mounting Holes
Gold Flash
30µin. Gold
DE-9PTI-F179C
DE-9PTI-F179C-30
4-40 Clinch Nuts
Gold Flash
30µin. Gold
DEE-9PTI-F179C
DEE-9PTI-F179C-30
Dual Float Bushings
Gold Flash
30µin. Gold
DEY-9PTI-F179C
DEY-9PTI-F179C-30
15
DA-15PTI-F179C DA-15PTI-F179C-30
DAE-15PTI-F179C DAE-15PTI-F179C-30
DAY-15PTI-F179C DAY-15PTI-F179C-30
25
DB-25PTI-F179C DB-25PTI-F179C-30
DBE-25PTI-F179C DBE-25PTI-F179C-30
DBY-25PTI-F179C DBY-25PTI-F179C-30
37
DC-37PTI-F179C DC-37PTI-F179C-30
DCE-37PTI-F179C DCE-37PTI-F179C-30
DCY-37PTI-F179C DCY-37PTI-F179C-30
50
DD-50PTI-F179C DD-50PTI-F179C-30
DDE-50PTI-F179C DDE-50PTI-F179C-30
DDY-50PTI-F179C DDY-50PTI-F179C-30
4-46
Wire Wrap Sockets
.375" Tail Length
Mounting Holes
Positions
9
15
25
37
50
Gold Flash
DE-9S-F179
DA-15S-F179
DB-25S-F179
DC-37S-F179
DD-50S-F179
30µin. Gold
DE-9S-F179-30
DA-15S-F179-30
DB-25S-F179-30
DC-37S-F179-30
DD-50S-F179-30
4-40 Clinch Nuts
Gold Flash
DEE-9S-F179
DAE-15S-F179
DBE-25S-F179
DCE-37S-F179
DDE-50S-F179
Dual Float Bushings
30µin. Gold
Gold Flash
DEE-9S-F179-30
DAE-15S-F179-30
DBE-25S-F179-30
DCE-37S-F179-30
DDE-50S-F179-30
DEY-9S-F179
DAY-15S-F179
DBY-25S-F179
DCY-37S-F179
DDY-50S-F179
30µin. Gold
DEY-9S-F179-30
DAY-15S-F179-30
DBY-25S-F179-30
DCY-37S-F179-30
DDY-50S-F179-30
Tin-Plated Shell
Mounting Holes
Positions
9
15
25
37
50
Gold Flash
DE-9ST-F179
DA-15ST-F179
DB-25ST-F179
DC-37ST-F179
DD-50ST-F179
30µin. Gold
DE-9ST-F179-30
DA-15ST-F179-30
DB-25ST-F179-30
DC-37ST-F179-30
DD-50ST-F179-30
4-40 Clinch Nuts
Dual Float Bushings
Gold Flash
30µin. Gold
Gold Flash
DEE-9ST-F179
DAE-15ST-F179
DBE-25ST-F179
DCE-37ST-F179
DDE-50ST-F179
DEE-9ST-F179-30
DAE-15ST-F179-30
DBE-25ST-F179-30
DCE-37ST-F179-30
DDE-50ST-F179-30
DEY-9ST-F179
DAY-15ST-F179
DBY-25ST-F179
DCY-37ST-F179
DDY-50ST-F179
30µin. Gold
DEY-9ST-F179-30
DAY-15ST-F179-30
DBY-25ST-F179-30
DCY-37ST-F179-30
DDY-50ST-F179-30
.585" Tail Length
Mounting Holes
Positions
Gold Flash
9
15
25
37
50
DE-9S-F179C
DA-15S-F179C
DB-25S-F179C
DC-37S-F179C
DD-50S-F179C
30µin. Gold
DE-9S-F179C-30
DA-15S-F179C-30
DB-25S-F179C-30
DC-37S-F179C-30
DD-50S-F179C-30
4-40 Clinch Nuts
Gold Flash
DEE-9S-F179C
DAE-15S-F179C
DBE-25S-F179C
DCE-37S-F179C
DDE-50S-F179C
Dual Float Bushings
30µin. Gold
Gold Flash
DEE-9S-F179C-30
DAE-15S-F179C-30
DBE-25S-F179C-30
DCE-37S-F179C-30
DDE-50S-F179C-30
DEY-9S-F179C
DAY-15S-F179C
DBY-25S-F179C
DCY-37S-F179C
DDY-50S-F179C
30µin. Gold
DEY-9S-F179C-30
DAY-15S-F179C-30
DBY-25S-F179C-30
DCY-37S-F179C-30
DDY-50S-F179C-30
Tin-Plated Shell
Mounting Holes
4-40 Clinch Nuts
Dual Float Bushings
Positions
Gold Flash
30µin. Gold
Gold Flash
30µin. Gold
Gold Flash
9
15
25
37
50
DE-9ST-F179C
DA-15ST-F179C
DB-25ST-F179C
DC-37ST-F179C
DD-50ST-F179C
DE-9ST-F179C-30
DA-15ST-F179C-30
DB-25ST-F179C-30
DC-37ST-F179C-30
DD-50ST-F179C-30
DEE-9ST-F179C
DAE-15ST-F179C
DBE-25ST-F179C
DCE-37ST-F179C
DDE-50ST-F179C
DEE-9ST-F179C-30
DAE-15ST-F179C-30
DBE-25ST-F179C-30
DCE-37ST-F179C-30
DDE-50ST-F179C-30
DEY-9ST-F179C
DAY-15ST-F179C
DBY-25ST-F179C
DCY-37ST-F179C
DDY-50ST-F179C
4-47
30µin. Gold
DEY-9ST-F179C-30
DAY-15ST-F179C-30
DBY-25ST-F179C-30
DCY-37ST-F179C-30
DDY-50ST-F179C-30
■ Available in vertical and right-angle dip solder PCB connectors and solder cup version for
wire termination.
■ Commercial version of M24308 military connectors with tin-plated or zinc-plated shell
and 30µin. gold plating.
■ Monoblock green diallyl phthalate insulator for improved electrical performance.
■ Machined contacts for precision performance.
■ Offered in 9, 15, 25, 37, and 50 (except right-angle version) position plugs and sockets.
■ Offered with .120 mounting holes, 4-40 clinch nuts (except right-angle version), or dual
float bushings (except right-angle version).
■ Approvals:
• UL Recognized - Files E170218 (UL1977)and E130965 (UL1863).
Insulator Material: Glass-filled diallyl phthalate (green)
UL 94V-0 rated
Contact Material: Plug - Brass (machined), Socket - Phosphor
bronze (machined)
Contact Plating: 30µin. gold over nickel
Current Rating:
Contact Resistance:
5 Amps
4-48
Solder Cup Plugs
Positions Mounting Hole 4-40 Clinch Nut Dual Float Bushings Mounting Hole 4-40 Clinch Nut Dual Float Bushings
9
DEM-9P
DEME-9P
DEMY-9P
DEM-9PTI
DEME-9PTI
DEMY-9PTI
15
DAM-15P
DAME-15P
DAMY-15P
DAM-15PTI
DAME-15PTI
DAMY-15PTI
25
DBM-25P
DBME-25P
DBMY-25P
DBM-25PTI
DBME-25PTI
DBMY-25PTI
37
DCM-37P
DCME-37P
DCMY-37P
DCM-37PTI
DCME-37PTI
DCMY-37PTI
50
DDM-50P
DDME-50P
DDMY-50P
DDM-50PTI
DDME-50PTI
DDMY-50PTI
Solder Cup Sockets
Tin-Plated Shell
9
DEM-9S
DEME-9S
DEMY-9S
DEM-9ST
DEME-9ST
DEMY-9ST
15
DAM-15S
DAME-15S
DAMY-15S
DAM-15ST
DAME-15ST
DAMY-15ST
25
DBM-25S
DBME-25S
DBMY-25S
DBM-25ST
DBME-25ST
DBMY-25ST
37
DCM-37S
DCME-37S
DCMY-37S
DCM-37ST
DCME-37ST
DCMY-37ST
50
DDM-50S
DDME-50S
DDMY-50S
DDM-50ST
DDME-50ST
DDMY-50ST
4-49
.283" footprint uses minimal board space.
Available with three contact tail lengths (.125", .158", and .185") and two contact diameters (.030" and .040").
Materials
Right-Angle PCB Plugs
Positions
9
15
25
37
.125 Tail Length
.030 Contact
Diameter
DEM-9PD
DAM-15PD
DBM-25PD
DCM-37PD
.158 Tail Length
.030 Contact
Diameter
DEM-9PL
DAM-15PL
DBM-25PL
DCM-37PL
.185 Tail Length
.030 Contact
Diameter
DEM-9PS
DAM-15PS
DBM-25PS
DCM-37PS
.125 Tail Length
.040 Contact
Diameter
DEM-9PA
DAM-15PA
DBM-25PA
DCM-37PA
.158 Tail Length
.040 Contact
Diameter
DEM-9PG
DAM-15PG
DBM-25PG
DCM-37PG
.185 Tail Length
.040 Contact
Diameter
DEM-9PW
DAM-15PW
DBM-25PW
DCM-37PW
.185 Tail Length
.030 Contact
Diameter
DEM-9PSTI
DAM-15PSTI
DBM-25PSTI
DCM-37PSTI
.125 Tail Length
.040 Contact
Diameter
DEM-9PATI
DAM-15PATI
DBM-25PATI
DCM-37PATI
.158 Tail Length
.040 Contact
Diameter
DEM-9PGTI
DAM-15PGTI
DBM-25PGTI
DCM-37PGTI
.185 Tail Length
.040 Contact
Diameter
DEM-9PWTI
DAM-15PWTI
DBM-25PWTI
DCM-37PWTI
Positions
9
15
25
37
.125 Tail Length
.030 Contact
Diameter
DEM-9PDTI
DAM-15PDTI
DBM-25PDTI
DCM-37PDTI
.158 Tail Length
.030 Contact
Diameter
DEM-9PLTI
DAM-15PLTI
DBM-25PLTI
DCM-37PLTI
4-50
Right-Angle PCB Sockets
Positions
9
15
25
37
.125 Tail Length
.030 Contact
Diameter
DEM-9SD
DAM-15SD
DBM-25SD
DCM-37SD
.158 Tail Length
.030 Contact
Diameter
DEM-9SL
DAM-15SL
DBM-25SL
DCM-37SL
.185 Tail Length
.030 Contact
Diameter
DEM-9SS
DAM-15SS
DBM-25SS
DCM-37SS
.125 Tail Length
.040 Contact
Diameter
DEM-9SA
DAM-15SA
DBM-25SA
DCM-37SA
.158 Tail Length
.040 Contact
Diameter
DEM-9SG
DAM-15SG
DBM-25SG
DCM-37SG
.185 Tail Length
.040 Contact
Diameter
DEM-9SW
DAM-15SW
DBM-25SW
DCM-37SW
.158 Tail Length
.030 Contact
Diameter
DEM-9SLT
DAM-15SLT
DBM-25SLT
DCM-37SLT
.185 Tail Length
.030 Contact
Diameter
DEM-9SST
DAM-15SST
DBM-25SST
DCM-37SST
.125 Tail Length
.040 Contact
Diameter
DEM-9SAT
DAM-15SAT
DBM-25SAT
DCM-37SAT
.158 Tail Length
.040 Contact
Diameter
DEM-9SGT
DAM-15SGT
DBM-25SGT
DCM-37SGT
.185 Tail Length
.040 Contact
Diameter
DEM-9SWT
DAM-15SWT
DBM-25SWT
DCM-37SWT
Tin-Plated Shell
Positions
9
15
25
37
.125 Tail Length
.030 Contact
Diameter
DEM-9SDT
DAM-15SDT
DBM-25SDT
DCM-37SDT
4-51
Vertical PCB Plugs
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEM-9PE
DEM-9PM
DEM-9PZ
DEM-9PB
DEM-9PH
DEM-9PX
15
DAM-15PE
DAM-15PM
DAM-15PZ
DAM-15PB
DAM-15PH
DAM-15PX
25
DBM-25PE
DBM-25PM
DBM-25PZ
DBM-25PB
DBM-25PH
DBM-25PX
37
DCM-37PE
DCM-37PM
DCM-37PZ
DCM-37PB
DCM-37PH
DCM-37PX
50
DDM-50PE
DDM-50PM
DDM-50PZ
DDM-50PB
DDM-50PH
DDM-50PX
Zinc-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEME-9PE
DEME-9PM
DEME-9PZ
DEME-9PB
DEME-9PH
DEME-9PX
15
DAME-15PE
DAME-15PM
DAME-15PZ
DAME-15PB
DAME-15PH
