The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
QR/P6 SERIES
QR/P6 SERIES RECTANGULAR MINIATURE MULTI-CONTACT RACK/PANEL CRIMP CONNECTOR
General
Nov.1.2022
Feb.1.2021 Copyright 2021
2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
The QR/P6 Series are miniaturized versions of the
QR/P and QR/P1 series. Rectangular multi-contact rack
and panel connectors for plug-in connection.
Available in 6, 12, 16, and 24 contacts for highly efficient and reliable crimp termination.
Features
(1) Offers smooth insertion/extraction and stable contact
pressure through point-blade contact, and has ample
allowance for the deviations in contact length specific
to plug-in connection.
(2) Miniaturized by separating power contacts from signal contacts.
(3) Signal contacts in the housing are located in pitches
of 2.54mm. The opposed contacts at one end of the
connector are spaced 6.9mm so that they can withstand high voltage. Can be used for power supplies.
Uses flame-retardant insulator (UL94-0).
(4) Miniaturized using guide pins integral with the insulator.
(5) Ensures smooth insertion and extraction, and
designed to be fixed with stepped screws on a panel
or rack.
(6) The female housing is designed to allow the contact
part of the female terminal to be below the mating
surface, meeting the Finger Test Requirements (complying with UL 1950)
(7) The connectors of the series have passed UL, CSA
and TÜV standard.
Application
PPC, Transmission/Reception equipment, Data
Communication, equipment, Vending machines,
Measuring Instruments, Automation equipment,
Switch-boards.
157 1
03/2021
04/2009
Main Specification
General ratings of QR/P6
Contact
Resistance
Insulation
Resistance
Withstand
Voltage
(for 1 min.)
Rated current
Rated voltage
Main materials
Power terminal
10mΩ or less at DC1A
Signal terminal
15.mΩ or less at DC1A
Insulator
PBT resin
Black
Terminal
Phosphor bronze
Selective Gold plating
with nickel underplating
5000MΩ or less at DC 500V
Power unit
AC 1000V
Signal unit
AC 500V
Power terminal
10A
Signal terminal
1A
*UL94V-0
QR/P6 ratings approved by safety standards
UL
Safety standard
Operating temperature range
Rated voltage
AC 120V
Power supply unit
AWG#14
10A
AWG#16
Nov.1.2022
TÜV
AC250V
AC 250V
Signal unit
AWG#18
5A
AWG#20
AWG#22
Rated current
CSA
−10∼+60℃
AWG Power supply
#24
Signal unit
AWG#26
AWG#28
AC125V
10A
8A
10A
5A
5A
3A
3A
3A
3A
1A
2A
1A
1A
2.5A
1A
1A
1A
Ordering Information
▲ Connector Unit
21
QR / P6 − 12 P − C − (01)
(1)
▲ Contact
(4)
(11)
QR / P1 − PC 1 A − 1 1 1
(1)
(1) Series name
(2) No.of contacts (6, 12, 16, 24)
(3) Shape of insulator mating part
P: Insulator male case
S: Insulator female case
(4) Type of termination
C: Crimp termination
(5) Male/ Female
PC: Male crimp terminal
SC: Female crimp terminal
(6) Type
1: Power terminal
2: Signal terminal
2 158
(2) (3)
(5) (6)(7)
(8)(9)(10)
(7) Crimp barrel size
A: For thin wires
B: For thick wires
(8) Shape
1: Loose contact
2: Chain contact
(9) Applicable wire
1: Power terminal AWG # 18 - # 24
Signal terminal AWG # 24 - # 28
2: Power terminal AWG # 14 - # 16
(10) Surface terminal
1: Selective gold plating with nickel underplating
(11) Specifications meeting UL, CSA TÜV requirements
03/2021
04/2009
Housing
Nov.1.2022
Male Housing
Famale housing
Unit: mm
HRS No.
No. of Pin
Part No.
A
B
C
CL0221-0162-0-21
CL221-0162-0-01
6
QR/P6-06P-C(01)
21
24.67
32.67
15.87
CL0221-0163-2-21
CL221-0163-2-01
12
21
QR/P6-12P-C(01)
33.47
41.47
24.67
CL0221-0207-6-21
CL221-0207-6-01
16
21
QR/P6-16P-C(01)
38.55
46.55
29.75
CL0221-0209-1-21
CL221-0209-1-01
24
21
QR/P6-24P-C(01)
48.71
56.71
39.91
Unit: mm
RoHS
HRS No.
No. of Pin
Part No.
A
B
C
CL0221-0161-7-21
CL221-0161-7-01
6
QR/P6-06S-C(01)
21
24.67
32.67
15.87
CL0221-0164-5-21
CL221-0164-5-01
12
21
QR/P6-12S-C(01)
33.47
41.47
24.67
CL221-0208-9-01
CL0221-0208-9-21
16
21
QR/P6-16S-C(01)
38.55
46.55
29.75
CL0221-0210-0-21
CL221-0210-0-01
24
21
QR/P6-24S-C(01)
48.71
56.71
39.91
RoHS
Note: Determine the combinations with the panel so that the mating clearance between the P side and S side is 1.5mm.
