Additional Resources:
Product Page
date
06/07/2016
page
1 of 7
SERIES: PBK-5 │ DESCRIPTION: AC-DC POWER SUPPLY
up to 5 W continuous output
ultra compact SIP package
universal input voltage: (85~264 Vac / 100~400 Vdc)
single regulated outputs from 3.3~24 Vdc
3,000 Vac isolation
over current, short circuit, and over voltage protections
UL 60950-1 safety approval
efficiency up to 75%
output
voltage
output
current
output
power
ripple
and noise1
efficiency
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
1
3.3
150
65
PBK-5-3
3.3
PBK-5-5
5
PBK-5-9
9
12
PBK-5-15
PBK-5-24
5
120
70
5
120
72
0.42
5
120
74
15
0.34
5
120
75
24
0.21
5
150
75
1. Measured at 20 MHz bandwidth, see Test Configuration section.
O
Note:
1
0.56
N
PBK-5-12
TI
MODEL
N
U
ED
FEATURES
PBK-5- XX - X
Base Number
Output Voltage
D
IS
C
PART NUMBER KEY
cui.com
Orientation
“blank” = vertical
B = right-angle
Product Page
CUI Inc │ SERIES: PBK-5 │ DESCRIPTION: AC-DC POWER SUPPLY
date 06/07/2016 │ page 2 of 7
INPUT
conditions/description
min
voltage
frequency
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac
at 230 Vac
leakage current
CY0 is 1nF/400Vac
max
units
85
100
264
400
Vac
Vdc
47
440
Hz
200
100
mA
mA
no load power consumption
1 A/250 V, slow-blow type (external, recommended)
U
input fuse
OUTPUT
parameter
min
line regulation
at full load
load regulation
at 10%~100% load
PBK-5-3
all other models
N
at 115 Vac
at 230 Vac
switching frequency
parameter
short circuit protection
0.25
mA
0.5
W
max
units
2200
1500
680
470
330
100
μF
μF
μF
μF
μF
μF
±0.1
±0.5
±1.0
±1.5
±2
±3
±1
±2
min
ms
ms
100
kHz
±0.02
%/°C
typ
max
units
continuous, auto restart
auto restart
110
IS
C
over current protection
O
temperature coefficient
PROTECTIONS
TI
capacitive load
3.3 Vdc output models
5 Vdc output models
9 Vdc output models
12 Vdc output models
15 Vdc output models
24 Vdc output models
hold-up time
typ
A
A
10
N
output current
voltage set accuracy
typ
ED
parameter
zener diode clamp
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output for 1 minute at 5mA
min
isolation resistance
typ
max
Vac
100
MΩ
UL 60950-1
safety standards
UL 60950-1
safety class
class II
conducted emissions
CISPR22/EN55022 external circuit required, Class A (see figure 2); Class B (see figure 3)
radiated emissions
CISPR22/EN55022 external circuit required, Class B (see figures 2 or 3)
ESD
IEC/EN61000-4-2 Class B, contact ±4 kV
D
safety approvals
radiated immunity
EFT/burst
IEC/EN61000-4-3 Class A, 10V/m
IEC/EN61000-4-4 Class B, ±2 kV (external circuit required, see figure 2)
IEC/EN61000-4-4 Class B, ±4 kV (external circuit required, see figure 3)
cui.com
units
3,000
Product Page
date 06/07/2016 │ page 3 of 7
SAFETY & COMPLIANCE (CONTINUED)
IEC/EN61000-4-5 Class B, ±1 kV/±2 kV (external circuit required, see figure 3)
min
conducted immunity
IEC/EN61000-4-6 Class A, 3 Vr.m.s (external circuit required, see figure 3)
PFM
IEC/EN61000-4-8 Class A, 10 A/m
voltage dips & interruptions
IEC/EN61000-4-11 Class B, 0%-70%
MTBF
at 25°C, max. load
RoHS
2011/65/EU
min
operating temperature
see derating curves
-25
storage temperature
case temperature
N
non-condensing
DERATING CURVES
Safe operating area
60
Safe operating area
40
-5
55
65
75
95
85
95
105 110 115
235 240 245
O
efficiency vs. load
PBK-5-12
110 VAC
240 VAC
IS
C
120 VAC
220 VAC
230 VAC
264 VAC
255
°C
85
100
80
60
Safe operating area
40
264
135
320
efficiency vs. input voltage (Vac)
PBK-5-3
PBK-5-5
PBK-5-9
PBK-5-12
PBK-5-15
PBK-5-24
Input Voltage (VAC)
efficiency vs. load
PBK-5-12
efficiency vs. input voltage (Vdc)
100 VDC
200 VDC
D
Efficency (%)
100
300 VDC
400 VDC
PBK-5-3
PBK-5-5
PBK-5-9
PBK-5-12
PBK-5-15
°C
Input Voltage (Vdc)
Load (%)
°C
85
105
85 VAC
125
units
load vs. input voltage (Vdc)
(at 25°C)
Input Voltage (Vac)
EFFICIENCY CURVES
Efficency (%)
85
max
45
Ambient Temperature (°C)
Efficiency (%)
-15
N
Load (%)
60
100
80
Load (%)
Load (%)
load vs. input voltage (Vac)
(at 25°C)
TI
load vs. ambient temperature
(at 110~240 Vac input voltage)
-25
typ
-40
humidity
PBK-5-24
Load (%)
units
hours
U
parameter
40
max
300,000
ENVIRONMENTAL
100
typ
ED
parameter
surge
Input Voltage (VDC)
cui.com
353
Product Page
date 06/07/2016 │ page 4 of 7
SOLDERABILITY
min
typ
max
units
for 3~5 seconds
350
360
370
°C
wave soldering
for 5~10 seconds
255
260
265
°C
parameter
min
dimensions
vertical models: 42 x 11 x 27
right-angle models: 42 x 25 x 13
material
UL94V-0
MECHANICAL
ED
parameter
hand soldering
typ
10
U
MECHANICAL DRAWING
VERTICAL ORIENTATION
N
PIN CONNECTIONS
-Vin (N)
3
+Vin (L)
5
+V(CAP)
7
-V(CAP)
12
-Vo
14
+Vo
O
Note: 1. It is required to add C1 between
pins 5 & 7 (see application circuits).