DAME-15PX
25
DBME-25PE
DBME-25PM
DBME-25PZ
DBME-25PB
DBME-25PH
DBME-25PX
37
DCME-37PE
DCME-37PM
DCME-37PZ
DCME-37PB
DCME-37PH
DCME-37PX
50
DDME-50PE
DDME-50PM
DDME-50PZ
DDME-50PB
DDME-50PH
DDME-50PX
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
Zinc-Plated Shell with Yellow Chromate Finish and Dual Float Bushings
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
9
DEMY-9PE
DEMY-9PM
DEMY-9PZ
DEMY-9PB
DEMY-9PH
DEMY-9PX
15
DAMY-15PE
DAMY-15PM
DAMY-15PZ
DAMY-15PB
DAMY-15PH
DAMY-15PX
25
DBMY-25PE
DBMY-25PM
DBMY-25PZ
DBMY-25PB
DBMY-25PH
DBMY-25PX
37
DCMY-37PE
DCMY-37PM
DCMY-37PZ
DCMY-37PB
DCMY-37PH
DCMY-37PX
50
DDMY-50PE
DDMY-50PM
DDMY-50PZ
DDMY-50PB
DDMY-50PH
DDMY-50PX
4-52
Vertical PCB Plugs (Cont’d)
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEM-9PETI
DEM-9PMTI
DEM-9PZTI
DEM-9PBTI
DEM-9PHTI
DEM-9PXTI
15
DAM-15PETI
DAM-15PMTI
DAM-15PZTI
DAM-15PBTI
DAM-15PHTI
DAM-15PXTI
25
DBM-25PETI
DBM-25PMTI
DBM-25PZTI
DBM-25PBTI
DBM-25PHTI
DBM-25PXTI
37
DCM-37PETI
DCM-37PMTI
DCM-37PZTI
DCM-37PBTI
DCM-37PHTI
DCM-37PXTI
50
DDM-50PETI
DDM-50PMTI
DDM-50PZTI
DDM-50PBTI
DDM-50PHTI
DDM-50PXTI
Tin-Plated Shell with Grounding Indents and 4-40 Clinch Nuts
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEME-9PETI
DEME-9PMTI
DEME-9PZTI
DEME-9PBTI
DEME-9PHTI
DEME-9PXTI
15
DAME-15PETI
DAME-15PMTI
DAME-15PZTI
DAME-15PBTI
DAME-15PHTI
DAME-15PXTI
25
DBME-25PETI
DBME-25PMTI
DBME-25PZTI
DBME-25PBTI
DBME-25PHTI
DBME-25PXTI
37
DCME-37PETI
DCME-37PMTI
DCME-37PZTI
DCME-37PBTI
DCME-37PHTI
DCME-37PXTI
50
DDME-50PETI
DDME-50PMTI
DDME-50PZTI
DDME-50PBTI
DDME-50PHTI
DDME-50PXTI
Tin-Plated Shell with Grounding Indents and Dual Float Bushings
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEMY-9PETI
DEMY-9PMTI
DEMY-9PZTI
DEMY-9PBTI
DEMY-9PHTI
DEMY-9PXTI
15
DAMY-15PETI
DAMY-15PMTI
DAMY-15PZTI
DAMY-15PBTI
DAMY-15PHTI
DAMY-15PXTI
25
DBMY-25PETI
DBMY-25PMTI
DBMY-25PZTI
DBMY-25PBTI
DBMY-25PHTI
DBMY-25PXTI
37
DCMY-37PETI
DCMY-37PMTI
DCMY-37PZTI
DCMY-37PBTI
DCMY-37PHTI
DCMY-37PXTI
50
DDMY-50PETI
DDMY-50PMTI
DDMY-50PZTI
DDMY-50PBTI
DDMY-50PHTI
DDMY-50PXTI
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEM-9SE
DEM-9SM
DEM-9SZ
DEM-9SB
DEM-9SH
DEM-9SX
15
DAM-15SE
DAM-15SM
DAM-15SZ
DAM-15SB
DAM-15SH
DAM-15SX
25
DBM-25SE
DBM-25SM
DBM-25SZ
DBM-25SB
DBM-25SH
DBM-25SX
37
DCM-37SE
DCM-37SM
DCM-37SZ
DCM-37SB
DCM-37SH
DCM-37SX
50
DDM-50SE
DDM-50SM
DDM-50SZ
DDM-50SB
DDM-50SH
DDM-50SX
4-53
Vertical PCB Sockets (Cont’d)
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEME-9SE
DEME-9SM
DEME-9SZ
DEME-9SB
DEME-9SH
DEME-9SX
15
DAME-15SE
DAME-15SM
DAME-15SZ
DAME-15SB
DAME-15SH
DAME-15SX
25
DBME-25SE
DBME-25SM
DBME-25SZ
DBME-25SB
DBME-25SH
DBME-25SX
37
DCME-37SE
DCME-37SM
DCME-37SZ
DCME-37SB
DCME-37SH
DCME-37SX
50
DDME-50SE
DDME-50SM
DDME-50SZ
DDME-50SB
DDME-50SH
DDME-50SX
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
9
DEMY-9SE
DEMY-9SM
DEMY-9SZ
DEMY-9SB
DEMY-9SH
DEMY-9SX
15
DAMY-15SE
DAMY-15SM
DAMY-15SZ
DAMY-15SB
DAMY-15SH
DAMY-15SX
25
DBMY-25SE
DBMY-25SM
DBMY-25SZ
DBMY-25SB
DBMY-25SH
DBMY-25SX
37
DCMY-37SE
DCMY-37SM
DCMY-37SZ
DCMY-37SB
DCMY-37SH
DCMY-37SX
50
DDMY-50SE
DDMY-50SM
DDMY-50SZ
DDMY-50SB
DDMY-50SH
DDMY-50SX
Tin-Plated Shell
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEM-9SET
DEM-9SMT
DEM-9SZT
DEM-9SBT
DEM-9SHT
DEM-9SXT
15
DAM-15SET
DAM-15SMT
DAM-15SZT
DAM-15SBT
DAM-15SHT
DAM-15SXT
25
DBM-25SET
DBM-25SMT
DBM-25SZT
DBM-25SBT
DBM-25SHT
DBM-25SXT
37
DCM-37SET
DCM-37SMT
DCM-37SZT
DCM-37SBT
DCM-37SHT
DCM-37SXT
50
DDM-50SET
DDM-50SMT
DDM-50SZT
DDM-50SBT
DDM-50SHT
DDM-50SXT
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
Tin-Plated Shell with 4-40 Clinch Nuts
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
9
DEME-9SET
DEME-9SMT
DEME-9SZT
DEME-9SBT
DEME-9SHT
DEME-9SXT
15
DAME-15SET
DAME-15SMT
DAME-15SZT
DAME-15SBT
DAME-15SHT
DAME-15SXT
25
DBME-25SET
DBME-25SMT
DBME-25SZT
DBME-25SBT
DBME-25SHT
DBME-25SXT
37
DCME-37SET
DCME-37SMT
DCME-37SZT
DCME-37SBT
DCME-37SHT
DCME-37SXT
50
DDME-50SET
DDME-50SMT
DDME-50SZT
DDME-50SBT
DDME-50SHT
DDME-50SXT
Tin-Plated Shell with Dual Float Bushings
Positions
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
9
DEMY-9SET
DEMY-9SMT
DEMY-9SZT
DEMY-9SBT
DEMY-9SHT
DEMY-9SXT
15
DAMY-15SET
DAMY-15SMT
DAMY-15SZT
DAMY-15SBT
DAMY-15SHT
DAMY-15SXT
25
DBMY-25SET
DBMY-25SMT
DBMY-25SZT
DBMY-25SBT
DBMY-25SHT
DBMY-25SXT
37
DCMY-37SET
DCMY-37SMT
DCMY-37SZT
DCMY-37SBT
DCMY-37SHT
DCMY-37SXT
50
DDMY-50SET
DDMY-50SMT
DDMY-50SZT
DDMY-50SBT
DDMY-50SHT
DDMY-50SXT
4-54
Shell Sizes (equivalent to standard size): E (Size 9), A (Size 15 ), B (Size 25 ), C (Size 25 ), and D (Size 25 ).
Offered in a variety of combination layouts in vertical style for PCB mount or solder cup style for wire termination.
Signal Contacts (Size 20) are fixed and non-removable.
Vertical Dip Solder Contacts are available with three contact tail
Removable Coaxial, High Power, High Voltage contacts must be ordered separately.
See Series 1 page 4-48 for specifications.
Available with 30µin. or 50µin. gold contact plating.
Materials
Connector Shell:
• Steel with zinc or cadmium plating and yellow chromate finish or tin plating (grounding indents on plug).
4-55
Combination Layouts
Shell Size
Contact Arrangement
Signal Contacts
Coax Cavities
Shell Size
Contact Arrangement
Signal Contacts
Coax Cavities
E
5W1
4
1
A
3W3
B
9W4
5
4
A
7W2
5
1
A
11W1
10
1
B
13W3
10
3
B
17W2
15
2
B
21W1
Shell Size
Contact Arrangement
Signal Contacts
Coax Cavities
C
C
C
13W6
7
5
8W8
17W5
12
5
Shell Size
Contact Arrangement
Signal Contacts
Coax Cavities
C
C
C
21WA-4
17
4
25W3
22
3
27W2
25
2
Shell Size
Contact Arrangement
Signal Contacts
Coax Cavities
D
24W7
25
2
D
36W4
32
4
D
43W2
41
2
NOTE: Mating face of plug is shown, socket is mirror image. Position numbers are for male only.
4-56
Combo D-sub Solder Cup Plugs
30µin. Gold Plating
Shell
Size Mounting Holes 4-40 Clinch Nuts Dual Float Bushings
E
DEM-XXWX*P
DEME XXWX*P
DEMY-XXWX*P
A
DAM-XXWX*P
DAME-XXWX*P
DAMY-XXWX*P
B
DBM-XXWX*P
DBME-XXWX*P
DBMY-XXWX*P
C
DCM-XXWX*P
DCME-XXWX*P
DCMY-XXWX*P
D
DDM-XXWX*P
DDME-XXWX*P
DDMY-XXWX*P
Mounting Holes
4-40 Clinch Nuts
Dual Float Bushings
DEM-XXWX*PTI
DEME-XXWX*PTI
DEMY-XXWX*PTI
DAM-XXWX*PTI
DAME-XXWX*PTI
DAMY-XXWX*PTI
DBM-XXWX*PTI
DBME-XXWX*PTI
DBMY-XXWX*PTI
DCM-XXWX*PTI
DCME-XXWX*PTI
DCMY-XXWX*PTI
DDM-XXWX*PTI
DDME-XXWX*PTI
DDMY-XXWX*PTI
Combo D-sub Solder Cup Sockets
30µin. Gold Plating
Shell
E
DEM-XXWX*S
DEME-XXWX*S
DEMY-XXWX*S
A
DAM-XXWX*S
DAME-XXWX*S
DAMY-XXWX*S
B
DBM-XXWX*S
DBME-XXWX*S
DBMY-XXWX*S
C
DCM-XXWX*S
DCME-XXWX*S
DCMY-XXWX*S
D
DDM-XXWX*S
DDME-XXWX*S
DDMY-XXWX*S
Mounting Holes
DEM-XXWX*ST
DAM-XXWX*ST
DBM-XXWX*ST
DCM-XXWX*ST
DDM-XXWX*ST
Tin-Plated Shell
4-40 Clinch Nuts
Dual Float Bushings
DEME-XXWX*ST
DEMY-XXWX*ST
DAME-XXWX*ST
DAMY-XXWX*ST
DBME-XXWX*ST
DBMY-XXWX*ST
DCME-XXWX*ST
DCMY-XXWX*ST
DDME-XXWX*ST
DDMY-XXWX*ST
Mounting Holes
DEMM-XXWX*S
DAMM-XXWX*S
DBMM-XXWX*S
DCMM-XXWX*S
DDMM-XXWX*S
Sockets
4-40 Clinch Nuts
DEMME-XXWX*S
DAMME-XXWX*S
DBMME-XXWX*S
DCMME-XXWX*S
DDMME-XXWX*S
Combo D-sub Solder Cup Plugs and Sockets
50µin. Gold Plating
Cadmium-Plated Shell with Yellow Chromate Finish
Shell
Size Mounting Holes
E
DEMM-XXWX*P
A
DAMM-XXWX*P
B
DBMM-XXWX*P
C
DCMM-XXWX*P
D
DDMM-XXWX*P
Plugs
DEMME-XXWX*P
DEMMY-XXWX*P
DAMME-XXWX*P
DAMMY-XXWX*P
DBMME-XXWX*P
DBMMY-XXWX*P
DCMME-XXWX*P
DCMMY-XXWX*P
DDMME-XXWX*P
DDMMY-XXWX*P
Dual Float Bushings
DEMMY-XXWX*S
DAMMY-XXWX*S
DBMMY-XXWX*S
DCMMY-XXWX*S
DDMMY-XXWX*S
*Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3.
