Additional Resources:
Product Page
3D Model
date
06/01/2022
page
1 of 6
SERIES: VSK-S5 │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 5.5 W continuous output
compact board mount design
universal input (85~264 Vac/110~370 Vdc)
single regulated output from 3.3~24 Vdc
over voltage, over temperature, and short circuit protections
UL/cUL safety approvals
efficiency up to 83%
MODEL
output
voltage
output
current
output
power
ripple
and noise1
efficiency
(Vdc)
max
(mA)
max
(W)
max
(mVp-p)
max
3.3
1250
4.125
120
74
VSK-S5-5UA
5
1000
5
120
78
VSK-S5-9UA
9
550
5
100
78
VSK-S5-12UA
12
420
5
100
80
VSK-S5-15UA
15
333
5
100
82
VSK-S5-24UA
24
230
5.5
100
83
VSK-S5-3R3UA
Notes:
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 μF ceramic and 10 μF electrolytic capacitors on the output.
PART NUMBER KEY
VSK-S5 - XXUA
Base Number
Output Voltage
cui.com
Product Page
3D Model
CUI Inc │ SERIES: VSK-S5│ DESCRIPTION: AC-DC POWER SUPPLY
date 06/01/2022 │ page 2 of 6
INPUT
parameter
conditions/description
min
voltage
frequency
max
units
85
110
typ
264
370
Vac
Vdc
47
63
Hz
current
at 110 Vac
at 230 Vac
110
70
mA
mA
inrush current
at 110 Vac
at 230 Vac
10
A
A
input fuse
recommended external 1 A/250 V, slow-blow type
±0.02
%/°C
temperature coefficient
OUTPUT
parameter
capcitive load1
3.3 Vdc model
5 Vdc model
9 Vdc model
12 Vdc model
15 Vdc model
24 Vdc model
min
line regulation
typ
max
units
4000
4000
1000
820
820
330
μF
μF
μF
μF
μF
μF
±0.5
load regulation
at 10~100% load
±1
voltage set accuracy
3.3 Vdc model
all other models
±3
±2
hold-up time
at 110 Vac
at 230 Vac
12
80
ms
ms
switching frequency
Notes:
140
kHz
max
units
1. Test without external circuit
PROTECTIONS
parameter
over voltage protection
shutdown
over current protection
auto recovery
hiccup, auto recovery
min
typ
110
SAFETY & COMPLIANCE
parameter
isolation voltage
for 1 minute
safety approvals
UL60950-1
safety class
Class II
conducted emissions
CISPR22/EN55022, Class B
radiated emissions
ESD
IEC/EN61000-4-2 Class B, contact ±6 kV / air ±8 kV
radiated immunity
IEC/EN61000-4-3 Class A, 10V/m
EFT/burst
surge
min
typ
4,000
IEC/EN61000-4-4 Class B, ±2 kV
IEC/EN61000-4-4 Class B, ±4 kV (external circuit required, see figure 2)
IEC/EN61000-4-5 Class B, ±1 kV / ±2 kV
IEC/EN61000-4-5 Class B, ±2 kV / ±4 kV (external circuit required, see figure 2)
conducted immunity
IEC/EN61000-4-6 Class A, 10 Vr.m.s
PFM
IEC/EN61000-4-8 Class A, 10 A/m
cui.com
max
units
Vac
Product Page
3D Model
date 06/01/2022 │ page 3 of 6
SAFETY & COMPLIANCE (CONTINUED)
parameter
voltage dips & interruptions
IEC/EN61000-4-11 Class B, 0%-70%
min
MTBF
as per MIL-HDBK-217F, at 25 °C
RoHS
2011/65/EU
typ
max
300,000
units
hours
ENVIRONMENTAL
parameter
min
operating temperature
see derating curves
storage temperature
storage humidity
non-condensing
DERATING CURVES
EFFICIENCY CURVES
cui.com
typ
max
units
-25
70
°C
-25
105
°C
95
Product Page
3D Model
date 06/01/2022 │ page 4 of 6
MECHANICAL
parameter
dimensions
50.8 x 25.4 x 15.16 (2.00 x 1.00 x 0.597 inch)
min
material
UL94V-0
weight
typ
max
units
mm
31
g
MECHANICAL DRAWING
units: mm [inch]
tolerance: ±0.50 [±0.020]
pin section tolerance: ±0.10 [±0.004]
1
AC(N)
2
AC(L)
3
+Vo
4
-Vo
15.16[0.597]
FUNCTION
6.00 [0.236]
PIN CONNECTIONS
PIN
Front View
Grid Size: 2.54 x 2.54mm
∅1.00[0.039]
2
4
20.32 [0.800]
3
25.40 [1.000]
1
4
3
1
2
45.72 [1.800]
Top View
PCB LAYOUT
50.80 [2.000]
Bottom View
cui.com
10.16 [0.400]
∅1.50 [0.059]
Product Page
3D Model
date 06/01/2022 │ page 5 of 6
TYPICAL APPLICATION CIRCUIT
Table 1
Figure 1
Note:
Recommended External Circuit Components
MODEL
C11
(μF)
C21
(μF)
FUSE
NTC
MOV
VSK-S5-3R3UA
1
220
1 A/250 V
12D-5
S14K350
VSK-S5-5UA
1
220
1 A/250 V
12D-5
S14K350
VSK-S5-9UA
1
100
1 A/250 V
12D-5
S14K350
VSK-S5-12UA
1
100
1 A/250 V
12D-5
S14K350
VSK-S5-15UA
1
100
1 A/250 V
12D-5
S14K350
VSK-S5-24UA
1
47
1 A/250 V
12D-5
S14K350
1. Output filtering capacitor C1 is a ceramic capacitor that is used to filter high frequency noise. C2 is an electrolytic capacitor. It is recommended to use high frequency and
low impedance electrolytic capacitors. For capacitance and current of capacitor please refer to the manufacturer’s datasheet. Voltage derating of capacitor should be 80%
or above.
EMC RECOMMENDED CIRCUIT
Table 2
Figure 2
FUSE
Note:
MOV
S14K350
CY1, CY2
1nF/400VAC
CX
0.1μF/275VAC
LCM
2.2mH
L1
4.7μH/2.0A
C1, C2
see Table 1
1. All specifications measured at Ta=25°C, humidity
很抱歉,暂时无法提供与“VSK-S5-12UA”相匹配的价格&库存,您可以联系我们找货
