Additional Resources:
Product Page
date
02/02/2018
page
1 of 7
SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY
up to 1 W continuous output
compact SIP package
single regulated outputs from 5~24 V
3,000 Vac isolation
over current and short circuit protections
CE, UL60950-1 safety approval
wide input voltage: 70~400 Vdc (85~264 Vac)
efficiency up to 68%
PBK-1-5
output
voltage
output
current
output
power
ripple
and noise1
efficiency2
(Vdc)
max
(mA)
max
(W)
max
(mVp-p)
typ
200
1
150
61
111
1
150
66
83
1
150
67
67
1
150
67
1
150
68
5
PBK-1-9
9
12
PBK-1-15
15
PBK-1-24
Note:
N
PBK-1-12
TI
MODEL
N
U
ED
FEATURES
24
42
1. Measured at 20 MHz bandwidth, see Test Configuration section.
2. At 230 Vac.
PBK-1- XX - X
Base Number
Output Voltage
D
IS
C
O
PART NUMBER KEY
cui.com
Orientation
“blank” = vertical
B = right-angle
Product Page
CUI Inc │ SERIES: PBK-1 │ DESCRIPTION: AC-DC POWER SUPPLY
date 02/02/2018 │ page 2 of 7
INPUT
conditions/description
max
units
voltage
85
70
264
400
Vac
Vdc
frequency
47
63
Hz
120
60
mA
mA
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac
at 230 Vac
min
10
no load power consumption
input fuse
1 A/250 V, slow-blow type (external, required)
min
W
max
units
470
150
100
μF
μF
μF
±1.5
±2
±2.5
±3
±10
±5
typ
10
line regulation
at full load
load regulation
at 10%~100% load
voltage set accuracy
5 Vdc output models
all other models
hold-up time
at 115 Vac
at 230 Vac
switching frequency
PROTECTIONS
80
300
N
temperature coefficient
TI
capacitive load
5 Vdc output models
9 Vdc output models
all other models
N
output current
A
A
0.5
U
OUTPUT
parameter
typ
ED
parameter
hiccup, continuous, auto restart
over current protection
auto restart
O
parameter
min
ms
ms
50
±0.1
typ
kHz
%/°C
max
120
units
SAFETY & COMPLIANCE
parameter
min
input to output, for 1 minute
typ
max
3,000
IS
C
isolation voltage
safety approvals
UL60950-1, CE
safety class
Class II
conducted emissions
CISPR32/EN55032 external circuit required, Class A (see figure 2); Class B (see figure 3)
radiated emissions
ESD
IEC/EN61000-4-2 Class B, contact ±4 kV
radiated immunity
IEC/EN61000-4-3 Class A, 10V/m (external circuit required, see figure 3)
EFT/burst
Vac
IEC/EN61000-4-4 Class B, ±2 kV (external circuit required, see figure 2)
IEC/EN61000-4-4 Class B, ±4 kV (external circuit required, see figure 3)
surge
IEC/EN61000-4-5 Class B, ±1 kV/±2 kV (external circuit required, see figure 3)
conducted immunity
IEC/EN61000-4-6 Class A, 3 Vr.m.s (external circuit required, see figure 3)
voltage dips & interruptions
IEC/EN61000-4-11 Class B, 0%-70% (external circuit required, see figure 3)
MTBF
as per MIL-HDBK-217F, 25°C
RoHS
2011/65/EU
D
units
300,000
cui.com
hours
Product Page
date 02/02/2018 │ page 3 of 7
ENVIRONMENTAL
parameter
min
operating temperature
humidity
non-condensing
units
85
°C
-25
105
°C
85
EFFICIENCY CURVES
80
75
70
65
LS01-15B05S
60
55
60
LS01-15B24S
LS01-15B12S
PBK-1-5
LS01-15B05S
PBK-1-12
PBK-1-24
N
PBK-1-12
LS01-15B24S
PBK-1-24
LS01-15B12S
Efficie ncy(%)
PBK-1-5
70
U
80
50
40
230
10
O
N
Input Voltage (Vac)
D
IS
C
85
TI
30
50
effieciency vs. output load (at 230 Vac)
effieciency vs. input voltage (full load)
Efficie ncy(%)
typ
ED
storage temperature
max
-25
cui.com
50
Output Current (%)
100
Product Page
date 02/02/2018 │ page 4 of 7
SOLDERABILITY
min
typ
max
units
for 3~5 seconds
350
360
370
°C
wave soldering
for 5~10 seconds
255
260
265
°C
parameter
min
dimensions
vertical: 35 x 11 x 25
right-angle: 35 x 13 x 25
material
UL94V-0
MECHANICAL
typ
max
units
mm
mm
weight
8
g
U
MECHANICAL DRAWING
VERTICAL ORIENTATION
O
N
TI
N
units: mm[inch]
tolerance: ±0.5[±0.020]
pin tolerance: ±0.1[±0.004]
Top View
PCB Layout
PIN CONNECTIONS
PIN
Front View
IS
C
D
ED
parameter
hand soldering
FUNCTION
1
-Vin (N)
3
+Vin (L)
5
+V(CAP)
7
-V(CAP)
10
-Vo
12
+Vo
Note: 1. It is required to add C1 between
pins 5 & 7 (see application circuits).