4-57
Call Toll Free: 1 (800) 323-9612
Combo D-sub Vertical PCB Plugs
30µin. Gold Plating
Zinc-Plated Shell with Yellow Chromate Finish and Mounting Holes
.125 Tail Length .158 Tail Length
.185 Tail Length .125 Tail Length
.030 Contact
.030 Contact
.030 Contact
.040 Contact
Shell Size
Diameter
Diameter
Diameter
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEM-XXWX*PH
DAM-XXWX*PH
DBM-XXWX*PH
DCM-XXWX*PH
DDM-XXWX*PH
DEM-XXWX*PX
DAM-XXWX*PX
DBM-XXWX*PX
DCM-XXWX*PX
DDM-XXWX*PX
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEME-XXWX*PB
DAME-XXWX*PB
DBME-XXWX*PB
DCME-XXWX*PB
DDME-XXWX*PB
DEME-XXWX*PH
DAME-XXWX*PH
DBME-XXWX*PH
DCME-XXWX*PH
DDME-XXWX*PH
DEME-XXWX*PX
DAME-XXWX*PX
DBME-XXWX*PX
DCME-XXWX*PX
DDME-XXWX*PX
.030 Contact
.030 Contact
.030 Contact
.040 Contact
Shell Size
Diameter
Diameter
Diameter
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMY-XXWX*PB
DAMY-XXWX*PB
DBMY-XXWX*PB
DCMY-XXWX*PB
DDMY-XXWX*PB
DEMY-XXWX*PH
DAMY-XXWX*PH
DBMY-XXWX*PH
DCMY-XXWX*PH
DDMY-XXWX*PH
DEMY-XXWX*PX
DAMY-XXWX*PX
DBMY-XXWX*PX
DCMY-XXWX*PX
DDMY-XXWX*PX
Tin-Plated Shell with Grounding Indents and Mounting Holes
.030 Contact
.030 Contact
.030 Contact
.040 Contact
Shell Size
Diameter
Diameter
Diameter
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEM-XXWX*PHTI
DAM-XXWX*PHTI
DBM-XXWX*PHTI
DCM-XXWX*PHTI
DDM-XXWX*PHTI
DEM-XXWX*PXTI
DAM-XXWX*PXTI
DBM-XXWX*PXTI
DCM-XXWX*PXTI
DDM-XXWX*PXTI
E
A
B
C
D
DEM-XXWX*PE
DAM-XXWX*PE
DBM-XXWX*PE
DCM-XXWX*PE
DDM-XXWX*PE
DEM-XXWX*PM
DAM-XXWX*PM
DBM-XXWX*PM
DCM-XXWX*PM
DDM-XXWX*PM
DEM-XXWX*PZ
DAM-XXWX*PZ
DBM-XXWX*PZ
DCM-XXWX*PZ
DDM-XXWX*PZ
DEM-XXWX*PB
DAM-XXWX*PB
DBM-XXWX*PB
DCM-XXWX*PB
DDM-XXWX*PB
.030 Contact
.030 Contact
.030 Contact
.040 Contact
Shell Size
Diameter
Diameter
Diameter
Diameter
E
A
B
C
D
E
A
B
C
D
E
A
B
C
D
DEME-XXWX*PE
DAME-XXWX*PE
DBME-XXWX*PE
DCME-XXWX*PE
DDME-XXWX*PE
DEMY-XXWX*PE
DAMY-XXWX*PE
DBMY-XXWX*PE
DCMY-XXWX*PE
DDMY-XXWX*PE
DEM-XXWX*PETI
DAM-XXWX*PETI
DBM-XXWX*PETI
DCM-XXWX*PETI
DDM-XXWX*PETI
DEME-XXWX*PM
DAME-XXWX*PM
DBME-XXWX*PM
DCME-XXWX*PM
DDME-XXWX*PM
DEMY-XXWX*PM
DAMY-XXWX*PM
DBMY-XXWX*PM
DCMY-XXWX*PM
DDMY-XXWX*PM
DEM-XXWX*PMTI
DAM-XXWX*PMTI
DBM-XXWX*PMTI
DCM-XXWX*PMTI
DDM-XXWX*PMTI
DEME-XXWX*PZ
DAME-XXWX*PZ
DBME-XXWX*PZ
DCME-XXWX*PZ
DDME-XXWX*PZ
DEMY-XXWX*PZ
DAMY-XXWX*PZ
DBMY-XXWX*PZ
DCMY-XXWX*PZ
DDMY-XXWX*PZ
DEM-XXWX*PZTI
DAM-XXWX*PZTI
DBM-XXWX*PZTI
DCM-XXWX*PZTI
DDM-XXWX*PZTI
DEM-XXWX*PBTI
DAM-XXWX*PBTI
DBM-XXWX*PBTI
DCM-XXWX*PBTI
DDM-XXWX*PBTI
* Note: XXWX means insert combo layout contact arrangement from page 4-56 in catalog number i.e., 13W3.
4-58
30µin. Gold Plating (Cont’d)
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
E
A
B
C
D
DEME-XXWX*PETI
DAME-XXWX*PETI
DBME-XXWX*PETI
DCME-XXWX*PETI
DDME-XXWX*PETI
DEME-XXWX*PMTI
DAME-XXWX*PMTI
DBME-XXWX*PMTI
DCME-XXWX*PMTI
DDME-XXWX*PMTI
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEME-XXWX*PZTI
DAME-XXWX*PZTI
DBME-XXWX*PZTI
DCME-XXWX*PZTI
DDME-XXWX*PZTI
DEME-XXWX*PBTI
DAME-XXWX*PBTI
DBME-XXWX*PBTI
DCME-XXWX*PBTI
DDME-XXWX*PBTI
DEME-XXWX*PHTI
DAME-XXWX*PHTI
DBME-XXWX*PHTI
DCME-XXWX*PHTI
DDME-XXWX*PHTI
DEME-XXWX*PXTI
DAME-XXWX*PXTI
DBME-XXWX*PXTI
DCME-XXWX*PXTI
DDME-XXWX*PXTI
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
E
A
B
C
D
DEMY-XXWX*PETI
DAMY-XXWX*PETI
DBMY-XXWX*PETI
DCMY-XXWX*PETI
DDMY-XXWX*PETI
DEMY-XXWX*PMTI
DAMY-XXWX*PMTI
DBMY-XXWX*PMTI
DCMY-XXWX*PMTI
DDMY-XXWX*PMTI
DEMY-XXWX*PZTI
DAMY-XXWX*PZTI
DBMY-XXWX*PZTI
DCMY-XXWX*PZTI
DDMY-XXWX*PZTI
DEMY-XXWX*PBTI
DAMY-XXWX*PBTI
DBMY-XXWX*PBTI
DCMY-XXWX*PBTI
DDMY-XXWX*PBTI
DEMY-XXWX*PHTI
DAMY-XXWX*PHTI
DBMY-XXWX*PHTI
DCMY-XXWX*PHTI
DDMY-XXWX*PHTI
DEMY-XXWX*PXTI
DAMY-XXWX*PXTI
DBMY-XXWX*PXTI
DCMY-XXWX*PXTI
DDMY-XXWX*PXTI
50µin. Gold Plating
Cadmium-Plated Shell with Yellow Chromate Finish and Mounting Holes
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEMM-XXWX*PE
DAMM-XXWX*PE
DBMM-XXWX*PE
DCMM-XXWX*PE
DDMM-XXWX*PE
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMM-XXWX*PM
DAMM-XXWX*PM
DBMM-XXWX*PM
DCMM-XXWX*PM
DDMM-XXWX*PM
DEMM-XXWX*PZ
DAMM-XXWX*PZ
DBMM-XXWX*PZ
DCMM-XXWX*PZ
DDMM-XXWX*PZ
DEMM-XXWX*PB
DAMM-XXWX*PB
DBMM-XXWX*PB
DCMM-XXWX*PB
DDMM-XXWX*PB
DEMM-XXWX*PH
DAMM-XXWX*PH
DBMM-XXWX*PH
DCMM-XXWX*PH
DDMM-XXWX*PH
DEMM-XXWX*PX
DAMM-XXWX*PX
DBMM-XXWX*PX
DCMM-XXWX*PX
DDMM-XXWX*PX
Cadmium-Plated Shell with Yellow Chromate Finish and 4-40 Clinch Nuts
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
E
A
B
C
D
DEMME-XXWX*PE
DAMME-XXWX*PE
DBMME-XXWX*PE
DCMME-XXWX*PE
DDMME-XXWX*PE
DEMME-XXWX*PM
DAMME-XXWX*PM
DBMME-XXWX*PM
DCMME-XXWX*PM
DDMME-XXWX*PM
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMME-XXWX*PZ
DAMME-XXWX*PZ
DBMME-XXWX*PZ
DCMME-XXWX*PZ
DDMME-XXWX*PZ
DEMME-XXWX*PB
DAMME-XXWX*PB
DBMME-XXWX*PB
DCMME-XXWX*PB
DDMME-XXWX*PB
DEMME-XXWX*PH
DAMME-XXWX*PH
DBMME-XXWX*PH
DCMME-XXWX*PH
DDMME-XXWX*PH
DEMME-XXWX*PX
DAMME-XXWX*PX
DBMME-XXWX*PX
DCMME-XXWX*PX
DDMME-XXWX*PX
Cadmium-Plated Shell with Yellow Chromate Finish and Dual Float Bushings
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
E
A
B
C
D
DEMMY-XXWX*PE
DAMMY-XXWX*PE
DBMMY-XXWX*PE
DCMMY-XXWX*PE
DDMMY-XXWX*PE
DEMMY-XXWX*PM
DAMMY-XXWX*PM
DBMMY-XXWX*PM
DCMMY-XXWX*PM
DDMMY-XXWX*PM
DEMMY-XXWX*PZ
DAMMY-XXWX*PZ
DBMMY-XXWX*PZ
DCMMY-XXWX*PZ
DDMMY-XXWX*PZ
DEMMY-XXWX*PB
DAMMY-XXWX*PB
DBMMY-XXWX*PB
DCMMY-XXWX*PB
DDMMY-XXWX*PB
DEMMY-XXWX*PH
DAMMY-XXWX*PH
DBMMY-XXWX*PH
DCMMY-XXWX*PH
DDMMY-XXWX*PH
DEMMY-XXWX*PX
DAMMY-XXWX*PX
DBMMY-XXWX*PX
DCMMY-XXWX*PX
DDMMY-XXWX*PX
4-59
Combo D-sub Vertical PCB Sockets
30µin. Gold Plating
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEM-XXWX*SE
DAM-XXWX*SE
DBM-XXWX*SE
DCM-XXWX*SE
DDM-XXWX*SE
.158 Tail Length
.030 Contact
Diameter
DEM-XXWX*SM
DAM-XXWX*SM
DBM-XXWX*SM
DCM-XXWX*SM
DDM-XXWX*SM
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEM-XXWX*SZ
DAM-XXWX*SZ
DBM-XXWX*SZ
DCM-XXWX*SZ
DDM-XXWX*SZ
DEM-XXWX*SB
DAM-XXWX*SB
DBM-XXWX*SB
DCM-XXWX*SB
DDM-XXWX*SB
DEM-XXWX*SH
DAM-XXWX*SH
DBM-XXWX*SH
DCM-XXWX*SH
DDM-XXWX*SH
DEM-XXWX*SX
DAM-XXWX*SX
DBM-XXWX*SX
DCM-XXWX*SX
DDM-XXWX*SX
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEME-XXWX*SE
DAME-XXWX*SE
DBME-XXWX*SE
DCME-XXWX*SE
DDME-XXWX*SE
.158 Tail Length
.030 Contact
Diameter
DEME-XXWX*SM
DAME-XXWX*SM
DBME-XXWX*SM
DCME-XXWX*SM
DDME-XXWX*SM
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEME-XXWX*SZ
DAME-XXWX*SZ
DBME-XXWX*SZ
DCME-XXWX*SZ
DDME-XXWX*SZ
DEME-XXWX*SB
DAME-XXWX*SB
DBME-XXWX*SB
DCME-XXWX*SB
DDME-XXWX*SB
DEME-XXWX*SH
DAME-XXWX*SH
DBME-XXWX*SH
DCME-XXWX*SH
DDME-XXWX*SH
DEME-XXWX*SX
DAME-XXWX*SX
DBME-XXWX*SX
DCME-XXWX*SX
DDME-XXWX*SX
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEMY-XXWX*SE
DAMY-XXWX*SE
DBMY-XXWX*SE
DCMY-XXWX*SE
DDMY-XXWX*SE
.158 Tail Length
.030 Contact
Diameter
DEMY-XXWX*SM
DAMY-XXWX*SM
DBMY-XXWX*SM
DCMY-XXWX*SM
DDMY-XXWX*SM
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMY-XXWX*SZ
DAMY-XXWX*SZ
DBMY-XXWX*SZ
DCMY-XXWX*SZ
DDMY-XXWX*SZ
DEMY-XXWX*SB
DAMY-XXWX*SB
DBMY-XXWX*SB
DCMY-XXWX*SB
DDMY-XXWX*SB
DEMY-XXWX*SH
DAMY-XXWX*SH
DBMY-XXWX*SH
DCMY-XXWX*SH
DDMY-XXWX*SH
DEMY-XXWX*SX
DAMY-XXWX*SX
DBMY-XXWX*SX
DCMY-XXWX*SX
DDMY-XXWX*SX
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEM-XXWX*SZT
DAM-XXWX*SZT
DBM-XXWX*SZT
DCM-XXWX*SZT
DDM-XXWX*SZT
DEM-XXWX*SBT
DAM-XXWX*SBT
DBM-XXWX*SBT
DCM-XXWX*SBT
DDM-XXWX*SBT
DEM-XXWX*SHT
DAM-XXWX*SHT
DBM-XXWX*SHT
DCM-XXWX*SHT
DDM-XXWX*SHT
DEM-XXWX*SXT
DAM-XXWX*SXT
DBM-XXWX*SXT
DCM-XXWX*SXT
DDM-XXWX*SXT
Tin-Plated Shell with Mounting Holes
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEM-XXWX*SET
DAM-XXWX*SET
DBM-XXWX*SET
DCM-XXWX*SET
DDM-XXWX*SET
.158 Tail Length
.030 Contact
Diameter
DEM-XXWX*SMT
DAM-XXWX*SMT
DBM-XXWX*SMT
DCM-XXWX*SMT
DDM-XXWX*SMT
4-60
Combo D-sub Vertical PCB Sockets (Cont’d)
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
E
A
B
C
D
DEME-XXWX*SET
DAME-XXWX*SET
DBME-XXWX*SET
DCME-XXWX*SET
DDME-XXWX*SET
DEME-XXWX*SMT
DAME-XXWX*SMT
DBME-XXWX*SMT
DCME-XXWX*SMT
DDME-XXWX*SMT
DEME-XXWX*SZT
DAME-XXWX*SZT
DBME-XXWX*SZT
DCME-XXWX*SZT
DDME-XXWX*SZT
DEME-XXWX*SBT
DAME-XXWX*SBT
DBME-XXWX*SBT
DCME-XXWX*SBT
DDME-XXWX*SBT
DEME-XXWX*SHT
DAME-XXWX*SHT
DBME-XXWX*SHT
DCME-XXWX*SHT
DDME-XXWX*SHT
DEME-XXWX*SXT
DAME-XXWX*SXT
DBME-XXWX*SXT
DCME-XXWX*SXT
DDME-XXWX*SXT
Tin-Plated Shell and Dual Float Bushings
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMY-XXWX*SET
DAMY-XXWX*SET
DBMY-XXWX*SET
DCMY-XXWX*SET
DDMY-XXWX*SET
DEMY-XXWX*SMT
