MDF76GW-30S-1H(55)
MDF76GW-30S-1H(55)
    HRS(广濑)
MDF76GW-30S-1H(55) 数据手册
1.0mm Pitch, Board-to-Wire LCD Interface Connectors MDF76 Series ■Increased Plug / Receptacle retention force Receptacle Plug Crimped contact Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Protrusion ■Features 1. High-speed data transfer Ground contacts opposite the signal contacts (Receptacle) provide superior impedance matching. 2. EMI protection Outer shell Ground contact ■Incorrect insertion prevention A vertically asymmetrical key form prevents reverse insertion. Metal shell provides shielding and ground connections. 3. Increased Plug / Receptacle retention force Unique configuration of the receptacle ground contacts mating with the corresponding plug increases the retention force between them. (MDF76-30P-1 Plug mated with MDF76KBW or MDF76LBRW Receptacles.) Board side receptacle 4. Incorrect insertion prevention Built-in polarizing features prevent reverse insertion of the plug in the receptacle. 5. High board retention force Metal shell is soldered directly to the PC board. 6. RoHS compliant All components and materials comply with the requirements of EU Directive 2002/95/EC. ■Applications Cable side plug Notebook computers, desktop computers, Liquid Crystal Panels, LCD monitors and other devices requiring discrete wire connections with a lowprofile high performance connectors. 2018.5② 1 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors ■Product Specifications Ratings Current rating (Note 1) Wire size 200V AC Voltage rating Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item 28 to 30 AWG : 1.0A 32 AWG : 0.8A 36 AWG : 0.5A Operating temperature range Operating humidity range -40ç to +85ç (Note 2) RH 20% to 80% Storage temperature range Storage humidity range -10ç to +60ç (Note 3) RH 40% to 70% (Note 3) Specification Conditions 1. Insulation resistance 100Mø min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown 500V AC / 1minute 3. Contact resistance 40mø max. 20mV max., at 1 mA. 4. Durability Contact resistance : 80mø max. 50 cycles No deformation of components affecting performance. 5. Vibration No electrical discontinuity of 1μs or longer No damage, cracks or parts dislocation. Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 axial directions 6. Shock No electrical discontinuity of 1μs or longer No damage, cracks or parts dislocation. Acceleration of 490m/s2, 11ms duration, sine half-wave, 3 cycles in each of the 3 axis 7. Humidity Contact resistance : 80mø max., Insulation resistance : 50Mø min. 96 hours at 60 ±2ç, and humidity of 90% to 95% 8. Temperature cycle 9. Resistance to soldering heat Contact resistance : 80mø max., -55ç → 5 to 35ç → 85ç → 5 to 35ç Insulation resistance : 50Mø min. Times : 30 min.→ 2 min. to 3 min. → 30 min. → 2min. to 3 min. No damage, cracks or parts dislocation. 5 cycle No deformation of components affecting performance. Reflow : At the recommended temperature profile Manual soldering : 300ç for 3 seconds Note 1:The current rating will differ depending on the wire size used. Note 2:Includes temperature rise caused by current flow. Note 3:The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. ■Material / Finish Plug Part Material Finish Remarks Insulator Polyamide Color : Beige UL94V-0 Ground plate Stainless steel Tin plated ------- Crimp contact Phosphor bronze Gold plated ------- Receptacle Part Material Finish Remarks Insulator Polyamide or LCP (Note 4) Color : Beige or black (Note 5) UL94V-0 Contacts Phosphor bronze Gold plated ------- Tin plated ------- Tin plated or gold plated (Note 6) UL94V-0 Ground contact Shell Stainless steel Note 4 : Low profile receptacles MDF76KBW and MDF76LBRW are polyamide. High profile receptacles MDF76TW, and MDF76GW are LCP. Note 5 : Low profile receptacles MDF76KBW, MDF76TW, and MDF76GW are beige. Reverse mounting MDF76LBRW is black. Note 6 : Low profile receptacles MDF76KBW and MDF76LBRW have tin plating on the solder leads. High profile receptacles MDF76TW and MDF76GW have gold plating on the solder leads. 