Additional Resources:
Product Page
date
11/14/2014
page
1 of 8
SERIES: ETSA 40W U │ DESCRIPTION: AC-DC POWER SUPPLY
40 W power
compact size
universal input (90~264 Vac)
single regulated output from 12~48 V
over voltage and short circuit protection
UL/cUL, GS, PSE safety approvals
level V efficiency
custom designs available
output
voltage
output
current
output
power
ripple and
noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
40
200
ETSA120330U
12
ETSA190210U
19
ETSA240167U
24
ETSA480083U
48
3.3
efficiency
level
2.1
40
240
V
40
240
V
0.83
40
300
V
1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors.
O
PART NUMBER KEY
D
IS
C
ETSA120330U X - XX - SZ - CXX
Base Number
example of 12 Vdc, 3.3 A
V
1.67
N
Notes:
TI
MODEL
N
U
ED
FEATURES
Reserved for Custom
DC Plug Type:
Configurations
see output plug options
on page 7
Input Cable:
Factory
“Blank” = No Cable
Designation
C = North American input cable
2 = European input cable
3 = United Kingdom input cable
4 = Australian input cable
5 = China input cable
6 = South Korea input cable
7 = Brazil input cable
8 = South Africa input cable
9 = Japan input cable
cui.com
Product Page
CUI Inc │ SERIES: ETSA 40W U │ DESCRIPTION: AC-DC POWER SUPPLY
date 11/14/2014 │ page 2 of 8
INPUT
conditions/description
min
90
frequency
47
inrush current
leakage current
no load power consumption
OUTPUT
parameter
min
max
units
264
Vac
63
Hz
typ
1.0
A
3.5
mA
0.3
W
max
units
±1
U
line regulation
typ
ED
parameter
voltage
load regulation
±5
PROTECTIONS
over voltage protection
protected through primary circuit IC
output shut down, auto restart
TI
SAFETY & COMPLIANCE
N
parameter
parameter
min
isolation voltage
input to output at 10 mA for 1 minute
typ
max
units
1,500
Vac
isolation resistance
input to output at 500 Vdc
safety approvals
UL 60950-1, EN 60950-1/IEC 60950-1, GS, PSE1
EMI/EMC
FCC part 15, subpart B, class B; CE; ICES-003; ANSI C63.4; EN 61204-3; EN 55022, class B; EN
55024; EN 61000-3-(2, 3); CISPR 22, class B; IEC 61000-4-(2, 3, 4, 5, 6, 8, 11)
RoHS
2011/65/EU
parameter
O
ENVIRONMENTAL
MΩ
N
1. excluding the 48 V model
100
max
units
°C
-10
70
°C
operating humidity
storage humidity
10
90
operating temperature
min
D
IS
C
storage temperature
cui.com
typ
Product Page
date 11/14/2014 │ page 3 of 8
MECHANICAL
80.6 x 50 x 31 (3.173 x 1.969 x 1.220 inches)
min
input plug
IEC320 / C14
weight1
48 V model
all other models
typ
max
units
mm
ED
parameter
dimensions
290
300
1. weight does not include AC Cord
MECHANICAL DRAWING
D
IS
C
O
N
TI
N
U
units: mm
tolerance: ±1mm
cui.com
g
g
Product Page
date 11/14/2014 │ page 4 of 8
DC CORD
ED
cord length
U
S&T
CABLE GAUGE
WIRE OD
CORD LENGTH
18 AWG
Ø2.2 x 4.4
1,530 mm ±100
ETSA190210U
20 AWG
Ø1.9 x 3.8
1,530 mm ±100
ETSA240167U
20 AWG
Ø1.9 x 3.8
1,530 mm ±100
ETSA480083U
22 AWG
Ø1.7 x 3.4
1,530 mm ±100
N
MODEL NO.
ETSA120330U
NORTH AMERICAN INPUT CABLE
Ĭijıı
IJĹĴıĮĴı
IS
C
O
N
units: mm
TI
AC CORD
EUROPEAN INPUT CABLE
ń
ŏ
ō
ĵ
D
IJķ
ijĶıŗ ſ
ŚńĮIJij
ŏİIJĵĹĸĸ
ŚőĮijĴ
units: mm
Ĭijıı
ĮĴı
cui.com
Product Page
date 11/14/2014 │ page 5 of 8
AC CORD (CONTINUED)
UNITED KINGDOM INPUT CABLE
units: mm
ŏ
ED
ń
ŏİIJĵĹĸĸ
ŚńĮIJij
ō
ĵ
U
+200
1830 -30
AUSTRALIAN INPUT CABLE
N
TI
ŏ
ŚőĮĴĶ
ō
ņ
N
O
IS
C
D
units: mm
BLACK INSULATION
1830 ±30
cui.com
ĵ
SOUTH KOREA INPUT CABLE
ō
+200
1830-30
ŏ
units: mm
ń
CHINA INPUT CABLE
ŚńĮIJij
+200
1830-30
ŏİIJĵĹĸĸ
ŏİIJĵĹĸķġIJıłġijĶıŗſ
units: mm
Product Page
date 11/14/2014 │ page 6 of 8
AC CORD (CONTINUED)
BRAZIL INPUT CABLE
ED
units: mm
U
1830±30
SOUTH AFRICA INPUT CABLE
TI
N
units: mm
1830±30
D
IS
C
units: mm
O
JAPAN INPUT CABLE
N
1830±30
cui.com
Product Page
date 11/14/2014 │ page 7 of 8
OUTPUT PLUG OPTIONS
14±0.5
ED
ø3.5 +0/-0.1
ø3.5 +0/-0.1
3.5 mm Phono Plug
14±0.5
*Tip positive
P1
P1R
C
Right Angle PXR
Standard PXX
B
A
O
IS
C
B
N
B
A
C
C
A
B
C
Unit
5.5
2.1
9.5
mm
P6/P6R
5.5
2.5
9.5
mm
P7/P7R
3.5
1.35
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
P9/P9R
3.8
1.05
9.5
mm
TI
Locking DC Plug
EIAJ Plugs
P5/P5R
N
Standard PX
B
A
B
A
C
A
U
Standard DC Plug
A
B
C
Unit
P10
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
EIAJ
A
B
C
P12/P12R
EIAJ-1
2.35
0.7
P13/P13R
EIAJ-2
4.0
1.7
P14/P14R
EIAJ-3
4.75
1.7
C
Right Angle PXXR
D
Stripped and Tinned
25±5
9±2
D
DC PLUG TYPE
PXX X X
Plug Type:
PXX = See above plug options
ST = Stripped and Tinned
Plug Angle:
“blank” = Straight
R = Right Angle
*Contact CUI for additional plug options
cui.com
Plug Polarity:
P = Center Positive
N = Center Negative
D
Unit
9.5
NA
mm
9.5
5.0
mm
9.5
5.0
mm
Product Page
date 11/14/2014 │ page 8 of 8
REVISION HISTORY
rev.
description
date
12/05/2011
initial release
updated P7/P7R B dimension
1.02
V-Infinity branding removed, ac cord drawing updated, safety and EMI/
EMC data updated
08/21/2012
1.03
updated series number
11/20/2012
1.04
added ac cord options
ED
1.0
1.01
03/14/2012
11/14/2014
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
ETSA240167UC-P5P-SZ 价格&库存
很抱歉,暂时无法提供与“ETSA240167UC-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
