Additional Resources:
Product Page
date
12/12/2014
page
1 of 7
SERIES: PSF-75 │ DESCRIPTION: AC-DC POWER SUPPLY
ED
FEATURES
up to 75 W continuous power
universal input (90~264 Vac)
built-in constant current limit circuitry
alarm signal for AC OK and battery low
short circuit, over load, over voltage, brown-out,
battery low, and battery polarity protections
• withstand 2G vibration test
• efficiency up to 88%
output
voltage
output
current1
(Vdc)
max
(A)
Vo1
Vo2
13.8
13.8
PSF-75-B
Vo1
Vo2
Vo3
13.8
13.8
5
PSF-75-C
Vo1
Vo2
27.6
27.6
PSF-75-D
Vo1
Vo2
Vo3
27.6
27.6
5
efficiency
max
(W)
max
(mVp-p)
typ
5.5
2.07
75
100
150
86
4.4
2.07
3
75
100
150
100
85
2.75
1.15
75
100
150
88
2.2
1.15
3
75
100
150
100
87
O
1. Vo2 battery discharge current must not exceed 50% of the rated power.
2. Maximum total combined power (rated power).
3. At 20 MHz bandwidth using a 12” twisted pair-wire, each output terminated with a 47 µF and 0.1 µF parallel capacitors.
IS
C
Notes:
ripple
and noise3
N
PSF-75-A
output
power2
TI
MODEL
N
U
D
PART NUMBER KEY
Base Number
PSF-75 - X - XXX
Output Voltage
A = 13.8 Vdc, 13.8 Vdc
B = 13.8 Vdc, 13.8 Vdc, 5 Vdc
C = 27.6 Vdc, 27.6 Vdc
D = 27.6 Vdc, 27.6 Vdc, 5 Vdc
cui.com
Chassis
“blank” = open frame
CNF = enclosed
Product Page
CUI Inc │ SERIES: PSF-75 │ DESCRIPTION: AC-DC POWER SUPPLY
date 12/12/2014
page 2 of 7
INPUT
parameter
conditions/description
min
typ
voltage
surge voltage
for maximum of 5 seconds
frequency
47
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac, cold start
at 230 Vac, cold start
leakage current
at 264 Vac
line regulation
low line to high line, at rated load
Vo1, Vo3
load regulation
10% to 100% rated load
Vo1
Vo3
voltage accuracy
Vo1
Vo3
hold-up time
at 115 Vac, full load
at 230 Vac, full load
setup time
at 115/230 Vac, full load, cold start
rise time
adjustability
Vo1
temperature coefficient
Vo1, 0°C~50°C
AC OK
PSF-75-A, PSF-75-C
PSF-75-B, PSF-75-D
TTL open collector output
relay contact output
battery low
PSF-75-A, PSF-75-B
PSF-75-C, PSF-75-D
很抱歉,暂时无法提供与“PSF-75-A”相匹配的价格&库存,您可以联系我们找货
