Universal Reversible USB 2.0 Cable (Right / LeftAngle Reversible A to B M/M), 3 ft. (0.91 m)
MODEL NUMBER: UR022-003-RA
Highlights
3-ft. (0.91 m), USB 2.0, Right /
Left Angle A to B Peripheral
device cable
Universal, Reversible "A"
connector allows plugging in any
direction
System Requirements
Any USB device requiring a
USB cable
USB2.0 performance only when
used with USB2.0 device and
USB2.0 controller
Package Includes
Reversible Right / Left Angle USB "A" connector plugs in any direction
Description
Tripp Lite's UR022-003-RA, 3-ft. (0.91 m) USB2.0 Right / Left Angle "A" to B device cable, with Universal /
Reversible "A" connector, meets or exceeds USB 2.0 specifications. No guessing on how to plug into the
Computer or Hub port... Connects in either direction. Backward compatible - can be used with older
USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, errorfree data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make
them perfect for multimedia applications. Features nickel plated connectors and gold plated copper
contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain
relief for extra durability and long life.
Features
3-ft. (0.91 m), USB 2.0 Right / Left Angle A-Male to B-Male, with Universal / Reversible "A" connector
USB 2.0 compliant, to 480Mbps transfer rates
Backward compatible with previous USB generations
Gold plated contacts and molded ends provide a lifetime of use
28AWG Data Pair, 24AWG Power pair
Specifications
OVERVIEW
UPC Code
037332179463
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Black
1/2
Right / Left Angle A-Male to BMale Device Cable - 3-ft. (0.91
m)
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
0.25 x 5.00 x 7.00
Shipping Dimensions (hwd / cm)
0.64 x 12.70 x 17.78
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
REVERSIBLE USB A (MALE)
Side B - Connector 1
USB B (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“UR022-003-RA”相匹配的价格&库存,您可以联系我们找货