DAMY-XXWX*SMT
DBMY-XXWX*SMT
DCMY-XXWX*SMT
DDMY-XXWX*SMT
DEMY-XXWX*SZT
DAMY-XXWX*SZT
DBMY-XXWX*SZT
DCMY-XXWX*SZT
DDMY-XXWX*SZT
DEMY-XXWX*SBT
DAMY-XXWX*SBT
DBMY-XXWX*SBT
DCMY-XXWX*SBT
DDMY-XXWX*SBT
DEMY-XXWX*SHT
DAMY-XXWX*SHT
DBMY-XXWX*SHT
DCMY-XXWX*SHT
DDMY-XXWX*SHT
DEMY-XXWX*SXT
DAMY-XXWX*SXT
DBMY-XXWX*SXT
DCMY-XXWX*SXT
DDMY-XXWX*SXT
50µin. Gold Plating
Shell
Size
E
A
B
C
D
.125 Tail Length
.030 Contact
Diameter
DEMM-XXWX*SE
DAMM-XXWX*SE
DBMM-XXWX*SE
DCMM-XXWX*SE
DDMM-XXWX*SE
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMM-XXWX*SM
DAMM-XXWX*SM
DBMM-XXWX*SM
DCMM-XXWX*SM
DDMM-XXWX*SM
DEMM-XXWX*SZ
DAMM-XXWX*SZ
DBMM-XXWX*SZ
DCMM-XXWX*SZ
DDMM-XXWX*SZ
DEMM-XXWX*SB
DAMM-XXWX*SB
DBMM-XXWX*PB
DCMM-XXWX*SB
DDMM-XXWX*SB
DEMM-XXWX*SH
DAMM-XXWX*SH
DBMM-XXWX*SH
DCMM-XXWX*SH
DDMM-XXWX*SH
DEMM-XXWX*SX
DAMM-XXWX*SX
DBMM-XXWX*SX
DCMM-XXWX*SX
DDMM-XXWX*SX
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
E
A
B
C
D
DEMME-XXWX*SE
DAMME-XXWX*SE
DBMME-XXWX*SE
DCMME-XXWX*SE
DDMME-XXWX*SE
DEMME-XXWX*SM
DAMME-XXWX*SM
DBMME-XXWX*SM
DCMME-XXWX*SM
DDMME-XXWX*SM
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
DEMME-XXWX*SZ
DAMME-XXWX*SZ
DBMME-XXWX*SZ
DCMME-XXWX*SZ
DDMME-XXWX*SZ
DEMME-XXWX*SB
DAMME-XXWX*SB
DBMME-XXWX*SB
DCMME-XXWX*SB
DDMME-XXWX*SB
DEMME-XXWX*SH
DAMME-XXWX*SH
DBMME-XXWX*SH
DCMME-XXWX*SH
DDMME-XXWX*SH
DEMME-XXWX*SX
DAMME-XXWX*SX
DBMME-XXWX*SX
DCMME-XXWX*SX
DDMME-XXWX*SX
Shell
Size
.125 Tail Length
.030 Contact
Diameter
.158 Tail Length
.030 Contact
Diameter
.185 Tail Length
.030 Contact
Diameter
.125 Tail Length
.040 Contact
Diameter
.158 Tail Length
.040 Contact
Diameter
.185 Tail Length
.040 Contact
Diameter
E
A
B
C
D
DEMMY-XXWX*SE
DAMMY-XXWX*SE
DBMMY-XXWX*SE
DCMMY-XXWX*SE
DDMMY-XXWX*SE
DEMMY-XXWX*SM
DAMMY-XXWX*SM
DBMMY-XXWX*SM
DCMMY-XXWX*SM
DDMMY-XXWX*SM
DEMMY-XXWX*SZ
DAMMY-XXWX*SZ
DBMMY-XXWX*SZ
DCMMY-XXWX*SZ
DDMMY-XXWX*SZ
DEMMY-XXWX*SB
DAMMY-XXWX*SB
DBMMY-XXWX*SB
DCMMY-XXWX*SB
DDMMY-XXWX*SB
DEMMY-XXWX*SH
DAMMY-XXWX*SH
DBMMY-XXWX*SH
DCMMY-XXWX*SH
DDMMY-XXWX*SH
DEMMY-XXWX*SX
DAMMY-XXWX*SX
DBMMY-XXWX*SX
DCMMY-XXWX*SX
DDMMY-XXWX*SX
4-61
■ Available in Coaxial (50Ω and 75Ω ), High-Voltage, and High-Power styles.
■ Cable termination and PCB mount contacts are available in right-angle and straight plugs
and receptacles.
■ Precision screw machine construction results in uniform contact impedance and excellent
contact retention.
■ Available with 30µin. or 50µin. gold contact plating.
■ Cable braid can be soldered or crimped.
■ See pages 4-55 thru 4-61 for Cinch combination layout D-subminiature connectors.
Termination Tooling
No tools are required for coaxial contact insertion. Contacts snap into connector. Coaxial and high-voltage contact
extraction tool #CET-C6B for removing contacts after termination. See page 4-103.
Tool to crimp sleeve over cable braid: Use 3-cavity die #CCD-26 with crimp frame #FCT-552. See page 4-103.
NOTE: In order to determine which contact to use with a cable wire not specifically listed:
Check the style of contact required: straight or right-angle, solder braid or crimp braid, etc.
Refer to the cable wire manufacturer’s specifications to determine:
- The O.D. of the insulator.
- The O.D. of the jacket.
Compare the above with the corresponding dimensions C and E in the straight contacts and dimensions B and
C in the right-angle contacts.
4-62
Ω
Materials
Receptacle: Body - Beryllium copper, Insulator - Teflon, Contacts - Brass.
Plug: Body - Brass, Insulator - Teflon, Contacts - Beryllium copper.
Plating: 30µin. gold over nickel, 50µin. gold over copper.
Electrical Characteristics
Dielectric Withstanding Voltage:
Cable Contacts: minimum AC 1000V RMS @ sea level.
PCB Contacts: minimum AC 800V RMS @ sea level.
Frequency Range: 0-900 MHz.
Right-Angle
Receptacle
Plug
Straight
Receptacle
Plug
Right-Angle PCB Coaxial Contacts - 50Ω
Plug
Recept.
30µin. Gold
DM53761-30
DM53763-30
50µin. Gold
DM53761-50
DM53763-50
Straight PCB Coaxial Contacts - 50Ω
Plug
Recept.
4-63
30µin. Gold
DM53760-30
DM53762-30
50µin. Gold
DM53760-50
DM53762-50
Ω
• Material and electrical specifications: See page 4-63.
Plug
Receptacle
Straight Solder Braid Coaxial Contacts
Plug
Plug
Plug
Plug
Recept.
Recept.
Recept.
Recept.
Plug
Recept.
30µin. Gold
DM53740-5008
DM53740-5001
DM53740-5002
DM53740-5005
DM53742-5006
DM53742-5001
DM53742-5002
DM53742-5004
DM53740-5000
DM53742-5000
50µin. Gold
DM53740-5105
DM53740-5099
DM53740-5104
DM53740-5101
DM53742-5092
DM53742-5089
DM53742-5091
DM53742-5086
DM53740-5100
DM53742-5085
A
in
.739
.739
.847
.847
.739
.739
.847
.847
.670
.670
Max.
mm
18.77
18.77
21.51
21.51
18.77
18.77
21.51
21.51
17.02
17.02
B Ref.
in
mm
0.929 23.60
0.929 23.60
1.037 26.34
1.037 26.34
0.929 23.60
0.929 23.60
1.037 26.34
1.037 26.34
0.860 21.84
0.860 21.84
in
.093
.125
.202
.202
.093
.125
.202
.202
.093
.093
C
B Ref.
in
mm
.929 23.60
.929 23.60
1.037 26.34
1.037 26.34
.929 23.60
.929 23.60
1.037
1.037
E +.005"
in
mm
.040 1.02
.067 1.70
.110 2.79
.125 3.18
.040 1.02
.067 1.70
.110 2.79
.125 3.18
.040 1.02
.040 1.02
RG Cable
Old
New
196/U
178B/U
187/U
179B/U
195/U
180B/U
58/U
58B/U
196/U
178B/U
187/U
179B/U
195/U
180B/U
58/U
58B/U
196/U
178B/U
196/U
178B/U
mm
3.15
3.86
5.97
5.97
3.15
3.86
E +.005"
in
mm
.040 1.02
.067 1.70
.110 2.79
.125 3.18
.040 1.02
.067 1.70
5.97
5.97
.110
.125
RG Cable
Old
New
196/U 178B/U
187/U 179B/U
195/U 180B/U
58/U
58B/U
196/U 178B/U
187/U, 179B/U,
188/U 316/BU
195/U 180B/U
58/U
58B/U
D
mm
2.36
3.18
5.13
5.13
2.36
3.18
5.13
5.13
2.36
2.36
in
.124
.152
.235
.235
.124
.152
.235
.235
.124
.124
in
.093
.125
.202
.202
.093
.125
mm
2.36
3.18
5.13
5.13
2.36
3.18
in
.124
.152
.235
.235
.124
.152
.202
.202
5.13
5.13
.235
.235
mm
3.15
3.86
5.97
5.97
3.15
3.86
5.97
5.97
3.15
3.15
Straight Crimp Braid Coaxial Contacts
Plug
Plug
Plug
Plug
Recept.
Recept.
30µin. Gold
DM53740
DM53740-1
DM53740-3
DM53740-5
DM53742
DM53742-1
50µin. Gold
DM53740-17
DM53740-15
DM53740-16
DM53740-18
DM53742-18
DM53742-16
A
in
.739
.739
.847
.847
.739
.739
Max.
mm
18.77
18.77
21.51
21.51
18.77
18.77
Recept.
Recept.
DM53742-3
DM53742-5
DM53742-17
DM53742-19
.847
.847
21.51
21.51
26.34
26.34
4-64
C
D
2.79
3.18
Ω
P
Right-Angle Solder Braid Coaxial Contacts - 50Ω
A
30µin. Gold
50µin. Gold
in
mm
in
B
mm
in
C
mm
in
D
mm
in
E
mm
in
F
mm
Old
RG Cable
New
RG 178B/U
RG 179B/U,
RG 316B/U
RG 180B/U
RG 58B/U
Plugs
DM53741-5000
DM53741-5001
DM53741-5059
DM53741-5062
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.492 12.50
.492 12.50
.040 1.02
.067 1.70
.093
.125
2.36
3.18
.125
.152
3.18
3.86
RG 196/U
RG 187/U
DM53741-5003
DM53741-5004
DM53741-5063
DM53741-5060
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.601 15.27
.601 15.27
.110 2.79
.125 3.18
.202
.202
5.13
5.13
.235
.235
5.97
5.97
RG 195/U
RG 196/U
Receptacles
DM53743-5000
DM53743-5001
DM53743-5073
DM53743-5076
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.492 12.50
.492 12.50
.040 1.02
.067 1.70
.093
.125
2.36
3.18
.125
.152
3.18
3.86
RG 196/U
RG 187/U
DM53743-5003
DM53743-5004
DM53743-5077
DM53743-5074
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.601 15.27
.601 15.27
.110 2.79
.125 3.18
.202
.202
5.13
5.13
.235
.235
5.97
5.97
RG 195/U
RG 58/U
D
mm
in
mm
in
mm
Old
New
RG 196/U
RG 187/U
RG 188/U
RG 195/U
RG 58/U
RG 178B/U
RG 179B/U,
RG 316B/U
RG 180B/U
RG 58B/U
RG 196/U
RG 187/U
RG 188/U
RG 195/U
RG 58/U
RG 178B/U
RG 179B/U,
RG 316B/U
RG 180B/U
RG 58B/U
RG 178B/U
RG 179B/U,
RG 316B/U
RG 180B/U
RG 58B/U
Right-Angle Crimp Braid Coaxial Contacts - 50Ω
30µin. Gold
50µin. Gold
in
A
mm
in
B
mm
Plugs
DM53741-0
DM53741-1
DM53741-12
DM53741-11
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.492 12.50
.492 12.50
.040 1.02
.067 1.70
.093
.125
2.36
3.18
.125
.152
3.18
3.86
DM53741-3
DM53741-4
DM53741-10
DM53741-13
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.601 15.27
.601 15.27
.110 2.79
.125 3.18
.202
.202
5.13
5.13
.235
.235
5.97
5.97
Receptacles
DM53743-2
DM53743-3
DM53743-18
DM53743-16
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.492 12.50
.492 12.50
.040 1.02
.067 1.70
.093
.125
2.36
3.18
.125
.152
3.18
3.86
DM53743-5
DM53743-6
DM53743-17
DM53743-19
.530
.530
13.46
13.46
.734
.734
18.64
18.64
.601 15.27
.601 15.27
.110 2.79
.125 3.18
.202
.202
5.13
5.13
.235
.235
5.97
5.97
in
C
mm
4-65
in
E
F
RG Cable
Ω
Materials
Receptacle: Body - Brass or beryllium copper, Insulator - Teflon, Contacts - Brass.
