QR/P-16P-C(01)
QR/P-16P-C(01)
    HRS(广濑)
QR/P-16P-C(01) 数据手册
QR/P Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rectangular, High Pin Count, Rack and Panel Crimp Connector Feb. 2022 QR/P Series/Rectangular, High Pin Count, Rack and Panel Crimp Connector General The QR/ P Series is a plug- in, rectangular, multi- pin count rack and panel connector for the connection and disconnection of power and signal circuits between units and racks of various electronic equipment. Five different pin counts are available: 4, 8, 12, 16 and 24. Wire connection is performed using crimp termination for easier workability and high reliability. Hirose' s unique ribbon- shaped, male and female dual- purpose contacts assure smooth insertion/ removal, making this the ideal rack and panel connector for plug- in connections. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Features 1. Margin in the effective mating length due to the plug- in design. 2. The males and female housings use the same contacts for a reduction in part procurement and management. 3. Floating bushing enables a floating design. 4. UL, CSA, TÜ V certified. Product Specifications Operating Temperature -10 to +60℃ Rated Current Rated Voltage Power 13A Max.(When using 14 AWG) Signal 7A Max. (When using 18 AWG) Power 600V AC Signal 250V AC Contact Resistance 10m Ω Max. (1A DC) Insulation Resistance 5000M Ω Min. (500V DC) Withstand Voltage Safety Standard Power 3000V AC for 1 min. Signal 1000V AC for 1 min. UL CSA Operating Temperature Rated Voltage -10 to +60℃ Power Signal 14 AWG 16 AWG Rated Current TÜV 120V AC 250V AC 600V AC 10A - 8A 1A 10A 18 AWG 20 AWG 22 AWG 3A 3A 2A 24 AWG 1A 2 250V AC, 300V DC 125V AC, 150V DC 10A 5A - 2.5A 1A QR/P Series/Rectangular, High Pin Count, Rack and Panel Crimp Connector Materials / Finish Item Material Color/Finish Remarks Insulator PBT Blue UL94V-0 Contact Phosphor Bronze Partial Gold Plating (Nickel Underplating) - Product Number Structure Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Connector Unit QR/P - 8 P - C (21) ❶ ❷ ❸ ❹ ❾ Contact QR/P - X C - 1 1 1 ❶ ❺ ❹ ❻ ❼ ❽ ❶ Siries Name QR/P ❻ Contact Type 1 : Loose Piece Contact 2 : Reel Contact ❷ No. of Pos. 4, 8, 12, 16, 24 ❼ Applicable Cable 1 : 14 to 16 AWG 2 : 18 to 24 AWG ❸ Insulator Gender P : Male Insulation Case S : Female Insulation Case ❽ Surface Treatment 1 : Partial Gold Plating (Nickel Underplating) ❹ Contact Connection Method C : Crimping ❾ Specification (21) : UL, CSA, TÜV ❺ Contact Type X : Male and Female Dual-purpose Contact 3 QR/P Series/Rectangular, High Pin Count, Rack and Panel Crimp Connector Housing Male Housing Unit : mm Part No. HRS No. No. of Pos. A B QR/P-4P-C(21) CL0221-0013-0-21 4 41.0 31.0 QR/P-8P-C(21) CL0221-0001-0-21 8 52.0 42.0 QR/P-12P-C(21) CL0221-0002-3-21 12 61.0 51.0 QR/P-16P-C(21) CL0221-0003-6-21 16 70.0 60.0 QR/P-24P-C(21) CL0221-0004-9-21 24 86.5 77.0 C D Purchase Unit 5.0 18.5 30pcs per bag 5.5 18.0 20pcs per bag Note : For 14-16 AWG compatible contacts, only 4 can be inserted (both sides). All contacts can be inserted for 4pos. Female Housing A B 3 4. φ 5 18 5 2- 5.5 7.3 24 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C 5 5 24 2.5 16 D 2- φ 4. 3 A B Floating Bushing (Floats 0.4mm Max. in Respect to Center) Unit : mm Part No. HRS No. No. of Pos. A B QR/P-4S-C(21) CL0221-0014-2-21 4 41.0 31.0 QR/P-8S-C(21) CL0221-0005-1-21 8 52.0 42.0 QR/P-12S-C(21) CL0221-0006-4-21 12 61.0 51.0 QR/P-16S-C(21) CL0221-0007-7-21 16 70.0 60.0 QR/P-24S-C(21) CL0221-0008-0-21 24 86.5 77.0 Note : For 14-16 AWG compatible contacts, only 4 can be inserted (both sides). All contacts can be inserted for 4pos. 4 Purchase Unit 30pcs per bag 20pcs per bag QR/P Series/Rectangular, High Pin Count, Rack and Panel Crimp Connector Contact (Male and Female Dual-purpose Contact) Part No. HRS No. QR/P-XC-111(12) CL0221-0009-2-12 QR/P-XC-211(12) CL0221-0011-4-12 QR/P-XC-121(12) CL0221-0010-1-12 QR/P-XC-221(12) CL0221-0012-7-12 Applicable Cable Type of Packing Purchase Unit Loose 100pcs per bag Reel 3,500pcs per reel Loose 100pcs per bag Reel 5,000pcs per reel 14 to 16 AWG 18 to 24 AWG Panel Mounting Dimensions Female Housing(QR/P-#S-C) φ4 .3 21 10 21 .5 φ4 R5 .3 R1 E F A B C D Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.7 3.6 18.7 Attachment from Panel Rear Side Type Rear Mount Front Mount Attachment from Panel Front Side Unit : mm 4pos. 8pos. 12pos. 16pos. 24pos. A 31.0 42.0 51.0 60.0 77.0 B 26.5 37.5 46.5 55.5 73.5 C 23.0 34.0 43.0 52.0 70.0 D 18.5 29.5 38.5 47.5 65.5 E 31.0 42.0 51.0 60.0 77.0 F 15.5 26.5 35.5 44.5 62.5 Note : The panel mounting dimensions of the male housing are symmetrical to the female housing in respect to the vertical axis. 5 QR/P Series/Rectangular, High Pin Count, Rack and Panel Crimp Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Tools Manual Crimp Tool Type Manual Crimp Tool Automatic Crimp Tool Applicator Extraction Tool Automatic Crimp Tool CM-105C Extraction Tool Part No. HRS No. Applicable Contact TC-2100-111 CL0250-0027-0-00 QR/P-XC-111 TC-2100-121 CL0250-0028-2-00 QR/P-XC-121 AP105-QR/P-XC-1 CL0901-2567-5-00 QR/P-XC-211 AP105-QR/P-XC-2 CL0901-2531-8-00 QR/P-XC-221 TC-2100-21 CL0250-0009-8-00 - While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 2/ 2022. Contents are subject to change without notice for the purpose of improvements. 6
QR/P-16P-C(01) 价格&库存
很抱歉,暂时无法提供与“QR/P-16P-C(01)”相匹配的价格&库存,您可以联系我们找货
