Additional Resources:
Product Page
3D Model
PCB Footprint
date
07/26/2021
page
1 of 9
SERIES: PDQ10-D │ DESCRIPTION: DC-DC CONVERTER
FEATURES
up to 10 W isolated output
industry standard 1” x 1” package
4:1 input range
single/dual regulated output
over voltage, input under voltage lockout, and short circuit protections
1,500 Vdc isolation voltage
five-sided shielded case
remote on/off control
output trim
-40 to 105°C temperature range
efficiency up to 86%
MODEL
input
voltage
output
voltage
output
current
output
power
ripple
& noise1
efficiency
typ
(Vdc)
range
(Vdc)
(Vdc)
min
(mA)
max
(mA)
max
(W)
max
(mVp-p)
typ
PDQ10-Q24-S3-D
24
9~36
3.3
8.25
75
81
PDQ10-Q24-S5-D
24
9~36
5
10
75
84
PDQ10-Q24-S12-D
24
9~36
12
10
100
86
PDQ10-Q24-S15-D
24
9~36
15
10
100
86
PDQ10-Q24-D5-D
24
9~36
±5
±1000
10
75
84
PDQ10-Q24-D12-D
24
9~36
±12
±416
10
100
86
PDQ10-Q24-D15-D
24
9~36
±15
±333
10
100
86
PDQ10-Q48-S3-D
48
18~75
3.3
8.25
75
82
PDQ10-Q48-S5-D
48
18~75
5
10
75
84
PDQ10-Q48-S12-D
48
18~75
12
10
100
86
PDQ10-Q48-S15-D
48
18~75
15
10
100
86
PDQ10-Q48-D5-D
48
18~75
±5
±1000
10
75
84
PDQ10-Q48-D12-D
48
18~75
±12
±416
10
100
86
PDQ10-Q48-D15-D
48
18~75
±15
±333
10
100
86
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, with 10 µF tantalum and 1 µF ceramic capacitors on the output.
2. All specifications are measured at Ta=25°C, nominal input voltage, and rated output load unless otherwise specified.
PART NUMBER KEY
PDQ10 - QXX - X XX - D
Base Number
Input Voltage
Packaging Style:
D = DIP
Output
S = single
D = dual
cui.com
Output Voltage
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PDQ10-D │ DESCRIPTION: DC-DC CONVERTER
date 07/26/2021 │ page 2 of 9
INPUT
parameter
conditions/description
operating input voltage
24 Vdc input models
48 Vdc input models
min
typ
max
units
9
18
24
48
36
75
Vdc
Vdc
surge voltage
for maximum of 100 ms
24 Vdc input models
48 Vdc input models
50
100
Vdc
Vdc
current
24 Vdc input models
48 Vdc input models
1.4
0.7
A
A
under voltage shutdown
24
24
48
48
remote on/off1
turn on (3.5~36 Vdc or open circuit)
turn off (
很抱歉,暂时无法提供与“PDQ10-Q48-S12-D”相匹配的价格&库存,您可以联系我们找货
