Additional Resources:
Product Page
3D Model
PCB Footprint
date
06/01/2022
page
1 of 5
SERIES: VSK-S3 │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 3 W continuous power
compact board mount design
universal input (85~264 Vac / 110~370 Vdc)
single output from 3.3~24 V
over voltage, over temperature, and short circuit protections
UL/cUL safety approvals
efficiency up to 78%
MODEL
VSK-S3-3R3U
output
voltage
output
current
output
power
ripple
and noise1
efficiency
(Vdc)
max
(A)
max
(W)
typ
(mVp-p)
typ
3.3
0.7
2.3
30
63
VSK-S3-5U
5
0.6
3
30
72
VSK-S3-9U
9
0.33
3
30
74
VSK-S3-12U
12
0.25
3
30
76
VSK-S3-15U
15
0.2
3
30
76
VSK-S3-24U
24
0.125
3
30
78
Notes:
1. Ripple and noise measured at 20 MHz bandwidth
PART NUMBER KEY
VSK-S3 - XXU
Base Number
Output Voltage
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: VSK-S3 │ DESCRIPTION: AC-DC POWER SUPPLY
date 06/01/2022 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
frequency
max
units
85
110
typ
264
370
Vac
Vdc
47
440
Hz
current
at 110 Vac
at 230 Vac
65
30
mA
mA
inrush current
at 110 Vac
at 230 Vac
10
A
A
external input fuse
(recommended)
slow blow, 250 V
0.5
A
OUTPUT
parameter
min
line regulation
load regulation
10 ~ 100%
temperature coefficient
typ
max
units
±0.5
±1
0.02
%/°C
hold-up time
at 230 Vac
50
ms
voltage accuracy
3.3 V model
all other models
±3
±2
100
kHz
switching frequency
PROTECTIONS
parameter
min
over voltage protection
chip lock up
auto recovery with no damage from a short on any output
typ
over temperature protection
max
units
150
°C
max
units
SAFETY & COMPLIANCE
parameter
min
typ
isolation voltage
primary to secondary (for 1 minute)
safety approvals
UL 60950-1
safety class
class II
EMI/EMC
EN 55022 (level A), IEC/EN 61000-4-2 (level 4, 8kV/15kV), IEC/EN 61000-4-3, IEC/EN 61000-4-4
(level 3, 2kV), IEC/EN 61000-4-5 (level 3, 1kV/2kV)
MTBF
25°C
RoHS
2011/65/EU
3,000
Vac
300,000
hrs
ENVIRONMENTAL
parameter
max
units
operating temperature
min
-25
70
°C
storage temperature
-40
105
°C
95
°C
95
case temperature
operating humidity
non-condensing
cui.com
typ
Product Page
3D Model
PCB Footprint
date 06/01/2022 │ page 3 of 5
DERATING CURVES
MECHANICAL
parameter
min
dimensions
1.457 x 0.908 x 0.591 (37.0 x 23.0 x 15.0 mm)
case material
UL94V-0
typ
max
units
inch
weight
25
g
MECHANICAL DRAWING
units: mm [inches]
tolerance: ±0.5 [±0.02]
pin section tolerance: ±0.10 [±0.004]
PIN CONNECTIONS
37.00 1.457
15.00 0.591
4.10 0.161
(TYP)
PIN
FUNCTION
1
L
3
N
13
N/C
14
0V
16
+Vo
22
+Vin(DC)
26
-Vin(DC)
0.80 0.031
(7 PLCS)
3.26 0.128
(2 PLCS)
8.34 0.328
1
3
2.61 0.103
(TYP)
13
23.00 0.906
2.54
1.2 0.047
(7 PLCS)
26
22
16
14
17.78 0.700
26
22
16
14
1
3.26 0.128
(2 PLCS)
BOTTOM VIEW
3
5.08 0.200
(TYP)
RECOMMENDED FOOTPRINT
TOP VIEW
13.42 0.528
cui.com
13
Product Page
3D Model
PCB Footprint
date 06/01/2022 │ page 4 of 5
TYPICAL APPLICATION CIRCUIT
Figure 2
VSK-S3 EMC Filtering Circuit
Figure 1
EXTERNAL CAPACITORS TYPICAL VALUE (Unit: µF)
MODEL
C1
C2
C3
TVS
VSK-S3-3R3U
150
0.1
4.7/400V
P4KE6.8A
VSK-S3-5U
150
0.1
4.7/400V
P4KE6.8A
VSK-S3-9U
150
0.1
4.7/400V
P4KE12A
VSK-S3-12U
150
0.1
4.7/400V
P4KE20A
VSK-S3-15U
150
0.1
4.7/400V
P4KE20A
VSK-S3-24U
150
0.1
4.7/400V
P4KE30A
Notes:
Note:
1. Output filtering capacitors C1, C3 is electrolytic capacitors, It is recommended to use high frequency
and low impedance electrolytic capacitors. For capacitance and current of capacitor please refer to
manufacture’s datasheet. Voltage derating of apacitor should be 80% or above. C2, C4 is ceramic
capacitors , it is used to filter high frequency noise. TVS is a recommended component to protect
post-circuits (when converter fails).
2. MOV is required for VSK-S3 models. Model: 471KD05, it is used to protect the device under surge.
3. It is recommended to connect FUSE, the parameter is 0.5A/250V slow blow. External input NTC is
recommended to use D -14 or 10Ω/2W wire-round resistor.
4. If EMC performance is required, recommended to add “EMC filter” at the input end(see figure 2)
C6:X capacitor, recommended parameter 0.1uF/275V; C7,C8:Y capacitor, recommended parameter
220pF/275V; NF: common model choke, recommended inductance is about 10mH-30mH.
5. Terminals 22 and 26 are internal rectification and filtering terminals. To protect the models further, it
is recommended to connect an electrolytic capacitor C3 (it is recommended to be 4.7uF/400V). If
operation voltage of the module is between 160~264VAC, C3 can be removed.
1. All specifications measured at Ta=25°C, humidity
很抱歉,暂时无法提供与“VSK-S3-3R3U”相匹配的价格&库存,您可以联系我们找货