Nominal Impedance: 75Ω .
Dielectric Withstanding Voltage: Minimum 1000V RMS @ sea level.
VWSR: 1.05 max. for 0-1 GHz and 1.25 max for 1-2 GHz
75Ω Crimp/Solder Termination Straight Coaxial Contacts
A
Plug
Plug
Recept.
Recept.
Recept.
Recept.
30µin. Gold
DM53750-12
DM53750-11
DM53752-8
DM53752-7
DM53752-6
DM53752-5
50µin. Gold
DM53750-52
DM53750-51
DM53752-58
DM53752-57
DM53752-56
DM53752-55
in
1.037
0.929
1.037
0.929
1.037
0.929
B
mm
26.34
23.60
26.34
23.60
26.34
23.60
in
.108
.067
.108
.067
.108
.067
mm
2.74
1.70
2.74
1.70
2.74
1.70
Material
Brass
Brass
Brass
Brass
Beryllium Copper
Beryllium Copper
Cable
Belden 8218
RG 179 B/U
Belden 8218
RG 179 B/U
Belden 8218
RG 179 B/U
mm
2.74
1.70
2.74
1.70
2.74
1.70
Material
Brass
Brass
Brass
Brass
Beryllium Copper
Beryllium Copper
Cable
Belden 8218
RG 179 B/U
Belden 8218
RG 179 B/U
Belden 8218
RG 179 B/U
75Ω Crimp/Crimp Termination Straight Coaxial Contacts
Plug
Plug
Recept.
Recept.
Recept.
Recept.
30µin. Gold
DM53750-010
DM53750-009
DM53752-004
DM53752-003
DM53752-002
DM53752-001
50µin. Gold
DM53750-510
DM53750-509
DM53752-504
DM53752-503
DM53752-502
DM53752-501
A
in
1.050
1.050
1.090
1.090
1.090
1.090
B
mm
26.67
26.67
27.69
27.69
27.69
27.69
4-66
in
.108
.067
.108
.067
.108
.067
Materials
Contact: Body - Nylon per MIL-P-20693
Dielectric Withstanding Voltage: Minimum AC 2800VAC RMS to shell @ sea level
High-Voltage Contacts - For #20 AWG wire
Right-Angle
Straight
Plug
Plug
Receptacle
Straight High-Voltage Contacts - #20 AWG Wire
Plug
Recept.
30µin. Gold
DM51157-0
DM51155-0
50µin. Gold
DM51157-8
DM51155-7
A
in
mm
.539 13.69
.539 13.69
B
in
mm
.734 18.64
.734 18.64
Wire
Size
#20
#20
B
in
mm
.697 17.70
.697 17.70
Wire
Size
#20
#20
Right-Angle High-Voltage Contacts - #20 AWG Wire
Plug
Recept.
30µin. Gold
50µin. Gold
DM51157-5000 DM51157-5005
DM51155-5000 DM51155-5004
A
in
mm
.491 12.47
.491 12.47
4-67
• High-Power Contacts will accommodate up to 40 Amps current rating.
Materials
• Contact Plating:
- 30µin. gold over nickel
- 50µin. gold over copper
• Receptacle: Beryllium copper
• Plug: Brass
Plug
Receptacle
Straight High-Power Contacts
A
Plug
Plug
Plug
Recept.
Recept.
Recept.
30µin. Gold
DM53745-1
DM53745-7
DM53745-8
DM53744-1
DM53744-6
DM53744-7
50µin. Gold
DM53745-28
DM53745-27
DM53745-25
DM53744-21
DM53744-25
DM53744-24
in
.666
.666
.666
.666
.666
.666
mm
16.92
16.92
16.92
16.92
16.92
16.92
B
in
.866
.866
.866
.866
.866
.866
4-68
mm
22.00
22.00
22.00
22.00
22.00
22.00
C
in
.188
.112
.069
.188
.112
.069
mm
4.78
2.84
1.75
4.78
2.84
1.75
Current
Rating
(Amps)
40
40
Wire
Size
(AWG)
#8
#12
#16
#8
#12
#16
High-reliability in a commercial grade connector.
Monoblock diallyl phthalate insulator for improved electrical performance.
Offered with .120 mounting holes, 4-40 clinch nuts, or dual float bushings.
Commercial version of M24308 Military connectors with tin-plated or zinc-plated shell and
30µin. gold contact plating.
■ Screw Machine Crimp and Poke contacts available as follows:
• Note that all contacts are packed loose.
• Plating options: 30µin. gold.
• Can be included with the connector or purchased separately (FO part numbers).
■ See pages 4-5 thru 4-10 for standard dimensions, contact arrangements, and panel
mounting specifications.
Insulator Material: Glass fiber-filled diallyl phthalate
(green), UL 94V-0
Connector Shell: Steel with zinc plating and yellow chromate finish
bronze (machined)
4-40 Clinch Nut: Steel with cadmium plating and yellow
chromate finish
Dual Float Bushing: Stainless steel, passivated
Operating Temperature: -65°C to + 125°C
Shock: 50G peak per MIL-STD-202, Method 213,
Condition G
Vibration: 12 cycles in three perpendicular directions @
10-2000Hz, per MIL-STD-202, Method 204, Condition D
Moisture Resistance: 90-95% relative humidity @ 40°C for 96
hours per MIL-STD-202, Method 103
Current Rating:
Contact Resistance:
Insulation Resistance:
5 Amps
2.7 milliohms maximum
5000 megohms maximum (initial);
1000 megohms (minimum) after
environmental testing
Individual Contact Insertion and
Separation Force (minimum/maximum): 0.7 oz./12 oz.
Durability: 500 mating cycles
4-70
Termination Tooling
Contact Insertion/Extraction Tool: #CIET-20-HD (Military #M81969/39-01). See page 4-103.
Crimp Contact Hand Tool: Military #M22520/2-01. See page 4-103. Contact Positioner
(below) required.
Positioner for machine contacts for Hand Tool #M22520/2-01 (locates contact in the correct
position): #M22520/2-08. See page 4-103.
Crimp and Poke - Plugs
Positions
9
15
25
37
50
Mounting Holes
30µin. Gold
Without
Contacts
Contacts
DEMA-9P
DEMA-9P-FO
DAMA-15P
DAMA-15P-FO
DBMA-25P
DBMA-25P-FO
DCMA-37P
DCMA-37P-FO
DDMA-50P
DDMA-50P-FO
4-40 Clinch Nuts
30µin. Gold
Without
Contacts
Contacts
DEMAE-9P
DEMAE-9P-FO
DAMAE-15P
DAMAE-15P-FO
DBMAE-25P
DBMAE-25P-FO
DCMAE-37P
DCMAE-37P-FO
DDMAE-50P
DDMAE-50P-FO
Dual Float
30µin. Gold
Contacts
DEMAY-9P
DAMAY-15P
DBMAY-25P
DCMAY-37P
DDMAY-50P
Bushings
Without
Contacts
DEMAY-9P-FO
DAMAY-15P-FO
DBMAY-25P-FO
DCMAY-37P-FO
DDMAY-50P-FO
4-40 Clinch Nuts
30µin. Gold
Without
Contacts
Contacts
DEMAE-9PTI
DEMAE-9PTI-FO
DAMAE-15PTI
DAMAE-15PTI-FO
DBMAE-25PTI
DBMAE-25PTI-FO
DCMAE-37PTI
DCMAE-37PTI-FO
DDMAE-50PTI
DDMAE-50PTI-FO
Dual Float
30µin. Gold
Contacts
DEMAY-9PTI
DAMAY-15PTI
DBMAY-25PTI
DCMAY-37PTI
DDMAY-50PTI
Bushings
Without
Contacts
DEMAY-9PTI-FO
DAMAY-15PTI-FO
DBMAY-25PTI-FO
DCMAY-37PTI-FO
DDMAY-50PTI-FO
Tin-Plated Shells with Grounding Indents
Positions
9
15
25
37
50
Mounting Holes
30µin. Gold
Without
Contacts
Contacts
DEMA-9PTI
DEMA-9PTI-FO
DAMA-15PTI DAMA-15PTI-FO
DBMA-25PTI DBMA-25PTI-FO
DCMA-37PTI DCMA-37PTI-FO
DDMA-50PTI DDMA-50PTI-FO
4-71
Crimp and Poke - Sockets
Mounting Holes
30µin. Gold
Without
Contacts
Contacts
DEMA-9S
DEMA-9S-FO
DAMA-15S
DAMA-15S-FO
DBMA-25S
DBMA-25S-FO
DCMA-37S
DCMA-37S-FO
DDMA-50S
DDMA-50S-FO
Positions
9
15
25
37
50
4-40 Clinch Nuts
30µin. Gold
Without
Contacts
Contacts
DEMAE-9S
DEMAE-9S-FO
DAMAE-15S
DAMAE-15S-FO
DBMAE-25S
DBMAE-25S-FO
DCMAE-37S
DCMAE-37S-FO
DDMAE-50S
DDMAE-50S-FO
Dual Float
30µin. Gold
Contacts
DEMAY-9S
DAMAY-15S
DBMAY-25S
DCMAY-37S
DDMAY-50S
Bushings
Without
Contacts
DEMAY-9S-FO
DAMAY-15S-FO
DBMAY-25S-FO
DCMAY-37S-FO
DDMAY-50S-FO
4-40 Clinch Nuts
30µin. Gold
Without
Contacts
Contacts
DEMAE-9ST
DEMAE-9ST-FO
DAMAE-15ST
DAMAE-15ST-FO
DBMAE-25ST
DBMAE-25ST-FO
DCMAE-37ST
DCMAE-37ST-FO
DDMAE-50ST
DDMAE-50ST-FO
Dual Float
30µin. Gold
Contacts
DEMAY-9ST
DAMAY-15ST
DBMAY-25ST
DCMAY-37ST
DDMAY-50ST
Bushings
Without
Contacts
DEMAY-9ST-FO
DAMAY-15ST-FO
DBMAY-25ST-FO
DCMAY-37ST-FO
DDMAY-50ST-FO
Tin-Plated Shell
Mounting Holes
30µin. Gold
Without
Contacts
Contacts
DEMA-9ST
DEMA-9ST-FO
DAMA-15ST
DAMA-15ST-FO
DBMA-25ST
DBMA-25ST-FO
DCMA-37ST
DCMA-37ST-FO
DDMA-50ST
DDMA-50ST-FO
Positions
9
15
25
37
50
Crimp and Poke Machined Contacts
Will accommodate 20, 22, and 24 AWG wire.
Contacts
Description
Pin
Socket
M39029/64-369
M39029/63-368
4-72
Meets all MIL-C-24308 Class G specifications.
Offered in Crimp and Poke and Solder Cup and PCB vertical and right-angle.
Offered in 9, 15, 25, 37, and 50 position plugs and sockets except right-angle (9 to 37 positions).
per MIL-M-14, Type SDG-F
Connector Shell: Steel with cadmium plating and yellow
chromate finish
bronze (machined)
Contact Plating: 50µin. gold over copper or nickel
Dual Float Bushing: Stainless steel, passivated or
non-magnetic brass
Shock: 50G peak per MIL-STD-202, Method 213, Condition G
10-2000Hz, per MIL-STD-202 Method 204,
Condition D
Current Rating:
Contact Resistance:
5 Amps
4-74
Available with .120 mounting holes, float bushings, or dual float bushings.
Order with contacts included or separately.
Order with contact Insertion/Extraction Tool included or order tool #CIET-20-HD separately. See page 4-103.
Crimp and Poke Plugs
Steel Shell
Contacts Included. Insertion/Extraction Tool Not Included.
Positions
Mounting Holes
Float Bushings
9
M24308/4-1F
M24308/4-302F
15
M24308/4-2F
M24308/4-303F
25
M24308/4-3F
M24308/4-304F
37
M24308/4-4F
M24308/4-305F
50
M24308/4-5F
M24308/4-306F
Dual Float Bushings
M24308/4-435F
M24308/4-436F
M24308/4-437F
M24308/4-438F
M24308/4-439F
Contacts Included. Insertion/Extraction Tool Included.
Positions
Mounting Holes
Float Bushings
9
M24308/4-6F
M24308/4-313F
15
M24308/4-7F
M24308/4-314F
25
M24308/4-8F
M24308/4-315F
37
M24308/4-9F
M24308/4-316F
50
M24308/4-10F
M24308/4-317F
Dual Float Bushings
M24308/4-446F
M24308/4-447F
M24308/4-448F
M24308/4-449F
M24308/4-450F
Contacts Not Included. Insertion/Extraction Tool Not Included.
Positions
Mounting Holes
Float Bushings
Dual Float Bushings
9
M24308/4-259F
M24308/4-324F
M24308/4-457F
15
M24308/4-260F
M24308/4-325F
M24308/4-458F
25
M24308/4-261F
M24308/4-326F
M24308/4-459F
37
M24308/4-262F
M24308/4-327F
M24308/4-460F
50
M24308/4-263F
M24308/4-328F
M24308/4-461F
4-75
Ordering Information
Crimp and Poke Sockets
Steel Shell
Positions
Mounting Holes
Float Bushings
9
M24308/2-1F
M24308/2-23F
15
M24308/2-2F
M24308/2-24F
25
M24308/2-3F
M24308/2-25F
37
M24308/2-4F
M24308/2-26F
50
M24308/2-5F
M24308/2-27F
Dual Float Bushings
M24308/2-342F
M24308/2-343F
M24308/2-344F
M24308/2-345F
M24308/2-346F
Positions
Mounting Holes
Float Bushings
9
M24308/2-6F
M24308/2-34F
15
M24308/2-7F
M24308/2-35F
25
M24308/2-8F
M24308/2-36F
37
M24308/2-9F
M24308/2-37F
50
M24308/2-10F
M24308/2-38F
Dual Float Bushings
M24308/2-353F
M24308/2-354F
M24308/2-355F
M24308/2-356F
M24308/2-357F
Positions
Mounting Holes
Float Bushings
Dual Float Bushings
9
M24308/2-281F
M24308/2-292F
M24308/2-482F
15
M24308/2-282F
M24308/2-293F
M24308/2-483F
25
M24308/2-283F
M24308/2-294F
M24308/2-484F
37
M24308/2-284F
M24308/2-295F
M24308/2-485F
50
M24308/2-285F
M24308/2-296F
M24308/2-486F
4-76
Tooling
• Contact Insertion/Extraction Tool: #CIET-20-HD (Military #M81969/39-01). See page 4-103.
