date 09/2010
page 1 of 7
a division of CUI INC
SERIES:
DESCRIPTION:
20 W DESKTOP
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•short circuit, over load protection
•LED indicator for power on
•meets EISA / efficiency level IV regulations
•custom designs available
MODEL
output voltage
nominal
(V dc)
min
(A)
max
(A)
ETS050400U
5
ETS060330U
6
ETS090220U
9
ETS120200U
12
ETS150133U
15
ETS180110U
18
ETS240100U
24
output wattage
ripple
max
(W)
max.
(mVp-p)
IV
1000 +150/-0
3.3
19.8
150
IV
1000 +150/-0
2.2
19.8
150
V
1830 +150/-0
2
24
150
V
1830 +150/-0
1.33
V
1830 +150/-0
1.1
19.8
150
V
1830 +150/-0
1
24
150
V
1830 +150/-0
co
nt
in
output current
ue
d
RoHS
efficiency level
cord length
(mm)
D
is
*full load, 100~240 Vac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
ETS050400U T C - XX - SZ - CXX
Base Number
Reserved for
custom orders
example of 5 V dc, 4.0 A
AC Input Plug:
blank = IEC 320 C14 plug
T = IEC 320 C6 plug
Input Cable:
C = included
blank = no cable
20050 SW 112th Ave. Tualatin, Oregon 97062
DC Plug type:
see output plug options
on page 5
phone 503.612.2300
Factory
Designation
fax 503.612.2382 www.v-infinity.com
date 09/2010
page 2 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
nom
240
V ac
input voltage range
90
255
V ac
rated frequency
50
60
Hz
frequency range
47
rated input current
63
Hz
0.8
A
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
30
50
A
A
no load power consumption
110 ~ 240 V ac
0.5
W
max
units
ue
d
inrush current
OUTPUT
parameter
min
line regulation
load regulation
output shut down
short circuit protection
output shut down and auto-restart
nt
SAFETY & EMI
in
over voltage protection
HI-POT
input to output at 10 mA for 1 second
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1)
EMI standard
±5
110%
min
nom
140%
V dc
max
units
1500
2121
V ac
V dc
100
M
FCC part 15 class B, CE (EN55022, EN55024)
3.5
mA
max
units
D
leakage current
RoHS compliant
±1
is
co
parameter
nom
yes
ENVIRONMENTAL
parameter
min
operating temperature
nom
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
phone 503.612.2300
date 09/2010
page 3 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
MECHANICAL DRAWING
99 L x 51 W x 31.7 H mm
tolerance: ±1 mm
D
is
co
nt
in
ue
d
case size
phone 503.612.2300
date 09/2010
page 4 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
co
Cable Gauge
18 AWG
ETS050400
18 AWG
ETS060330
18 AWG
ETS090220
18 AWG
ETS120200
20 AWG
ETS150133
ETS180110
20 AWG
ETS240100
20 AWG
D
is
Cable Length: refer to page 1
nt
in
ue
d
DC CORD
phone 503.612.2300
date 09/2010
page 5 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
OUTPUT PLUG OPTIONS
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
˄ˇʳ̈́˃ˁˈ
˄ˇʳ̈́˃ˁˈ
*Tip positive
P1
P1R
Standard DC Plug
Right Angle PXR
nt
Locking DC Plug
Standard PXX
is
D
A
5.5
5.5
A
5.5
5.5
3.5
3.8
3.8
B
2.1
2.5
B
2.1
2.5
1.3
1.35
1.05
C
9.5
9.5
9.5
9.5
9.5
C
9.5
9.5
Unit
mm
mm
mm
mm
mm
Unit
mm
mm
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
EIAJ Plugs
P10
P11
co
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
in
Standard PX
ue
d
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
3.5 mm Phono Plug
C
9.5
9.5
9.5
D
NA
5.0
5.0
Unit
mm
mm
mm
Right Angle PXXR
Stripped and Tinned
˅ˈ̈́ˈ
DC PLUG TYPE
ST
PXX X X
stripped and tinned
Plug type
Plug angle:
“blank” = standard
R = right angle
*Contact CUI for additional output plug options.
phone 503.612.2300
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
date 09/2010
page 6 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
AC CORD
C14
D
is
co
nt
in
ue
d
C6
*Contact CUI for additional ac cord input blade options.
phone 503.612.2300
date 09/2010
page 7 of 7
SERIES:
DESCRIPTION:
20 W DESKTOP
INDIVIDUAL PACKAGING
tolerance
± 1 mm
tolerance
+7 / -0 mm
D
is
PACKAGING
co
nt
in
ue
d
RoHS Compliant
phone 503.612.2300
很抱歉,暂时无法提供与“ETS050400U-P6N-ET”相匹配的价格&库存,您可以联系我们找货
