Universal Reversible USB 2.0 Cable (Reversible
A to Right-Angle 5Pin Mini B M/M), 3 ft. (0.91 m)
MODEL NUMBER: UR030-003-RAB
Highlights
Universal / Reversible A
connector eliminates guesswork as to connector orientation
Right-Angle Mini B connector
ideal in situations where space
is at a premium, and reduces
stress / excessive bending on
the cable
Meets or Exceeds USB 2.0
Specifications
Connects to Cameras, PDA's,
etc with Mini-B 5-Pin connectors
System Requirements
Any USB device requiring a
USB cable with Mini-B 5-Pin
connector
USB2.0 performance only when
used with USB2.0 device and
USB2.0 controller
Package Includes
Universal / Reversible "A" connector allows plugging in any direction
Description
Tripp Lite's UR030-003-RAB, 3-ft. (0.91 m), USB 2.0 Universal / Reversible "A" to Right-Angle Mini-B 5pin device cable, meets or exceeds USB 2.0 Specifications. Connects a Digital camera, PDA, Cell Phone,
etc to a USB port on a computer or hub. Backward compatible - can be used with older USB1.1
applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free
data communications. Features nickel plated connectors and gold plated copper contacts for superior
conductivity. The cable is manufactured with molded connectors and integral strain relief for extra
durability and long life.
Features
Universal / Reversible "A" connector plugs in any direction
Right-Angle Mini B connector ideal in situations where space is at a premium, and reduces stress /
excessive bending on the cable
Meets or Exceeds USB 2.0 Specifications
Connects to Cameras, Cell Phones, PDA's, etc with 5-Pin Mini-B USB connectors
Supports faster data transfer rate (1.5 to 480 Mbps) for low speed and high speed devices including
multimedia applications
Premium double-shielded cables with tinned copper braid and aluminum Mylar foil
Nickel plated connectors and gold plated copper contacts for superior conductivity.
Molded connectors and integral strain relief for extra durability and long life.
Specifications
OVERVIEW
UPC Code
037332182234
Technology
USB 2.0 (High Speed)
1/2
3-ft. (0.91 m) USB2.0 Universal /
Reversible A to Right-Angle
Mini-B Device Cable (A Male to
5Pin Mini-B Male)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Black
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
0.25 x 5.00 x 9.30
Shipping Dimensions (hwd / cm)
0.64 x 12.70 x 23.62
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
REVERSIBLE USB A (MALE)
Side B - Connector 1
USB MINI-B 5-PIN (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“UR030-003-RAB”相匹配的价格&库存,您可以联系我们找货
