date 09/2010
page 1 of 6
a division of CUI INC
SERIES:
DESCRIPTION:
15 W WALL PLUG
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•short circuit
•meets EISA / efficiency level IV regulations
•custom designs available
ed
RoHS
MODEL
output voltage
nominal
(V dc)
min
(A)
max
(A)
max
(W)
max.
(mVp-p)
EPS050260UH
5
13
150
IV
1000 +150/-0
EPS060250UH
6
15
150
IV
1000 +150/-0
EPS070214UH
7.5
14.7
150
IV
1000 +150/-0
EPS090166UH
9
14.9
150
IV
1000 +150/-0
EPS120125UH
12
15
150
IV
1830 +150/-0
EPS150100UH
15
15
150
IV
1830 +150/-0
EPS240063UH
24
ripple*
nt
in
u
output wattage
co
18
efficiency level
cord length
(mm)
14.9
150
IV
1830 +150/-0
15
250
IV
1830 +150/-0
15.1
250
IV
1830 +150/-0
is
EPS180083UH
EPS200075UH
output current
D
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
EPS050260UH - XX - SZ - CXX
Base Number
Reserved for
custom orders
example of 5 V dc, 2.6 A
DC Plug type:
see output plug options
on page 5
20050 SW 112th Ave. Tualatin, Oregon 97062
Factory
Designation
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 09/2010
page 2 of 6
SERIES:
DESCRIPTION:
15 W WALL PLUG
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
240
V ac
input voltage range
90
264
V ac
rated frequency
50
60
Hz
47
frequency range
nom
63
Hz
inrush current
at 115 V ac, cool start
at 230 V ac, cool start
30
50
A
A
no load power consumption
0.3
W
max
units
parameter
ed
OUTPUT
min
line regulation
in
u
load regulation
over voltage protection
output shutdown
short circuit protection
output shut down and auto restart
HI-POT
input to output at 10 mA for 1 minute
co
parameter
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL (60950-1)
EMI standard
FCC part 15 class B
±5
min
nom
V dc
max
units
3000
V ac
M
0.25
mA
max
units
40
°C
yes
D
RoHS compliant
140%
100
is
leakage current
±1
110%
nt
SAFETY & EMI
nom
ENVIRONMENTAL
parameter
min
operating temperature
nom
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
phone 503.612.2300
date 09/2010
page 3 of 6
SERIES:
DESCRIPTION:
15 W WALL PLUG
MECHANICAL DRAWING
Fixed (UL)
weight
180 g
case size
72 L x 47.6 W x 35 H mm
tolerance: ±1 mm
in
u
ed
input plug
co
nt
35±1
D
is
72±1
45.8±1.0
17.06±1.18
phone 503.612.2300
ed
in
u
DESCRIPTION:
phone 503.612.2300
20 AWG
20 AWG
20 AWG
20 AWG
Black wire, white stripe: Positive
15 W WALL PLUG
EPS150100
EPS180083
EPS200075
EPS240063
Cable Gauge
18 AWG
EPS050260
18 AWG
EPS060250
18 AWG
EPS070214
20 AWG
EPS090166
20 AWG
EPS120125
Ferrite core with one turns wire
14.2X28.5X8.2(004)
nt
SERIES:
co
is
D
Cable Length: refer to page 1
date 09/2010
page 4 of 6
DC CORD
date 09/2010
page 5 of 6
SERIES:
DESCRIPTION:
15 W WALL PLUG
DC OUTPUT PLUG OPTIONS
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
3.5 mm Phono Plug
˄ˇʳ̈́˃ˁˈ
˄ˇʳ̈́˃ˁˈ
*Tip positive
P1
P1R
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
in
u
Standard PX
Right Angle PXR
nt
Locking DC Plug
Standard PXX
is
D
A
5.5
5.5
A
5.5
5.5
3.5
3.8
3.8
B
2.1
2.5
B
2.1
2.5
1.3
1.35
1.05
C
12
9.5
9.5
9.5
9.5
C
9.5
9.5
Unit
mm
mm
mm
mm
mm
Unit
mm
mm
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
EIAJ Plugs
P10
P11
co
ed
Standard DC Plug
C
9.5
9.5
9.5
D
NA
5.0
5.0
Unit
mm
mm
mm
Right Angle PXXR
Stripped and Tinned
˅ˈ̈́ˈ
DC PLUG TYPE
ST
PXX X X
stripped and tinned
Plug type
Plug angle:
“blank” = standard
R = right angle
*Contact CUI for additional output plug options.
phone 503.612.2300
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
date 09/2010
page 6 of 6
SERIES:
DESCRIPTION:
15 W WALL PLUG
INDIVIDUAL PACKAGING
± 1 mm
tolerance
+7 / -0 mm
D
is
PACKAGING
co
nt
in
u
ed
tolerance
phone 503.612.2300
EPS060250UH-P5RP-SZ 价格&库存
很抱歉,暂时无法提供与“EPS060250UH-P5RP-SZ”相匹配的价格&库存,您可以联系我们找货