• Wire termination hand tool: #M22520/2-01. See page 4-103.
• Positioner for machine contacts for hand tool #M22520/2-08 (locates contact in the correct position). See page 4-103.
Crimp and Poke Contacts
• Will accommodate 20, 22, and 24 AWG wire.
Description
Pin
Socket
M39029/64-369
M39029/63-368
4-77
Available with .120" mounting holes, float bushings, or dual float bushings.
Solder Cup Plugs
Steel Shell
Positions
9
15
25
37
50
Mounting Holes
M24308/3-1F
M24308/3-2F
M24308/3-3F
M24308/3-4F
M24308/3-5F
Float Bushings
M24308/3-12F
M24308/3-13F
M24308/3-14F
M24308/3-15F
M24308/3-16F
Dual Float Bushings
M24308/3-17F
M24308/3-18F
M24308/3-19F
M24308/3-20F
M24308/3-21F
Brass Non-Magnetic Shell
Positions
Mounting Holes
9
M24308/7-1F
15
M24308/7-2F
25
M24308/7-3F
37
M24308/7-4F
50
M24308/7-5F
Float Bushings
M24308/7-12F
M24308/7-13F
M24308/7-14F
M24308/7-15F
M24308/7-16F
Dual Float Bushings
M24308/7-17F
M24308/7-18F
M24308/7-19F
M24308/7-20F
M24308/7-21F
Mounting Holes
M24308/1-1F
M24308/1-2F
M24308/1-3F
M24308/1-4F
M24308/1-5F
Float Bushings
M24308/1-12F
M24308/1-13F
M24308/1-14F
M24308/1-15F
M24308/1-16F
Dual Float Bushings
M24308/1-23F
M24308/1-24F
M24308/1-25F
M24308/1-26F
M24308/1-27F
Positions
Mounting Holes
9
M24308/5-1F
15
M24308/5-2F
25
M24308/5-3F
37
M24308/5-4F
50
M24308/5-5F
Float Bushings
M24308/5-12F
M24308/5-13F
M24308/5-14F
M24308/5-15F
M24308/5-16F
Dual Float Bushings
M24308/5-23F
M24308/5-24F
M24308/5-25F
M24308/5-26F
M24308/5-27F
Solder Cup Sockets
Steel Shell
Positions
9
15
25
37
50
4-78
Right-Angle
Right-Angle Connector
.283" footprint requires minimal PCB space.
Available with three contact tail lengths (.127", .158", and .183") with .030"
contact diameter.
Available with two contact tail lengths (.127" and .183") with .040"
contact diameter.
Offered with .120" mounting holes.
Mounting bracket: Black nylon. Can be removed if necessary.
Right-Angle PCB Plugs (Sockets not available)
Steel Shell
.127 Tail Length
.158 Tail Length
.183 Tail Length
.127 Tail Length
.183 Tail Length
Positions .030 Contact Diameter .030 Contact Diameter .030 Contact Diameter .040 Contact Diameter .040 Contact Diameter
9
M24308/24-25F
M24308/24-31F
M24308/24-49F
M24308/24-37F
M24308/24-55F
15
M24308/24-26F
M24308/24-32F
M24308/24-50F
M24308/24-38F
M24308/24-56F
25
M24308/24-27F
M24308/24-33F
M24308/24-51F
M24308/24-39F
M24308/24-57F
37
M24308/24-28F
M24308/24-34F
M24308/24-52F
M24308/24-40F
M24308/24-58F
Vertical Connector
Available with two contact tail lengths (.158" and .183") and two contact
Vertical PCB Plugs
Steel Shell
.158 Tail Length
.183 Tail Length
.158 Tail Length
.183 Tail Length
Positions .030 Contact Diameter .030 Contact Diameter .040 Contact Diameter .040 Contact Diameter
9
M24308/24-1F
M24308/24-7F
M24308/24-13F
M24308/24-19F
15
M24308/24-2F
M24308/24-8F
M24308/24-14F
M24308/24-20F
25
M24308/24-3F
M24308/24-9F
M24308/24-15F
M24308/24-21F
37
M24308/24-4F
M24308/24-10F
M24308/24-16F
M24308/24-22F
50
M24308/24-5F
M24308/24-11F
M24308/24-17F
M24308/24-23F
Steel Shell
.158 Tail Length
.183 Tail Length
.158 Tail Length
.183 Tail Length
9
M24308/23-1F
M24308/23-7F
M24308/23-13F
M24308/23-19F
15
M24308/23-2F
M24308/23-8F
M24308/23-14F
M24308/23-20F
25
M24308/23-3F
M24308/23-9F
M24308/23-15F
M24308/23-21F
37
M24308/23-4F
M24308/23-10F
M24308/23-16F
M24308/23-22F
50
M24308/23-5F
M24308/23-11F
M24308/23-17F
M24308/23-23F
4-79
Cinch backshells are offered in a variety of styles, each having a specific strength.
• Backshells have two-piece construction and are frequently used where appearance is a major factor.
RFI/EMI shielding capability is also an option:
- Plastic Backshells: No shielding.
- Metallized Plastic: Economical method of shielding.
- Diecast Backshells: Maximum shielding.
• Cinch SDH Series backshells utilize Cinch’s Latch-N-Lock™ system with quick release
disconnect. Just squeeze the latch levers to release the connector. Also available with standard
4-40 mounting hardware.
• Junction Shells come in a variety of sizes and shapes including right-angle and low profile.
They are generally of one-piece construction with an adjustable clamp, but there is no shielding.
• Hoods have an improved appearance versus junction shells but no shielding. They are all-plastic
and come in right-angle or straight configurations.
• Hardware, in the form of adjustable grommets or strain relief clamps and 4-40 screws, is generally
supplied with the product; however, a variety of optional hardware is also available in the accessories
section of this catalog.
4-80
The following is a summary of the various backshells, junction shells, and hoods that Cinch offers:
Backshells
Type
Material
Series
2-Piece
Plastic
DPH
Shell Sizes*
EABC
Cable Exit
180°
Fits Connector Series marked with “•”:
D*A Series
HTD Series
D*U Series
Series 3
T Series Metal Shell
T Series All-Plastic
Basic D
Series 1
2-Piece 2-Piece
Metallized Diecast
DCH
DMH
EABCD
EABCD
2-Piece
Diecast
Ethernet
Black Plastic
Gray Plastic
SDH - B
SDH - G
A
EABC
EABC
90°/180°
Super-D Connection System
180°
180°
90°/180°
90°/180°
Junction Shells/Hoods
Junction Shells
Straight Round
Clamp Clamp
Metal
Metal
Type
Material
Hoods
Rt. Angle Deep Straight Switching
Clamp
Metal
Clamp
Metal
Shell Sizes*
ABCD ABCD EABCD EABCD
Cable Exit
180°
180°
90°
180°
D*A Series
D*U Series
Series 3
Basic D Series
Series 1
Shell
Metal
Phenolic Straight Rt. Angle
Plastic
Plastic Plastic
ABCD
AB
EAB
AB
180°
180°
180°
90°
*Conversion Chart between Standard Density Connectors and HPD/HTD Series 1.5 Density Connectors
Shell Size
E
A
B
C
D
Standard
D-sub
9
15
25
37
50
1.5 D-Sub
HTD
15
26
44
62
N/A
4-81
Standard two-piece construction available in plastic, metallized plastic, or diecast zinc versions with 180° straight cable entry.
Fits standard metal shell D-subminiature plugs and sockets as well as HTD Series 1.5 D-subs.
Ethernet hoods are available in diecast 15 position versions only with both 90° and 180° cable entry.
Included in all backshells:
- Hardware: 4-40 screws, hex nuts, 4-40 screw mounting bracket.
- Grommets: To accommodate most cable sizes. Grommets also function as strain reliefs.
Backshells are individually bagged.
Note that slide locks may not be used with these backshells.
Optional thumbscrew for backshell must be ordered separately if required.
Materials
4-40 screws, hex nuts, mounting bracket: Steel with zinc plating and clear chromate coating.
Standard Backshells:
- Plastic Backshells: ABS (black), hardware - steel with zinc plating, grommets - polyphenylene, (black).
- Metallized Plastic Backshells: ABS with nickel over copper plating, hardware - steel with zinc plating,
grommets - PVC (black).
- Diecast Backshells: Diecast zinc, grommets - PVC (black).
Ethernet Backshells: Diecast zinc, grommets - PVC (black).
Plastic
Metallized
Ethernet Straight
Diecast
Ethernet Right-Angle
4-82
Straight (180°) Standard Backshells
Plastic and Metallized Plastic Backshells
Dimensions
Shell
Size
E
A
B
C
D
A
in
1.225
1.540
2.090
2.730
2.645
mm
31.12
39.12
53.09
69.34
67.18
B
in
mm
1.547 39.29
1.516 38.51
1.655 42.04
1.830 46.48
1.855 41.12
C
in
0.640
0.640
0.710
0.906
0.940
D
mm
16.26
16.26
18.03
23.01
23.88
4-83
in
0.645
0.645
0.645
0.645
0.750
mm
16.38
16.38
16.38
16.38
19.05
E
in
mm
0.400 10.16
0.400 10.16
0.522 13.26
0.725 18.42
0.725 18.42
F
in
0.984
1.312
1.857
2.500
2.406
mm
24.99
33.32
47.17
63.50
61.11
EMI/RFI Shielded Diecast Backshells
Dimensions
Shell
Size
in
A
mm
in
B
mm
C
E
A
B
C
D
1.225
1.540
2.090
2.730
2.624
31.12
39.12
53.09
69.34
66.65
1.465
1.600
1.570
1.810
1.800
37.21
40.64
39.88
45.97
45.72
in
0.620
0.620
0.690
0.862
0.862
D
E
F
mm
in
mm
in
mm
in
mm
15.75
15.75
17.53
21.89
21.89
0.620
0.620
0.620
0.620
0.730
15.75
15.75
15.75
15.75
18.54
0.400
0.400
0.525
0.725
0.725
10.16
10.16
13.34
18.42
18.42
0.984
1.312
1.857
2.500
2.406
24.99
33.32
47.17
63.50
61.11
D*H Two-Piece Backshells
Fits
Shell Standard
Size
Density
Fits
HTD 1.5
Density
Cable Entry
Style
Plastic
Cable
Dia. (in)
Metallized
Plastic
Cable
Dia. (in)
Diecast
Metal
Cable
Dia. (in)
E
9
15
Straight (180°)
DPH-E-001
.210-.320
DCH-E-001
.210-.350
DMH-E-001
.210-.320
A
15
26
Straight (180°)
DPH-A-001
.210-.320
DCH-A-001
.210-.350
DMH-A-001
.210-.320
B
25
44
Straight (180°)
DPH-B-001
.230-.450
DCH-B-001
.230-.450
DMH-B-001
.230-.450
C
37
62
Straight (180°)
DPH-C-001
.350-.650
DCH-C-001
.350-.640
DMH-C-001
.350-.650
D
50
N/A
Straight (180°)
DPH-D-001
.350-.650
DCH-D-001
.350-.640
DMH-D-001
.350-.640
4-84
Straight (180°) Diecast Ethernet Backshells
Right-Angle (90°) Diecast Ethernet Backshells
D*H Ethernet Diecast Backshells
Fits
Shell
Size
A
A
Fits
Standard
Cable
Cable Entry
Density Diameter (in)
Style
15
.210-.320
Straight (180°) DMH-A-001XL
15
.210-.320
Rt. Angle (90°) DMH-A-901X
A
in
mm
1.550 39.37
1.550 39.37
B
in
mm
1.880 47.75
1.880 47.75
C
in
mm
0.710 18.03
0.710 18.03
D
in
mm
0.64 16.26
0.64 16.26
E
in
mm
0.522 13.26
0.522 13.26
F
in
mm
1.312 33.32
1.312 33.32
THUMBSCREWS (OPTIONAL) FOR D*H BACKSHELLS
Order #4-40-THMB-1 (two each required per backshell).
(Will not work with ethernet type backshells)
4-85
■ The Cinch Super D Interconnection System is a simple, fast, economical, and reliable way for
mating connectors from cable to cable or cable to panel.
■ Snap-on Super D plastic hoods captivate connectors providing positive, self-latching, audible
mating with reliable retention and Latch-N-Lock quick release disconnect.
■ Snap-on Super-D plastic hoods are also available with filler ends to utilize 4-40
mounting hardware.
■ Super D hoods are available:
- Straight (180°) or Right-Angle (90°) cable entry.
- Sizes: 9, 15, 25, and 37.
- Sizes 15, 25, and 37 are available in standard or large cable openings.
■ Black SDH backshells accommodate any standard metal shell IDC, solder cup, or crimp
and poke D-subminiature connector.