Bottom View
cui.com
Product Page
date 02/02/2018 │ page 5 of 7
MECHANICAL DRAWING (CONTINUED)
RIGHT-ANGLE ORIENTATION
N
U
ED
units: mm[inch]
Side View
Top View
PCB Layout
N
TI
Front View
PIN CONNECTIONS
PIN
FUNCTION
1
-Vin (N)
3
+Vin (L)
5
+V(CAP)
7
-V(CAP)
10
-Vo
12
+Vo
O
IS
C
Bottom View
TEST CONFIGURATION
Figure 1
Table 1
C o nn ec t Os c illo grap h P ro be
C o pp e r s he e t
C1
$&1
+Vo
L1
C2
AC -D C
-Vo
C3
C4
Lo ad
F U SE
D
Recommended External Circuit Components
VOUT
(Vdc)
C11
C21
L11
C31
C4
CY0
(Y1
capacitor)
5
10μF/400V
150μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
9
10μF/400V
150μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
12
10μF/400V
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
15
10μF/400V
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
24
10μF/400V
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
Note:
CY0
cui.com
1. Required components.
2. 1 A/250 V fuse required.
Product Page
date 02/02/2018 │ page 6 of 7
TYPICAL APPLICATION CIRCUIT
Figure 2
ķ
L2
17&
+ V in ( L)
A C -D C
C1
M OV1
-V(c a p )
- V in ( N )
C 3 TV S C 4 RL
+V (ca p )
AC (N)
L1
C2
+ Vo
- Vo
C Y0
Table 2
VOUT
(Vdc)
C11
L2
C21,2
L11
C31
U
ED
)86(
A C ( L)
C4
CY0
FUSE1
TVS
NTC
MOV1
10μF/400V
4.7mH
150μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
1A/250V
SMBJ7.0A
5D-9
S14K350
10μF/400V
4.7mH
150μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
1A/250V
SMBJ12A
5D-9
S14K350
12
10μF/400V
4.7mH
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
1A/250V
SMBJ20A
5D-9
S14K350
15
10μF/400V
4.7mH
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
1A/250V
SMBJ20A
5D-9
S14K350
24
10μF/400V
4.7mH
100μF/35V
2.2μH
68μF/35V
0.1μF/50V
1nF/400Vac
1A/250V
SMBJ30A
5D-9
S14K350
TI
N
5
9
Note:
2. When 5 Vdc model is operating in the -25~0C or 55~85C range, C2 needs to be a 270 μF/16 V solid capacitor.
EMC RECOMMENDED CIRCUIT
LD M
FUSE
N
A C ( L)
LC M
M O V2
CX
O
Figure 3
+ V in ( L)
AC -DC
C Y2
C1
+V(c a p )
C3
TV S C 4
RL
-V ( c a p )
-Vo
-V in ( N )
C Y0
Table 3
MOV2
S14K350
CY1, CY2
1nF/400Vac
CX
0.1μF/275Vac
LCM
3.5mH
LDM
5mH
FUSE
1A/250V, slow blow
Note:
Also refer to Table 2.
D
IS
C
C 2 L1
C Y1
AC (N)
Notes:
+ Vo
1.
2.
3.
4.
C1 and C3 are electrolytic capacitors. They are required for both AC input and DC input.
For AC input, C1 is used as a filter capacitor. The recommended C1 value is 10 μF/400 V.
For DC input, C1 is used as an EMC filter capacitor. The recommended C1 value is 10μF/400V. When the input voltage is above 370VDC, we recommend a 10μF/450V capacitor.
C2 and C3 are output filer capacitors, we recommend high frequency and low impedance electrolytic capacitors. For capacitance and rated ripple current of capacitors refer to
the datasheets provided by the manufacturers, voltage derating of capacitors should be 80% or above.
5. C4 is a ceramic capacitor which is used to filter high frequency noise. C2, C3 and L1 form a pi-type filter circuit. For current of L1 and L2 refer to the datasheets provided by
the manufacturers, current derating should be 80% or above. TVS is a recommended component to protect post-circuits (if converter fails). We recommend using a 5D-9
external input NTC.
6. For standard EMC requirements, please refer to figure 2. If a higher EMC is required, please refer to figure 3.
7. All specifications measured at Ta=25C, humidity
很抱歉,暂时无法提供与“PBK-1-12-B”相匹配的价格&库存,您可以联系我们找货