TI
FUNCTION
1
N
PIN
Front View
IS
C
D
units
mm
mm
weight
units: mm[inch]
tolerance: ±0.5[±0.020]
pin tolerance: ±0.1[±0.004]
max
Top View
PCB Layout
Bottom View
cui.com
g
Product Page
date 06/07/2016 │ page 5 of 7
MECHANICAL DRAWING (CONTINUED)
RIGHT-ANGLE ORIENTATION
ED
units: mm[inch]
FUNCTION
1
-Vin (N)
3
+Vin (L)
5
+V(CAP)
7
-V(CAP)
12
-Vo
14
+Vo
U
PIN CONNECTIONS
PIN
Front View
Side View
N
TI
N
Bottom View
O
Top View
PCB Layout
IS
C
TEST CONFIGURATION
Table 1
Recommended External Circuit Components
C on n e c t Os c illo g r ap h Pro b e
C o pp e r s h e e t
Figure 1
F U SE
C1
D
$&1
+Vo
L1
C2
AC -D C
-Vo
C Y0
C3
C4
L oa d
VOUT
(Vdc)
C11
C21
L11
C31
C4
CY0
(Y1
capacitor)
3.3
22μF/400V
470μF/10V
0.47μH
150μF/35V
100nF/50V
1nF/400Vac
5
22μF/400V
470μF/16V
0.47μH
150μF/35V
100nF/50V
1nF/400Vac
9
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
1nF/400Vac
12
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
1nF/400Vac
15
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
1nF/400Vac
24
22μF/400V
100μF/35V
4.7μH
47μF/35V
100nF/50V
1nF/400Vac
Note:
1. Required components.
2. 1 A/250 V fuse required.
cui.com
Product Page
date 06/07/2016 │ page 6 of 7
TYPICAL APPLICATION CIRCUIT
1 7&
Figure 2
MOV
CX 1
C1
7
1
C3 T VS C4 RL
5 AC -D C
A C( N)
L1
+V o C2
14
3
ED
) 86 (
AC( L )
12
-Vo
Note: (1) is Pi filter circuit.
C Y0
U
Table 2
Recommended external circuit components
VOUT
(Vdc)
C11
C21
L11
C31
C4
CX1
3.3
22μF/400V
470μF/10V
0.47μH
150μF/35V
100nF/50V
0.1µF/275Vac
5
22μF/400V
470μF/16V
0.47μH
150μF/35V
100nF/50V
0.1µF/275Vac
1nF/400Vac
9
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
0.1µF/275Vac
1nF/400Vac
12
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
0.1µF/275Vac
15
22μF/400V
330μF/25V
1μH
150μF/35V
100nF/50V
0.1µF/275Vac
24
22μF/400V
100μF/35V
4.7μH
47μF/35V
100nF/50V
0.1µF/275Vac
AC(L)
FUSE
LDM
LCM
CY2
C1
O
IS
C
D
1.
2.
3.
4.
5.
6.
7.
8.
9.
TVS
1nF/400Vac
1A/250V
5D-9
S14K350
SMBJ7.0A
1A/250V
5D-9
S14K350
SMBJ7.0A
1A/250V
5D-9
S14K350
SMBJ12A
1nF/400Vac
1A/250V
5D-9
S14K350
SMBJ20A
1nF/400Vac
1A/250V
5D-9
S14K350
SMBJ20A
1nF/400Vac
1A/250V
5D-9
S14K350
SMBJ30A
5
L1
TVS
14
+Vo
CY1
AC-DC
7
C2
C4
RL
C3
-Vo
12
AC(N)
AC(N)
Notes:
MOV
AC(L)
CX
Figure 3
NTC
N
N
EMC RECOMMENDED CIRCUIT
FUSE
TI
Note:
CY0
CY0
Table 3
MOV2
S10K300
CY1, CY2
1nF/400Vac
CX
0.1μF/275Vac
LCM
3.5mH
LDM
5mH
FUSE
1A/250V
Note:
1. Also refer to Table 2.
C1, C2, and C3 are electrolytic capacitors. They are required for both AC input and DC input.
For AC input, C1 is used as a filter capacitor. The recommended C1 value is 22 μF/400 V.
For DC input, C1 is used as an EMC filter capacitor. The recommended C1 value is 10μF/400V. When the input voltage is above 370VDC, we recommend a 10μF/450V capacitor.
C2 and C3 are output filer capacitors, we recommend high frequency and low impedance electrolytic capacitors. For capacitance and rated ripple current of capacitors refer to
the datasheets provided by the manufacturers, voltage derating of capacitors should be 80% or above.
C4 is a ceramic capacitor which is used to filter high frequency noise.
C2, C3 and L1 form a pi-type filter circuit. For the current of L1, refer to the datasheets provided by the manufacturers, current derating should be 80% or above.
TVS is a recommended component to protect post-circuits (if converter fails).
For standard EMC requirements, please refer to figure 2. If a higher EMC is required, please refer to figure 3.
All specifications measured at Ta=25C, humidity
很抱歉,暂时无法提供与“PBK-5-12”相匹配的价格&库存,您可以联系我们找货