Contact
Male power terminal
Female power terminal
Selective gold plated with nickel underplating
Applicable
Wire
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0114-7-12
100pin
CL0221-0114-7-12 QR/P1-PC1B-121(12) contact
UL1015
AWG#14∼16 CL221-0118-8-12
Chain
3,000pin
QR/P1-PC1B-221
12)
CL0221-0118-8-12
contact
Loose
CL221-0102-8-12
100pin
CL0221-0102-8-12 QR/P1-PC1A-111(12) contact
UL1007
Chain
AWG#18∼24 CL221-0106-9-12
CL0221-0106-9-12 QR/P1-PC1A-211(12) contact 5,000pin
Applicable
Wire
HRS No.
Part No.
Type Packing RoHS
Loose
CL221-0116-2-12
100pin
CL0221-0116-2-12 QR/P1-SC1B-121(12) contact
UL1015
AWG#14∼16 CL221-0120-0-12
Chain 3,000pin
CL0221-0120-0-12 QR/P1-SC1B-221(12) contact
Loose
CL221-0104-3-12
100pin
CL0221-0104-3-12 QR/P1-SC1A-111(12) contact
UL1007
Chain
AWG#18∼24 CL221-0108-4-12
CL0221-0108-4-12 QR/P1-SC1A-211(12) contact 5,000pin
159 3
03/2021
04/2009
Contact
Male signal terminal
Female signal terminal
Nov.1.2022
Applicable
Wire
HRS No.
Part No.
Type Packing RoHS
CL0221-0103-0-12 QR/P1-PC2A-111(12) Loose
CL221-0103-0-12
100pin
UL1007
AWG#24∼28 CL221-0107-1-12
CL0221-0107-1-12 QR/P1-PC2A-211(12) Chain 5,000pin
Applicable
Wire
HRS No.
Type Packing RoHS
Part No.
CL221-0105-6-12
100pin
CL0221-0105-6-12 QR/P1-SC2A-111(12) Loose
UL1007
AWG#24∼28 CL221-0109-7-12
CL0221-0109-7-12 QR/P1-SC2A-211(12) Chain 5,000pin
Panel Mounting Dimensions (for Cases with P Insulation)
Unit: mm
No. of pin
Mounting on
panel inside
8 Pin
12 Pin
16 Pin
24 Pin
A
14.87
19.27
21.85
26.95
B
17.17
25.97
31.18
41.34
C
18.17
26.97
32.05
42.21
D
24.67
33.47
38.55
48.71
E
16.37
25.17
30.25
40.41
19.87
28.67
33.75
43.91
24.67
33.47
38.55
48.71
Mounting on
F
panel outside
G
Mounting on panel outside
Applicable Tools
Type
HRS No.
Part No.
Applicator terminay
CL0250-0020-0-00
CL250-0020-0
TC-QR/P1-PC1B
TC-QR/P1-PC1A
QR/P1-PC1B-121
QR/P1-PC1A-111
TC-QR/P1-SC1B
TC-QR/P1-SC1A
TC-QR/P1-PC2A
QR/P1-SC1B-121
QR/P1-SC1A-111
QR/P1-PC2A-111
CL0250-0018-9-00
CL250-0018-9
TC-QR/P1-SC2A
CL0901-2529-6-00
CL901-2529-6
AP105-QR/P1-1B-2
QR/P1-SC2A-111
QR/P1-PC1B-221
CL0901-2527-0-00
CL901-2527-0
AP105-QR/P1-1A-1
CL0901-2528-3-00
CL901-2528-3
AP105-QR/P1-2A-1
CL0250-0242-2-00
CL250-0242-2
TC-QR/P6-21
CL0250-0015-0-00
CL250-0015-0
Hand Crimp
CL0250-0022-6-00
CL250-0022-6
Tool
CL0250-0017-6-00
CL250-0017-6
CL0250-0016-3-00
CL250-0016-3
Auto Crimp
Machine
Applicator
Hand crimping tool
4 160
Automatic crimping machine
CM-105
CL901-0005-4
Hand Tool
QR/P1-SC1B-221
QR/P1-PC1A-211
QR/P1-SC1A-211
QR/P1-PC2A-211
QR/P1-SC2A-211
03/2021
04/2009
Contacts for thick wire Contact Configuration
Male Housing (Viewed from Wiring Side)
1
2 3
■: indicates a contact hole for thick wire
QR/P6-6P-C (01)
QR/P6-6P-C(21)
Nov.1.2022
4
5 6
QR/P6-12P-C (01)
1
2 3 4 5 6
QR/P6-16P-C (01)
QR/P6-12P-C(21)
7
8 9 10 11 12
QR/P6-24P-C (01)
1
2 3 4 5 6 7 8
QR/P1-32P-C (01)
QR/P6-16P-C(21)
9
1
10 1112 13 14 15 16
2 3 4 5 6 7 8 9 10 11 12
QR/P6-24P-C(21)
13
14 15 16 17 18 19 20 21 22 23 24
161 5
03/2021
04/2009
很抱歉,暂时无法提供与“QR/P6-12S-C(01)”相匹配的价格&库存,您可以联系我们找货