2 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector MDF 76 # – * P – 1 C 1 2 3 4 5 6 1 Series Name : MDF76 3 Number of contacts : 30 2 Form type 4 Connector type Plug Blank : Standard P : Plug Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle (Low profile) S : Receptalce KBW : Standard, mid-mount 5 Contact pitch : 1mm LBRW : Reverse, mid-mount 6 Housing type Receptacle (High profile) C : Crimp TW : Standard, mid-mount GW : Standard, top board H : Right angle SMT ●Contacts MDF 76 – 2836 PCF A 1 1 2 Applicable conductor 2836 : 28 to 36 AWG 2 3 3 Plating A : Gold plated Packaging PCF : Male crimp contact / reel 3 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors ■Plug (Discrete cable) P=1 6.9 2.3 33.3 31.9 29 Contact No.1 indicator Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5 34.9 Shown terminated • Supplied in bag. (100 pieces/bag) • Contacts supplied separate All dimensions : mm Part No. HRS No. No. of contacts Insulator Color MDF76-30P-1C 547-0918-1 30 Beige ■Crimp contact Part No. HRS No. Packaging Quantity Finish Reel 1 Reel / 30,000 Gold plated MDF76-2836PCFA(41) 547-0919-4 41 0.75 0.7 ●Applicable wire (Tin plated annealed copper wire) Wire size (Stranded wire conductor) Jacket diameter 0.6mm max. 30 AWG (7 / 0.10mm) 0.9 2.15 5.95 28 AWG (7 / 0.127mm) 32 AWG (7 / 0.08mm) 0.4mm max. 0.55 36 AWG (7 / 0.05mm) Note : When using other than the recommended wire, contact nearest Hirose sales representative. ●Tools t=0.15 Part No. HRS No. Applicator Type AP105-MDF76-2836P 901-4613-1 Press CM-105C 901-0001-0 Extraction tool DF-C-PO(B) 550-0179-2 All dimensions : mm 4 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors ■Receptacles (Low profile) ●Right angle, Standard, mid-mount, SMT No.1 (Ground) 31 No.31 (Signal) Lead pitch=1 No.2 (Signal) No.32 (Ground) 1.55 Contact pitch = 1 29 3.3 1.9 All dimensions : mm Part No. HRS No. MDF76KBW-30S-1H(55) 547-0606-9 55 No. of contacts 30 Insulator Color Packaging Above the mounting surface Beige 3,000 pcs. / reel 1.0mm ●Right angle, Reverse, mid-mount, SMT No.32 (Ground) 31 No.2 (Signal) Lead pitch=1 No.31 (Signal) No.1 (Ground) 0.2 37.35 0.15 2.8 1.2 0.4 Gold plated 1.55 1.1 40.05 Contact pitch = 1 29 1 3.3 1.9 All dimensions : mm Part No. HRS No. No. of contacts Insulator Color Packaging Above the mounting surface MDF76LBRW-30S-1H(55) 547-0607-1 55 30 Black 3,000 pcs. / reel 1.1mm ■Receptacles (High profile) ●Right angle, Standard, mid-mount, SMT No.1 (Ground) 31 No.31 (Signal) Lead pitch=1 No.2 (Signal) No.32 (Ground) 0.2 Gold plated Contact pitch = 1 1.5 2.3 37.35 40.05 1.2 3.25 0.4 0.8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Gold plated 1 1 37.35 40.05 1.2 0.2 0.15 2.8 0.4 3.45 1.9 29 All dimensions : mm Part No. HRS No. No. of contacts Insulator Color Packaging Above the mounting surface MDF76TW-30S-1H(55) 547-0912-5 55 30 Beige 2,500 pcs. / reel 1.5mm 5 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors ■Receptacles (High profile) ●Right angle, Standard, top board, SMT No.1 (Ground) 31 Lead pitch=1 0.4 No.31 (Signal) No.2 (Signal) No.32 (Ground) 0.8 1.2 3.25 0.4 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Gold plated 2.35 37.35 40.05 3.45 1.3 Contact pitch = 1 29 All dimensions : mm Part No. HRS No. No. of contacts Insulator Color Packaging Above the mounting surface MDF76GW-30S-1H(55) 547-0916-6 55 30 Beige 2,500 pcs. / reel 2.35mm ■Recommended PCB mounting pattern ●Mid-mount No.1(Ground) (Note) 31±0.05 For receptacles : (1) 0.6±0.05 No.2(Signal) (Note) (0.3) 3.5±0.05 1.5±0.1 (0.5) 3±0.1 MDF76TW-30S-1H(**) No.32 (Ground) No.31(Signal) P=1±0.03 1±0.1 MDF76LBRW-30S-1H(**) 0.8±0.08 29±0.05 2.2±0.05 0.5±0.05 