■ Gray SDH backshells accommodate the Cinch All-Plastic IDC T-Series connector on
pages 4-38 thru 4-39.
■ Each Super-D plastic hood includes a stay band to strain relief the cable wire. Stay band tool
SD-MSBT is required. Extra stay bands are available on page 4-90.
Hood: Modified phenylene oxide - black for metal
shell connectors or gray for all-plastic
IDC connectors
Latch Block: Diecast zinc
Screws for Latching Blocks: Steel with nickel plating
Stay Band: Steel with zinc plating and clear chromate finish
4-86
Straight (180°) Cable Entry Black Backshells for Metal Shell Connectors
Adapter Hood with Latches
Adapter Hood with Filler Ends
Right-Angle (90°) Cable Entry Black Backshells for Metal Shell Connectors
Dimensions
Positions
9
15
25
37
A + .020"
in
1.47
1.80
2.35
2.99
(.58mm)
mm
37.34
45.72
59.69
75.95
B +.020"
in
.31
.31
.33
.37
(.58mm)
mm
7.87
7.87
8.40
9.40
C +.020" (.58mm)
in
mm
.41
10.41
.47
11.94
.50
12.70
4-87
D +.020"
in
1.94
2.25
2.94
3.59
(.58mm)
mm
49.21
57.15
74.61
91.28
E+.020"
in
1.25
1.34
1.50
1.53
(.58mm)
mm
31.75
34.13
38.10
38.89
Latches
Standard
Large
Positions Cable Opening Cable Opening
9
SDH-9BL
N/A
15
SDH-15BL
SDH-15BLL
25
SDH-25BL
SDH-25BLL
37
SDH-37BL
SDH-37BLL
Filler Ends
Standard
Large
SDH-9BF
N/A
SDH-15BF
SDH-15BFL
SDH-25BF
SDH-25BFL
SDH-37BF
SDH-37BFL
Filler Ends w/4-40 Screws
Standard
Large
SDH-9BFCS
N/A
SDH-15BFCS
SDH-15BFLCS
SDH-25BFCS
SDH-25BFLCS
SDH-37BFCS
SDH-37BFLCS
Standard Cable
Positions
Opening
9
SDH-9RBL
15
SDH-15RBL
25
SDH-25RBL
37
SDH-37RBL
Latches
Large Cable
Opening
N/A
SDH-15RBLL
SDH-25RBLL
SDH-37RBLL
Latching Blocks for Super D Adapter System
Description
Latching Block
Latching Block with SEM Screws
Removable Mounting Screws
for Adapter Hood
For Panel Thickness
N/A
Up to .060"
Qty per pack
1 each
2 each
N/A
.060" to .080"
.080” to .125"
1 each
2 each
2 each
4-88
Qty Required
Per SDH Hood
2 each
2 each
2 each
2 each
2 each
Catalog Number
SD-LB
SD-LB-060
4-40UNC2AX3/4
SD-LB-060-080
SD-LB-125
Fits only T Series All-Plastic IDC connector on pages 4-38 thru 4-39.
Straight (180°) Cable Entry Gray Backshells for All-Plastic Connectors
Dimensions
Positions
9
15
25
37
A +.020" (.58mm)
in
mm
1.47
37.34
1.80
45.72
2.35
59.69
2.99
75.95
B +.020"
in
.31
.31
.33
.37
(.58mm)
mm
7.87
7.87
8.40
9.40
C +.020"
in
--.41
.47
.50
(.58mm)
mm
--10.41
11.94
12.70
Latches
Large
Standard
9
15
25
37
SDH-9GL
SDH-15GL
SDH-25GL
SDH-37GL
N/A
SDH-15GLL
SDH-25GLL
SDH-37GLL
Filler Ends
Standard
Large
SDH-9GF
SDH-15GF
SDH-25GF
SDH-37GF
4-89
N/A
SDH-15GFL
SDH-25GFL
SDH-37GFL
Standard
Large
SDH-9GFCS
SDH-15GFCS
SDH-25GFCS
SDH-37GFCS
N/A
SDH-15GFLCS
SDH-25GFLCS
SDH-37GFLCS
Right-Angle (90°) Cable Entry Gray Backshells for All-Plastic Connectors
• Fits only IDC connectors on pages 4-38 thru 4-39.
Dimensions
Positions
9
15
25
37
A +.020" (.58mm)
in
mm
1.94
49.21
2.25
57.15
2.94
74.61
3.59
91.28
B +.020"
in
.31
.31
.33
.37
(.58mm)
mm
7.87
7.87
8.40
9.40
C +.020"
in
-.41
.47
.50
(.58mm)
mm
--10.41
11.94
12.70
D +.020"
in
1.25
1.34
1.50
1.53
Standard Cable
Positions
Opening
9
SDH-9RGL
15
SDH-15RGL
25
SDH-25RGL
37
SDH-37RGL
Latches
Large Cable
Opening
N/A
SDH-15RGLL
SDH-25RGLL
SDH-37RGLL
Accessories for Gray Backshells
Positions
9
15
25
37
Optional
Additional
Strain Reliefs* Stay Bands**
SD-WC9
SD-9-15-SB
SD-WC15
SD-9-15-SB
SD-WC25
SD-25-37-SB
SD-WC37
SD-25-37-SB
* Two each required per backshell.
** Stay band tool #SD-MSBT required. See page 4-100..
Screw for screwlocking connector assembly - (2 each required): 4-40UNC2AX3/4.
See page 4-85 for latch block drawing.
4-90
(.58mm)
mm
31.75
34.13
38.10
38.89
■ Shell Material: Zinc-plated low carbon steel with yellow chromate finish.
■ Clamp: Zinc-plated steel with yellow chromate finish.
■ Screw: Zinc-plated steel with yellow chromate finish.
■ Stop Nut: Zinc-plated brass with yellow chromate finish.
Straight Clamp
Shell
Size
A
B
C
D
A
Positions in
15
1.531
25
2.078
37
2.718
50
2.625
B
mm
38.89
52.78
69.04
66.68
in
.500
.500
.500
.609
mm
38.89
52.78
in
.500
.500
mm
30.56
38.89
52.78
69.04
66.68
in
0.718
0.718
0.968
1.187
1.250
C
mm
12.70
12.70
12.70
15.47
in
1.312
1.852
2.500
2.406
mm
12.70
12.70
in
1.312
1.852
mm
18.24
18.24
24.59
30.15
31.75
in
.984
1.312
1.852
2.500
2.406
mm
33.32
47.04
63.50
61.11
E
in
.296
.296
.296
.390
mm
7.52
7.52
7.52
9.91
F
in
mm
.312
7.92
.796 20.22
.687 17.45
.687 17.45
in
.640
.640
.640
.703
G
mm
10.31
15.06
E
in
mm
.984 23.72
1.515 38.48
in
.125
.187
mm
16.26
16.26
16.26
17.86
Round Clamp
Shell
Size
A
B
A
Positions in
15
1.531
25
2.078
B
C
mm
33.32
47.04
D
in
.406
.593
F
mm
3.18
4.75
G
in
mm
1.031 26.19
1.062 26.97
Right-Angle Clamp
Shell
Size
E
A
B
C
D
A
Positions in
9
1.203
15
1.531
25
2.078
37
2.718
50
2.625
B
C
mm
24.99
33.32
47.04
63.50
61.11
4-92
E
in
.437
.437
.437
.437
.562
F
mm
11.10
11.10
11.10
11.10
14.27
in
.437
.437
.625
.812
.906
G
mm
11.10
11.10
15.88
20.62
23.01
in
.468
.468
.468
.468
.531
H
mm
11.89
11.89
11.89
11.89
13.49
in
.281
.281
.281
.281
.343
mm
7.14
7.14
7.14
7.14
8.71
Deep Straight Clamp
Shell
Size
E
A
B
C
D
A
Positions
9
15
25
37
50
in
1.203
1.531
2.078
2.718
2.625
B
mm
30.56
38.89
52.78
69.04
66.68
in
.484
.484
.484
.484
.593
mm
12.29
12.29
12.29
12.29
15.06
C
in
0.984
1.312
1.852
2.500
2.406
mm
24.99
33.32
47.04
63.50
61.11
in
.578
.578
.578
.578
.687
D
mm
14.68
14.68
14.68
14.68
17.45
E
in
.375
.713
1.000
1.375
1.406
mm
9.53
18.11
25.40
34.93
35.71
F
in
.375
.312
.312
.312
.406
G
mm
9.53
7.92
7.92
7.92
10.31
in
.750
.750
1.000
1.000
1.125
H
mm
19.05
19.05
25.40
25.40
28.58
in
1.219
1.250
1.531
1.531
1.656
mm
30.96
31.75
38.89
38.89
42.06
Switching Shell
Shell
Size
A
B
C
D
A
Positions
15
25
37
50
in
1.531
2.078
2.718
2.625
mm
38.89
52.78
69.04
66.68
B
in
.500
.500
.500
.609
C
mm
12.70
12.70
12.70
15.47
in
1.312
1.852
2.500
2.406
mm
33.32
47.04
63.50
61.11
Junction Shells - Metal
Shell
Size
E
A
B
C
D
Fits
Standard
Density
9
15
25
37
50
Straight
Clamp
N/A
DA-19678-1
DB-19678-2
DC-19678-3
DD-19678-4
Round
Clamp
N/A
DA-20961
DB-20962
N/A
N/A
Right-Angle
Clamp
DE-19977-5
DA-19977-1
DB-19977-2
DC-19977-3
DD-19977-4
4-93
Deep Straight
Clamp
DE-24657
DA-24658
DB-24659
DC-24660
DD-24661
Switching
Shell
N/A
DA-19678-6
DB-19678-7
DC-19678-8
DD-19678-9
Phenolic Hood
Shell Material: Phenolic (black).
#4-40 Screws: Steel with nickel plating.
Shell
Size
A
B
A
Positions in
15
1.297
25
1.406
B
mm
32.94
35.71
in
1.219
1.797
C
mm
30.96
45.64
in
.266
.328
D
mm
6.76
8.33
in
1.312
1.852
mm
33.32
47.04
E
in
mm
1.641 41.68
2.203 55.96
All-Plastic Straight (180°) Hood
Shell Material: Nylon (gray).
Connector Not Included
Shell
Size
E
A
B
A
Positions in
9
1.218
15
1.546
25
2.093
B
mm
30.94
38.27
53.16
in
1.000
1.000
1.250
C
mm
25.40
25.40
31.75
in
.984
1.312
1.852
D
mm
23.72
33.32
47.04
in
.500
.500
.500
mm
12.70
12.70
12.70
E
in
mm
.562 14.27
.562 14.27
.562 14.27
in
.281
.360
.493
F
E
in
mm
.562 14.28
.562 14.28
in
.360
.360
mm
7.14
9.14
12.52
All-Plastic Right-Angle (90°) Hood
Shell
Size
A
B
A
Positions in
15
1.822
25
2.368
B
mm
46.28
60.15
in
1.000
1.250
C
mm
25.40
31.75
in
1.312
1.852
D
mm
33.32
47.04
in
.500
.500
Plastic Hoods
Shell
Size
E
A
B
C
D
Standard
Density
9
15
25
37
50
Phenolic
Hood
N/A
DA-51225-1
DB-51226-1A
N/A
N/A
Straight
Hood
DE-51218-1
DA-51210-1
DB-51212-1
N/A
N/A
Right
Angle
N/A
DA-51211-1
DB-51213-1
N/A
N/A
4-94
mm
12.70
12.70
F
mm
9.14
9.14
in
.218
.360
.360
G
mm
7.14
9.14
9.14
Dust Caps
For use with all Cinch D-subminiature connectors.
Used to protect connector contacts when connector is not mated.
Made of polyethylene (black).
Fits
Shell
Size
E
E
A
A
B
B
C
C
D
D
Fits
Standard
Density Catalog No. Description
9
DE-59-20
Socket
9
DE-60-20
Plug
15
DA-59-20
Socket
15
DA-60-20
Plug
25
DB-59-20
Socket
25
DB-60-20
Plug
37
DC-59-20
Socket
37
DC-60-20
Plug
50
DD-59-20
Socket
50
DD-60-20
Plug
A
in
.694
.749
1.022
1.077
1.562
1.635
2.210
2.283
2.116
2.179
B
mm
17.63
19.02
25.95
27.36
39.67
41.52
56.13
57.99
53.75
55.35
in
.627
.682
.955
1.010
1.495
1.568
2.143
2.216
2.049
2.112
C
mm
15.93
17.32
24.25
25.65
37.97
39.83
54.43
56.29
52.04
53.64
in
.362
.412
.362
.412
.362
.430
.362
.430
.474
.536
D
in
mm
.295
7.49
.345
8.76
.295
7.49
.345
8.76
.295
7.49
.363
9.22
.295
7.49
.363
9.22
.407 10.34
.469 11.91
mm
9.19
10.46
9.19
10.46
9.19
10.92
9.19
10.92
12.04
13.61
Guide Pin Plates
• Aligns connectors before actual mating. Generally used in blind mate applications.
Male or female guide plates will accommodate Cinch male or female connectors.
Plate: Cold-rolled steel with cadmium plating and yellow chromate finish.
Guide pin (male): Stainless steel, passivated.
Screws, rivets (male plate), washers (male plate): Steel with cadmium plating and yellow chromate finish.
