Additional Resources:
Product Page
3D Model
date
06/01/2022
page
1 of 6
SERIES: VSK-S15 │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 15W continuous power
compact board mount design
universal input (85~264 Vac / 100~370 Vdc)
single output from 3.3~48 Vdc
over voltage, over current, and short circuit protections
UL/cUL safety approvals
efficiency up to 85%
MODEL
output
voltage
output
current
output
power
ripple
and noise1
efficiency
(Vdc)
max
(A)
max
(W)
typ
(mVp-p)
typ
3.3
3
9.9
50
73
VSK-S15-5U
5
2.8
14
50
76
VSK-S15-9U
9
1.6
14.4
50
78
VSK-S15-12U
12
1.25
15
50
80
VSK-S15-15U
15
1.0
15
50
80
VSK-S15-24U
24
0.625
15
50
84
VSK-S15-48U
48
0.32
15
50
85
VSK-S15-3R3U
Notes:
1. Ripple and noise are measured at 20 MHz BW by “parallel cable” method with 1 uF ceramic and 10 uF electrolytic capacitors on the output.
PART NUMBER KEY
VSK-S15 - XXU
Base Number
Output Voltage
cui.com
Product Page
3D Model
CUI Inc │ SERIES: VSK-S15 │ DESCRIPTION: AC-DC POWER SUPPLY
date 06/01/2022 │ page 2 of 6
INPUT
parameter
conditions/description
min
voltage
frequency
max
units
85
100
typ
264
370
Vac
Vdc
47
63
Hz
370
220
mA
mA
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac
at 230 Vac
10
A
A
leakage current
at 230 Vac, 50 Hz (RMS)
0.1
mA
input fuse
2 A/250 V, slow-blow type (external)
OUTPUT
parameter
capacitive load
3.3 Vdc output model
5 Vdc output model
9 Vdc output model
12 Vdc output model
15 Vdc output model
24 Vdc output model
48 Vdc output model
line regulation
at full load
load regulation
at 10~100% load
min
voltage set accuracy
hold-up time
at 115 Vac
at 230 Vac
switching frequency
temperature coefficient
typ
max
units
36,000
20,000
6,000
3,000
3,000
900
370
μF
μF
μF
μF
μF
μF
μF
±0.5
±1
±2
15
80
ms
ms
65
kHz
±0.02
%/°C
PROTECTIONS
parameter
min
over current protection
auto restart
110
continuous, auto restart
over voltage protection
5 Vdc output model
9 Vdc output model
12 Vdc output model
15 Vdc output model
24 Vdc output model
48 Vdc output model
typ
max
units
7.5
7.5
12
60
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
Vdc
max
units
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output for 1 minute
safety approvals
UL60950-1, CE
safety class
class II
conducted emissions
CISPR22/EN55022, Class B
radiated emissions
ESD
IEC/EN61000-4-2 Class B, contact ±6 kV/air ±8 kV
radiated immunity
IEC/EN61000-4-3 Class A, 10V/m
EFT/burst
min
typ
3,000
IEC/EN61000-4-4 Class B, ±2 kV
IEC/EN61000-4-4 Class B, ±4 kV (external circuit required, see figure 2)
cui.com
Vac
Product Page
3D Model
date 06/01/2022 │ page 3 of 6
SAFETY & COMPLIANCE (CONTINUED)
parameter
surge
IEC/EN61000-4-5 Class B, ±1 kV/±2 kV
IEC/EN61000-4-5 Class B, ±2 kV/±4 kV (external circuit required, see figure 2)
min
typ
conducted immunity
IEC/EN61000-4-6 Class A, 10 Vr.m.s
PFM
IEC/EN61000-4-8 Class A, 10 A/m
voltage dips & interruptions
IEC/EN61000-4-11 Class B, 0%-70%
MTBF
as per MIL-HDBK-217F at 25 °C
RoHS
2011/65/EU
max
300,000
units
hrs
ENVIRONMENTAL
parameter
min
operating temperature
see derating curves
storage temperature
storage humidity
typ
max
units
-40
70
°C
-40
105
°C
95
non-condensing
DERATING CURVES
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
for 3~5 seconds
350
360
370
°C
wave soldering
for 5~10 seconds (see wave soldering profile)
255
260
265
°C
Peak Temp. 260°C Max.
Wave Soldering Time
4 Sec. Max.
250
Temperature (°C)
200
10 Sec. Max.
150
100
50
Time (sec.)
cui.com
Product Page
3D Model
date 06/01/2022 │ page 4 of 6
MECHANICAL
parameter
dimensions
62.0 x 45.0 x 22.5 (2.44 x 1.77 x 0.88 inch)
min
case material
UL94V-0
typ
max
units
mm
weight
85
cooling
g
convection cooling
MECHANICAL DRAWING
units: mm[inches]
tolerance: ±0.50[±0.020]
pin diameter: Ø1.00[0.039]±0.10[±0.004]
62.0 2.441
PIN CONNECTIONS
PIN
FUNCTION
1
AC(N)
2
AC(L)
3
-Vo
4
+Vo
22.5 0.886
6.0 0.236
(TYP)
4.0 0.157
54.0 2.126
2
3
4
17.5 0.689
45.0 1.772
1
1
20.0 0.787
3
4
2
Ø1.50[Ø0.059]
Grid size: 2.54 x 2.54
Top View
PCB Layout
BOTTOM VIEW
cui.com
4.0 0.157
(2 PLCS)
Product Page
3D Model
date 06/01/2022 │ page 5 of 6
TYPICAL APPLICATION CIRCUIT
Figure 1
Table 1
Recommended External Circuit Components
MODEL
FUSE
MOV1
C1
C2
TVS
VSK-S15-3R3U
2A/250V
S14K350
1µF
680μF
SMBJ7.0A
VSK-S15-5U
2A/250V
S14K350
1µF
680μF
SMBJ7.0A
VSK-S15-9U
2A/250V
S14K350
1µF
470μF
SMBJ12A
VSK-S15-12U
2A/250V
S14K350
1µF
220μF
SMBJ20A
VSK-S15-15U
2A/250V
S14K350
1µF
220μF
SMBJ20A
VSK-S15-24U
2A/250V
S14K350
1µF
68μF
SMBJ30A
VSK-S15-48U
2A/250V
S14K350
1µF
33μF
SMBJ64A
EMC RECOMMENDED CIRCUIT
Figure 2
Table 2
Note:
MOV1
S14K350
CY1, CY2
1000pF/400Vac
CX
0.1μF/275Vac
LCM
10mH
LDM
4.7μH/2A
Also refer to Table 1
Notes:
1. Output filtering capacitor C2 is an electrolytic capacitor, It is recommended to use high frequency and low impedance electrolytic capacitors. For capacitance and current
of capacitor please refer to manufacture’s datasheet. Voltage derating of capacitor should be 80% or above. C1 is used to filter high frequency noise. TVS is
recommended component to protect post-circuits (when converter fails).
2. All specifications measured at Ta=25C, humidity
很抱歉,暂时无法提供与“VSK-S15-15U”相匹配的价格&库存,您可以联系我们找货
