Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/08/2021
page
1 of 5
SERIES: PEM1A-S │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 1 W isolated output
industry standard SIP 7 package
1:1 input range
single unregulated output
4,000 Vdc isolation voltage
-40 to 85°C temperature range
efficiency up to 70%
UL/cUL safety approval
MODEL
input
voltage
PEM1A-S5-S5-S
Notes:
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
max
(mA)
max
(W)
max
(mVp-p)
typ
5
4.5~5.5
5
200
1
100
70
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, output terminated with a 0.1 µF multilayer low ESR ceramic capacitor.
2. All specifications measured at Ta=25°C, nominal input voltage, rated output load, and after warm up unless otherwise specified.
PART NUMBER KEY
PEM1A - SXX - SXX - S
Base Number
Output Voltage
Input Voltage
cui.com
Packaging Style:
SIP
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PEM1A-S │ DESCRIPTION: DC-DC CONVERTER
date 07/08/2021 │ page 2 of 5
INPUT
parameter
conditions/description
operating input voltage
min
typ
max
units
4.5
5
5.5
Vdc
min
typ
max
units
1200
μF
±5
OUTPUT
parameter
maximum capacitive load
1
voltage accuracy
at full load, Vin nominal,
see tolerance envelope curves
line regulation
for Vin change of 1%
measured from low to high line, full load
±1.2
load regulation
measured from 10~100% load
±12
±15
switching frequency
at Vin nominal
65
105
kHz
typ
max
units
Note:
50
1. Maximum capacitive load is defined as the capacitive load that will allow start up in under 1 second without damage.
SAFETY AND COMPLIANCE
parameter
isolation voltage
input to output for 1 second
isolation resistance
at 500 Vdc
min
4,000
Vdc
1,000
MΩ
isolation capacitance
75
safety approvals
UL/cUL (60950-1, 2nd Edition)
MTBF
as per MIL-HDBK-217F, full load, 25°C
as per MIL-HDBK-217F, full load, 85°C
RoHS
2011/65/EU
850,000
123,000
pF
hours
hours
ENVIRONMENTAL
parameter
min
typ
max
units
operating temperature
-40
85
°C
storage temperature
-55
125
°C
95
max
units
260
°C
operating humidity
non-condensing
SOLDERABILITY
parameter
wave soldering
see wave solder profile
Note:
min
2. The wave solder profile is measured on lead temperature.
3. Need to keep the solder parts internal temperature less than about 210°C.
cui.com
typ
Product Page
3D Model
PCB Footprint
date 07/08/2021 │ page 3 of 5
MECHANICAL
parameter
dimensions
19.60 x 7.05 x 10.20
min
case material
non-conductive black plastic (UL94V-0)
typ
max
mm
weight
2.7
g
MECHANICAL DRAWING
units: mm
tolerance: X.X = ±0.5 mm
X.XX = ±0.25 mm
PIN CONNECTIONS
PIN
Function
1
+Vin
2
-Vin
5
-Vout
7
+Vout
units
Front View
Bottom View
Recommended PCB Layout
Top View
cui.com
Side View
Product Page
3D Model
PCB Footprint
date 07/08/2021 │ page 4 of 5
PERFORMANCE CURVES
PACKAGING
units: mm
Tube Size: 15.5 x 8 x 520 mm
QTY: 25 pcs
cui.com
Product Page
3D Model
PCB Footprint
date 07/08/2021 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
07/25/2016
1.01
company logo updated
03/30/2021
1.02
performance curves updated
07/08/2021
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“PEM1A-S5-S5-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+55.08426
- 5+54.34363
- 10+53.54745
- 25+51.97742
- 50+50.40156
- 100+48.82592
- 250+47.25116
- 500+44.10065