MDF76KBW-30S-1H(**) 37.65±0.05 1.2±0.1 40.65±0.1 Note : For MDF76LBRW, No.32 (Ground and No.31 (Signal) are on left side. ●Top board 31±0.05 For receptacles : No.1(Ground) 3.25±0.1 MDF76GW-30S-1H(**) 1.5±0.05 P=1±0.05 No.31(Signal) No.2(Signal) 0.6±0.05 0.8±0.1 No.32 (Ground) 1.8±0.1 (3.9) 0.3±0.15 1.8±0.1 No conductive traces 36.85±0.1 (37.35±0.3) (40.45) All dimensions : mm 6 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors BPackaging Specifications ◆MDF76TW-30S-1H(55) MDF76GW-30S-1H(55) 2 12 1.95 Ø1 .5 + 0 4 Unreeling direction 1.75 Part Number Label (Ø80) (42) 56 52.4 Ø13 A A 0.4 0.2 Unreeling direction A 2.95 (56.5) (1.6) .75 R0 (2) All dimensions : mm ◆MDF76KBW-30S-1H(55) MDF76LBRW-30S-1H(55) 2 12 1.8 4 Unreeling direction 1.75 .5 Ø1 A-A Part Number Label 26.2 A (Ø80) (Ø380) (42) A .75 R0 (2) Unreeling direction 56 52.4 Ø13 0.2 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 26.2 A-A (Ø380) A 0 .1 t=0.4 (56.5) (2) 2.3 All dimensions : mm 7 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors BUsage Recommendations 1.Recommended temperature profile Temperature (ç) 10sMAX 255çMAX 250 220ç 200 30 to 60sec 180ç 150 60 to 120sec Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 Time (Seconds) Note 1 : Up to 2 cycles of Reflow soldering is possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering 3.Recommended screen thickness and open area ratio 4.Board warpage 300±10ç for 3 seconds 5.Cleaning conditions 6.Wire preparation and contact crimping Refer to "Nylon Connector Use Handbook". 7.Crimped contact extraction ■ Insert the contact retention tool in the insulator body and carefully lift the molded-in retention tab while pulling on the wire at the same time (Fig. 1). Do not deflect the molded-in retention tab more than is needed to release the contact. The tab should return to its initial position after the contact is removed. Note : If the tab is not returning to it’s initial position carefully push I back before inserting the crimped contact. Permanent breakage of the molded-in retention tab will require replacement of the entire plug. Thickness : 0.15mm Open area ratio : 100% Maximum of 0.03mm at the connector center, with both ends of the connector as reference points. Refer to “Nylon Connector Use Handbook”. The crimp contact termination must be performed using specified tools. All dimensions and crimp conditions are listed in applicable Crimp Condition Table and Crimping Quality Standards Manual. Contact extraction tool Plug Molded-in contact retention tab Pull-out Contact Figure 1. Contact Extraction 8 MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors 8.Crimped contact insertion Contact must be inserted horizontally oriented as shown on Fig. 2 Do NOT attempt to insert crimped contact in any other direction. Horizontal insertion ! Insert MDF76-30P-1C Plug MDF76-2836PCFA(41) Crimped contact Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Figure 2. Crimped Contact Insertion 9.Connector mating / unmating Mating / unmating of the connectors should be done in the direction parallel to the receptacle’s mounting surface. Do not attempt to mate/unmate in any other direction. Note : The connectors will self-guide themselves within the 20° angle, as shown in Fig. 3. MDF76 # W-30S-1H(**) Receptacle 20° Max. MDF76-30P-1C PCB Figure 3. Angular mating / unmating 10.Precautions Do not mate / unmate the connectors when the receptacle is NOT mounted on the PC board. Differences in color shade of molded components will not affect form, fit or function. Contact HRS if additional information is required. 9 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors MEMO: 10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors MEMO: 11 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors 12
MDF76GW-30S-1H(55) 价格&库存
很抱歉,暂时无法提供与“MDF76GW-30S-1H(55)”相匹配的价格&库存,您可以联系我们找货