Socket
Plug
Fits
Shell Standard
Size Density
A
Plug
Socket
N/A
N/A
in
mm
in
B
mm
C
in
D
mm
in
F
mm
in
mm
in
G
mm
K
in
mm
E
9
A
15
DA-22213
DA-22214
2.281 57.93
1.000 25.40
1.312 33.32
.750 19.05
.898
22.81
1.663 42.24
1.906 48.41
B
25
DB-22255
DB-22254
2.820 71.63
1.000 25.40
1.852 47.04
.750 19.05
1.168
29.67
2.203 55.96
2.446 62.13
C
37
DC-22070
DC-22071
3.468 88.09
1.000 25.40
2.500 63.50
.750 19.05
1.492
37.90
2.851 72.42
3.094 78.59
D
50
DD-21962
DD-21961
3.375 85.73
1.125 28.58
2.406 61.112
.874 21.88
1.437
36.50
2.749 69.82
3.000 76.20
4-96
Slide Lock Assemblies
• A slide lock assembly is a metal bracket offered with hardware necessary to mount into the standard connector
mounting holes. It consists of the lock retainer plate, two screws, two washers, and two nuts. Two lock posts are
required to fit into the mounting holes of the mating connector. These must be ordered separately.
Compatible with all Cinch Backshells, Hoods, and Junction Shells except D*H Series, SDH Series, and phenolic hood.
Compatible with all Cinch metal shell D-subminiature connectors.
Materials
• Slide Lock Plate: Stainless steel, passivated.
Slide lock hex nut, washer #4-40 screw: Steel with zinc plating and yellow chromate finish.
Lockpost, washer, lockwasher, and hex nut: Steel with zinc plating and yellow chromate finish.
Consists of Lock Retainer and two lock posts (order separately).
NOTE: Not compatible with D*H Series or SDH Series backshells.
Shell
Size
E
A
B
C
D
Fits
Standard
Density
9
15
25
37
50
Lock
Retainer
DE-51224-1
DA-51220-1
DB-51221-1
DC-51222-1
DD-51223-1
A
in
1.442
1.770
2.293
2.958
2.847
B
mm
36.63
44.96
58.24
75.13
72.31
in
.500
.500
.500
.500
.609
C
mm
12.70
12.70
12.70
12.70
15.47
in
0.984
1.312
1.852
2.500
2.406
mm
24.99
33.27
47.04
63.50
62.48
Lock Post: #D53018. Two (2) required with each Slide Lock Assembly.
4-97
Screwlocks
Screwlocks are designed to retain the same size mated connectors together or to secure the connector to a rack/panel.
Screwlocks may be used on plugs or sockets.
Female screwlocks consist of one #4-40 screw with a #4-40 hole in the top, two flat washers to accommodate different panel
thicknesses, one lockwasher, and one #4-40 nut. Military female screwlocks include three flat washers.
Male screwlocks consist of one #4-40 slotted screw and a spring tension clip. Different sizes accommodate the various
connector flange sizes and types of backshells or hoods (if applicable).
Two screwlocks are required per connector.
Military screwlocks meet all requirements of MIL-C-24308.
Materials
Commercial Screwlock Assemblies:
• Male Screwlock Assembly: Clip and screw are steel with zinc plating and yellow chromate finish.
• Female Screwlock Assembly: Washers (2), lockwashers, hex nuts, and nuts are steel with zinc plating
M24308 Military Screwlock Assemblies:
• Male Screwlock Assembly: Clip and screw are steel with cadmium plating and yellow chromate finish.
• Female Screwlock Assembly: Washers (3), lockwashers, hex nuts, and nuts are steel with cadmium plating and
Female Screwlock
Male Screwlock
4-98
Screwlock assemblies will not fit D*H or SDH Series backshells.
Male Screwlocks
Shell Size
Positions
A
Commercial:
D20419-0
D20419-16
D20419-21
D20420-0
D20420-12
D20420-15
E
9
A
15
B
25
C
37
P/S
S*
P/S
S*
P*
S
P/S*
P*
S
P/S*
D
50
B
in
mm
in
mm
0.250
0.250
0.281
0.250
0.281
0.281
56.35
56.35
63.34
56.35
63.34
63.34
0.033
0.048
0.059
0.033
0.048
0.059
0.84
1.22
1.50
0.84
1.22
1.50
Military MIL-C-24308:
Per MIL spec
M24308/25-9F
M24308/25-10F Per MIL spec
S
P/S*
P*
P/S
P/S
P/S
P/S
P/S
NOTE: P = Plug, S= Socket
* Indicates use with junction shell
Female Screwlocks
Shell Size
Positions
E
9
A
15
B
25
C
37
D
50
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
P/S
A
in
mm
Commercial:
D20418-2
D20418-39
0.312
0.628
M24308/26-1F
M24308/26-2F
Per MIL spec
Per MIL spec
70.32
141.55
4-99
Auto-Clinch™ D Semi-Automatic Termination Tool
Auto Clinch D is a semi-automatic, pneumatically powered, and electrically
controlled termination machine designed to terminate IDC D-subminiature
connectors. It employs a selective programmer and a common nest for
all four connector sizes and can be equipped to terminate metal shell
connectors. It can also be optionally equipped with remote visual color
code display for training sequences. It has a provision for omission of wires.
Auto-Clinch D Tool
Part No.: ACD-432
Certi-Clinch™ D Field Termination Tool
*For 24-26 AWG Wire
Certi-Clinch D is designed for mass termination of individual wires,
eliminating wire stripping, soldering, and crimping. It handles all four
connector sizes, is readily portable, and requires no set-up time and little
operator time. Rugged, all-metal construction affords trouble-free long life.
For metal shell IDC D-subminiature connectors.
Part No. SD-CCWN
Certi-Clinch D Field
Termination Tool
For all-plastic IDC D-subminiature connectors.
Part No. SD-CC
Conversion nest for converting all-plastic type to metal shell.
Part No. SD-CCN
Uni-Clinch™ D Single-Wire Hand Insertion Tool
Designed to insert one 22-26 AWG wire at a time, Uni-Clinch D is used
as a field repair tool by field service engineers.
Part No. SD-UC
Uni-Clinch Hand
Insertion Tool
Super D™ Manual Stay Band Tool
Designed for applying the steel stay band/strain relief to the cable before
termination of wires to the connector, the manual Stay Band Tool applies
both stay band sizes to the full range of cable sizes.
Part No. SD-MSBT
Manual Tool
NOTE: All termination tools on this page are used in conjunction with T* Series D-subminiature connectors.
4-100
Hand Crimping Tool for Stamped Contact 300 PC Reels
Two types of transport for connector chains
are available with crimping ranges of 20
through 30 AWG for B crimpings
Part Number
D*A Series
20 through 26 AWG Wire
GHC-B
D*A Series
28 through 30 AWG Wire
GHC-B1
HTD Series
HTD-266
Contact Crimp Hand Tool
(300 Contact Reel)
Hand Crimping Tool for Loose Stamped Contacts
D*A Series
D*U Series
HTD Series
Part Number
HTD-544
BT-20-HC
HTD-544
(HTD-544)
Contact Insertion/Extraction Tool for Stamped Contacts
D*A Series
D*U Series
HTD Series
Part Number
CIET-20-HDB
CIET-20-HDB
CIET-22-DF
Contact Insertion/Extraction Hand Tool
For D*A and D*U Series for Stamped
Contacts
(CIET-20-HDB)
(BT-20-HC)
For D1/2 Contacts
(CIET-22-DF)
4-101
Semi-Automatic Stripping and Crimping Tool
Advantages and Characteristics
• Stripping and crimping in one easy operation
• Easy to install and adjust
• Requires little maintenance
• Wearing parts replaced in a matter of minutes
• Long service life thanks to best-quality materials
• Different quick change applicators in the same stripper crimper
• Increased productivity
Our GSC-20-30 crimp machine in
operation with stripper crimper and
quick change tool
Stripper Crimper
Description
D*A Series
Stripper Crimper Only
D*A Series
Applicator Only
For 20-24 AWG
D*A Series
Applicator Only
For 26-30 AWG
HTD Series
HTD Series
Applicator Only
22-28 AWG
D*U Series
D*U Series
Applicator Only
20-28
Part Number
599-11-11-578
598-98-97-630
598-98-97-632
599-11-11-518
598-98-97-636
599-11-11-258
598-98-97-638
Comments
Comes equipped with the applicator
for 20-24 AWG contacts
Applicator only
For 20-24 AWG contacts
Applicator only
For 26-30 AWG contacts
Comes equipped with applicator
for 22-28 AWG contacts
Applicator only
For 22-28 AWG contacts
for 20-28 AWG contacts
Applicator only
For 20-28 AWG contacts
Stripper Crimper Spare Parts
Part Number
598-98-97-631
598-98-97-633
598-98-97-637
598-98-97-639
598-98-97-640
598-98-97-641
598-98-97-642
598-98-97-643
598-98-97-644
598-98-97-645
Description
D*A Punch & Anvil Kit 20-24 AWG
D*A Punch & Anvil Kit 26-30 AWG
HTD Series Punch & Anvil Kit
D*U Series Punch & Anvil Kit
Stripping Blades for 20-24 AWG Wire
Stripping Blades for 26-30 AWG Wire
D*A Series Contact shear blade
Shear blade holder
Sensor switch
Strip blade holder
Catalog Number
SCPA-631
SCPA-633
SCPA-637
SCPA-639
SCSB-640
SCSB-641
SCCS-642
SCSH-643
SCSS-644
SCBH-645
4-102
Catalog Number
GSC-20-30
ASC-20-24
ASC-26-30
HTD-518
ASC-DH
ESC-20-3
ASC-DU
Metal Shell High-Reliability Crimp
and Poke Termination Tool
Hand crimping tool for high-reliability
machined D*U, Series 3, and M24308
Crimp and Poke contacts.
M22520/2-01
M22520/2-01
NOTE: Positioner required with
crimping tool
Metal Shell Military Crimp and Poke
Positioner--A device when attached
to a crimping tool that locates the
contact in the correct position.
Positioner for machined contacts
D*U Series Positioner
Part No.: 599-11-11-580
Catalog No.: EP-580
Series 3 and M24308 Connector Positioner
Part No.: 598-98-97-618
Catalog No.: M22520/2-08
For inserting or extracting machined D*U,
Series 3, or M24308 Crimp and Poke
contacts.
Part No.: CIET-20-HD
CIET-20-HD
Military Extraction Tip Only
For extracting high-reliability machined
D*U, Series 3, or M24308 Crimp and Poke
contacts.
Part No.: CET-20-11
CET-20-11
Crimp Ferrule
Coaxial and High-Voltage Contact
Extraction Tool
For extracting co-axial and high-voltage
contacts from metal shell high-reliability
connectors.
Part No.: CET-C6B
CET-C6B
Pneumatic Bench Top Press for
Crimping Ferrules
This lightweight, portable press is used
to crimp the ferrules on the overmold
shielding hardware kits. Crimp dies
ordered separately.
FCT-551
Part No.: 599-11-11-551
Catalog No.: FCT-551
Hand Tool for Crimping Ferrules
and Coax Contacts
Uses same crimp dies as pneumatic tool.
Part No.: 599-11-11-552
Catalog No.: FCT-552
Catalog
Number
CF-51
CF-42
CF-43
CF-44
CF-45
CF-46
CF-47
CF-50
Part
Number
Type
462-44-22-451 1
462-44-22-442 1
462-44-22-443 1
462-44-22-444 1
462-44-22-445 1
462-44-22-446 1
462-44-22-447 2
462-44-22-450 2
Crimp Die
Part No.
598-98-97-607
598-98-97-600
598-98-97-601
598-98-97-602
598-98-97-603
598-98-97-604
598-98-97-605
598-98-97-606
FCT-552
4-103
Crimp Die
Catalog No.
CD-07
CD-00
CD-01
CD-02
CD-03
CD-04
CD-05
CD-06
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Cinch Connectivity Solutions:
TB-25S DAKL-15SUT DEU-9S-FO DEU-9P-FO DAKL-15PUTI DEU-9P DEU-9S DEKL-9PUTI DEKL-9SUT TA15P DCU-37S DBU-25P DBU-25S DBKL-25SUT DAU-15S-FO DBKL-25PUTI TE9SSH DAU-15P-FO DAU-15P
DAU-15S DBU-25S-FO DCU-37P DEM9S DEM9P DBU-25P-FO DCKL-37SUT DCU-37S-FO DDU-50P DDU50P-FO DEKL-9PATI-F DEU-9PTI-FO DEU-9ST-FO M39029/63-368 M39029/64-369 TB-25P TB-25PSH TE-9P
TE-9S M24308/2-3F M24308/3-2F M24308/4-1F M24308/4-3F M24308/4-4F M24308/4-5F TC-37PSCH
DDU50SFO TA-H15S TC-H37S DAUH-15P-FO DEUH-9S-FO DDUH-50P-FO DAUH-15S-FO DBUH-25P-FO
DCUH-37S-FO DCU-37P-FO DBUH-25S-FO DEUH-9P-FO DEKL-9PATI-E DAKL-15SAT-E DCMA37S DBMA25P
DAMA15P M24308/2-2F DAMA15S DEMA9S DDMA50S M24308/2-1F M24308/2-4F DDMA50P DCMA37P
M24308/4-2F DEMA9P M24308/4-327F M24308/1-14F M24308/1-16F M24308/1-1F M24308/1-2F M24308/1-3F
M24308/1-4F M24308/1-5F M24308/2-23F M24308/2-24F M24308/2-25F M24308/2-281F M24308/2-282F
M24308/2-283F M24308/2-284F M24308/2-285F M24308/23-10F M24308/23-11F M24308/23-1F M24308/23-2F
M24308/23-4F M24308/23-9F M24308/24-1F M24308/24-2F M24308/24-3F M24308/24-4F M24308/24-5F
M24308/2-5F
