date 09/2010
page 1 of 6
a division of CUI INC
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•interchangeable input blades
•short circuit, over load protection
•meets EISA / efficiency level IV regulations
•custom designs available
MODEL
output voltage
output current
ue
d
RoHS
output wattage
ripple*
max
(W)
max.
(mVp-p)
13
150
IV
1830 +150/-0
15
150
IV
1830 +150/-0
2.14
15
150
IV
1830 +150/-0
1.7
15.3
150
IV
1830 +150/-0
1.25
15
150
IV
1830 +150/-0
1
15
150
IV
1830 +150/-0
15.3
150
IV
1830 +150/-0
15
150
IV
1830 +150/-0
15.1
150
IV
1830 +150/-0
min
(A)
max
(A)
EMS050260
5
EMS060250
6
EMS070214
7
EMS090170
9
EMS120125
12
EMS150100
15
EMS180084
18
EMS200075
EMS240063
24
is
co
nt
in
nominal
(V dc)
efficiency level
cord length
(mm)
D
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
EMS050260 - XX - SZ - CXX
Base Number
Reserved for custom
configurations
example of 5 V dc, 2.6 A
DC Plug type:
see output plug options
on page 5
20050 SW 112th Ave. Tualatin, Oregon 97062
Factory
Designation
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 09/2010
page 2 of 6
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
nom
240
V ac
input voltage range
90
255
V ac
rated frequency
50
60
Hz
frequency range
47
rated input current
63
Hz
0.6
A
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
30
60
A
A
no load power consumption
0.3
W
max
units
ue
d
inrush current
OUTPUT
parameter
min
line regulation
load regulation
output shut down
short circuit protection
output shut down and auto-restart
nt
SAFETY & EMI
in
over voltage protection
HI-POT
input to output at 10 mA for 1 second
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1)
EMI standard
is
co
parameter
±1
±5
110%
min
nom
140%
V dc
max
units
3000
4242
V ac
V ac
100
M
FCC part 15 class B, CE (EN55022, EN55024)
0.25
mA
max
units
yes
D
leakage current
RoHS compliant
nom
ENVIRONMENTAL
parameter
min
operating temperature
nom
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
phone 503.612.2300
date 09/2010
page 3 of 6
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
MECHANICAL DRAWING
ˇˆˁˈ̈́˄ˁ˃
input plug
(UL, UK, VDE, SAA)
case size
74 L x 43.5 W x 34 H mm
tolerance: ±1 mm
ue
d
ˆˇ̈́˄ˁ˃
D
is
co
nt
in
ˊˇ̈́˄ˁ˃
˃ˌ˔
phone 503.612.2300
date 09/2010
page 4 of 6
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
co
Cable Gauge
18 AWG
EMS050260
18 AWG
EMS060250
18 AWG
EMS070214
20 AWG
EMS090170
20 AWG
EMS120125
EMS150100
20 AWG
EMS180084
20 AWG
EMS200075
20 AWG
EMS240063
20 AWG
D
is
Cable Length: refer to page 1
nt
in
ue
d
DC CORD
phone 503.612.2300
date 09/2010
page 5 of 6
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
OUTPUT PLUG OPTIONS
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
˄ˇʳ̈́˃ˁˈ
˄ˇʳ̈́˃ˁˈ
*Tip positive
P1
P1R
Standard DC Plug
Right Angle PXR
nt
Locking DC Plug
Standard PXX
is
D
A
5.5
5.5
A
5.5
5.5
3.5
3.8
3.8
B
2.1
2.5
B
2.1
2.5
1.3
1.35
1.05
C
9.5
9.5
9.5
9.5
9.5
C
9.5
9.5
Unit
mm
mm
mm
mm
mm
Unit
mm
mm
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
EIAJ Plugs
P10
P11
co
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
in
Standard PX
ue
d
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
3.5 mm Phono Plug
C
9.5
9.5
9.5
D
NA
5.0
5.0
Unit
mm
mm
mm
Right Angle PXXR
Stripped and Tinned
˅ˈ̈́ˈ
DC PLUG TYPE
ST
PXX X X
stripped and tinned
Plug type
Plug angle:
“blank” = standard
R = right angle
*Contact CUI for additional output plug options.
phone 503.612.2300
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
date 09/2010
page 6 of 6
SERIES:
DESCRIPTION:
15 W MULTI-BLADE
INDIVIDUAL PACKAGING
± 1 mm
tolerance
+7 / -0 mm
D
is
PACKAGING
co
nt
in
ue
d
tolerance
phone 503.612.2300
很抱歉,暂时无法提供与“EMS120125-P2P-SZ”相匹配的价格&库存,您可以联系我们找货
